Dear LAMMPS users (and devs),
I have written a function that requires inversion, multiplication of complex matrices.
Before including this function in LAMMPS code, I have tested it outside independently, built with LAPACK
#include <complex>
#include <cmath>
#include <algorithm>
#include <iostream>
#include <vector>
using std::complex;
using std::vector;
extern "C" {
void zgesv_(int* n, int* nrhs, complex<double>* a, int* lda, int* ipiv, complex<double>* b, int* ldb, int* info);
void zgemm_(char* transa, char* transb, int* m, int* n, int* k, complex<double>* alpha,
complex<double>* a, int* lda, complex<double>* b, int* ldb,
complex<double>* beta, complex<double>* c, int* ldc);
void zgemv_(char* trans, int* m, int* n, complex<double>* alpha,
complex<double>* a, int* lda, complex<double>* x, int* incx,
complex<double>* beta, complex<double>* y, int* incy);
void calculate_energy_absorption() {
//other parts of code.....
zgesv_(called);
if (i == 0) {
std::copy(p.begin(), p.end(), transfer_matrix.begin());
} else {
zgemm_(called);
for (int i = 0; i < n_bulk; i++) {
zgemv_(called);
int main() {
//test_variable definition
calculate_energy_absorption();
return 0;
it compiles with the following command
g++ -o test test.cpp -std=c++11 -llapack -lopenblas
and I get the results I expect.
But when I migrate this function to the target fix code, am unable to compile it. Heres what I did
I included
void calculate_energy_absorption();in that fix class’s private scope in its header file. -
In the cpp file
using namespace LAMMPS_NS;
using namespace FixConst;
using namespace MathConst;
using std::complex;
using std::vector;
using std::cout;
using std::endl;
extern "C" {
added the above at the top and defined the function
void FixTTMMod::calculate_energy_absorption() {
//idential to the code i tested outside lammps
- In CMake list, added the package to the condition that searches for LAPACK AND BLAS
if(PKG_MSCG OR PKG_ATC OR PKG_AWPMD OR PKG_ML-QUIP OR PKG_LATTE OR PKG_ELECTRODE OR PKG_EXTRA-FIX[**here**])
enable_language(C)
find_package(LAPACK)
find_package(BLAS)
Then compiled as usual, lapack and blas is found
Found BLAS: /usr/lib/x86_64-linux-gnu/libopenblas.so
-- Looking for cheev_
-- Looking for cheev_ - found
-- Found LAPACK: /usr/lib/x86_64-linux-gnu/libopenblas.so;-lm;-ldl
However, this happens at the end
[ 99%] Built target lammps
[ 99%] Building CXX object CMakeFiles/lmp.dir/home/sabik/lammps_t/src/main.cpp.o
[100%] Linking CXX executable lmp_fxv
/usr/bin/ld: liblammps_fxv.a(fix_ttm_mod.cpp.o): in function `LAMMPS_NS::FixTTMMod::calculate_energy_absorption()':
/home/sabik/lammps_t/src/EXTRA-FIX/fix_ttm_mod.cpp:1641: undefined reference to `zgesv_'
/usr/bin/ld: /home/sabik/lammps_t/src/EXTRA-FIX/fix_ttm_mod.cpp:1646: undefined reference to `zgemm_'
/usr/bin/ld: /home/sabik/lammps_t/src/EXTRA-FIX/fix_ttm_mod.cpp:1659: undefined reference to `zgemv_'
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/lmp.dir/build.make:109: lmp_fxv] Error 1
make[1]: *** [CMakeFiles/Makefile2:187: CMakeFiles/lmp.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
Obviously, these function are defined in openblas and works independently. How to solve this linking issue?
