Lj/sf/dipole/sf formula
I am trying to use a potential provided in the following paper:
Orsi, M., 2014. Comparative assessment of the ELBA coarse-grained model for water. Molecular Physics , 112 (11), pp.1566-1576.
The pair style provided in this paper matches with lj/sf/dipole/sf pair style in LAMMPS except for one factor which I am confused about. The dipole-dipole (Epp) interaction for this pair style is defined in LAMMPS as:
However, in the paper, it is defined as:
The first factor is missing in the LAMMPS (or atleast I think so and maybe wrong). Can you please guide me if the factor is actually missing or my understanding is incorrect?
Thank you.
It depends on the unit system, for some unit systems that prefactor is 1.0. So the two formulas are equivalent.
For example, see https://www.reddit.com/r/askscience/comments/19pnw8/in_planck_units_why_is_the_coulomb_constant_set/.
Thank you for your response, Dr. Moore. I am using real units for my simulation and not sure if the prefactor will be 1.0 in this case. In the case of coulombic pair style, a prefactor C is defined which is the same as 1/(4piepsilon_0). See:
The value of this prefactor C for real units is defined in update.cpp as:
force->qqr2e = 332.06371; // see also force->qqr2d_lammps_real
Thank you for your guidance.
LAMMPS automatically does the right thing depending on the unit system that you choose. Just make sure the units are correct for the potential parameters that you input into LAMMPS.
Thank you again, Dr. Moore. I understand that both the formulas are same (in my original post) and LAMMPS will take care of the prefactor. I will make sure that the units of the potential parameters are correct (all in real units in my case).
