I am trying to fit the force constants for a HfO2 slab. My perturbation calculations progressed fine.
However, when I try to fit the force constants using: 'fitfc -f -er=8.5 -fr=4.25, I get the following error message:
Performing least square fit…
Problem size= 12960 x 45
Done
Creating Force constants…
Done
Performing normal modes calculations
kmesh= 6 5 2
*** Error in `fitfc’: double free or corruption (out): 0x00000000008f60a0 ***
Aborted (core dumped)
Could you please provide some directions as to where I may be going wrong?
hello Anjana
have you solved this problem ? i also met the same recommendation. if you have solved it, can you please tell me the method how to remove this error?
Thank you very much
waiting your reply !
Hello, Prof. avdw,
I have the same problem. showing "vol_2
p+0.1_12_0
Generating Fitting matrices
1/576
Problem size= 576 x 0
Done
Done
kmesh= 3 4 2
*** glibc detected *** fitfc: double free or corruption (out): 0x00000000022df830 ***
======= Backtrace: =========
/lib64/libc.so.6[0x3093e75f3e]
/lib64/libc.so.6[0x3093e78dd0]
fitfc[0x4152ca]
/lib64/libc.so.6(__libc_start_main+0xfd)[0x3093e1ed1d]
fitfc[0x4027a9]
======= Memory map: ========"
Have you solved the problem with the last user?
Can you help me to check the reason of the come out of this warning?
I am facing the same problem. I am working on FCC systems with 108 atoms. The configuration that I am trying to get the force constant values has 106 Ni atoms and 2 Cr atoms in it. The error I am getting for the fitfc -f -fr=3.5 is this:
Problem size= 209952 x 3945
Done
Done
kmesh= 2 5 1
For generating the perturbed folders, I used this command:
I had a same problem (double free or corruption) in atat_50.
Try older version of atat.
I have not tried all the version, but fitfc -f works in atat_10.
Hello, I also meet same problem, my solved method is decrease the value of “-frnn”.
First my -frnn=1.5, then have same error. I try to decrease the value to 1.2, It successful run.
Yes, changing the force constant range helps. If it’s too large the fitting matrices may get too large (out of mem) or singular.
-sfc=2 or 1 can help reduce such and debug (although more approximate).
You can see a summary of the fitted force constants with grep svsl vol_0/fc.out
