I am currently trying to measure the enthalpy profile within a thin slap in a 3D simulation box, i.e., I split the box into 2D bins with the command
compute bins fluid chunk/atom bin/2d x lower 0.5 z lower 0.5 bound y -0.4 0.4
and then want to calculate the enthalpy via H = U + pV for each bin.
I first determine the per-atom stress (already measured in units of [p][V]) via
compute peratomStress all stress/atom NULL
In the next step, I first just looked at the output of the first three components of the stress tensor
fix stressComponentsSlap fluid ave/chunk 1 1 1 bins c_perAtomStress[1] c_perAtomStress[2] c_perAtomStress[2] file stressSlap.txt
Worked quite well.
Because the pressure*volume per bin would then bis simply given by the negative sum over the first three components of the perAtomStress vector divided by 3 , I would like to define a per-atom variable like
variable perAtomPressure equal -(c_peratomStress[1]+c_peratomStress[2]+c_peratomStress[3])/3
and output the binned data via
fix pVslap fluid ave/chunk 1 1 1 bins v_perAtomPressure file pVslap.txt
Now, we come to my problem:
I receive the error message: “Fix ave/chunk variable is not atom-style variable”
Apparently, I define the per-atom pressure variable in the wrong way. It is supposed to add the three components of the stress tensor for each atom, which it obviously does not.
From the variable command documentation, however, I cannot find how to do this properly. Is it possible to do something like this in LAMMPS?
Sven Auschra
