Try:
mpr.get_entry_by_material_id({"task_ids":"mp-37405"})
To be very explicit about what is happening here: if you ask for a specific task_id or material_id it has to be the canonical material_id (“mp-id”). Unfortunately, due to recent database changes, the canonical mp-id has changed as you’ve noticed. With this query, we are instead asking to find a material where it’s task_ids list (note the plural) contains the specific task_id you’re asking for. That’s why, if you make the query above, you will get this in response:
ComputedEntry mvc-16102 - Al5 Cu1 Se8
Energy = -61.4075
Correction = 0.0000
Parameters:
run_type = GGA
is_hubbard = False
pseudo_potential = {'functional': 'PBE', 'labels': ['Al', 'Cu_pv', 'Se'], 'pot_type': 'paw'}
hubbards = {}
potcar_symbols = ['PBE Al', 'PBE Cu_pv', 'PBE Se']
oxide_type = None
Data:
oxide_type = None
i.e. it returns mvc-16102.
If you do want the data for that specific task, you would ask for:
mpr.get_task_data('mp-37405')
and this would return:
[{'energy': -61.40748582,
'energy_per_atom': -4.386248987142857,
'volume': 299.91559029019317,
'nsites': 14,
'composition_unit_cell': {'Al': 5.0, 'Cu': 1.0, 'Se': 8.0},
'formula_pretty': 'Al5CuSe8',
'is_hubbard': False,
'hubbards': {},
'elements': ['Al', 'Cu', 'Se'],
'nelements': 3,
'spacegroup': {'source': 'spglib',
'symbol': 'F-43m',
'number': 216,
'point_group': '-43m',
'crystal_system': 'cubic',
'hall': 'F -4 2 3'},
'band_gap': 0.8704000000000001,
'density': 4.59619122937921,
'oxide_type': None,
'full_formula': 'Al5Cu1Se8',
'material_id': 'mp-37405'}]
The reason for this distinction is that there are many tasks performed by the Materials Project for any given single material, and we try to present the best aggregated data we can, while also giving people access to the underlying individual calculation tasks in case they are of interest to you.
