Hi there,
I am building lammps on AMD GPU gfx906. I am using lammps-15Apr20. All the makefiles are original.
In the lib/gpu, make -f Makefile.hip -j goes well. libgpu.a, hip_get_devices and Makefile.lammps are there.
Then in the src, make yes-GPU and make hip -j lead to the following error in the linker.
My modules are 1) compiler/devtoolset/7.3.1 2) compiler/rocm/2.9 3) compiler/cmake/3.15.6 4) mpi/hpcx/2.4.1/gcc-7.3.1.
So how can I solve this issue?
/lib/…/lib64/crt1.o: In function _start': (.text+0x20): undefined reference to
main’
clang-10: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: *** [Makefile:95: …/lmp_hip] Error 1
make[1]: Leaving directory ‘/public/home/nsccsz_user14/source_lammps-15Apr20/src/Obj_hip’
make: *** [Makefile:207: hip] Error 2
Haidong
