Hi All,
I have been confused about lj/cut args. In the manual it is written that lj/cut args = cut off and cut off = global cut off for LJ interactions ( distance units). This game me an impression that args should be 2.5, but I see an examples where they use 7.5 as a global cut off. I guess that I am missing something. I would appreciate if someone can answer my question or can send me a link where it is explained.
Rose
Hi All,
why should the cutoff by (only) 2.5 (and 2.5 in what units)?
i and many others have used and will use many different values for the
cutoff varying over a wide range of values depending on the details of
the specific system, the model and the choice of units.
for any additional information, i suggest you review your text book on
MD where it describes the reason for using a cutoff and how a suitable
value is chosen.
axel
As Axel said, note that the 2.5 or 7.5 are in distance units.
The units command is often different in different input scripts.
2.5 is a typical value for LJ units. 7.5 is typical
for real or metal units, since distance = Angstroms.
Thank you Axel and Steve.
Rose
