While using ABF, InputPrefix is used to merge windows and get a free energy profile. Is the same suggested for eABF?
I used InputPrefix to merge windows and get a free energy profile, but as mentioned in the documentation there are visual blips in it. I tried the recommended solutions, taking values for the extreme points in a window from .grad file and/or interpolate the end points in .zgrad file. But the free energy profiles I got from these two and the one I get if I do not do any changes are slightly different. Different in the sense that now free energy difference of bounded and unbounded state has increased by 0.05-0.2 kcal/mol (Order is like this: No changes < Interpolation < taking values from .grad file). Therefore I am confused which method should I use here to get the free energy profile?
Or shall I use slightly overlapping windows ?
Megha
