I’m beginner in lammps. I’ve been trying develop nanoindentation code for Al-Cu-Mg nanorod. My script is here. Why I’ve been facing the issues of lost atoms in every step of indent run zone. Is there any mistake on my code?
3D indenter simulation
atom_style atomic
read_data alloy.lmp
pair_style meam
pair_coeff * * library.meam Al Si Mg Cu Fe alloy.meam Al Mg Cu
define groups
region fixed block 0 89.1 0 10 0 89.1
group lower region fixed
region thermo block 0 89.1 10 20 0 89.1
group thermostat region thermo
region mobile block 0 89.1 20 89.1 0 89.1
group mobile region mobile
velocity all create 300.0 12345 mom yes rot no dist gaussian
fix 1 mobile nve
fix 2 thermostat nvt temp 300.0 300.0 0.1
fix 3 lower setforce 0.0 0.0 0.0
------------------ Equilibration Run ------------------
timestep 0.001
thermo 100
fix 4 all npt temp 300.0 300.0 0.1 iso 0.0 0.0 1.0
thermo_style custom step temp press pxx pyy pzz
run 100
unfix 4
run with indenter
reset_timestep 0
variable y equal " 89.1-stepdt0.0001"
print “y is $y”
variable disp equal “stepdt0.0001”
variable f1 equal f_5[1]
variable f2 equal f_5[2]
variable f3 equal f_5[3]
variable load equal “((v_f1)^2 + (v_f2)^2 + (v_f3)^2)^(1/2)”
variable force equal fmax
variable stp equal “step”
Dumps (optional)
fix 5 mobile indent 50 sphere 20 v_y 50 50.0
thermo 100
thermo_style custom step temp v_y f_5[1] f_5[2] f_5[3] fmax #displacement force in all three direction
fix 6 all print 100 “stp{force} ${disp}” title “step load disp” file output_data3.txt screen no
dump 1 all atom 100 dump.indent
run 30000
