I’m running into a problem with fix vector in the latest stable LAMMPS. I’ve reduced it to a short testcase (a modification of the LJ melt example ; runs in under 1 second on 1 core). This has crashed on two distinct HPC systems, and with both serial or MPI executables. I think the problem may be related to memory allocation (not) occurring in fix_vector.cpp’s init() when a run command with “pre no” is used (?). Other data related fixes, such as ave/time, work if inserted in its place. It also works if “pre no” in the final run command is changed to “pre yes”. In my actual use case, I need the “pre no” run command. I’d be really interested in a patch if one is made. I pasted the testcase input and output at the end of this mail.
Also, there’s a broken link on http://lammps.sandia.gov/doc/fix.html – the vector command link goes to vector.html instead of fix_vector.html. I’ve really enjoyed using LAMMPS and have found its documentation and mailing list archives to be quite helpful! Thanks for all your work.
sincerely,
Brian Barnes
-----INPUT-----
3d Lennard-Jones melt
units lj
atom_style atomic
lattice fcc 0.8442
region box block 0 10 0 10 0 10
create_box 1 box
create_atoms 1 box
mass 1 1.0
velocity all create 3.0 87287
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 2.5
neighbor 0.3 bin
neigh_modify every 20 delay 0 check no
fix 1 all nve
thermo 1
#run 10 # uncommenting this line delays the crash
fix 2 all vector 1 c_thermo_temp # this fix causes crash with later ‘pre no’ run
run 10 pre yes post no
run 10 pre no post yes
-----END INPUT-----
-----OUTPUT-----
LAMMPS (9 Dec 2014)
Lattice spacing in x,y,z = 1.6796 1.6796 1.6796
Created orthogonal box = (0 0 0) to (16.796 16.796 16.796)
Created 4000 atoms
Setting up run …
Memory usage per processor = 2.19271 Mbytes
Step Temp E_pair E_mol TotEng Press
0 3 -6.7733681 0 -2.2744931 -3.7033504
1 2.9951987 -6.7662407 0 -2.2745659 -3.6588262
2 2.9802109 -6.7439895 0 -2.2747908 -3.5226206
3 2.9532502 -6.7039491 0 -2.2751813 -3.2867189
4 2.9112587 -6.6412126 0 -2.2754163 -2.9370172
5 2.8498812 -6.5487251 0 -2.274972 -2.4537522
6 2.7636568 -6.4191689 0 -2.2747202 -1.8155961
7 2.6467777 -6.2451068 0 -2.2759327 -1.0023218
8 2.4951145 -6.0194029 0 -2.2776669 -0.0006588972
9 2.3100696 -5.742567 0 -2.2783289 1.1746157
10 2.1031859 -5.4317227 0 -2.2777326 2.4556252
Loop time of 0.0311601 on 1 procs for 10 steps with 4000 atoms
11 1.8973697 -5.1217377 0 -2.2763946 3.7176309
_pmiu_daemon(SIGCHLD): [NID 00017] [c0-0c0s4n1] [Tue Dec 23 16:47:34 2014] PE RANK 0 exit signal Segmentation fault
Application 4821326 exit codes: 139
Application 4821326 resources: utime ~0s, stime ~1s, Rss ~124240, inblocks ~12868, outblocks ~33468
-----END OUTPUT----
The binary used to run that example was created with an Intel compiler (icc 14.0.2).
