The lpad webgui command no longer works for me. It’s been a while since I used it and I don’t know what changed.
$ lpad webgui
File "/usr/local/var/pyenv/versions/borealis/bin/lpad", line 8, in <module>
sys.exit(lpad())
File "/usr/local/var/pyenv/versions/3.8.3/envs/borealis/lib/python3.8/site-packages/fireworks/scripts/lpad_run.py", line 1209, in lpad
args.func(args)
File "/usr/local/var/pyenv/versions/3.8.3/envs/borealis/lib/python3.8/site-packages/fireworks/scripts/lpad_run.py", line 561, in webgui
p1.start()
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/process.py", line 121, in start
self._popen = self._Popen(self)
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/context.py", line 224, in _Popen
return _default_context.get_context().Process._Popen(process_obj)
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/context.py", line 283, in _Popen
return Popen(process_obj)
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/popen_spawn_posix.py", line 32, in __init__
super().__init__(process_obj)
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/popen_fork.py", line 19, in __init__
self._launch(process_obj)
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/popen_spawn_posix.py", line 47, in _launch
reduction.dump(process_obj, fp)
File "/usr/local/var/pyenv/versions/3.8.3/lib/python3.8/multiprocessing/reduction.py", line 60, in dump
ForkingPickler(file, protocol).dump(obj)
TypeError: cannot pickle '_thread.lock' object
This happens in FireWorks==1.9.5 on both Python 3.8.0 and Python 3.8.3. lpad reset doesn’t change this.
lpad get_fws works fine. So does running workflows with this my_launchpad.yaml file and this MongoDB server.
I could try running the lpad command in the PyCharm debugger, but in the stack trace it looks like the webgui() function calls p1.start() on a Process object that contains a Thread lock.
I tried creating a fresh Python 3.8.3 virtualenv and running pip install FireWorks>=1.9.5. pip list prints:
Package Version
click 7.1.2
FireWorks 1.9.5
Flask 1.1.2
flask-paginate 0.7.0
gunicorn 20.0.4
itsdangerous 1.1.0
Jinja2 2.11.2
MarkupSafe 1.1.1
monty 3.0.4
pip 20.1.1
pymongo 3.10.1
python-dateutil 2.8.1
ruamel.yaml 0.16.10
ruamel.yaml.clib 0.2.0
setuptools 49.2.0
six 1.15.0
tabulate 0.8.7
tqdm 4.47.0
Werkzeug 1.0.1
wheel 0.34.2
