I am currently running optimization workflows (with OptimizeFW, not wf_structure_optimization to be able to change the workflow name) for a large number of LLZO structures and some of the workflows fizzled while the VASP calculations finished successfully (files zipped, OUTCAR looks ok). In the output file, I could find this error :
ERROR:custodian.custodian:MaxForceErrorHandler
repeated 5 times which stops the workflow:
custodian.custodian.MaxCorrectionsPerJobError: Max errors per job reached: 5.
I checked custodian which indicates the MaxForceErrorHandler is deprecated. Is it possible to deactivate the MaxForceErrorHandler ? Since the structures are partially randomly generated, it is certainly be a problem with initial POSCAR (I checked however I don’t submit structures with atoms too close) but since VASP calculations finished, I am not sure.
