Metallic Glass Creation
Hello.
So I am currently trying to create Ni62Nb38 binary metallic glass. When I run my simulation and analyze it in OVITO, I see that as the glass cools down to low temperatures, then atoms cluster together instead of a disarrayed structure. How can I fix this?
Thank you so much for your help and time.
Script:
units lj
atom_style atomic
region sim_box block -20.0 20.0 -20.0 20.0 -20.0 20.0
create_box 2 sim_box
mass 1 1.0 # Ni
mass 2 1.0 # Nb
create_atoms 1 random 315 22222222 sim_box # Ni
create_atoms 2 random 190 11111111 sim_box # Nb
pair_style lj/cut 2.5
pair_coeff 1 1 1.0 1.0 # Ni-Ni
pair_coeff 2 2 1.75 1.178 # Nb-Nb
pair_coeff 1 2 1.32 1.085 # Ni-Nb
neighbor 2.0 bin
velocity all create 0.25 12345 loop geom
minimize 1e-7 1e-9 10000 10000
timestep 0.02
thermo 100
dump 1 all atom 1000 dump.the_goat
fix 1 all npt temp 0.25 2.0 0.1 iso 0.001 0.001 5.0
run 400000
unfix 1
fix 1 all npt temp 2.0 2.0 0.1 iso 0.001 0.001 5.0
run 1000000
unfix 1
fix 1 all npt temp 2.0 0.1 0.1 iso 0.001 0.001 5.0
run 1700000
unfix 1
fix 1 all npt temp 0.1 0.1 0.1 iso 0.001 0.001 5.0
run 1000000 # Adjust this to sufficient time for equilibration (10 ns = 1000000 timesteps)
unfix 1
fix 1 all nve
run 3000000 # 30 ns in timesteps of 0.01
unfix 1
run 20000
When trying to model an actual material, LJ units are rarely a good idea. It just makes your life difficult.
Also, is a simple Lennard-Jones potential with very short cut-offs a good model for this system (its an actual question, I don’t know your system) ?
Simon
Hi Dr. Simon,
I see what you mean about the cut-off distance. I will look to see if that is the problem. I will double check my values and make sure that they are correct. Thank you so much for your advice.
Extremely unlikely.
The whole point of multibody potentials is that LJ potentials (and any purely radial potential in general) cannot capture the ground state angular configurations in solid-state materials.
