Hi @munrojm!
I am trying to access the Provenance docs to retrieve tags
, but I am facing an error I don’t quite understand.
with MPRester(api_key=key) as mpr:
docs = mpr.provenance.search()
returns
TypeError: __init__() got an unexpected keyword argument 'input_structure'
even though I clearly didn’t pass any keyword arguments. Any idea what’s going on?
This is the traceback, in case it’s needed.
c:\Users\anton\omissis\MP_tags.py in <module>
19 with MPRester(api_key=key) as mpr:
20 print("working on it")
----> 21 docs = mpr.provenance.search()
22 # print(type(docs))
23 # tags = docs.tags
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\mp_api\core\client.py in search(self, num_chunks, chunk_size, all_fields, fields, **kwargs)
784 # documented kwargs.
785
--> 786 return self._get_all_documents(
787 kwargs,
788 all_fields=all_fields,
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\mp_api\core\client.py in _get_all_documents(self, query_params, all_fields, fields, chunk_size, num_chunks)
833 chosen_param = list_entries[0][0] if len(list_entries) > 0 else None
834
--> 835 results = self._query_resource(
836 query_params,
837 fields=fields,
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\mp_api\core\client.py in _query_resource(self, criteria, fields, suburl, use_document_model, parallel_param, num_chunks, chunk_size)
286 url += "/"
287
--> 288 data = self._submit_requests(
289 url=url,
290 criteria=criteria,
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\mp_api\core\client.py in _submit_requests(self, url, criteria, use_document_model, parallel_param, num_chunks, chunk_size)
385 initial_params_list = [{"url": url, "verify": True, "params": copy(crit)} for crit in new_criteria]
386
--> 387 initial_data_tuples = self._multi_thread(use_document_model, initial_params_list)
388
389 for data, subtotal, crit_ind in initial_data_tuples:
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\mp_api\core\client.py in _multi_thread(self, use_document_model, params_list, progress_bar)
585
586 for future in finished:
--> 587 data, subtotal = future.result()
588 if progress_bar is not None:
589 progress_bar.update(len(data["data"]))
c:\Users\anton\miniconda3\envs\mp\lib\concurrent\futures\_base.py in result(self, timeout)
436 raise CancelledError()
437 elif self._state == FINISHED:
--> 438 return self.__get_result()
439
440 self._condition.wait(timeout)
c:\Users\anton\miniconda3\envs\mp\lib\concurrent\futures\_base.py in __get_result(self)
388 if self._exception:
389 try:
--> 390 raise self._exception
391 finally:
392 # Break a reference cycle with the exception in self._exception
c:\Users\anton\miniconda3\envs\mp\lib\concurrent\futures\thread.py in run(self)
50
51 try:
---> 52 result = self.fn(*self.args, **self.kwargs)
53 except BaseException as exc:
54 self.future.set_exception(exc)
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\mp_api\core\client.py in _submit_request_and_process(self, url, verify, params, use_document_model)
624
625 if self.monty_decode:
--> 626 data = json.loads(response.text, cls=MontyDecoder)
627 else:
628 data = json.loads(response.text)
c:\Users\anton\miniconda3\envs\mp\lib\json\__init__.py in loads(s, cls, object_hook, parse_float, parse_int, parse_constant, object_pairs_hook, **kw)
357 if parse_constant is not None:
358 kw['parse_constant'] = parse_constant
--> 359 return cls(**kw).decode(s)
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\monty\json.py in decode(self, s)
438 """
439 d = json.JSONDecoder.decode(self, s)
--> 440 return self.process_decoded(d)
441
442
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\monty\json.py in process_decoded(self, d)
423 return bson.objectid.ObjectId(d["oid"])
424
--> 425 return {self.process_decoded(k): self.process_decoded(v) for k, v in d.items()}
426
427 if isinstance(d, list):
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\monty\json.py in <dictcomp>(.0)
424
426
426
--> 428 return [self.process_decoded(x) for x in d]
429
430 return d
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\monty\json.py in <listcomp>(.0)
426
429
430 return d
424
426
424
426
426
429
430 return d
426
429
430 return d
424
426
424
426
407 data = {k: v for k, v in d.items() if not k.startswith("@")}
408 if hasattr(cls_, "from_dict"):
--> 409 return cls_.from_dict(data)
410 if pydantic is not None and issubclass(cls_, pydantic.BaseModel):
411 return cls_(**data)
c:\Users\anton\miniconda3\envs\mp\lib\site-packages\monty\json.py in from_dict(cls, d)
176 """
177 decoded = {k: MontyDecoder().process_decoded(v) for k, v in d.items() if not k.startswith("@")}
--> 178 return cls(**decoded)
179
180 def to_json(self) -> str:
Thank you!
