I have two monomers (A and B) and terminator (C). I want to make a polymer like
C-(-AAABAAABAAAB-)n -C
This is how I tried to do this:
But I am getting random number of A followed by one B.
You should change a few things to accomplish your goal:
# Groups
ITEM GROUPS
a *AAA*,1,b:2
b *B*,1,a:2
c *C,1,a:1,1,a:2,1,b:1,1,b:2
ITEM END
# Clusters
ITEM CLUSTERS
poly alternate,1
ITEM END
# Polymers
ITEM POLYMERS
poly
1 a,30,b,30,c,2
ITEM END
The above solution would also work when choosing a random polymer, since the connectivity does not allow connections between monomers a and a or monomers b and b. Note that the number of repeat units of a and b have to be equal within a delta of 1 – e.g. 29 and 30 or 30 and 30 – in order to obtain a valid polymer. Alternatively, you could combine monomer a and b into one monomer mono:
# Groups
ITEM GROUPS
mono *AAAB*,1,mono:2
term *C,1,mono:1,1,mono:2,1
ITEM END
# Clusters
ITEM CLUSTERS
poly alternate,1
ITEM END
# Polymers
ITEM POLYMERS
poly
1 mono,30,term,2
ITEM END
In the latter solution, you could also use random instead of alternate, since here the resulting polymer constitutes of only one monomer.
Thanks for your reply.
I actually needed to change the number of As and Bs (AAAAAAAAABAAAAAAAAAB…), So I ended up using the block template and manually writing the sequence (a,10,b,1,a,10,b,1…).
