Hi, everyone!
When I’m trying to run e.g.:
from matminer.featurizers.conversions import StrToComposition
it fails and says
cannot import name ‘MPRester’ from ‘pymatgen’
I guess it is related to the problem with new pymatgen version, which was discussed here https://matsci.org/t/bug-import-statements-from-pymatgen-are-outdated-w-newest-version/35599/5 but the solution presented there is inappropriate here.
I tried:
- to install an earlier version of pymatgen by
conda install -n my_env -c conda-forge pymatgen~=2021.1 scikit-learn plotly tqdm - to install matminer code in developmental mode
but it all didn’t work out.
So I guess, the only solution is to ask the developers of Matminer to update the code…when you will able to do it?
Thank you in advance!
