Hi all,
I am trying to simulate coarse grained cellulose chain using martini force field parameters.
I used the following parmeters from this Paper (https://pubs.acs.org/doi/10.1021/jp5105938)
pair_coeff 	1 1 1.33 4.7
pair_coeff 	2 2 0.478 6.2
pair_coeff 	3 3 1.33 4.7
pair_coeff 	4 4 1.33 4.7
pair_coeff 	5 5 0.478 6.2
pair_coeff 	6 6 1.33 4.7
bond_coeff 	1 71.7 2.32
bond_coeff 	2 71.7 2.22
bond_coeff 	3 71.7 5.55
bond_coeff 	4 71.7 2.20
bond_coeff 	5 71.7 2.30
angle_coeff 	1 11.95 166
angle_coeff 	2 11.95 85
angle_coeff 	3 11.95 85
angle_coeff 	4 11.95 113
angle_coeff     5 11.95 80
angle_coeff     6 11.95 165
dihedral_coeff 1 2.39 1 0
dihedral_coeff 2 2.39 1 0
The (.in) file is given below:
    units         real
     dimension     3
     boundary     p p p
     atom_style   full
#     neighbor       2.5 bin
#     neigh_modify   delay 5
pair_style	lj/cut 12.0
#pair_modify 	mix arithmetic
pair_modify    shift yes mix geometric
bond_style	harmonic
angle_style	harmonic
dihedral_style  harmonic
read_data	cell5.lmp
include         Parameter.lammps
# Assign original velocities to atoms
compute         new all temp
velocity        all create 298.1 487639 temp new
# Set up ensemble
 fix             1 all nvt temp 298.1 298.1 100.0
timestep        5
# Output temperature, energy, pressure of the system
     thermo_style    custom step temp etotal pe ke pxx pyy pzz
     thermo_modify   flush yes
     thermo          100
     dump            1 all xyz 100 dumpcg13.xyz
run             200000
     write_data     cg13.data
But, I am not getting the negative potential energy. Do you have any suugestions?
Pinky
