Hi all,
I have several hundred lammps data files with slight changes in structure that I would like to perform the same procedure on. The input files have ordered names like data11, data12, data 2*3 etc. I’m using read_data to read all those data files. How could I achieve this? Any help would be appreciated.
Hao
You could use a BASH script to get a list of all of these data files and then create and run a LAMMPS script.
Something like this:
file_array=$(find ./ -name “data*”)
for file in ${file_array[@]}
do
Start writing your input scripts here
cat <${file}.in
Your LAMMPS settings here
read_data ${file}
More LAMMPS commands here
EOM
Run LAMMPS script
mpirun -n 10 ${file}.in
done
you could create a file with all the files and then use a file style variable to read them in and loop over them in a LAMMPS input.
please see the documentation for the variable command.
axel
Thank you all for the advice. They are very helpful!
Hao
