Respected Developer,
Output file shows 'lost atoms error ’ , on decreasing box length in x-direction by 6 units from both sides. Although the positions of the particle is still within the new dimensions.
Initial configuration (dump_Pxx_d60_300K.dat)
px_min px_max 0.5634 120.363 (px : particle position in x-direction)
Initial xlo xhi -5.535 126.5
after step decrease by 6 units from both sides
Final xlo xhi 0.465 120.5
Since, particle px_min & px_max is within xlo xhi (final) respectively, then why ‘LOST atom error’ is there??
input2 (1.39 KB)
output.dat (2.43 KB)
dump_Pxx_d60_300K.dat (729 KB)
Output file shows 'lost atoms error ' , on decreasing box length in
x-direction)
then why 'LOST atom error' is there??
changing box dimensions may require to move atoms between subdomains.
if atoms have to be moved by a larger distance than the communication
cutoff, they will be lost.
This question is in common for may ones.
I do appreciate Axel’s response, could you please elucidate your purpose?
