low pressure fails in fix gcmc
I’m tring simulate adsoprtion of pure gas in a box (Argon to 87K)
I created a data.file with a cube of l 20A and a atom Ar inside.
then I created a mol file with a Argon atom
in my input file a create region and atom
region
region zone1 block 0 {l} 0 {l} 0 ${l}
probe
molecule Arprobe Ar.txt
create atoms
create_atoms 0 random 10 {vel_seed} zone1 mol Arprobe {vel_seed}
group
group Ars type 1 0
mass
mass * 39.948000000
Minimization Step
min_style cg
min_modify line quadratic
minimize 1.0e-6 1.0e-6 100000 100000
reset_timestep 0
velocity
velocity Ars create {Temp} {vel_seed} sum yes dist uniform loop all
compute TArs Ars temp
compute_modify TArs dynamic/dof yes
nvt
fix Arsnvt Ars nvt temp 87 87 10.0
fix_modify Arsnvt dynamic/dof yes temp TArs
thermo_style custom step vol temp press atoms v_rho v_T v_P
thermo ${Nequilib}
timestep 0.5
run ${Nequilib}
unfix Arsnvt
reset_timestep 0
gcmc
fix Arsgcmc Ars gcmc 100 100 0 {vel_seed} 87 {mu} ${drTrasl} mol Arprobe pressure 0.1 fugacity_coeff 0.998 tfac_insert 2 full_energy
compute average density (probe/cell)
fix rho_Ave Ars ave/time 1 10000 10000 v_rho file rho_ave.log ave running
#compute average temp
fix temp_Ave Ars ave/time 1 10000 10000 v_T file temp_ave.log ave running
#compute average press
fix press_Ave Ars ave/time 1 10000 10000 v_P file press_ave.log ave running
dynamically update default temperature ndof
compute_modify thermo_temp dynamic/dof yes
thermo_style custom step vol temp press atoms v_rho v_T v_P etotal
thermo 1000
timestep 0.5
run 10000
After equilibration nvt I noticed with no insert of molecules is done to gcmc. the temp becomes O so also the pressure
Why?
there is a bug?, or lammps cannot calculare a low pressure
my nvt output
Step Volume Temp Press Atoms v_rho v_T v_P
0 8000 87 14.468132 11 0.001375 87 14.468132
10000 8000 84.32683 14.34321 11 0.001375 84.32683 14.34321
0 atoms in group FixGCMC:gcmc_exclusion_group:Arsgcmc
0 atoms in group FixGCMC:rotation_gas_atoms:Arsgcmc
WARNING: Neighbor exclusions used with KSpace solver may give inconsistent Coulombic energies (…/neighbor.cpp:472)
Per MPI rank memory allocation (min/avg/max) = 10.11 | 10.11 | 10.11 Mbytes
Step Volume Temp Press Atoms v_rho v_T v_P TotEng
0 8000 84.32683 14.342547 11 0.001375 84.32683 14.342547 1.3743711
WARNING: Using kspace solver on system with no charge (…/kspace.cpp:289)
1000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
2000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
3000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
4000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
5000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
6000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
7000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
8000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
9000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
10000 8000 0 -0.084108694 0 0 0 -0.084108694 -0.0049065989
how I could fix it??
Regards
Al
Hello Alberto , I have some comments .
Hope it helps.!
You mean just inserting Argon in a box with argon ?? If that so, the box will empty or fill related to the vapor pressure of argon at that temperature, Do you know it. ??? that will give you a hint if the box should be empty or with very little amount of particles or filled
Argon is an atom, why using a the mol file??? it is just necessary when you are inserting molecules
region
probe
Again this is actually not needed
create atoms
group
group Ars type 1 0
mass
mass * 39.948000000
Minimization Step
min_style cg
reset_timestep 0
velocity
nvt
thermo ${Nequilib}
timestep 0.5
run ${Nequilib}
unfix Arsnvt
Why did you unfix the nvt ?? the gcmc works better when coupled with md to update the positions of the particles.
reset_timestep 0
gcmc
you should not use full energy with Argon atoms it slows down the calculation and is not nesesary as you also don’t have charges
At your input pressure 0.1 you should see if it is above or below the vapor pressure of argon at that temperature, if it is below you have a gas phase, at fist approximation you could estimate the number of argon particles in the volume of the simulation box by using ideal gases this will give you a hit of what result to expect .
thermo 1000
timestep 0.5
run 10000
Why?
my nvt output
Do not use kspace you don’t have charges
