Recently I wanted to try the KOKKOS package and I encountered a problem with qeq/reax/kk. Namely, when I start a simulation on a GPU I get an “out of memory” error, even when there is only one atom in a system. A simple input script which triggers this error is attached to the e-mail. The command I use for running the simulation is “lmp_kokkos -k on gpus 1 -sf kk -in out_of_memory.in”.
The GPU is GTX 1080 and I used “Maxwell53” as a value of the “KOKKOS_ARCH” variable, as it is the highest compute capability available. I have no problems with using other KOKKOS-accelerated pair styles, including reax/c/kk with the charge equilibration disabled.
Below is a stack trace from gdb.
I would greatly appreciate any help.
Cheers,
Michal
#0 0x00007f1527357418 in __GI_raise ([email protected]…4654…=6) at …/sysdeps/unix/sysv/linux/raise.c:54
#1 0x00007f152735901a in __GI_abort () at abort.c:89
#2 0x00007f1527ebb84d in __gnu_cxx::__verbose_terminate_handler() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#3 0x00007f1527eb96b6 in ?? () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#4 0x00007f1527eb9701 in std::terminate() () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#5 0x00007f1527eb9919 in __cxa_throw () from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x0000000000e4e443 in Kokkos::Impl::throw_runtime_exception (msg=“cudaMalloc( &ptr, arg_alloc_size ) error( cudaErrorMemoryAllocation): out of memory …/…/lib/kokkos/core/src/Cuda/Kokkos_CudaSpace.cpp:249”)
at …/…/lib/kokkos/core/src/impl/Kokkos_Error.cpp:72
#7 0x0000000000e58970 in Kokkos::Impl::cuda_internal_error_throw (e=, [email protected]…4654…=0xeecdc0 “cudaMalloc( &ptr, arg_alloc_size )”, [email protected]…4654…=0xeeccc8 “…/…/lib/kokkos/core/src/Cuda/Kokkos_CudaSpace.cpp”,
[email protected]…4654…=249) at …/…/lib/kokkos/core/src/Cuda/Kokkos_Cuda_Impl.cpp:133
#8 0x0000000000e54bd5 in Kokkos::Impl::cuda_internal_safe_call (line=249, file=0xeeccc8 “…/…/lib/kokkos/core/src/Cuda/Kokkos_CudaSpace.cpp”, name=0xeecdc0 “cudaMalloc( &ptr, arg_alloc_size )”, e=)
at …/…/lib/kokkos/core/src/Cuda/Kokkos_Cuda_Error.hpp:60
#9 Kokkos::CudaSpace::allocate (arg_alloc_size=18446744073564053424, this=0x7ffc32d3e500) at …/…/lib/kokkos/core/src/Cuda/Kokkos_CudaSpace.cpp:249
#10 Kokkos::Experimental::Impl::SharedAllocationRecord<Kokkos::CudaSpace, void>::SharedAllocationRecord (this=0x88b10b0, arg_space=…, arg_label=“qeq/kk:jlist”, arg_alloc_size=18446744073564053296,
arg_dealloc=0xa14610 <Kokkos::Experimental::Impl::(anonymous namespace)::deallocate<Kokkos::CudaSpace, Kokkos::Experimental::Impl::ViewValueFunctor<Kokkos::Cuda, int, true> >(Kokkos::Experimental::Impl::SharedAllocationRecord<void, void>)>) at …/…/lib/kokkos/core/src/Cuda/Kokkos_CudaSpace.cpp:451
#11 0x0000000000a2a8ca in Kokkos::Experimental::Impl::SharedAllocationRecord<Kokkos::CudaSpace, Kokkos::Experimental::Impl::ViewValueFunctor<Kokkos::Cuda, int, true> >::SharedAllocationRecord (arg_alloc=18446744073564053296,
arg_label=“qeq/kk:jlist”, arg_space=…, this=0x88b10b0) at …/…/lib/kokkos/core/src/impl/KokkosExp_SharedAlloc.hpp:209
#12 Kokkos::Experimental::Impl::SharedAllocationRecord<Kokkos::CudaSpace, Kokkos::Experimental::Impl::ViewValueFunctor<Kokkos::Cuda, int, true> >::allocate (arg_alloc=18446744073564053296, arg_label=“qeq/kk:jlist”, arg_space=…)
at …/…/lib/kokkos/core/src/impl/KokkosExp_SharedAlloc.hpp:234
#13 Kokkos::Experimental::Impl::ViewMapping<Kokkos::Experimental::ViewTraits<int, Kokkos::LayoutLeft, Kokkos::Cuda, void>, void>::allocate_shared<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::integral_constant<unsigned int, 0u>, Kokkos::CudaSpace, Kokkos::Cuda> (arg_layout=…, arg_prop=…, this=0x7ffc32d3e5e8) at …/…/lib/kokkos/core/src/impl/KokkosExp_ViewMapping.hpp:2568
#14 Kokkos::Experimental::View<int*, Kokkos::LayoutLeft, Kokkos::Cuda, void>::View<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >(Kokkos::Experimental::Impl::ViewCtorProp<std::__cxx11::basic_string<char, std::char_traits, std::allocator > > const&, std::enable_if<!Kokkos::Experimental::Impl::ViewCtorProp<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >::has_pointer, Kokkos::LayoutLeft>::type const&) (this=0x7ffc32d3e5e0, arg_prop=…, arg_layout=…) at …/…/lib/kokkos/core/src/KokkosExp_View.hpp:1238
#15 0x0000000000d035b4 in Kokkos::Experimental::View<int*, Kokkos::LayoutLeft, Kokkos::Cuda, void>::View<char [13]> (arg_N7=0, arg_N6=0, arg_N5=0, arg_N4=0, arg_N3=0, arg_N2=0, arg_N1=0, arg_N0=, arg_label=…,
this=0x7ffc32d3e5e0) at …/…/lib/kokkos/core/src/KokkosExp_View.hpp:1337
#16 LAMMPS_NS::FixQEqReaxKokkosKokkos::Cuda::allocate_matrix ([email protected]…4654…=0x88c16b0) at …/fix_qeq_reax_kokkos.cpp:306
#17 0x0000000000d0cc78 in LAMMPS_NS::FixQEqReaxKokkosKokkos::Cuda::pre_force (this=0x88c16b0, vflag=) at …/fix_qeq_reax_kokkos.cpp:232
#18 0x00000000004c90b4 in LAMMPS_NS::ModifyKokkos::setup_pre_force (this=0x8dc9b70, vflag=2) at …/modify_kokkos.cpp:118
#19 0x00000000009f824e in LAMMPS_NS::VerletKokkos::setup (this=0x8dced20) at …/verlet_kokkos.cpp:123
#20 0x000000000048fe6e in LAMMPS_NS::Run::command ([email protected]…4654…=0x7ffc32d442d0, [email protected]…4654…=1, [email protected]…4654…=0x8dc36c0) at …/run.cpp:177
#21 0x00000000005feb69 in LAMMPS_NS::Input::command_creator<LAMMPS_NS::Run> (lmp=, narg=1, arg=0x8dc36c0) at …/input.cpp:859
#22 0x00000000005fce4f in LAMMPS_NS::Input::execute_command ([email protected]…4654…=0x5290050) at …/input.cpp:842
#23 0x00000000005fd9b7 in LAMMPS_NS::Input::file (this=0x5290050) at …/input.cpp:243
#24 0x0000000000418af6 in main (argc=9, argv=0x7ffc32d44598) at …/main.cpp:31
out_of_memory.in (430 Bytes)
