Hello i’m doing a simulation with MEAM potential but i have some problems, for example when i build a video the atoms have a strong movement, even changing temperature until 100 or 10 k, but the total energy and potential energy are stable, for me is not logical, because it’s a simulation of a solid, in this case palladium and the analysis should show a solid, and show me a fluid.
I assumed that was a problem of equilibration but it is not true, the particles never stoped of move, never show me a solid structure, here a example of a input file that i use. Thanks.
units real
boundary f f f
atom_style full
read_data data.pdme4
pair_style meam
pair_coeff * * /home/home/Descargas/lammps-11Nov13/potentials/library.meam Pd /home/home/Descargas/lammps-11Nov13/potentials/Pd2.meam Pd
#pair_coeff 1 1 10.563 2.5158
#pair_coeff 2 2 13.48709 2.4622
dihedral_style none
improper_style none
group paladiorodio id 1
neighbor 4.0 bin
neigh_modify every 1 delay 1 check yes
fix 2 all nvt temp 100.0 100.0 30
fix reflect all wall/reflect xlo EDGE xhi EDGE ylo EDGE yhi EDGE zlo EDGE zhi EDGE
velocity all create 100 432567 dist uniform
compute cna all cna/atom 3.5
compute centro all centro/atom fcc
compute cluster all cluster/atom 4.0
compute coord all coord/atom 3.5
compute ackland all ackland/atom
timestep 1
thermo 5000
thermo_style custom step temp pe etotal ecoul evdwl enthalpy
thermo_modify norm yes
dump video all atom 5000 dump.pdme7-TIF
dump 1 all custom 5000 dump.fcc3 id x y z c_cna c_centro c_cluster c_coord c_ackland
restart 50000000 restart.*.pdme7-TIF
run 50000000
