Dear Su
It is not too difficult to create a complex system with polymers
and particles mixed together. I wrote a molecule builder to help with
this process (http://moltemplate.org), but there are several other
good programs which do the same thing at
http://lammps.sandia.gov/prepost.html. if you are familiar with the
LAMMPS data file format, you can write you own script to build these
files yourself if you prefer. Here are some snapshots of simulations
of cells we've been working on:
http://moltemplate.org/images/misc/polymers_follow_a_curve.jpg
http://moltemplate.org/images/prokaryotes/ultrasmall_Luef++Banfield2015_model_2016-9-02.jpg
http://moltemplate.org/images/prokaryotes/confined_supercoiling_2016-1-13.jpg
--- walls ----
You can create a smooth cylinder barrier to confine the polymers using
"fix wall"
http://lammps.sandia.gov/doc/fix_wall.html
http://lammps.sandia.gov/doc/region.html
More complex wall shapes can be formed by joining multiple regions
together, or by arranging atoms on the boundary, and immobilizing
them. (Which you can do by omitting them from the group of atoms that
you move using fix nve, fix langeven. That's how I created the blue
ellipsoidal wall in the second image.)
http://lammps.sandia.gov/doc/group.html
--- disparate sizes ---
One issue with your simulations is the large difference in particle
sizes in your simulations. Some of your particles are much bigger
than others. Some of my simulations have this issue too. This will
slow your simulations. But it is still possible to run these kinds of
simulations efficiently in LAMMPS if you use the the "multi" options
with the "comm_modify" and "neighbor" commands:
http://lammps.sandia.gov/doc/comm_modify.html
http://lammps.sandia.gov/doc/neighbor.html
Alternately, you can construct large hollow spheres using many small spheres
(For example, see
http://espressomd.org/wordpress/wp-content/uploads/2012/01/reynwar07a-cover.png)
To hold the small spheres together, you can use "fix rigid". I am not
sure if this would be faster.
http://lammps.sandia.gov/doc/fix_rigid.html
--- hydrodynamics ---
I was not clear exactly how you wanted to model the solvent. And
even if you had indicated it, I wouldn't have been able to offer much
helpful advice. Getting the dynamics correct is not too important in
the simulations I have run so far, and I never had to worry about
hydrodynamics.
There are a lot of fixes, packages, and external programs which
couple particles in LAMMPS to a fluid in various ways. I strongly
suspect you will be able to find something which will do what you
need.
I don't think I answered all your questions, but hopefully I convinced
you that you can probably do what you're trying to do in LAMMPS.
Good luck.
Andrew
