Hi! I’ve been trying to run a simple simulation to be able to generate a graph of potential energy vs volume of an unminimised cell. However, when I try to run it, LAMMPS returns the error “MEAM library error 3”!
I don’t understand what could trigger it as the exact same MEAM library in other simulations works fine, so I tried looking inside pair_meamc.cpp, but I don’t understand from it what’s the error 3 on the function meam_setup_param.
Any input would be appreciated!
Bellow is my simulation and the library files :
Input file :
Antoine Rincent, 2019
suffix omp
package omp 1
variable lattconst equal 3
variable repetition equal 20
variable testnum equal 1
variable foldernum equal 0
variable testname string Alpur_UvsV
log {testname}_{foldernum}_${testnum}.potentialtest
---------- Initialize Simulation ---------------------
clear
atom_style atomic
atom_modify map array
---------- Create Atoms ---------------------
lattice fcc ${lattconst}
region box block 0 {repetition} 0 {repetition} 0 ${repetition} units lattice
create_box 2 box
lattice fcc ${lattconst} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1 # un latice unit par direction
create_atoms 2 box
group solid region box
set group solid type/fraction 1 0.0 420
---------- Define Interatomic Potential ---------------------
pair_style meam/c
pair_coeff * * libraryNiAlCo.meam Al Ni NiAlCo.meam Al Ni
neighbor 2.0 bin
delete_atoms overlap 0.35 all all
---------- Run Minimization ---------------------
thermo 1
thermo_style custom step temp vol pe press
thermo_modify flush yes norm no
fix 1 all nvt temp 0.1 0.1 0.1
variable iteration equal “step”
variable tempe equal “temp”
variable potential equal “pe”
variable pressure equal “press”
variable volume equal “vol”
fix 2 all print 1 "{iteration} {tempe} {volume} {potential} {pressure}" file {testname}_{foldernum}_{testnum}.results screen no title “step temp vol pe press”
run 1
définition de variables
variable natoms equal “count(all)”
affichage des variables définies
print “Number of atoms = ${natoms};”
print “All done!”
libraryNiAlCo.meam :
elt lat z ielement atwt
alpha b0 b1 b2 b3 alat esub asub
t0 t1 t2 t3 rozero ibar
‘Ni’ ‘fcc’ 12 1 58.690
5.0842175782 2.56 1.50 6.00 1.50 3.5213917703 4.45 0.94
1 3.10 1.80 4.36 1.00 3
‘Al’ ‘fcc’ 12 1 26.982
4.6855976824 3.20 2.60 6.00 2.60 4.0446507884 3.36 1.16
1 3.05 0.51 7.75 1.00 3
‘Co’ ‘hcp’ 12 1 58.933
5.2356147485 3.50 0.00 0.00 4.00 2.5000000000 4.41 0.90
1 3.00 5.00 -1.00 1.00 3
NiAlCo.meam :
rc = 4.5
delr = 0.1
augt1 = 0
erose_form = 2
ialloy = 2
zbl(1,1) = 0
nn2(1,1) = 1
attrac(1,1) = 0.05
repuls(1,1) = 0.05
Cmin(1,1,1) = 0.81
Cmax(1,1,1) = 2.8
Ec(1,1) = 4.45
re(1,1) = 2.49
zbl(2,2) = 0
nn2(2,2) = 1
attrac(2,2) = 0.05
repuls(2,2) = 0.05
Cmin(2,2,2) = 0.49
Cmax(2,2,2) = 2.8
Ec(2,2) = 3.36
re(2,2) = 2.86
zbl(3,3) = 0
nn2(3,3) = 1
attrac(3,3) = 0
repuls(3,3) = 0
Cmin(3,3,3) = 0.49
Cmax(3,3,3) = 2
Ec(3,3) = 4.41
re(3,3) = 2.5
rho0(1) = 1
rho0(2) = 1
rho0(3) = 1
zbl(1,2) = 0
nn2(1,2) = 1
Ec(1,2) = 4.5307
re(1,2) = 2.4916
alpha(1,2) = 4.82953834827973
attrac(1,2) = 0.05
repuls(1,2) = 0.05
Cmin(1,1,2) = 1.6
Cmin(2,2,1) = 0.49
Cmin(1,2,1) = 0.64
Cmin(1,2,2) = 0.64
Cmin(2,1,1) = 0.64
Cmin(2,1,2) = 0.64
Cmax(1,1,2) = 2.8
Cmax(2,2,1) = 2.8
Cmax(1,2,1) = 1.44
Cmax(1,2,2) = 2.8
Cmax(2,1,1) = 1.44
Cmax(2,1,2) = 2.8
lattce(1,2) = ‘b2’
zbl(1,3) = 0
nn2(1,3) = 1
Ec(1,3) = 4.31
re(1,3) = 2.43
alpha(1,3) = 5.19486200471772
attrac(1,3) = 0.025
repuls(1,3) = 0.025
Cmin(1,1,3) = 0.81
Cmin(3,3,1) = 0.49
Cmin(1,3,1) = 0.64
Cmin(1,3,3) = 0.64
Cmin(3,1,1) = 0.64
Cmin(3,1,3) = 0.64
Cmax(1,1,3) = 2.8
Cmax(3,3,1) = 2.8
Cmax(1,3,1) = 2.8
Cmax(1,3,3) = 2.8
Cmax(3,1,1) = 2.8
Cmax(3,1,3) = 2.8
lattce(1,3) = ‘b2’
zbl(2,3) = 0
nn2(2,3) = 1
Ec(2,3) = 4.45
re(2,3) = 2.476
alpha(2,3) = 4.88849071730002
attrac(2,3) = 0.025
repuls(2,3) = 0.025
Cmin(2,2,3) = 1.1
Cmin(3,3,2) = 0.49
Cmin(2,3,2) = 0.49
Cmin(2,3,3) = 0.49
Cmin(3,2,2) = 0.49
Cmin(3,2,3) = 0.49
Cmax(2,2,3) = 2.8
Cmax(3,3,2) = 2
Cmax(2,3,2) = 2.8
Cmax(2,3,3) = 1.44
Cmax(3,2,2) = 2.8
Cmax(3,2,3) = 1.44
lattce(2,3) = ‘b2’
Cmax(1,2,3) = 1.44
Cmax(1,3,2) = 2.38
Cmax(2,3,1) = 1.44
Cmin(1,2,3) = 0.56
Cmin(1,3,2) = 0.97
Cmin(2,3,1) = 0.56
Thanks a lot and have a nice day!
Antoine.
