lpad not found, help needed.
I tried to follow the installation instructions at http://pythonhosted.org/FireWorks/installation.html (using pip) on two different computers (OSX and Cent OS), with a python distribution supplied by anaconda (v2.7.12). In both of these, the pip install went off without any isues, but then in trying to Testing Connection to remote server, I run into the following error:
$ lpad -l my_launchpad_testing.yaml get_wflows
-bash: lpad: command not found
This is using version 1.4.1
On the OSX machine, I cloned the github source and installed it using the setup file. Then in running unit tests via:
python setup.py test
Here is the failure (The full log file is attached):
Ran 116 tests in 113.174s
OK
Exception in thread pymongo_server_monitor_thread:
File "/usr/local/miniconda/lib/python2.7/threading.py", line 801, in __bootstrap_inner
self.run()
File "/usr/local/miniconda/lib/python2.7/threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "/Users/rbiswas/.local/lib/python2.7/site-packages/pymongo/periodic_executor.py", line 124, in _run
while not self._stopped and _time() < deadline:
TypeError: 'NoneType' object is not callable
Exception in thread pymongo_kill_cursors_thread:
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
time[master]fireworks$
failure.log (28.7 KB)
Hi Rahul,
Can you try typing:
“lpad version”
and seeing if that works in either installation? Let me know what it says.
A few other notes:
i) I had no trouble installing fireworks (including lpad) using anaconda on Mac OS/X using a scratch environment with the commands:
conda create -n scratch_env python=2.7 pip
source activate scratch_env
pip install fireworks
lpad version
this will print out some text confirming that lpad is installed, namely:
(u’FireWorks version:', ‘1.4.1’)
(u’located in:', ‘/Users/ajain/miniconda3/envs/scratch_env/lib/python2.7/site-packages’)
ii) Also, note that there is a fireworks conda installation as well that you can try:
https://anaconda.org/matsci/fireworks
Best
Anubhav
OK
File “/usr/local/miniconda/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
self.run()
File “/usr/local/miniconda/lib/python2.7/threading.py”, line 754, in run
File “/Users/rbiswas/.local/lib/python2.7/site-packages/pymongo/periodic_executor.py”, line 124, in _run
TypeError: ‘NoneType’ object is not callable
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
Hi Anubhav,
In both the installs, I got
lpad version
Similarly, I also created a conda environment using exactly what you did. I still get the same problem as shown below:
$ conda create -n scratch_env python=2.7 pip
$ Linking packages …
[ COMPLETE ]|#################################################################################| 100%
(scratch_env) time$ lpad version
Rahul
On Tue, Mar 7, 2017 at 9:13 AM, Anubhav Jain [email protected] wrote:
Hi Rahul,
Can you try typing:
“lpad version”
A few other notes:
lpad version
Best
Anubhav
OK
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
You received this message because you are subscribed to a topic in the Google Groups “fireworkflows” group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/fireworkflows/5OUVYjhPjLI/unsubscribe.
To unsubscribe from this group and all its topics, send an email to [email protected].
To post to this group, send email to [email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/ff91a752-06ac-44e6-80ef-65b29807a530%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Hi Rahul,
If you have followed the same commands as me on Mac OS/X, unfortunately I don’t have any other suggestions. You can try a fresh install of miniconda from the web site with the Mac binary. Alternatively, you can try the conda install of FireWorks as detailed in the last email rather than pip or github.
Other than that, I wouldn’t be able to know more about the problem unless I can reproduce it on my end or hear about it from others. So far this is the first I’ve heard of this particular issue.
Note also that for some reason, your “which pip” gives:
/usr/local/miniconda/envs/scratch_env/bin/pip
mine for “which pip” gives:
/Users/ajain/miniconda3/envs/scratch_env/bin/pip
suggesting there is a difference in the way anaconda is installed - i.e. usr/local versus /Users/ and miniconda vs miniconda3
Best
Anubhav
On Tue, Mar 7, 2017 at 9:54 AM, Rahul Biswas [email protected] wrote:
Hi Anubhav,
lpad version
To activate this environment, use:
To deactivate this environment, use:
> source deactivate scratch_env
time$ source activate scratch_env
(scratch_env) time$ which pip
(scratch_env) time$ pip install fireworks
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/CALoPJkVc4-p9HaFsvr%2BMQyZ7t8Ktmrp3CpSpSt8bQrn9h5W4rA%40mail.gmail.com.
Anubhav
Rahul
Hi Rahul,
Can you try typing:
“lpad version”
A few other notes:
lpad version
Best
Anubhav
OK
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
Hi Anubhav,
  1. Good news: I could get the conda install you suggested working (at least to the lpad version stage) on my osx laptop! No new environment required.
  2. But for information on the previous error:
I don’t believe my miniconda is very special. During installation, miniconda allows the user the option of choosing the install location, with the default being ${HOME}/miniconda. In your case you must have accepted that, while I usually choose it to be /usr/local/miniconda .
Rahul
On Tue, Mar 7, 2017 at 10:48 AM, Anubhav Jain [email protected] wrote:
Hi Rahul,
Best
Anubhav
Hi Anubhav,
lpad version
Anubhav
Rahul
Hi Rahul,
Can you try typing:
“lpad version”
A few other notes:
lpad version
Best
Anubhav
OK
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
Hi Rahul
1 - could you share what changed to fix the issue? Just to document the solution in case anyone else sees this issue
2 - i couldn’t tell from the message whether you will still having additional. if that’s the case could you submit a new ticket?
Best
Anubhav
On Tuesday, March 7, 2017 at 1:23:48 PM UTC-8, Rahul Biswas wrote:
Hi Anubhav,
  1. But for information on the previous error:
Rahul
Hi Rahul,
Best
Anubhav
Hi Anubhav,
lpad version
Rahul
Hi Rahul,
Can you try typing:
“lpad version”
A few other notes:
lpad version
Best
Anubhav
OK
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
Anubhav
Actually forget #1 - I just realized that you used “conda install” to solve it. So we still don’t know why reproducing my steps to use pip doesn’t help on your system, but I guess at least we have a way forward.
On Tuesday, March 7, 2017 at 1:51:26 PM UTC-8, Anubhav Jain wrote:
Hi Rahul
Best
Anubhav
Hi Anubhav,
Rahul
Hi Rahul,
Best
Anubhav
Hi Anubhav,
lpad version
Rahul
Hi Rahul,
Can you try typing:
“lpad version”
A few other notes:
lpad version
Best
Anubhav
OK
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
Anubhav
Hi Abhunav,
Right. I realized you had just missed that earlier. Thanks for the conda pointer!
For 2. I seem to be good to go for now using the conda install. The pip install did not work for reasons I did not understand (and you have the log files for my attempt). If there is additional information that you can think of that would help you deal with this if this issue gets reported again, I would be happy to get those details to you.
Rahul
Hi Rahul
Best
Anubhav
Hi Anubhav,
Rahul
Hi Rahul,
Best
Anubhav
Hi Anubhav,
lpad version
Rahul
Hi Rahul,
Can you try typing:
“lpad version”
A few other notes:
lpad version
Best
Anubhav
OK
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
self.run()
Anubhav
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/fb7065da-f941-4d2c-9f86-69c4ae962993%40googlegroups.com.
I am meeting a similar problem about the installation of fireworks in a conda environment:
enter: $lpad version
usage: lpad [-h] [-v] [-o {json,yaml}] [-l LAUNCHPAD_FILE] [-c CONFIG_DIR] [–logdir LOGDIR] [–loglvl LOGLVL] [-s]
{init,reset,add,check_wflow,get_launchdir,append_wflow,dump_wflow,add_scripts,get_fws,get_fws_in_wflows,track_fws,rerun_fws,defuse_fws,pause_fws,reignite_fws,resume_fws,update_fws,get_wflows,defuse_wflows,pause_wflows,reignite_wflows,archive_wflows,delete_wflows,get_qids,cancel_qid,detect_unreserved,detect_lostruns,set_priority,webgui,recover_offline,forget_offline,admin,report,introspect}
lpad: error: argument command: invalid choice: ‘version’ (choose from ‘init’, ‘reset’, ‘add’, ‘check_wflow’, ‘get_launchdir’, ‘append_wflow’, ‘dump_wflow’, ‘add_scripts’, ‘get_fws’, ‘get_fws_in_wflows’, ‘track_fws’, ‘rerun_fws’, ‘defuse_fws’, ‘pause_fws’, ‘reignite_fws’, ‘resume_fws’, ‘update_fws’, ‘get_wflows’, ‘defuse_wflows’, ‘pause_wflows’, ‘reignite_wflows’, ‘archive_wflows’, ‘delete_wflows’, ‘get_qids’, ‘cancel_qid’, ‘detect_unreserved’, ‘detect_lostruns’, ‘set_priority’, ‘webgui’, ‘recover_offline’, ‘forget_offline’, ‘admin’, ‘report’, ‘introspect’)
How to solve it?
Thanks.
