I am trying to run loop in lammps input file through the command
------------------------------- Initialization Section --------------------
#—loop for 100 run–
variable i loop 100
label loop
include system.in.init
------------------------------- Atom Definition Section -------------------
read_data system.data
------------------------------- Settings Section --------------------------
include system.in.settings
------------------------------- Run Section -------------------------------
Only the groupB atoms are immobile.
group mobile subtract all groupB
print “--------- beginning minimization (using fix langevin) ---------”
timestep 0.1
group one id 73
fix 2 one setforce 0.0 0.0 0.0
fix 6 mobile setforce NULL NULL 0.0
velocity mobile set NULL NULL 0.0
#fix 5 all enforce2d
fix fxlan mobile langevin 1.0 1.0 100.0 48279
#fix fxlan mobile langevin 1.0 1.0 100.0 4928459
fix fxnve mobile nve
thermo 100
run 5000
unfix fxlan
unfix fxnve
unfix 6
unfix 2
– simulation protocol –
print “--------- beginning simulation (using fix npt) ---------”
dump 1 all custom 1000 traj_npt$i.lammpstrj id mol type x y z ix iy iz
thermo_style custom step temp pe etotal press vol epair ebond eangle edihed
thermo 200 # time interval for printing out “thermo” data
------------------------- NPT ---------------------------
fix Ffreezestuff groupB rigid single force * off off off torque * off off off
fix 4 mobile setforce NULL NULL 0.0
#velocity mobile create 300.0 4928459 dist gaussian
#fix 5 mobile momentum 1 linear 1 1 0
fix fxMoveStuff mobile npt temp 273 273 100 iso 100 100 400.0 dilate mobile drag 0.0
compute tempMobile mobile temp
compute pressMobile all pressure tempMobile
thermo_style custom step c_tempMobile c_pressMobile temp press vol
fix_modify fxMoveStuff temp tempMobile
timestep 0.01
run 2000000
#timestep 0.06
#run 500000
write_data system_after_npt_$i.data
undump 1
unfix fxMoveStuff
unfix 4
unfix Ffreezestuff
next i
jump SELF loop
label break
but there is this error:
ERROR: Units command after simulation box is defined (…/input.cpp:2007)
Last command: units real
Can anyone suggest anything in this.
Thanyou
Andri
run.in.npt (2.03 KB)
