When I have an ave/histo fix and try to read it in python with lmp.numpy.extract_fix('histogram', LMP_STYLE_GLOBAL, LMP_TYPE_ARRAY), it returns the value stored in row 0, column 0, which are the default values given in numpy_wrapper.py line 220, but not what the documentation says: “Return type: integer or double value, pointer to 1d or 2d double array or None”.
Reading the documentation, I would expect that a global fix which is an array would make lmp.numpy.extract_fix() return a 2-D Numpy Array. Instead, it returns the (0,0) element of that array.
I believe there’s a bug in the numpy wrapper implementation which does not call self.darray() to convert the data if the style is LMP_STYLE_GLOBAL.
Maybe the documentation is also imprecise when telling me it returns a pointer to a numpy array? I read that as meaning a numpy array, just like other methods do, that’s why I also suspect a documentation bug.
lmp.numpy.extract_compute() seems to adequately treat global computes, so I may be able to provide a patch for that tomorrow.
I’m running version 2 Aug 2023 - Update 2, but the code in the develop branch is the same.
Please provide a minimal working example file (ideally based on an existing LAMMPS example that runs very fast) so that we don’t have to reverse engineer what you did and spend a lot of time just to figure out how to reproduce what you are seeing.
I just remembered…
This is not going to be as simple as you would expect. That is due to a design choice in the LAMMPS C++ code that goes back a very, very long time (long before the python module and the C-library interface).
When accessing global values from a fix only a single scalar may be looked up and will be returned. Please see the first “Note” block for the documentation of the underlying C-library interface function: 1.1.5. Compute, fixes, variables — LAMMPS documentation
That is why the arguments “nrow” and “ncol” exist.
Computes are different in this regard.
TL;DR: this is not a bug but the expected behavior. The only problem is that the documentation of the python module functions does not mention it (only the C-library interface docs). This will be fixed in the next version of LAMMPS.
Per the documentation, I would expect histo to be either a numpy array or a pointer to be interpreted as gibberish if not properly cast. Instead I get a Float which is exactly the (0, 0) term of the array.
Ah, ok, good point. I was only reading the python documentation. So to obtain the histogram as a numpy array I should loop through the values in range(0,nbins), for each column in the array. I can do that in my code, no problem, that’s what I was about to do in order to not depend on a development version of LAMMPS.
I wonder if it would be more beneficial to implement this loop in the numpy wrapper itself, because if the data is internally an array, a regular user would expect that a numpy wrapper for an API would return the array, not an element, silently defaulting to (0,0). On the other hand, I can see the argument that the numpy wrapper, the python API and the C API should be consistent. Either way, the documentation should be fixed indeed.
I was thinking the same thing. But it is not for me alone to make that decision. If the change would be made, it would best be done in the C-library interface and then propagated throughout. The code already needs to malloc() space for a single double value and then pass it to the calling code as a pointer which is then required to free the pointer. Switching this to a malloc() for an entire vector or array would not make that much of a difference.
I would suggest that you describe the situation and submit this as a feature request issue on GitHub Issues · lammps/lammps · GitHub and I can bring this up at the next meeting of the LAMMPS developers in early April.
