Matching compute temp/profile with compute temp/deform
Dear LAMMPS users,
I am attempting to perform an NEMD shear flow simulation of dumbbell particles using fix nvt and fix deform. The dumbbells are comprised of a linear spring and two spherical particles.
I have attached a minimal script with the appropriate molecule file. The lammps version used is lammps-2Aug2023 compiled in Linux.
in.nvt_with_hookean_DB_particle_lang_eq_minimal (3.1 KB)
molecule.Old_B_db (182 Bytes)
Does anyone have any advice how to get compute temp/profile and compute temp/deform to match closely? At all flow rates considered there seems to be a systematic difference between the temperature computed from compute temp/profile and compute temp/deform.
Luke Debono
Why do you think they should match?
I’m using this as a test to determine whether the particles are streaming according to the box deformation, as stated in the documentation for compute temp/deform.
Dear LAMMPS users,
This issue was fixed by using fix nvt/sllod and refining the bin size for compute temp/profile.
Luke Debono
