ATAT has been used by Zaddach et al. to produce the special quasirandom structure of high entropy alloys of Ni-Fe-Cr-Co-Mn (JOM, Vol. 65, No. 12, 2013).
Is it possible to use mcsqs code to create Mg based quaternary and quinary alloys. They are not necessarily high entropy alloys and may include constituent elements with having 1% at. or less than 1% at. compositions.
The resulting SQS may be used to find the phase diagrams and stacking fault energies.
mcsqs should be able to handle this - but keep in mind that <1% composition means a supercell of at least 100 atoms and probably more since other constraints need to be satisfied for a good SQS!
There is no "best" setting for the range of correlations that have to match the disordered states.
Larger numbers give you the potential to reach a higher accuracy, but the resulting SQS need to be larger. "Best" depends on your trade-off between accuracy and computational cost.
You should read the original references on SQS if you want to understand better what these correlations range mean:
In terms of time, it usually takes a few minutes to run corrdump (but 10 is probably a rather long range (too long), which implies hundreds of clusters, which could take a long time…)
I suggest you start small (with -2 only and set it to the nearest neighbor distance) and see how long it takes. Gradually increase it as needed.
The message: "Impossible to match point correlations due to incompatible supercell size." Just tells you that give the concentration you gave as input, it is impossible to even contruct a single supercell of the size you request that would have that composition. For instance, if you have compositions like A=0.70,B=0.25,C=0.05 on one site, you’d need a multiple of 20 atoms per supercell.
You mentioned:
"For instance, if you have compositions like A=0.70,B=0.25,C=0.05 on one site, you’d need a multiple of 20 atoms per supercell."
Has this "multiples of 20 atoms" been inferred from dividing 100 by the least atomic % of the constituent element?
e.g. if A=0.70,B=0.28,C=0.02, then
the least at. % is 2percent, and a multiple of 50 atoms per supercell is needed?
