I tried to run this my input script: in.CUGSMNEW. I got lost atoms warning. The run started with 10330 atoms and ended with 10328 atoms. I observed that the 2 lost atoms are within the simulation box. From Lammps documentation, it is stated that this could due to too large a timestep or huge forces and velocities. I want to be sure of effect of this on the result analysis.
My biggest surprise is that my tool moved backward and started machining in the opposite direction. I thought may be I need to state the direction of the velocity in the input script or needs to check my data file. Even with 150000 runs no observable chips. Any clue about this is welcomed and appreciated
in.CUGSMNEW (1.7 KB)
I attached the script and the jpeg from OVITO. Thanks
