I am trying to use Lammps for my study. I am new and getting used to it.
Right now, i am trying to minimize the illite surface. i am using clayff
forcefield. I built the structure using Materials Studio and then converted in to lammps
data file. But when i try to minimize a illite surface, the energies are very huge
and the total structure collapses. I tried dumping the xyz coordinates and found the initial
structure is fine, but for some reason the pair energy is terrible worse. I did look at the
data file and found that pair coefficients are fine. Do know what has gone wrong
Herewith, i give the input file and datafile i used.
Kindly help me in this regard
#Lammps Input script for water
units real
newton on
processors * * *
#Defining different potential types
atom_style full
pair_style lj/cut/coul/long 10.0
bond_style harmonic
angle_style harmonic
dihedral_style harmonic
improper_style harmonic
read_data mus-20.lammps05
kspace_style ewald 1e-4
dielectric 1.0
#Data reading and neighbouring
neighbor 2.0 bin
dump 1 all xyz 1 dump.test.xyz
dump_modify 1 sort id
#Minimization
min_style cg
minimize 1.0e-6 1.0e-8 500 1000
Lammps Datafile
LAMMPS 2005 data file for mus-20
672 atoms
960 bonds
2496 angles
5760 dihedrals
192 impropers
8 atom types
7 bond types
17 angle types
24 dihedral types
3 improper types
0.000000000 20.808000000 xlo xhi
0.000000000 18.048000000 ylo yhi
0.000000000 20.078000000 zlo zhi
Masses
1 26.981541
2 26.981541
3 28.085501
4 15.999400
5 15.999400
6 15.999400
7 1.007940
8 39.098301
Pair Coeffs
1 0.0000013275 4.2718397269
2 0.0000018394 3.3022013769
3 0.0000018394 3.3022013769
4 0.1553999393 3.1655414285
5 0.1553999393 3.1655414285
6 0.1553999393 3.1655414285
7 0.0000000000 0.0000000000
8 0.1000000849 3.3340100368
Bond Coeffs
1 0.0000 0.0000
2 0.0000 0.0000
3 0.0000 0.0000
4 0.0000 0.0000
5 0.0000 0.0000
6 0.0000 0.0000
7 554.1348 1.0000
Angle Coeffs
1 0.0000 0.0000
2 0.0000 0.0000
3 0.0000 0.0000
4 0.0000 0.0000
5 0.0000 0.0000
6 0.0000 0.0000
7 0.0000 0.0000
8 0.0000 0.0000
9 0.0000 0.0000
10 0.0000 0.0000
11 0.0000 0.0000
12 0.0000 0.0000
13 0.0000 0.0000
14 0.0000 0.0000
15 0.0000 0.0000
16 0.0000 0.0000
17 0.0000 0.0000
Dihedral Coeffs
1 0.0000 1 0
2 0.0000 1 0
3 0.0000 1 0
4 0.0000 1 0
5 0.0000 1 0
6 0.0000 1 0
7 0.0000 1 0
8 0.0000 1 0
9 0.0000 1 0
10 0.0000 1 0
11 0.0000 1 0
12 0.0000 1 0
13 0.0000 1 0
14 0.0000 1 0
15 0.0000 1 0
16 0.0000 1 0
17 0.0000 1 0
18 0.0000 1 0
19 0.0000 1 0
20 0.0000 1 0
21 0.0000 1 0
22 0.0000 1 0
23 0.0000 1 0
24 0.0000 1 0
Improper Coeffs
1 0.0000 0
2 0.0000 0
3 0.0000 0
Atoms
1 0 1 1.575000 1.295297990 0.739968020 0.004015600
2 0 2 1.575000 2.346102026 2.328191877 2.730608149
3 0 3 2.100000 0.166464008 3.880320065 7.308391851
4 0 4 -1.168750 2.007972038 2.265023884 1.104289994
5 0 5 -1.050000 0.197675994 4.006656052 8.994944278
6 0 4 -1.168750 2.179637998 0.848255971 3.332947873
7 0 4 -1.168750 1.331712063 3.356928080 3.373103955
8 0 5 -1.050000 1.310904021 2.815488058 6.826520072
9 0 6 -0.950000 0.228887998 0.640704021 9.035099761
10 0 7 0.425000 0.228887998 1.669440022 9.035099761
11 0 1 1.575000 3.896297990 5.251968020 0.004015600
12 0 3 2.100000 4.947102026 6.840191877 2.730608149
13 0 3 2.100000 2.767464008 8.392320065 7.308391851
14 0 5 -1.050000 4.608972038 6.777023884 1.104289994
15 0 5 -1.050000 2.798675994 8.518656052 8.994944278
16 0 5 -1.050000 4.780637998 5.360255971 3.332947873
17 0 5 -1.050000 3.932712063 7.868928080 3.373103955
18 0 4 -1.168750 3.911904021 7.327488058 6.826520072
19 0 6 -0.950000 2.829887998 5.152704021 9.035099761
20 0 7 0.425000 2.829887998 6.181440022 9.035099761
21 0 1 1.575000 3.906702011 0.739968020 10.034984400
22 0 3 2.100000 2.855897974 2.328191877 7.308391851
23 0 3 2.100000 5.035535992 3.880320065 2.730608149
24 0 5 -1.050000 3.194027962 2.265023884 8.934710006
25 0 5 -1.050000 5.004324007 4.006656052 1.044055722
26 0 5 -1.050000 3.022362002 0.848255971 6.706052127
27 0 5 -1.050000 3.870287937 3.356928080 6.665896045
28 0 4 -1.168750 3.891095979 2.815488058 3.212479928
29 0 6 -0.950000 4.973112002 0.640704021 1.003900240
30 0 7 0.425000 4.973112002 1.669440022 1.003900240
31 0 1 1.575000 1.305702011 5.251968020 10.034984400
32 0 2 1.575000 0.254897974 6.840191877 7.308391851
33 0 3 2.100000 2.434535992 8.392320065 2.730608149
34 0 4 -1.168750 0.593027962 6.777023884 8.934710006
35 0 5 -1.050000 2.403324007 8.518656052 1.044055722
36 0 4 -1.168750 0.421362002 5.360255971 6.706052127
37 0 4 -1.168750 1.269287937 7.868928080 6.665896045
38 0 5 -1.050000 1.290095979 7.327488058 3.212479928
39 0 6 -0.950000 2.372112002 5.152704021 1.003900240
40 0 7 0.425000 2.372112002 6.181440022 1.003900240
41 0 1 1.575000 3.906702010 8.284031980 -0.004015600
42 0 2 1.575000 2.855897974 6.695808123 -2.730608149
43 0 3 2.100000 5.035535992 5.143679935 12.769608149
44 0 4 -1.168750 3.194027962 6.758976116 -1.104289994
45 0 5 -1.050000 5.004324007 5.017343948 11.083055723
46 0 4 -1.168750 3.022362002 8.175744029 -3.332947873
47 0 4 -1.168750 3.870287937 5.667071920 -3.373103955
48 0 5 -1.050000 3.891095979 6.208511942 13.251479928
49 0 6 -0.950000 4.973112001 8.383295979 11.042900240
50 0 7 0.425000 4.973112001 7.354559978 11.042900240
51 0 1 1.575000 1.305702010 3.772031980 -0.004015600
52 0 3 2.100000 0.254897974 2.183808123 -2.730608149
53 0 3 2.100000 2.434535992 0.631679935 12.769608149
54 0 5 -1.050000 0.593027962 2.246976116 -1.104289994
55 0 5 -1.050000 2.403324007 0.505343948 11.083055723
56 0 5 -1.050000 0.421362002 3.663744029 -3.332947873
57 0 5 -1.050000 1.269287937 1.155071920 -3.373103955
58 0 4 -1.168750 1.290095979 1.696511942 13.251479928
59 0 6 -0.950000 2.372112001 3.871295979 11.042900240
60 0 7 0.425000 2.372112001 2.842559978 11.042900240
61 0 1 1.575000 1.295297990 8.284031980 10.043015599
62 0 3 2.100000 2.346102026 6.695808123 12.769608149
63 0 3 2.100000 0.166464008 5.143679935 -2.730608149
64 0 5 -1.050000 2.007972039 6.758976116 11.143289994
65 0 5 -1.050000 0.197675993 5.017343948 -1.044055722
66 0 5 -1.050000 2.179637998 8.175744029 13.371947873
67 0 5 -1.050000 1.331712063 5.667071920 13.412103955
68 0 4 -1.168750 1.310904021 6.208511942 -3.212479928
69 0 6 -0.950000 0.228887998 8.383295979 -1.003900240
70 0 7 0.425000 0.228887998 7.354559978 -1.003900240
71 0 1 1.575000 3.896297990 3.772031980 10.043015599
72 0 2 1.575000 4.947102026 2.183808123 12.769608149
73 0 3 2.100000 2.767464008 0.631679935 -2.730608149
74 0 4 -1.168750 4.608972039 2.246976116 11.143289994
75 0 5 -1.050000 2.798675993 0.505343948 -1.044055722
76 0 4 -1.168750 4.780637998 3.663744029 13.371947873
77 0 4 -1.168750 3.932712063 1.155071920 13.412103955
78 0 5 -1.050000 3.911904021 1.696511942 -3.212479928
79 0 6 -0.950000 2.829887998 3.871295979 -1.003900240
80 0 7 0.425000 2.829887998 2.842559978 -1.003900240
81 0 8 1.000000 -0.000000000 0.875328026 5.019500000
82 0 8 1.000000 2.601000000 5.387328026 5.019500000
83 0 8 1.000000 -0.000000000 8.148671974 15.058500000
84 0 8 1.000000 2.601000000 3.636671974 15.058500000
85 0 1 1.575000 6.497297990 0.739968020 0.004015600
86 0 2 1.575000 7.548102026 2.328191877 2.730608149
87 0 3 2.100000 5.368464008 3.880320065 7.308391851
88 0 4 -1.168750 7.209972038 2.265023884 1.104289994
89 0 5 -1.050000 5.399675994 4.006656052 8.994944278
90 0 4 -1.168750 7.381637998 0.848255971 3.332947873
91 0 4 -1.168750 6.533712063 3.356928080 3.373103955
92 0 5 -1.050000 6.512904021 2.815488058 6.826520072
93 0 6 -0.950000 5.430887998 0.640704021 9.035099761
94 0 7 0.425000 5.430887998 1.669440022 9.035099761
95 0 1 1.575000 9.098297990 5.251968020 0.004015600
96 0 3 2.100000 10.149102026 6.840191877 2.730608149
97 0 3 2.100000 7.969464008 8.392320065 7.308391851
98 0 5 -1.050000 9.810972038 6.777023884 1.104289994
99 0 5 -1.050000 8.000675994 8.518656052 8.994944278
100 0 5 -1.050000 9.982637998 5.360255971 3.332947873
101 0 5 -1.050000 9.134712063 7.868928080 3.373103955
102 0 4 -1.168750 9.113904021 7.327488058 6.826520072
103 0 6 -0.950000 8.031887998 5.152704021 9.035099761
104 0 7 0.425000 8.031887998 6.181440022 9.035099761
105 0 1 1.575000 9.108702011 0.739968020 10.034984400
106 0 3 2.100000 8.057897974 2.328191877 7.308391851
107 0 3 2.100000 10.237535992 3.880320065 2.730608149
108 0 5 -1.050000 8.396027962 2.265023884 8.934710006
109 0 5 -1.050000 10.206324007 4.006656052 1.044055722
110 0 5 -1.050000 8.224362002 0.848255971 6.706052127
111 0 5 -1.050000 9.072287937 3.356928080 6.665896045
112 0 4 -1.168750 9.093095979 2.815488058 3.212479928
113 0 6 -0.950000 10.175112002 0.640704021 1.003900240
114 0 7 0.425000 10.175112002 1.669440022 1.003900240
115 0 1 1.575000 6.507702011 5.251968020 10.034984400
116 0 2 1.575000 5.456897974 6.840191877 7.308391851
117 0 3 2.100000 7.636535992 8.392320065 2.730608149
118 0 4 -1.168750 5.795027962 6.777023884 8.934710006
119 0 5 -1.050000 7.605324007 8.518656052 1.044055722
120 0 4 -1.168750 5.623362002 5.360255971 6.706052127
121 0 4 -1.168750 6.471287937 7.868928080 6.665896045
122 0 5 -1.050000 6.492095979 7.327488058 3.212479928
123 0 6 -0.950000 7.574112002 5.152704021 1.003900240
124 0 7 0.425000 7.574112002 6.181440022 1.003900240
125 0 1 1.575000 9.108702010 8.284031980 -0.004015600
126 0 2 1.575000 8.057897974 6.695808123 -2.730608149
127 0 3 2.100000 10.237535992 5.143679935 12.769608149
128 0 4 -1.168750 8.396027962 6.758976116 -1.104289994
129 0 5 -1.050000 10.206324007 5.017343948 11.083055723
130 0 4 -1.168750 8.224362002 8.175744029 -3.332947873
131 0 4 -1.168750 9.072287937 5.667071920 -3.373103955
132 0 5 -1.050000 9.093095979 6.208511942 13.251479928
133 0 6 -0.950000 10.175112001 8.383295979 11.042900240
134 0 7 0.425000 10.175112001 7.354559978 11.042900240
135 0 1 1.575000 6.507702010 3.772031980 -0.004015600
136 0 3 2.100000 5.456897974 2.183808123 -2.730608149
137 0 3 2.100000 7.636535992 0.631679935 12.769608149
138 0 5 -1.050000 5.795027962 2.246976116 -1.104289994
139 0 5 -1.050000 7.605324007 0.505343948 11.083055723
140 0 5 -1.050000 5.623362002 3.663744029 -3.332947873
141 0 5 -1.050000 6.471287937 1.155071920 -3.373103955
142 0 4 -1.168750 6.492095979 1.696511942 13.251479928
143 0 6 -0.950000 7.574112001 3.871295979 11.042900240
144 0 7 0.425000 7.574112001 2.842559978 11.042900240
145 0 1 1.575000 6.497297990 8.284031980 10.043015599
146 0 3 2.100000 7.548102026 6.695808123 12.769608149
147 0 3 2.100000 5.368464008 5.143679935 -2.730608149
148 0 5 -1.050000 7.209972039 6.758976116 11.143289994
149 0 5 -1.050000 5.399675993 5.017343948 -1.044055722
150 0 5 -1.050000 7.381637998 8.175744029 13.371947873
151 0 5 -1.050000 6.533712063 5.667071920 13.412103955
152 0 4 -1.168750 6.512904021 6.208511942 -3.212479928
153 0 6 -0.950000 5.430887998 8.383295979 -1.003900240
154 0 7 0.425000 5.430887998 7.354559978 -1.003900240
155 0 1 1.575000 9.098297990 3.772031980 10.043015599
156 0 2 1.575000 10.149102026 2.183808123 12.769608149
157 0 3 2.100000 7.969464008 0.631679935 -2.730608149
158 0 4 -1.168750 9.810972039 2.246976116 11.143289994
159 0 5 -1.050000 8.000675993 0.505343948 -1.044055722
160 0 4 -1.168750 9.982637998 3.663744029 13.371947873
161 0 4 -1.168750 9.134712063 1.155071920 13.412103955
162 0 5 -1.050000 9.113904021 1.696511942 -3.212479928
163 0 6 -0.950000 8.031887998 3.871295979 -1.003900240
164 0 7 0.425000 8.031887998 2.842559978 -1.003900240
165 0 8 1.000000 5.202000000 0.875328026 5.019500000
166 0 8 1.000000 7.803000000 5.387328026 5.019500000
167 0 8 1.000000 5.202000000 8.148671974 15.058500000
168 0 8 1.000000 7.803000000 3.636671974 15.058500000
169 0 1 1.575000 11.699297990 0.739968020 0.004015600
170 0 2 1.575000 12.750102026 2.328191877 2.730608149
171 0 3 2.100000 10.570464008 3.880320065 7.308391851
172 0 4 -1.168750 12.411972038 2.265023884 1.104289994
173 0 5 -1.050000 10.601675994 4.006656052 8.994944278
174 0 4 -1.168750 12.583637998 0.848255971 3.332947873
175 0 4 -1.168750 11.735712063 3.356928080 3.373103955
176 0 5 -1.050000 11.714904021 2.815488058 6.826520072
177 0 6 -0.950000 10.632887998 0.640704021 9.035099761
178 0 7 0.425000 10.632887998 1.669440022 9.035099761
179 0 1 1.575000 14.300297990 5.251968020 0.004015600
180 0 3 2.100000 15.351102026 6.840191877 2.730608149
181 0 3 2.100000 13.171464008 8.392320065 7.308391851
182 0 5 -1.050000 15.012972038 6.777023884 1.104289994
183 0 5 -1.050000 13.202675994 8.518656052 8.994944278
184 0 5 -1.050000 15.184637998 5.360255971 3.332947873
185 0 5 -1.050000 14.336712063 7.868928080 3.373103955
186 0 4 -1.168750 14.315904021 7.327488058 6.826520072
187 0 6 -0.950000 13.233887998 5.152704021 9.035099761
188 0 7 0.425000 13.233887998 6.181440022 9.035099761
189 0 1 1.575000 14.310702011 0.739968020 10.034984400
190 0 3 2.100000 13.259897974 2.328191877 7.308391851
191 0 3 2.100000 15.439535992 3.880320065 2.730608149
192 0 5 -1.050000 13.598027962 2.265023884 8.934710006
193 0 5 -1.050000 15.408324007 4.006656052 1.044055722
194 0 5 -1.050000 13.426362002 0.848255971 6.706052127
195 0 5 -1.050000 14.274287937 3.356928080 6.665896045
196 0 4 -1.168750 14.295095979 2.815488058 3.212479928
197 0 6 -0.950000 15.377112002 0.640704021 1.003900240
198 0 7 0.425000 15.377112002 1.669440022 1.003900240
199 0 1 1.575000 11.709702011 5.251968020 10.034984400
200 0 2 1.575000 10.658897974 6.840191877 7.308391851
201 0 3 2.100000 12.838535992 8.392320065 2.730608149
202 0 4 -1.168750 10.997027962 6.777023884 8.934710006
203 0 5 -1.050000 12.807324007 8.518656052 1.044055722
204 0 4 -1.168750 10.825362002 5.360255971 6.706052127
205 0 4 -1.168750 11.673287937 7.868928080 6.665896045
206 0 5 -1.050000 11.694095979 7.327488058 3.212479928
207 0 6 -0.950000 12.776112002 5.152704021 1.003900240
208 0 7 0.425000 12.776112002 6.181440022 1.003900240
209 0 1 1.575000 14.310702010 8.284031980 -0.004015600
210 0 2 1.575000 13.259897974 6.695808123 -2.730608149
211 0 3 2.100000 15.439535992 5.143679935 12.769608149
212 0 4 -1.168750 13.598027962 6.758976116 -1.104289994
213 0 5 -1.050000 15.408324007 5.017343948 11.083055723
214 0 4 -1.168750 13.426362002 8.175744029 -3.332947873
215 0 4 -1.168750 14.274287937 5.667071920 -3.373103955
216 0 5 -1.050000 14.295095979 6.208511942 13.251479928
217 0 6 -0.950000 15.377112001 8.383295979 11.042900240
218 0 7 0.425000 15.377112001 7.354559978 11.042900240
219 0 1 1.575000 11.709702010 3.772031980 -0.004015600
220 0 3 2.100000 10.658897974 2.183808123 -2.730608149
221 0 3 2.100000 12.838535992 0.631679935 12.769608149
222 0 5 -1.050000 10.997027962 2.246976116 -1.104289994
223 0 5 -1.050000 12.807324007 0.505343948 11.083055723
224 0 5 -1.050000 10.825362002 3.663744029 -3.332947873
225 0 5 -1.050000 11.673287937 1.155071920 -3.373103955
226 0 4 -1.168750 11.694095979 1.696511942 13.251479928
227 0 6 -0.950000 12.776112001 3.871295979 11.042900240
228 0 7 0.425000 12.776112001 2.842559978 11.042900240
229 0 1 1.575000 11.699297990 8.284031980 10.043015599
230 0 3 2.100000 12.750102026 6.695808123 12.769608149
231 0 3 2.100000 10.570464008 5.143679935 -2.730608149
232 0 5 -1.050000 12.411972039 6.758976116 11.143289994
233 0 5 -1.050000 10.601675993 5.017343948 -1.044055722
234 0 5 -1.050000 12.583637998 8.175744029 13.371947873
235 0 5 -1.050000 11.735712063 5.667071920 13.412103955
236 0 4 -1.168750 11.714904021 6.208511942 -3.212479928
237 0 6 -0.950000 10.632887998 8.383295979 -1.003900240
238 0 7 0.425000 10.632887998 7.354559978 -1.003900240
239 0 1 1.575000 14.300297990 3.772031980 10.043015599
240 0 2 1.575000 15.351102026 2.183808123 12.769608149
241 0 3 2.100000 13.171464008 0.631679935 -2.730608149
242 0 4 -1.168750 15.012972039 2.246976116 11.143289994
243 0 5 -1.050000 13.202675993 0.505343948 -1.044055722
244 0 4 -1.168750 15.184637998 3.663744029 13.371947873
245 0 4 -1.168750 14.336712063 1.155071920 13.412103955
246 0 5 -1.050000 14.315904021 1.696511942 -3.212479928
247 0 6 -0.950000 13.233887998 3.871295979 -1.003900240
248 0 7 0.425000 13.233887998 2.842559978 -1.003900240
249 0 8 1.000000 10.404000000 0.875328026 5.019500000
250 0 8 1.000000 13.005000000 5.387328026 5.019500000
251 0 8 1.000000 10.404000000 8.148671974 15.058500000
252 0 8 1.000000 13.005000000 3.636671974 15.058500000
253 0 1 1.575000 16.901297990 0.739968020 0.004015600
254 0 2 1.575000 17.952102026 2.328191877 2.730608149
255 0 3 2.100000 15.772464008 3.880320065 7.308391851
256 0 4 -1.168750 17.613972038 2.265023884 1.104289994
257 0 5 -1.050000 15.803675994 4.006656052 8.994944278
258 0 4 -1.168750 17.785637998 0.848255971 3.332947873
259 0 4 -1.168750 16.937712063 3.356928080 3.373103955
260 0 5 -1.050000 16.916904021 2.815488058 6.826520072
261 0 6 -0.950000 15.834887998 0.640704021 9.035099761
262 0 7 0.425000 15.834887998 1.669440022 9.035099761
263 0 1 1.575000 19.502297990 5.251968020 0.004015600
264 0 3 2.100000 20.553102026 6.840191877 2.730608149
265 0 3 2.100000 18.373464008 8.392320065 7.308391851
266 0 5 -1.050000 20.214972038 6.777023884 1.104289994
267 0 5 -1.050000 18.404675994 8.518656052 8.994944278
268 0 5 -1.050000 20.386637998 5.360255971 3.332947873
269 0 5 -1.050000 19.538712063 7.868928080 3.373103955
270 0 4 -1.168750 19.517904021 7.327488058 6.826520072
271 0 6 -0.950000 18.435887998 5.152704021 9.035099761
272 0 7 0.425000 18.435887998 6.181440022 9.035099761
273 0 1 1.575000 19.512702011 0.739968020 10.034984400
274 0 3 2.100000 18.461897974 2.328191877 7.308391851
275 0 3 2.100000 20.641535992 3.880320065 2.730608149
276 0 5 -1.050000 18.800027962 2.265023884 8.934710006
277 0 5 -1.050000 20.610324007 4.006656052 1.044055722
278 0 5 -1.050000 18.628362002 0.848255971 6.706052127
279 0 5 -1.050000 19.476287937 3.356928080 6.665896045
280 0 4 -1.168750 19.497095979 2.815488058 3.212479928
281 0 6 -0.950000 20.579112002 0.640704021 1.003900240
282 0 7 0.425000 20.579112002 1.669440022 1.003900240
283 0 1 1.575000 16.911702011 5.251968020 10.034984400
284 0 2 1.575000 15.860897974 6.840191877 7.308391851
285 0 3 2.100000 18.040535992 8.392320065 2.730608149
286 0 4 -1.168750 16.199027962 6.777023884 8.934710006
287 0 5 -1.050000 18.009324007 8.518656052 1.044055722
288 0 4 -1.168750 16.027362002 5.360255971 6.706052127
289 0 4 -1.168750 16.875287937 7.868928080 6.665896045
290 0 5 -1.050000 16.896095979 7.327488058 3.212479928
291 0 6 -0.950000 17.978112002 5.152704021 1.003900240
292 0 7 0.425000 17.978112002 6.181440022 1.003900240
293 0 1 1.575000 19.512702010 8.284031980 -0.004015600
294 0 2 1.575000 18.461897974 6.695808123 -2.730608149
295 0 3 2.100000 20.641535992 5.143679935 12.769608149
296 0 4 -1.168750 18.800027962 6.758976116 -1.104289994
297 0 5 -1.050000 20.610324007 5.017343948 11.083055723
298 0 4 -1.168750 18.628362002 8.175744029 -3.332947873
299 0 4 -1.168750 19.476287937 5.667071920 -3.373103955
300 0 5 -1.050000 19.497095979 6.208511942 13.251479928
301 0 6 -0.950000 20.579112001 8.383295979 11.042900240
302 0 7 0.425000 20.579112001 7.354559978 11.042900240
303 0 1 1.575000 16.911702010 3.772031980 -0.004015600
304 0 3 2.100000 15.860897974 2.183808123 -2.730608149
305 0 3 2.100000 18.040535992 0.631679935 12.769608149
306 0 5 -1.050000 16.199027962 2.246976116 -1.104289994
307 0 5 -1.050000 18.009324007 0.505343948 11.083055723
308 0 5 -1.050000 16.027362002 3.663744029 -3.332947873
309 0 5 -1.050000 16.875287937 1.155071920 -3.373103955
310 0 4 -1.168750 16.896095979 1.696511942 13.251479928
311 0 6 -0.950000 17.978112001 3.871295979 11.042900240
312 0 7 0.425000 17.978112001 2.842559978 11.042900240
313 0 1 1.575000 16.901297990 8.284031980 10.043015599
314 0 3 2.100000 17.952102026 6.695808123 12.769608149
315 0 3 2.100000 15.772464008 5.143679935 -2.730608149
316 0 5 -1.050000 17.613972039 6.758976116 11.143289994
317 0 5 -1.050000 15.803675993 5.017343948 -1.044055722
318 0 5 -1.050000 17.785637998 8.175744029 13.371947873
319 0 5 -1.050000 16.937712063 5.667071920 13.412103955
320 0 4 -1.168750 16.916904021 6.208511942 -3.212479928
321 0 6 -0.950000 15.834887998 8.383295979 -1.003900240
322 0 7 0.425000 15.834887998 7.354559978 -1.003900240
323 0 1 1.575000 19.502297990 3.772031980 10.043015599
324 0 2 1.575000 20.553102026 2.183808123 12.769608149
325 0 3 2.100000 18.373464008 0.631679935 -2.730608149
326 0 4 -1.168750 20.214972039 2.246976116 11.143289994
327 0 5 -1.050000 18.404675993 0.505343948 -1.044055722
328 0 4 -1.168750 20.386637998 3.663744029 13.371947873
329 0 4 -1.168750 19.538712063 1.155071920 13.412103955
330 0 5 -1.050000 19.517904021 1.696511942 -3.212479928
331 0 6 -0.950000 18.435887998 3.871295979 -1.003900240
332 0 7 0.425000 18.435887998 2.842559978 -1.003900240
333 0 8 1.000000 15.606000000 0.875328026 5.019500000
334 0 8 1.000000 18.207000000 5.387328026 5.019500000
335 0 8 1.000000 15.606000000 8.148671974 15.058500000
336 0 8 1.000000 18.207000000 3.636671974 15.058500000
337 0 1 1.575000 1.295297990 9.763968020 0.004015600
338 0 2 1.575000 2.346102026 11.352191877 2.730608149
339 0 3 2.100000 0.166464008 12.904320065 7.308391851
340 0 4 -1.168750 2.007972038 11.289023884 1.104289994
341 0 5 -1.050000 0.197675994 13.030656052 8.994944278
342 0 4 -1.168750 2.179637998 9.872255971 3.332947873
343 0 4 -1.168750 1.331712063 12.380928080 3.373103955
344 0 5 -1.050000 1.310904021 11.839488058 6.826520072
345 0 6 -0.950000 0.228887998 9.664704021 9.035099761
346 0 7 0.425000 0.228887998 10.693440022 9.035099761
347 0 1 1.575000 3.896297990 14.275968020 0.004015600
348 0 3 2.100000 4.947102026 15.864191877 2.730608149
349 0 3 2.100000 2.767464008 17.416320065 7.308391851
350 0 5 -1.050000 4.608972038 15.801023884 1.104289994
351 0 5 -1.050000 2.798675994 17.542656052 8.994944278
352 0 5 -1.050000 4.780637998 14.384255971 3.332947873
353 0 5 -1.050000 3.932712063 16.892928080 3.373103955
354 0 4 -1.168750 3.911904021 16.351488058 6.826520072
355 0 6 -0.950000 2.829887998 14.176704021 9.035099761
356 0 7 0.425000 2.829887998 15.205440022 9.035099761
357 0 1 1.575000 3.906702011 9.763968020 10.034984400
358 0 3 2.100000 2.855897974 11.352191877 7.308391851
359 0 3 2.100000 5.035535992 12.904320065 2.730608149
360 0 5 -1.050000 3.194027962 11.289023884 8.934710006
361 0 5 -1.050000 5.004324007 13.030656052 1.044055722
362 0 5 -1.050000 3.022362002 9.872255971 6.706052127
363 0 5 -1.050000 3.870287937 12.380928080 6.665896045
364 0 4 -1.168750 3.891095979 11.839488058 3.212479928
365 0 6 -0.950000 4.973112002 9.664704021 1.003900240
366 0 7 0.425000 4.973112002 10.693440022 1.003900240
367 0 1 1.575000 1.305702011 14.275968020 10.034984400
368 0 2 1.575000 0.254897974 15.864191877 7.308391851
369 0 3 2.100000 2.434535992 17.416320065 2.730608149
370 0 4 -1.168750 0.593027962 15.801023884 8.934710006
371 0 5 -1.050000 2.403324007 17.542656052 1.044055722
372 0 4 -1.168750 0.421362002 14.384255971 6.706052127
373 0 4 -1.168750 1.269287937 16.892928080 6.665896045
374 0 5 -1.050000 1.290095979 16.351488058 3.212479928
375 0 6 -0.950000 2.372112002 14.176704021 1.003900240
376 0 7 0.425000 2.372112002 15.205440022 1.003900240
377 0 1 1.575000 3.906702010 17.308031980 -0.004015600
378 0 2 1.575000 2.855897974 15.719808123 -2.730608149
379 0 3 2.100000 5.035535992 14.167679935 12.769608149
380 0 4 -1.168750 3.194027962 15.782976116 -1.104289994
381 0 5 -1.050000 5.004324007 14.041343948 11.083055723
382 0 4 -1.168750 3.022362002 17.199744029 -3.332947873
383 0 4 -1.168750 3.870287937 14.691071920 -3.373103955
384 0 5 -1.050000 3.891095979 15.232511942 13.251479928
385 0 6 -0.950000 4.973112001 17.407295979 11.042900240
386 0 7 0.425000 4.973112001 16.378559978 11.042900240
387 0 1 1.575000 1.305702010 12.796031980 -0.004015600
388 0 3 2.100000 0.254897974 11.207808123 -2.730608149
389 0 3 2.100000 2.434535992 9.655679935 12.769608149
390 0 5 -1.050000 0.593027962 11.270976116 -1.104289994
391 0 5 -1.050000 2.403324007 9.529343948 11.083055723
392 0 5 -1.050000 0.421362002 12.687744029 -3.332947873
393 0 5 -1.050000 1.269287937 10.179071920 -3.373103955
394 0 4 -1.168750 1.290095979 10.720511942 13.251479928
395 0 6 -0.950000 2.372112001 12.895295979 11.042900240
396 0 7 0.425000 2.372112001 11.866559978 11.042900240
397 0 1 1.575000 1.295297990 17.308031980 10.043015599
398 0 3 2.100000 2.346102026 15.719808123 12.769608149
399 0 3 2.100000 0.166464008 14.167679935 -2.730608149
400 0 5 -1.050000 2.007972039 15.782976116 11.143289994
401 0 5 -1.050000 0.197675993 14.041343948 -1.044055722
402 0 5 -1.050000 2.179637998 17.199744029 13.371947873
403 0 5 -1.050000 1.331712063 14.691071920 13.412103955
404 0 4 -1.168750 1.310904021 15.232511942 -3.212479928
405 0 6 -0.950000 0.228887998 17.407295979 -1.003900240
406 0 7 0.425000 0.228887998 16.378559978 -1.003900240
407 0 1 1.575000 3.896297990 12.796031980 10.043015599
408 0 2 1.575000 4.947102026 11.207808123 12.769608149
409 0 3 2.100000 2.767464008 9.655679935 -2.730608149
410 0 4 -1.168750 4.608972039 11.270976116 11.143289994
411 0 5 -1.050000 2.798675993 9.529343948 -1.044055722
412 0 4 -1.168750 4.780637998 12.687744029 13.371947873
413 0 4 -1.168750 3.932712063 10.179071920 13.412103955
414 0 5 -1.050000 3.911904021 10.720511942 -3.212479928
415 0 6 -0.950000 2.829887998 12.895295979 -1.003900240
416 0 7 0.425000 2.829887998 11.866559978 -1.003900240
417 0 8 1.000000 -0.000000000 9.899328026 5.019500000
418 0 8 1.000000 2.601000000 14.411328026 5.019500000
419 0 8 1.000000 -0.000000000 17.172671974 15.058500000
420 0 8 1.000000 2.601000000 12.660671974 15.058500000
421 0 1 1.575000 6.497297990 9.763968020 0.004015600
422 0 2 1.575000 7.548102026 11.352191877 2.730608149
423 0 3 2.100000 5.368464008 12.904320065 7.308391851
424 0 4 -1.168750 7.209972038 11.289023884 1.104289994
425 0 5 -1.050000 5.399675994 13.030656052 8.994944278
426 0 4 -1.168750 7.381637998 9.872255971 3.332947873
427 0 4 -1.168750 6.533712063 12.380928080 3.373103955
428 0 5 -1.050000 6.512904021 11.839488058 6.826520072
429 0 6 -0.950000 5.430887998 9.664704021 9.035099761
430 0 7 0.425000 5.430887998 10.693440022 9.035099761
431 0 1 1.575000 9.098297990 14.275968020 0.004015600
432 0 3 2.100000 10.149102026 15.864191877 2.730608149
433 0 3 2.100000 7.969464008 17.416320065 7.308391851
434 0 5 -1.050000 9.810972038 15.801023884 1.104289994
435 0 5 -1.050000 8.000675994 17.542656052 8.994944278
436 0 5 -1.050000 9.982637998 14.384255971 3.332947873
437 0 5 -1.050000 9.134712063 16.892928080 3.373103955
438 0 4 -1.168750 9.113904021 16.351488058 6.826520072
439 0 6 -0.950000 8.031887998 14.176704021 9.035099761
440 0 7 0.425000 8.031887998 15.205440022 9.035099761
441 0 1 1.575000 9.108702011 9.763968020 10.034984400
442 0 3 2.100000 8.057897974 11.352191877 7.308391851
443 0 3 2.100000 10.237535992 12.904320065 2.730608149
444 0 5 -1.050000 8.396027962 11.289023884 8.934710006
445 0 5 -1.050000 10.206324007 13.030656052 1.044055722
446 0 5 -1.050000 8.224362002 9.872255971 6.706052127
447 0 5 -1.050000 9.072287937 12.380928080 6.665896045
448 0 4 -1.168750 9.093095979 11.839488058 3.212479928
449 0 6 -0.950000 10.175112002 9.664704021 1.003900240
450 0 7 0.425000 10.175112002 10.693440022 1.003900240
451 0 1 1.575000 6.507702011 14.275968020 10.034984400
452 0 2 1.575000 5.456897974 15.864191877 7.308391851
453 0 3 2.100000 7.636535992 17.416320065 2.730608149
454 0 4 -1.168750 5.795027962 15.801023884 8.934710006
455 0 5 -1.050000 7.605324007 17.542656052 1.044055722
456 0 4 -1.168750 5.623362002 14.384255971 6.706052127
457 0 4 -1.168750 6.471287937 16.892928080 6.665896045
458 0 5 -1.050000 6.492095979 16.351488058 3.212479928
459 0 6 -0.950000 7.574112002 14.176704021 1.003900240
460 0 7 0.425000 7.574112002 15.205440022 1.003900240
461 0 1 1.575000 9.108702010 17.308031980 -0.004015600
462 0 2 1.575000 8.057897974 15.719808123 -2.730608149
463 0 3 2.100000 10.237535992 14.167679935 12.769608149
464 0 4 -1.168750 8.396027962 15.782976116 -1.104289994
465 0 5 -1.050000 10.206324007 14.041343948 11.083055723
466 0 4 -1.168750 8.224362002 17.199744029 -3.332947873
467 0 4 -1.168750 9.072287937 14.691071920 -3.373103955
468 0 5 -1.050000 9.093095979 15.232511942 13.251479928
469 0 6 -0.950000 10.175112001 17.407295979 11.042900240
470 0 7 0.425000 10.175112001 16.378559978 11.042900240
471 0 1 1.575000 6.507702010 12.796031980 -0.004015600
472 0 3 2.100000 5.456897974 11.207808123 -2.730608149
473 0 3 2.100000 7.636535992 9.655679935 12.769608149
474 0 5 -1.050000 5.795027962 11.270976116 -1.104289994
475 0 5 -1.050000 7.605324007 9.529343948 11.083055723
476 0 5 -1.050000 5.623362002 12.687744029 -3.332947873
477 0 5 -1.050000 6.471287937 10.179071920 -3.373103955
478 0 4 -1.168750 6.492095979 10.720511942 13.251479928
479 0 6 -0.950000 7.574112001 12.895295979 11.042900240
480 0 7 0.425000 7.574112001 11.866559978 11.042900240
481 0 1 1.575000 6.497297990 17.308031980 10.043015599
482 0 3 2.100000 7.548102026 15.719808123 12.769608149
483 0 3 2.100000 5.368464008 14.167679935 -2.730608149
484 0 5 -1.050000 7.209972039 15.782976116 11.143289994
485 0 5 -1.050000 5.399675993 14.041343948 -1.044055722
486 0 5 -1.050000 7.381637998 17.199744029 13.371947873
487 0 5 -1.050000 6.533712063 14.691071920 13.412103955
488 0 4 -1.168750 6.512904021 15.232511942 -3.212479928
489 0 6 -0.950000 5.430887998 17.407295979 -1.003900240
490 0 7 0.425000 5.430887998 16.378559978 -1.003900240
491 0 1 1.575000 9.098297990 12.796031980 10.043015599
492 0 2 1.575000 10.149102026 11.207808123 12.769608149
493 0 3 2.100000 7.969464008 9.655679935 -2.730608149
494 0 4 -1.168750 9.810972039 11.270976116 11.143289994
495 0 5 -1.050000 8.000675993 9.529343948 -1.044055722
496 0 4 -1.168750 9.982637998 12.687744029 13.371947873
497 0 4 -1.168750 9.134712063 10.179071920 13.412103955
498 0 5 -1.050000 9.113904021 10.720511942 -3.212479928
499 0 6 -0.950000 8.031887998 12.895295979 -1.003900240
500 0 7 0.425000 8.031887998 11.866559978 -1.003900240
501 0 8 1.000000 5.202000000 9.899328026 5.019500000
502 0 8 1.000000 7.803000000 14.411328026 5.019500000
503 0 8 1.000000 5.202000000 17.172671974 15.058500000
504 0 8 1.000000 7.803000000 12.660671974 15.058500000
505 0 1 1.575000 11.699297990 9.763968020 0.004015600
506 0 2 1.575000 12.750102026 11.352191877 2.730608149
507 0 3 2.100000 10.570464008 12.904320065 7.308391851
508 0 4 -1.168750 12.411972038 11.289023884 1.104289994
509 0 5 -1.050000 10.601675994 13.030656052 8.994944278
510 0 4 -1.168750 12.583637998 9.872255971 3.332947873
511 0 4 -1.168750 11.735712063 12.380928080 3.373103955
512 0 5 -1.050000 11.714904021 11.839488058 6.826520072
513 0 6 -0.950000 10.632887998 9.664704021 9.035099761
514 0 7 0.425000 10.632887998 10.693440022 9.035099761
515 0 1 1.575000 14.300297990 14.275968020 0.004015600
516 0 3 2.100000 15.351102026 15.864191877 2.730608149
517 0 3 2.100000 13.171464008 17.416320065 7.308391851
518 0 5 -1.050000 15.012972038 15.801023884 1.104289994
519 0 5 -1.050000 13.202675994 17.542656052 8.994944278
520 0 5 -1.050000 15.184637998 14.384255971 3.332947873
521 0 5 -1.050000 14.336712063 16.892928080 3.373103955
522 0 4 -1.168750 14.315904021 16.351488058 6.826520072
523 0 6 -0.950000 13.233887998 14.176704021 9.035099761
524 0 7 0.425000 13.233887998 15.205440022 9.035099761
525 0 1 1.575000 14.310702011 9.763968020 10.034984400
526 0 3 2.100000 13.259897974 11.352191877 7.308391851
527 0 3 2.100000 15.439535992 12.904320065 2.730608149
528 0 5 -1.050000 13.598027962 11.289023884 8.934710006
529 0 5 -1.050000 15.408324007 13.030656052 1.044055722
530 0 5 -1.050000 13.426362002 9.872255971 6.706052127
531 0 5 -1.050000 14.274287937 12.380928080 6.665896045
532 0 4 -1.168750 14.295095979 11.839488058 3.212479928
533 0 6 -0.950000 15.377112002 9.664704021 1.003900240
534 0 7 0.425000 15.377112002 10.693440022 1.003900240
535 0 1 1.575000 11.709702011 14.275968020 10.034984400
536 0 2 1.575000 10.658897974 15.864191877 7.308391851
537 0 3 2.100000 12.838535992 17.416320065 2.730608149
538 0 4 -1.168750 10.997027962 15.801023884 8.934710006
539 0 5 -1.050000 12.807324007 17.542656052 1.044055722
540 0 4 -1.168750 10.825362002 14.384255971 6.706052127
541 0 4 -1.168750 11.673287937 16.892928080 6.665896045
542 0 5 -1.050000 11.694095979 16.351488058 3.212479928
543 0 6 -0.950000 12.776112002 14.176704021 1.003900240
544 0 7 0.425000 12.776112002 15.205440022 1.003900240
545 0 1 1.575000 14.310702010 17.308031980 -0.004015600
546 0 2 1.575000 13.259897974 15.719808123 -2.730608149
547 0 3 2.100000 15.439535992 14.167679935 12.769608149
548 0 4 -1.168750 13.598027962 15.782976116 -1.104289994
549 0 5 -1.050000 15.408324007 14.041343948 11.083055723
550 0 4 -1.168750 13.426362002 17.199744029 -3.332947873
551 0 4 -1.168750 14.274287937 14.691071920 -3.373103955
552 0 5 -1.050000 14.295095979 15.232511942 13.251479928
553 0 6 -0.950000 15.377112001 17.407295979 11.042900240
554 0 7 0.425000 15.377112001 16.378559978 11.042900240
555 0 1 1.575000 11.709702010 12.796031980 -0.004015600
556 0 3 2.100000 10.658897974 11.207808123 -2.730608149
557 0 3 2.100000 12.838535992 9.655679935 12.769608149
558 0 5 -1.050000 10.997027962 11.270976116 -1.104289994
559 0 5 -1.050000 12.807324007 9.529343948 11.083055723
560 0 5 -1.050000 10.825362002 12.687744029 -3.332947873
561 0 5 -1.050000 11.673287937 10.179071920 -3.373103955
562 0 4 -1.168750 11.694095979 10.720511942 13.251479928
563 0 6 -0.950000 12.776112001 12.895295979 11.042900240
564 0 7 0.425000 12.776112001 11.866559978 11.042900240
565 0 1 1.575000 11.699297990 17.308031980 10.043015599
566 0 3 2.100000 12.750102026 15.719808123 12.769608149
567 0 3 2.100000 10.570464008 14.167679935 -2.730608149
568 0 5 -1.050000 12.411972039 15.782976116 11.143289994
569 0 5 -1.050000 10.601675993 14.041343948 -1.044055722
570 0 5 -1.050000 12.583637998 17.199744029 13.371947873
571 0 5 -1.050000 11.735712063 14.691071920 13.412103955
572 0 4 -1.168750 11.714904021 15.232511942 -3.212479928
573 0 6 -0.950000 10.632887998 17.407295979 -1.003900240
574 0 7 0.425000 10.632887998 16.378559978 -1.003900240
575 0 1 1.575000 14.300297990 12.796031980 10.043015599
576 0 2 1.575000 15.351102026 11.207808123 12.769608149
577 0 3 2.100000 13.171464008 9.655679935 -2.730608149
578 0 4 -1.168750 15.012972039 11.270976116 11.143289994
579 0 5 -1.050000 13.202675993 9.529343948 -1.044055722
580 0 4 -1.168750 15.184637998 12.687744029 13.371947873
581 0 4 -1.168750 14.336712063 10.179071920 13.412103955
582 0 5 -1.050000 14.315904021 10.720511942 -3.212479928
583 0 6 -0.950000 13.233887998 12.895295979 -1.003900240
584 0 7 0.425000 13.233887998 11.866559978 -1.003900240
585 0 8 1.000000 10.404000000 9.899328026 5.019500000
586 0 8 1.000000 13.005000000 14.411328026 5.019500000
587 0 8 1.000000 10.404000000 17.172671974 15.058500000
588 0 8 1.000000 13.005000000 12.660671974 15.058500000
589 0 1 1.575000 16.901297990 9.763968020 0.004015600
590 0 2 1.575000 17.952102026 11.352191877 2.730608149
591 0 3 2.100000 15.772464008 12.904320065 7.308391851
592 0 4 -1.168750 17.613972038 11.289023884 1.104289994
593 0 5 -1.050000 15.803675994 13.030656052 8.994944278
594 0 4 -1.168750 17.785637998 9.872255971 3.332947873
595 0 4 -1.168750 16.937712063 12.380928080 3.373103955
596 0 5 -1.050000 16.916904021 11.839488058 6.826520072
597 0 6 -0.950000 15.834887998 9.664704021 9.035099761
598 0 7 0.425000 15.834887998 10.693440022 9.035099761
599 0 1 1.575000 19.502297990 14.275968020 0.004015600
600 0 3 2.100000 20.553102026 15.864191877 2.730608149
601 0 3 2.100000 18.373464008 17.416320065 7.308391851
602 0 5 -1.050000 20.214972038 15.801023884 1.104289994
603 0 5 -1.050000 18.404675994 17.542656052 8.994944278
604 0 5 -1.050000 20.386637998 14.384255971 3.332947873
605 0 5 -1.050000 19.538712063 16.892928080 3.373103955
606 0 4 -1.168750 19.517904021 16.351488058 6.826520072
607 0 6 -0.950000 18.435887998 14.176704021 9.035099761
608 0 7 0.425000 18.435887998 15.205440022 9.035099761
609 0 1 1.575000 19.512702011 9.763968020 10.034984400
610 0 3 2.100000 18.461897974 11.352191877 7.308391851
611 0 3 2.100000 20.641535992 12.904320065 2.730608149
612 0 5 -1.050000 18.800027962 11.289023884 8.934710006
613 0 5 -1.050000 20.610324007 13.030656052 1.044055722
614 0 5 -1.050000 18.628362002 9.872255971 6.706052127
615 0 5 -1.050000 19.476287937 12.380928080 6.665896045
616 0 4 -1.168750 19.497095979 11.839488058 3.212479928
617 0 6 -0.950000 20.579112002 9.664704021 1.003900240
618 0 7 0.425000 20.579112002 10.693440022 1.003900240
619 0 1 1.575000 16.911702011 14.275968020 10.034984400
620 0 2 1.575000 15.860897974 15.864191877 7.308391851
621 0 3 2.100000 18.040535992 17.416320065 2.730608149
622 0 4 -1.168750 16.199027962 15.801023884 8.934710006
623 0 5 -1.050000 18.009324007 17.542656052 1.044055722
624 0 4 -1.168750 16.027362002 14.384255971 6.706052127
625 0 4 -1.168750 16.875287937 16.892928080 6.665896045
626 0 5 -1.050000 16.896095979 16.351488058 3.212479928
627 0 6 -0.950000 17.978112002 14.176704021 1.003900240
628 0 7 0.425000 17.978112002 15.205440022 1.003900240
629 0 1 1.575000 19.512702010 17.308031980 -0.004015600
630 0 2 1.575000 18.461897974 15.719808123 -2.730608149
631 0 3 2.100000 20.641535992 14.167679935 12.769608149
632 0 4 -1.168750 18.800027962 15.782976116 -1.104289994
633 0 5 -1.050000 20.610324007 14.041343948 11.083055723
634 0 4 -1.168750 18.628362002 17.199744029 -3.332947873
635 0 4 -1.168750 19.476287937 14.691071920 -3.373103955
636 0 5 -1.050000 19.497095979 15.232511942 13.251479928
637 0 6 -0.950000 20.579112001 17.407295979 11.042900240
638 0 7 0.425000 20.579112001 16.378559978 11.042900240
639 0 1 1.575000 16.911702010 12.796031980 -0.004015600
640 0 3 2.100000 15.860897974 11.207808123 -2.730608149
641 0 3 2.100000 18.040535992 9.655679935 12.769608149
642 0 5 -1.050000 16.199027962 11.270976116 -1.104289994
643 0 5 -1.050000 18.009324007 9.529343948 11.083055723
644 0 5 -1.050000 16.027362002 12.687744029 -3.332947873
645 0 5 -1.050000 16.875287937 10.179071920 -3.373103955
646 0 4 -1.168750 16.896095979 10.720511942 13.251479928
647 0 6 -0.950000 17.978112001 12.895295979 11.042900240
648 0 7 0.425000 17.978112001 11.866559978 11.042900240
649 0 1 1.575000 16.901297990 17.308031980 10.043015599
650 0 3 2.100000 17.952102026 15.719808123 12.769608149
651 0 3 2.100000 15.772464008 14.167679935 -2.730608149
652 0 5 -1.050000 17.613972039 15.782976116 11.143289994
653 0 5 -1.050000 15.803675993 14.041343948 -1.044055722
654 0 5 -1.050000 17.785637998 17.199744029 13.371947873
655 0 5 -1.050000 16.937712063 14.691071920 13.412103955
656 0 4 -1.168750 16.916904021 15.232511942 -3.212479928
657 0 6 -0.950000 15.834887998 17.407295979 -1.003900240
658 0 7 0.425000 15.834887998 16.378559978 -1.003900240
659 0 1 1.575000 19.502297990 12.796031980 10.043015599
660 0 2 1.575000 20.553102026 11.207808123 12.769608149
661 0 3 2.100000 18.373464008 9.655679935 -2.730608149
662 0 4 -1.168750 20.214972039 11.270976116 11.143289994
663 0 5 -1.050000 18.404675993 9.529343948 -1.044055722
664 0 4 -1.168750 20.386637998 12.687744029 13.371947873
665 0 4 -1.168750 19.538712063 10.179071920 13.412103955
666 0 5 -1.050000 19.517904021 10.720511942 -3.212479928
667 0 6 -0.950000 18.435887998 12.895295979 -1.003900240
668 0 7 0.425000 18.435887998 11.866559978 -1.003900240
669 0 8 1.000000 15.606000000 9.899328026 5.019500000
670 0 8 1.000000 18.207000000 14.411328026 5.019500000
671 0 8 1.000000 15.606000000 17.172671974 15.058500000
672 0 8 1.000000 18.207000000 12.660671974 15.058500000
Bonds
1 1 1 54
2 2 1 4
3 1 1 75
4 1 1 371
5 3 1 281
6 3 1 405
7 4 2 4
8 4 2 6
9 4 2 7
10 4 2 28
11 5 3 5
12 6 3 36
13 5 3 8
14 5 3 279
15 2 51 4
16 1 31 5
17 1 323 5
18 6 369 6
19 6 275 7
20 5 22 8
21 7 9 10
22 3 273 9
23 3 397 9
24 2 11 44
25 1 11 14
26 1 11 25
27 3 11 39
28 3 11 79
29 1 11 149
30 5 12 14
31 5 12 16
32 5 12 17
33 5 12 122
34 5 13 15
35 6 13 37
36 6 13 18
37 5 13 362
38 1 41 14
39 1 61 15
40 1 357 15
41 5 23 16
42 5 33 17
43 4 116 18
44 3 31 19
45 3 71 19
46 7 19 20
47 2 21 74
48 1 21 24
49 1 21 55
50 3 21 93
51 1 21 351
52 3 21 385
53 5 22 24
54 5 22 26
55 5 22 27
56 5 23 25
57 6 23 28
58 6 23 91
59 1 71 24
60 1 135 25
61 5 349 26
62 5 87 27
63 7 29 30
64 3 85 29
65 3 377 29
66 1 31 64
67 2 31 34
68 3 31 59
69 1 31 297
70 4 32 34
71 4 32 36
72 4 32 37
73 4 32 270
74 5 33 35
75 5 33 38
76 6 33 342
77 2 61 34
78 1 41 35
79 1 337 35
80 5 264 38
81 3 51 39
82 7 39 40
83 2 41 44
84 3 41 365
85 1 41 411
86 3 41 153
87 4 42 44
88 4 42 46
89 4 42 47
90 4 42 68
91 5 43 45
92 6 43 76
93 5 43 48
94 5 43 151
95 1 71 45
96 1 115 45
97 6 409 46
98 6 147 47
99 5 62 48
100 7 49 50
101 3 357 49
102 3 145 49
103 1 51 54
104 1 51 65
105 3 51 79
106 1 51 277
107 5 52 54
108 5 52 56
109 5 52 57
110 5 52 330
111 5 53 55
112 6 53 77
113 6 53 58
114 5 53 402
115 1 397 55
116 5 63 56
117 5 73 57
118 4 324 58
119 3 71 59
120 7 59 60
121 1 61 64
122 3 61 345
123 3 61 301
124 1 61 391
125 5 62 64
126 5 62 66
127 5 62 67
128 5 63 65
129 6 63 68
130 6 63 299
131 1 263 65
132 5 389 66
133 5 295 67
134 7 69 70
135 3 337 69
136 3 293 69
137 2 71 74
138 1 71 89
139 4 72 74
140 4 72 76
141 4 72 77
142 4 72 142
143 5 73 75
144 5 73 78
145 6 73 382
146 1 377 75
147 5 136 78
148 7 79 80
149 1 85 138
150 2 85 88
151 1 85 159
152 1 85 455
153 3 85 489
154 4 86 88
155 4 86 90
156 4 86 91
157 4 86 112
158 5 87 89
159 6 87 120
160 5 87 92
161 2 135 88
162 1 115 89
163 6 453 90
164 5 106 92
165 7 93 94
166 3 481 93
167 2 95 128
168 1 95 98
169 1 95 109
170 3 95 123
171 3 95 163
172 1 95 233
173 5 96 98
174 5 96 100
175 5 96 101
176 5 96 206
177 5 97 99
178 6 97 121
179 6 97 102
180 5 97 446
181 1 125 98
182 1 145 99
183 1 441 99
184 5 107 100
185 5 117 101
186 4 200 102
187 3 115 103
188 3 155 103
189 7 103 104
190 2 105 158
191 1 105 108
192 1 105 139
193 3 105 177
194 1 105 435
195 3 105 469
196 5 106 108
197 5 106 110
198 5 106 111
199 5 107 109
200 6 107 112
201 6 107 175
202 1 155 108
203 1 219 109
204 5 433 110
205 5 171 111
206 7 113 114
207 3 169 113
208 3 461 113
209 1 115 148
210 2 115 118
211 3 115 143
212 4 116 118
213 4 116 120
214 4 116 121
215 5 117 119
216 5 117 122
217 6 117 426
218 2 145 118
219 1 125 119
220 1 421 119
221 3 135 123
222 7 123 124
223 2 125 128
224 3 125 449
225 1 125 495
226 3 125 237
227 4 126 128
228 4 126 130
229 4 126 131
230 4 126 152
231 5 127 129
232 6 127 160
233 5 127 132
234 5 127 235
235 1 155 129
236 1 199 129
237 6 493 130
238 6 231 131
239 5 146 132
240 7 133 134
241 3 441 133
242 3 229 133
243 1 135 138
244 1 135 149
245 3 135 163
246 5 136 138
247 5 136 140
248 5 136 141
249 5 137 139
250 6 137 161
251 6 137 142
252 5 137 486
253 1 481 139
254 5 147 140
255 5 157 141
256 3 155 143
257 7 143 144
258 1 145 148
259 3 145 429
260 1 145 475
261 5 146 148
262 5 146 150
263 5 146 151
264 5 147 149
265 6 147 152
266 5 473 150
267 7 153 154
268 3 421 153
269 2 155 158
270 1 155 173
271 4 156 158
272 4 156 160
273 4 156 161
274 4 156 226
275 5 157 159
276 5 157 162
277 6 157 466
278 1 461 159
279 5 220 162
280 7 163 164
281 1 169 222
282 2 169 172
283 1 169 243
284 1 169 539
285 3 169 573
286 4 170 172
287 4 170 174
288 4 170 175
289 4 170 196
290 5 171 173
291 6 171 204
292 5 171 176
293 2 219 172
294 1 199 173
295 6 537 174
296 5 190 176
297 7 177 178
298 3 565 177
299 2 179 212
300 1 179 182
301 1 179 193
302 3 179 207
303 3 179 247
304 1 179 317
305 5 180 182
306 5 180 184
307 5 180 185
308 5 180 290
309 5 181 183
310 6 181 205
311 6 181 186
312 5 181 530
313 1 209 182
314 1 229 183
315 1 525 183
316 5 191 184
317 5 201 185
318 4 284 186
319 3 199 187
320 3 239 187
321 7 187 188
322 2 189 242
323 1 189 192
324 1 189 223
325 3 189 261
326 1 189 519
327 3 189 553
328 5 190 192
329 5 190 194
330 5 190 195
331 5 191 193
332 6 191 196
333 6 191 259
334 1 239 192
335 1 303 193
336 5 517 194
337 5 255 195
338 7 197 198
339 3 253 197
340 3 545 197
341 1 199 232
342 2 199 202
343 3 199 227
344 4 200 202
345 4 200 204
346 4 200 205
347 5 201 203
348 5 201 206
349 6 201 510
350 2 229 202
351 1 209 203
352 1 505 203
353 3 219 207
354 7 207 208
355 2 209 212
356 3 209 533
357 1 209 579
358 3 209 321
359 4 210 212
360 4 210 214
361 4 210 215
362 4 210 236
363 5 211 213
364 6 211 244
365 5 211 216
366 5 211 319
367 1 239 213
368 1 283 213
369 6 577 214
370 6 315 215
371 5 230 216
372 7 217 218
373 3 525 217
374 3 313 217
375 1 219 222
376 1 219 233
377 3 219 247
378 5 220 222
379 5 220 224
380 5 220 225
381 5 221 223
382 6 221 245
383 6 221 226
384 5 221 570
385 1 565 223
386 5 231 224
387 5 241 225
388 3 239 227
389 7 227 228
390 1 229 232
391 3 229 513
392 1 229 559
393 5 230 232
394 5 230 234
395 5 230 235
396 5 231 233
397 6 231 236
398 5 557 234
399 7 237 238
400 3 505 237
401 2 239 242
402 1 239 257
403 4 240 242
404 4 240 244
405 4 240 245
406 4 240 310
407 5 241 243
408 5 241 246
409 6 241 550
410 1 545 243
411 5 304 246
412 7 247 248
413 1 253 306
414 2 253 256
415 1 253 327
416 1 253 623
417 3 253 657
418 4 254 256
419 4 254 258
420 4 254 259
421 4 254 280
422 5 255 257
423 6 255 288
424 5 255 260
425 2 303 256
426 1 283 257
427 6 621 258
428 5 274 260
429 7 261 262
430 3 649 261
431 2 263 296
432 1 263 266
433 1 263 277
434 3 263 291
435 3 263 331
436 5 264 266
437 5 264 268
438 5 264 269
439 5 265 267
440 6 265 289
441 6 265 270
442 5 265 614
443 1 293 266
444 1 313 267
445 1 609 267
446 5 275 268
447 5 285 269
448 3 283 271
449 3 323 271
450 7 271 272
451 2 273 326
452 1 273 276
453 1 273 307
454 1 273 603
455 3 273 637
456 5 274 276
457 5 274 278
458 5 274 279
459 5 275 277
460 6 275 280
461 1 323 276
462 5 601 278
463 7 281 282
464 3 629 281
465 1 283 316
466 2 283 286
467 3 283 311
468 4 284 286
469 4 284 288
470 4 284 289
471 5 285 287
472 5 285 290
473 6 285 594
474 2 313 286
475 1 293 287
476 1 589 287
477 3 303 291
478 7 291 292
479 2 293 296
480 3 293 617
481 1 293 663
482 4 294 296
483 4 294 298
484 4 294 299
485 4 294 320
486 5 295 297
487 6 295 328
488 5 295 300
489 1 323 297
490 6 661 298
491 5 314 300
492 7 301 302
493 3 609 301
494 1 303 306
495 1 303 317
496 3 303 331
497 5 304 306
498 5 304 308
499 5 304 309
500 5 305 307
501 6 305 329
502 6 305 310
503 5 305 654
504 1 649 307
505 5 315 308
506 5 325 309
507 3 323 311
508 7 311 312
509 1 313 316
510 3 313 597
511 1 313 643
512 5 314 316
513 5 314 318
514 5 314 319
515 5 315 317
516 6 315 320
517 5 641 318
518 7 321 322
519 3 589 321
520 2 323 326
521 4 324 326
522 4 324 328
523 4 324 329
524 5 325 327
525 5 325 330
526 6 325 634
527 1 629 327
528 7 331 332
529 1 337 390
530 2 337 340
531 1 337 411
532 3 337 617
533 4 338 340
534 4 338 342
535 4 338 343
536 4 338 364
537 5 339 341
538 6 339 372
539 5 339 344
540 5 339 615
541 2 387 340
542 1 367 341
543 1 659 341
544 6 611 343
545 5 358 344
546 7 345 346
547 3 609 345
548 2 347 380
549 1 347 350
550 1 347 361
551 3 347 375
552 3 347 415
553 1 347 485
554 5 348 350
555 5 348 352
556 5 348 353
557 5 348 458
558 5 349 351
559 6 349 373
560 6 349 354
561 1 377 350
562 1 397 351
563 5 359 352
564 5 369 353
565 4 452 354
566 3 367 355
567 3 407 355
568 7 355 356
569 2 357 410
570 1 357 360
571 1 357 391
572 3 357 429
573 5 358 360
574 5 358 362
575 5 358 363
576 5 359 361
577 6 359 364
578 6 359 427
579 1 407 360
580 1 471 361
581 5 423 363
582 7 365 366
583 3 421 365
584 1 367 400
585 2 367 370
586 3 367 395
587 1 367 633
588 4 368 370
589 4 368 372
590 4 368 373
591 4 368 606
592 5 369 371
593 5 369 374
594 2 397 370
595 1 377 371
596 5 600 374
597 3 387 375
598 7 375 376
599 2 377 380
600 3 377 489
601 4 378 380
602 4 378 382
603 4 378 383
604 4 378 404
605 5 379 381
606 6 379 412
607 5 379 384
608 5 379 487
609 1 407 381
610 1 451 381
611 6 483 383
612 5 398 384
613 7 385 386
614 3 481 385
615 1 387 390
616 1 387 401
617 3 387 415
618 1 387 613
619 5 388 390
620 5 388 392
621 5 388 393
622 5 388 666
623 5 389 391
624 6 389 413
625 6 389 394
626 5 399 392
627 5 409 393
628 4 660 394
629 3 407 395
630 7 395 396
631 1 397 400
632 3 397 637
633 5 398 400
634 5 398 402
635 5 398 403
636 5 399 401
637 6 399 404
638 6 399 635
639 1 599 401
640 5 631 403
641 7 405 406
642 3 629 405
643 2 407 410
644 1 407 425
645 4 408 410
646 4 408 412
647 4 408 413
648 4 408 478
649 5 409 411
650 5 409 414
651 5 472 414
652 7 415 416
653 1 421 474
654 2 421 424
655 1 421 495
656 4 422 424
657 4 422 426
658 4 422 427
659 4 422 448
660 5 423 425
661 6 423 456
662 5 423 428
663 2 471 424
664 1 451 425
665 5 442 428
666 7 429 430
667 2 431 464
668 1 431 434
669 1 431 445
670 3 431 459
671 3 431 499
672 1 431 569
673 5 432 434
674 5 432 436
675 5 432 437
676 5 432 542
677 5 433 435
678 6 433 457
679 6 433 438
680 1 461 434
681 1 481 435
682 5 443 436
683 5 453 437
684 4 536 438
685 3 451 439
686 3 491 439
687 7 439 440
688 2 441 494
689 1 441 444
690 1 441 475
691 3 441 513
692 5 442 444
693 5 442 446
694 5 442 447
695 5 443 445
696 6 443 448
697 6 443 511
698 1 491 444
699 1 555 445
700 5 507 447
701 7 449 450
702 3 505 449
703 1 451 484
704 2 451 454
705 3 451 479
706 4 452 454
707 4 452 456
708 4 452 457
709 5 453 455
710 5 453 458
711 2 481 454
712 1 461 455
713 3 471 459
714 7 459 460
715 2 461 464
716 3 461 573
717 4 462 464
718 4 462 466
719 4 462 467
720 4 462 488
721 5 463 465
722 6 463 496
723 5 463 468
724 5 463 571
725 1 491 465
726 1 535 465
727 6 567 467
728 5 482 468
729 7 469 470
730 3 565 469
731 1 471 474
732 1 471 485
733 3 471 499
734 5 472 474
735 5 472 476
736 5 472 477
737 5 473 475
738 6 473 497
739 6 473 478
740 5 483 476
741 5 493 477
742 3 491 479
743 7 479 480
744 1 481 484
745 5 482 484
746 5 482 486
747 5 482 487
748 5 483 485
749 6 483 488
750 7 489 490
751 2 491 494
752 1 491 509
753 4 492 494
754 4 492 496
755 4 492 497
756 4 492 562
757 5 493 495
758 5 493 498
759 5 556 498
760 7 499 500
761 1 505 558
762 2 505 508
763 1 505 579
764 4 506 508
765 4 506 510
766 4 506 511
767 4 506 532
768 5 507 509
769 6 507 540
770 5 507 512
771 2 555 508
772 1 535 509
773 5 526 512
774 7 513 514
775 2 515 548
776 1 515 518
777 1 515 529
778 3 515 543
779 3 515 583
780 1 515 653
781 5 516 518
782 5 516 520
783 5 516 521
784 5 516 626
785 5 517 519
786 6 517 541
787 6 517 522
788 1 545 518
789 1 565 519
790 5 527 520
791 5 537 521
792 4 620 522
793 3 535 523
794 3 575 523
795 7 523 524
796 2 525 578
797 1 525 528
798 1 525 559
799 3 525 597
800 5 526 528
801 5 526 530
802 5 526 531
803 5 527 529
804 6 527 532
805 6 527 595
806 1 575 528
807 1 639 529
808 5 591 531
809 7 533 534
810 3 589 533
811 1 535 568
812 2 535 538
813 3 535 563
814 4 536 538
815 4 536 540
816 4 536 541
817 5 537 539
818 5 537 542
819 2 565 538
820 1 545 539
821 3 555 543
822 7 543 544
823 2 545 548
824 3 545 657
825 4 546 548
826 4 546 550
827 4 546 551
828 4 546 572
829 5 547 549
830 6 547 580
831 5 547 552
832 5 547 655
833 1 575 549
834 1 619 549
835 6 651 551
836 5 566 552
837 7 553 554
838 3 649 553
839 1 555 558
840 1 555 569
841 3 555 583
842 5 556 558
843 5 556 560
844 5 556 561
845 5 557 559
846 6 557 581
847 6 557 562
848 5 567 560
849 5 577 561
850 3 575 563
851 7 563 564
852 1 565 568
853 5 566 568
854 5 566 570
855 5 566 571
856 5 567 569
857 6 567 572
858 7 573 574
859 2 575 578
860 1 575 593
861 4 576 578
862 4 576 580
863 4 576 581
864 4 576 646
865 5 577 579
866 5 577 582
867 5 640 582
868 7 583 584
869 1 589 642
870 2 589 592
871 1 589 663
872 4 590 592
873 4 590 594
874 4 590 595
875 4 590 616
876 5 591 593
877 6 591 624
878 5 591 596
879 2 639 592
880 1 619 593
881 5 610 596
882 7 597 598
883 2 599 632
884 1 599 602
885 1 599 613
886 3 599 627
887 3 599 667
888 5 600 602
889 5 600 604
890 5 600 605
891 5 601 603
892 6 601 625
893 6 601 606
894 1 629 602
895 1 649 603
896 5 611 604
897 5 621 605
898 3 619 607
899 3 659 607
900 7 607 608
901 2 609 662
902 1 609 612
903 1 609 643
904 5 610 612
905 5 610 614
906 5 610 615
907 5 611 613
908 6 611 616
909 1 659 612
910 7 617 618
911 1 619 652
912 2 619 622
913 3 619 647
914 4 620 622
915 4 620 624
916 4 620 625
917 5 621 623
918 5 621 626
919 2 649 622
920 1 629 623
921 3 639 627
922 7 627 628
923 2 629 632
924 4 630 632
925 4 630 634
926 4 630 635
927 4 630 656
928 5 631 633
929 6 631 664
930 5 631 636
931 1 659 633
932 5 650 636
933 7 637 638
934 1 639 642
935 1 639 653
936 3 639 667
937 5 640 642
938 5 640 644
939 5 640 645
940 5 641 643
941 6 641 665
942 6 641 646
943 5 651 644
944 5 661 645
945 3 659 647
946 7 647 648
947 1 649 652
948 5 650 652
949 5 650 654
950 5 650 655
951 5 651 653
952 6 651 656
953 7 657 658
954 2 659 662
955 4 660 662
956 4 660 664
957 4 660 665
958 5 661 663
959 5 661 666
960 7 667 668
Angles
1 1 4 1 54
2 2 54 1 75
3 2 54 1 371
4 3 54 1 281
5 3 54 1 405
6 1 4 1 75
7 1 4 1 371
8 4 4 1 281
9 4 4 1 405
10 2 75 1 371
11 3 75 1 281
12 3 75 1 405
13 3 371 1 281
14 3 371 1 405
15 5 281 1 405
16 6 4 2 6
17 6 4 2 7
18 6 4 2 28
19 6 6 2 7
20 6 6 2 28
21 6 7 2 28
22 7 36 3 5
23 8 5 3 8
24 8 5 3 279
25 7 36 3 8
26 7 36 3 279
27 8 8 3 279
28 9 1 4 2
29 10 1 4 51
30 9 51 4 2
31 11 31 5 3
32 11 323 5 3
33 12 31 5 323
34 13 2 6 369
35 13 2 7 275
36 14 3 8 22
37 15 273 9 10
38 15 397 9 10
39 16 273 9 397
40 1 44 11 14
41 1 44 11 25
42 4 44 11 39
43 4 44 11 79
44 1 44 11 149
45 2 14 11 25
46 3 14 11 39
47 3 14 11 79
48 2 14 11 149
49 3 25 11 39
50 3 25 11 79
51 2 25 11 149
52 5 39 11 79
53 3 149 11 39
54 3 149 11 79
55 8 14 12 16
56 8 14 12 17
57 8 14 12 122
58 8 16 12 17
59 8 16 12 122
60 8 17 12 122
61 7 37 13 15
62 7 18 13 15
63 8 15 13 362
64 17 37 13 18
65 7 37 13 362
66 7 18 13 362
67 11 11 14 12
68 12 11 14 41
69 11 41 14 12
70 11 61 15 13
71 11 357 15 13
72 12 61 15 357
73 14 12 16 23
74 14 12 17 33
75 13 116 18 13
76 16 31 19 71
77 15 31 19 20
78 15 71 19 20
79 1 74 21 24
80 1 74 21 55
81 4 74 21 93
82 1 74 21 351
83 4 74 21 385
84 2 24 21 55
85 3 24 21 93
86 2 24 21 351
87 3 24 21 385
88 3 55 21 93
89 2 55 21 351
90 3 55 21 385
91 3 351 21 93
92 5 93 21 385
93 3 351 21 385
94 8 8 22 24
95 8 8 22 26
96 8 8 22 27
97 8 24 22 26
98 8 24 22 27
99 8 26 22 27
100 8 16 23 25
101 7 28 23 16
102 7 91 23 16
103 7 28 23 25
104 7 91 23 25
105 17 28 23 91
106 11 21 24 22
107 12 21 24 71
108 11 71 24 22
109 11 11 25 23
110 12 11 25 135
111 11 135 25 23
112 14 22 26 349
113 14 22 27 87
114 13 2 28 23
115 15 85 29 30
116 15 377 29 30
117 16 85 29 377
118 3 5 31 19
119 2 5 31 64
120 1 34 31 5
121 3 5 31 59
122 2 5 31 297
123 3 64 31 19
124 4 34 31 19
125 5 19 31 59
126 3 297 31 19
127 1 34 31 64
128 3 64 31 59
129 2 64 31 297
130 4 34 31 59
131 1 34 31 297
132 3 297 31 59
133 6 34 32 36
134 6 34 32 37
135 6 34 32 270
136 6 36 32 37
137 6 36 32 270
138 6 37 32 270
139 8 17 33 35
140 8 17 33 38
141 7 342 33 17
142 8 35 33 38
143 7 342 33 35
144 7 342 33 38
145 9 31 34 32
146 10 31 34 61
147 9 61 34 32
148 11 41 35 33
149 11 337 35 33
150 12 41 35 337
151 13 32 36 3
152 13 32 37 13
153 14 33 38 264
154 16 11 39 51
155 15 11 39 40
156 15 51 39 40
157 2 14 41 35
158 1 44 41 14
159 3 14 41 365
160 2 14 41 411
161 3 14 41 153
162 1 44 41 35
163 3 35 41 365
164 2 35 41 411
165 3 35 41 153
166 4 44 41 365
167 1 44 41 411
168 4 44 41 153
169 3 411 41 365
170 5 365 41 153
171 3 411 41 153
172 6 44 42 46
173 6 44 42 47
174 6 44 42 68
175 6 46 42 47
176 6 46 42 68
177 6 47 42 68
178 7 76 43 45
179 8 45 43 48
180 8 45 43 151
181 7 76 43 48
182 7 76 43 151
183 8 48 43 151
184 10 11 44 41
185 9 11 44 42
186 9 41 44 42
187 11 71 45 43
188 11 115 45 43
189 12 71 45 115
190 13 42 46 409
191 13 42 47 147
192 14 43 48 62
193 15 357 49 50
194 15 145 49 50
195 16 357 49 145
196 4 4 51 39
197 1 4 51 54
198 1 4 51 65
199 4 4 51 79
200 1 4 51 277
201 3 54 51 39
202 3 65 51 39
203 5 39 51 79
204 3 277 51 39
205 2 54 51 65
206 3 54 51 79
207 2 54 51 277
208 3 65 51 79
209 2 65 51 277
210 3 277 51 79
211 8 54 52 56
212 8 54 52 57
213 8 54 52 330
214 8 56 52 57
215 8 56 52 330
216 8 57 52 330
217 7 77 53 55
218 7 58 53 55
219 8 55 53 402
220 17 77 53 58
221 7 77 53 402
222 7 58 53 402
223 12 1 54 51
224 11 1 54 52
225 11 51 54 52
226 11 21 55 53
227 12 21 55 397
228 11 397 55 53
229 14 52 56 63
230 14 52 57 73
231 13 324 58 53
232 16 31 59 71
233 15 31 59 60
234 15 71 59 60
235 1 34 61 15
236 2 15 61 64
237 3 15 61 345
238 3 15 61 301
239 2 15 61 391
240 1 34 61 64
241 4 34 61 345
242 4 34 61 301
243 1 34 61 391
244 3 64 61 345
245 3 64 61 301
246 2 64 61 391
247 5 345 61 301
248 3 391 61 345
249 3 391 61 301
250 8 48 62 64
251 8 48 62 66
252 8 48 62 67
253 8 64 62 66
254 8 64 62 67
255 8 66 62 67
256 8 56 63 65
257 7 68 63 56
258 7 299 63 56
259 7 68 63 65
260 7 299 63 65
261 17 68 63 299
262 12 31 64 61
263 11 31 64 62
264 11 61 64 62
265 11 51 65 63
266 12 51 65 263
267 11 263 65 63
268 14 62 66 389
269 14 62 67 295
270 13 42 68 63
271 15 337 69 70
272 15 293 69 70
273 16 337 69 293
274 3 24 71 19
275 3 45 71 19
276 5 19 71 59
277 4 74 71 19
278 3 89 71 19
279 2 24 71 45
280 3 24 71 59
281 1 74 71 24
282 2 24 71 89
283 3 45 71 59
284 1 74 71 45
285 2 45 71 89
286 4 74 71 59
287 3 89 71 59
288 1 74 71 89
289 6 74 72 76
290 6 74 72 77
291 6 74 72 142
292 6 76 72 77
293 6 76 72 142
294 6 77 72 142
295 8 57 73 75
296 8 57 73 78
297 7 382 73 57
298 8 75 73 78
299 7 382 73 75
300 7 382 73 78
301 10 21 74 71
302 9 21 74 72
303 9 71 74 72
304 11 1 75 73
305 12 1 75 377
306 11 377 75 73
307 13 72 76 43
308 13 72 77 53
309 14 73 78 136
310 16 11 79 51
311 15 11 79 80
312 15 51 79 80
313 1 88 85 138
314 2 138 85 159
315 2 138 85 455
316 3 138 85 29
317 3 138 85 489
318 1 88 85 159
319 1 88 85 455
320 4 88 85 29
321 4 88 85 489
322 2 159 85 455
323 3 159 85 29
324 3 159 85 489
325 3 455 85 29
326 3 455 85 489
327 5 29 85 489
328 6 88 86 90
329 6 88 86 91
330 6 88 86 112
331 6 90 86 91
332 6 90 86 112
333 6 91 86 112
334 7 120 87 89
335 8 89 87 92
336 8 89 87 27
337 7 120 87 92
338 7 120 87 27
339 8 92 87 27
340 9 85 88 86
341 10 85 88 135
342 9 135 88 86
343 11 115 89 87
344 11 71 89 87
345 12 115 89 71
346 13 86 90 453
347 13 86 91 23
348 14 87 92 106
349 15 21 93 94
350 15 481 93 94
351 16 21 93 481
352 1 128 95 98
353 1 128 95 109
354 4 128 95 123
355 4 128 95 163
356 1 128 95 233
357 2 98 95 109
358 3 98 95 123
359 3 98 95 163
360 2 98 95 233
361 3 109 95 123
362 3 109 95 163
363 2 109 95 233
364 5 123 95 163
365 3 233 95 123
366 3 233 95 163
367 8 98 96 100
368 8 98 96 101
369 8 98 96 206
370 8 100 96 101
371 8 100 96 206
372 8 101 96 206
373 7 121 97 99
374 7 102 97 99
375 8 99 97 446
376 17 121 97 102
377 7 121 97 446
378 7 102 97 446
379 11 95 98 96
380 12 95 98 125
381 11 125 98 96
382 11 145 99 97
383 11 441 99 97
384 12 145 99 441
385 14 96 100 107
386 14 96 101 117
387 13 200 102 97
388 16 115 103 155
389 15 115 103 104
390 15 155 103 104
391 1 158 105 108
392 1 158 105 139
393 4 158 105 177
394 1 158 105 435
395 4 158 105 469
396 2 108 105 139
397 3 108 105 177
398 2 108 105 435
399 3 108 105 469
400 3 139 105 177
401 2 139 105 435
402 3 139 105 469
403 3 435 105 177
404 5 177 105 469
405 3 435 105 469
406 8 92 106 108
407 8 92 106 110
408 8 92 106 111
409 8 108 106 110
410 8 108 106 111
411 8 110 106 111
412 8 100 107 109
413 7 112 107 100
414 7 175 107 100
415 7 112 107 109
416 7 175 107 109
417 17 112 107 175
418 11 105 108 106
419 12 105 108 155
420 11 155 108 106
421 11 95 109 107
422 12 95 109 219
423 11 219 109 107
424 14 106 110 433
425 14 106 111 171
426 13 86 112 107
427 15 169 113 114
428 15 461 113 114
429 16 169 113 461
430 3 89 115 103
431 2 89 115 148
432 1 118 115 89
433 3 89 115 143
434 2 89 115 45
435 3 148 115 103
436 4 118 115 103
437 5 103 115 143
438 3 45 115 103
439 1 118 115 148
440 3 148 115 143
441 2 148 115 45
442 4 118 115 143
443 1 118 115 45
444 3 45 115 143
445 6 118 116 120
446 6 118 116 121
447 6 118 116 18
448 6 120 116 121
449 6 120 116 18
450 6 121 116 18
451 8 101 117 119
452 8 101 117 122
453 7 426 117 101
454 8 119 117 122
455 7 426 117 119
456 7 426 117 122
457 9 115 118 116
458 10 115 118 145
459 9 145 118 116
460 11 125 119 117
461 11 421 119 117
462 12 125 119 421
463 13 116 120 87
464 13 116 121 97
465 14 117 122 12
466 16 95 123 135
467 15 95 123 124
468 15 135 123 124
469 2 98 125 119
470 1 128 125 98
471 3 98 125 449
472 2 98 125 495
473 3 98 125 237
474 1 128 125 119
475 3 119 125 449
476 2 119 125 495
477 3 119 125 237
478 4 128 125 449
479 1 128 125 495
480 4 128 125 237
481 3 495 125 449
482 5 449 125 237
483 3 495 125 237
484 6 128 126 130
485 6 128 126 131
486 6 128 126 152
487 6 130 126 131
488 6 130 126 152
489 6 131 126 152
490 7 160 127 129
491 8 129 127 132
492 8 129 127 235
493 7 160 127 132
494 7 160 127 235
495 8 132 127 235
496 10 95 128 125
497 9 95 128 126
498 9 125 128 126
499 11 155 129 127
500 11 199 129 127
501 12 155 129 199
502 13 126 130 493
503 13 126 131 231
504 14 127 132 146
505 15 441 133 134
506 15 229 133 134
507 16 441 133 229
508 4 88 135 123
509 1 88 135 138
510 1 88 135 149
511 4 88 135 163
512 1 88 135 25
513 3 138 135 123
514 3 149 135 123
515 5 123 135 163
516 3 25 135 123
517 2 138 135 149
518 3 138 135 163
519 2 138 135 25
520 3 149 135 163
521 2 149 135 25
522 3 25 135 163
523 8 138 136 140
524 8 138 136 141
525 8 138 136 78
526 8 140 136 141
527 8 140 136 78
528 8 141 136 78
529 7 161 137 139
530 7 142 137 139
531 8 139 137 486
532 17 161 137 142
533 7 161 137 486
534 7 142 137 486
535 12 85 138 135
536 11 85 138 136
537 11 135 138 136
538 11 105 139 137
539 12 105 139 481
540 11 481 139 137
541 14 136 140 147
542 14 136 141 157
543 13 72 142 137
544 16 115 143 155
545 15 115 143 144
546 15 155 143 144
547 1 118 145 99
548 2 99 145 148
549 3 99 145 429
550 3 99 145 49
551 2 99 145 475
552 1 118 145 148
553 4 118 145 429
554 4 118 145 49
555 1 118 145 475
556 3 148 145 429
557 3 148 145 49
558 2 148 145 475
559 5 429 145 49
560 3 475 145 429
561 3 475 145 49
562 8 132 146 148
563 8 132 146 150
564 8 132 146 151
565 8 148 146 150
566 8 148 146 151
567 8 150 146 151
568 8 140 147 149
569 7 152 147 140
570 7 47 147 140
571 7 152 147 149
572 7 47 147 149
573 17 152 147 47
574 12 115 148 145
575 11 115 148 146
576 11 145 148 146
577 11 135 149 147
578 12 135 149 11
579 11 11 149 147
580 14 146 150 473
581 14 146 151 43
582 13 126 152 147
583 15 421 153 154
584 15 41 153 154
585 16 421 153 41
586 3 108 155 103
587 3 129 155 103
588 5 103 155 143
589 4 158 155 103
590 3 173 155 103
591 2 108 155 129
592 3 108 155 143
593 1 158 155 108
594 2 108 155 173
595 3 129 155 143
596 1 158 155 129
597 2 129 155 173
598 4 158 155 143
599 3 173 155 143
600 1 158 155 173
601 6 158 156 160
602 6 158 156 161
603 6 158 156 226
604 6 160 156 161
605 6 160 156 226
606 6 161 156 226
607 8 141 157 159
608 8 141 157 162
609 7 466 157 141
610 8 159 157 162
611 7 466 157 159
612 7 466 157 162
613 10 105 158 155
614 9 105 158 156
615 9 155 158 156
616 11 85 159 157
617 12 85 159 461
618 11 461 159 157
619 13 156 160 127
620 13 156 161 137
621 14 157 162 220
622 16 95 163 135
623 15 95 163 164
624 15 135 163 164
625 1 172 169 222
626 2 222 169 243
627 2 222 169 539
628 3 222 169 113
629 3 222 169 573
630 1 172 169 243
631 1 172 169 539
632 4 172 169 113
633 4 172 169 573
634 2 243 169 539
635 3 243 169 113
636 3 243 169 573
637 3 539 169 113
638 3 539 169 573
639 5 113 169 573
640 6 172 170 174
641 6 172 170 175
642 6 172 170 196
643 6 174 170 175
644 6 174 170 196
645 6 175 170 196
646 7 204 171 173
647 8 173 171 176
648 8 173 171 111
649 7 204 171 176
650 7 204 171 111
651 8 176 171 111
652 9 169 172 170
653 10 169 172 219
654 9 219 172 170
655 11 199 173 171
656 11 155 173 171
657 12 199 173 155
658 13 170 174 537
659 13 170 175 107
660 14 171 176 190
661 15 105 177 178
662 15 565 177 178
663 16 105 177 565
664 1 212 179 182
665 1 212 179 193
666 4 212 179 207
667 4 212 179 247
668 1 212 179 317
669 2 182 179 193
670 3 182 179 207
671 3 182 179 247
672 2 182 179 317
673 3 193 179 207
674 3 193 179 247
675 2 193 179 317
676 5 207 179 247
677 3 317 179 207
678 3 317 179 247
679 8 182 180 184
680 8 182 180 185
681 8 182 180 290
682 8 184 180 185
683 8 184 180 290
684 8 185 180 290
685 7 205 181 183
686 7 186 181 183
687 8 183 181 530
688 17 205 181 186
689 7 205 181 530
690 7 186 181 530
691 11 179 182 180
692 12 179 182 209
693 11 209 182 180
694 11 229 183 181
695 11 525 183 181
696 12 229 183 525
697 14 180 184 191
698 14 180 185 201
699 13 284 186 181
700 16 199 187 239
701 15 199 187 188
702 15 239 187 188
703 1 242 189 192
704 1 242 189 223
705 4 242 189 261
706 1 242 189 519
707 4 242 189 553
708 2 192 189 223
709 3 192 189 261
710 2 192 189 519
711 3 192 189 553
712 3 223 189 261
713 2 223 189 519
714 3 223 189 553
715 3 519 189 261
716 5 261 189 553
717 3 519 189 553
718 8 176 190 192
719 8 176 190 194
720 8 176 190 195
721 8 192 190 194
722 8 192 190 195
723 8 194 190 195
724 8 184 191 193
725 7 196 191 184
726 7 259 191 184
727 7 196 191 193
728 7 259 191 193
729 17 196 191 259
730 11 189 192 190
731 12 189 192 239
732 11 239 192 190
733 11 179 193 191
734 12 179 193 303
735 11 303 193 191
736 14 190 194 517
737 14 190 195 255
738 13 170 196 191
739 15 253 197 198
740 15 545 197 198
741 16 253 197 545
742 3 173 199 187
743 2 173 199 232
744 1 202 199 173
745 3 173 199 227
746 2 173 199 129
747 3 232 199 187
748 4 202 199 187
749 5 187 199 227
750 3 129 199 187
751 1 202 199 232
752 3 232 199 227
753 2 232 199 129
754 4 202 199 227
755 1 202 199 129
756 3 129 199 227
757 6 202 200 204
758 6 202 200 205
759 6 202 200 102
760 6 204 200 205
761 6 204 200 102
762 6 205 200 102
763 8 185 201 203
764 8 185 201 206
765 7 510 201 185
766 8 203 201 206
767 7 510 201 203
768 7 510 201 206
769 9 199 202 200
770 10 199 202 229
771 9 229 202 200
772 11 209 203 201
773 11 505 203 201
774 12 209 203 505
775 13 200 204 171
776 13 200 205 181
777 14 201 206 96
778 16 179 207 219
779 15 179 207 208
780 15 219 207 208
781 2 182 209 203
782 1 212 209 182
783 3 182 209 533
784 2 182 209 579
785 3 182 209 321
786 1 212 209 203
787 3 203 209 533
788 2 203 209 579
789 3 203 209 321
790 4 212 209 533
791 1 212 209 579
792 4 212 209 321
793 3 579 209 533
794 5 533 209 321
795 3 579 209 321
796 6 212 210 214
797 6 212 210 215
798 6 212 210 236
799 6 214 210 215
800 6 214 210 236
801 6 215 210 236
802 7 244 211 213
803 8 213 211 216
804 8 213 211 319
805 7 244 211 216
806 7 244 211 319
807 8 216 211 319
808 10 179 212 209
809 9 179 212 210
810 9 209 212 210
811 11 239 213 211
812 11 283 213 211
813 12 239 213 283
814 13 210 214 577
815 13 210 215 315
816 14 211 216 230
817 15 525 217 218
818 15 313 217 218
819 16 525 217 313
820 4 172 219 207
821 1 172 219 222
822 1 172 219 233
823 4 172 219 247
824 1 172 219 109
825 3 222 219 207
826 3 233 219 207
827 5 207 219 247
828 3 109 219 207
829 2 222 219 233
830 3 222 219 247
831 2 222 219 109
832 3 233 219 247
833 2 233 219 109
834 3 109 219 247
835 8 222 220 224
836 8 222 220 225
837 8 222 220 162
838 8 224 220 225
839 8 224 220 162
840 8 225 220 162
841 7 245 221 223
842 7 226 221 223
843 8 223 221 570
844 17 245 221 226
845 7 245 221 570
846 7 226 221 570
847 12 169 222 219
848 11 169 222 220
849 11 219 222 220
850 11 189 223 221
851 12 189 223 565
852 11 565 223 221
853 14 220 224 231
854 14 220 225 241
855 13 156 226 221
856 16 199 227 239
857 15 199 227 228
858 15 239 227 228
859 1 202 229 183
860 2 183 229 232
861 3 183 229 513
862 3 183 229 133
863 2 183 229 559
864 1 202 229 232
865 4 202 229 513
866 4 202 229 133
867 1 202 229 559
868 3 232 229 513
869 3 232 229 133
870 2 232 229 559
871 5 513 229 133
872 3 559 229 513
873 3 559 229 133
874 8 216 230 232
875 8 216 230 234
876 8 216 230 235
877 8 232 230 234
878 8 232 230 235
879 8 234 230 235
880 8 224 231 233
881 7 236 231 224
882 7 131 231 224
883 7 236 231 233
884 7 131 231 233
885 17 236 231 131
886 12 199 232 229
887 11 199 232 230
888 11 229 232 230
889 11 219 233 231
890 12 219 233 95
891 11 95 233 231
892 14 230 234 557
893 14 230 235 127
894 13 210 236 231
895 15 505 237 238
896 15 125 237 238
897 16 505 237 125
898 3 192 239 187
899 3 213 239 187
900 5 187 239 227
901 4 242 239 187
902 3 257 239 187
903 2 192 239 213
904 3 192 239 227
905 1 242 239 192
906 2 192 239 257
907 3 213 239 227
908 1 242 239 213
909 2 213 239 257
910 4 242 239 227
911 3 257 239 227
912 1 242 239 257
913 6 242 240 244
914 6 242 240 245
915 6 242 240 310
916 6 244 240 245
917 6 244 240 310
918 6 245 240 310
919 8 225 241 243
920 8 225 241 246
921 7 550 241 225
922 8 243 241 246
923 7 550 241 243
924 7 550 241 246
925 10 189 242 239
926 9 189 242 240
927 9 239 242 240
928 11 169 243 241
929 12 169 243 545
930 11 545 243 241
931 13 240 244 211
932 13 240 245 221
933 14 241 246 304
934 16 179 247 219
935 15 179 247 248
936 15 219 247 248
937 1 256 253 306
938 2 306 253 327
939 2 306 253 623
940 3 306 253 197
941 3 306 253 657
942 1 256 253 327
943 1 256 253 623
944 4 256 253 197
945 4 256 253 657
946 2 327 253 623
947 3 327 253 197
948 3 327 253 657
949 3 623 253 197
950 3 623 253 657
951 5 197 253 657
952 6 256 254 258
953 6 256 254 259
954 6 256 254 280
955 6 258 254 259
956 6 258 254 280
957 6 259 254 280
958 7 288 255 257
959 8 257 255 260
960 8 257 255 195
961 7 288 255 260
962 7 288 255 195
963 8 260 255 195
964 9 253 256 254
965 10 253 256 303
966 9 303 256 254
967 11 283 257 255
968 11 239 257 255
969 12 283 257 239
970 13 254 258 621
971 13 254 259 191
972 14 255 260 274
973 15 189 261 262
974 15 649 261 262
975 16 189 261 649
976 1 296 263 266
977 1 296 263 277
978 4 296 263 291
979 4 296 263 331
980 1 296 263 65
981 2 266 263 277
982 3 266 263 291
983 3 266 263 331
984 2 266 263 65
985 3 277 263 291
986 3 277 263 331
987 2 277 263 65
988 5 291 263 331
989 3 65 263 291
990 3 65 263 331
991 8 266 264 268
992 8 266 264 269
993 8 266 264 38
994 8 268 264 269
995 8 268 264 38
996 8 269 264 38
997 7 289 265 267
998 7 270 265 267
999 8 267 265 614
1000 17 289 265 270
1001 7 289 265 614
1002 7 270 265 614
1003 11 263 266 264
1004 12 263 266 293
1005 11 293 266 264
1006 11 313 267 265
1007 11 609 267 265
1008 12 313 267 609
1009 14 264 268 275
1010 14 264 269 285
1011 13 32 270 265
1012 16 283 271 323
1013 15 283 271 272
1014 15 323 271 272
1015 1 326 273 276
1016 1 326 273 307
1017 4 326 273 9
1018 1 326 273 603
1019 4 326 273 637
1020 2 276 273 307
1021 3 276 273 9
1022 2 276 273 603
1023 3 276 273 637
1024 3 307 273 9
1025 2 307 273 603
1026 3 307 273 637
1027 3 603 273 9
1028 5 9 273 637
1029 3 603 273 637
1030 8 260 274 276
1031 8 260 274 278
1032 8 260 274 279
1033 8 276 274 278
1034 8 276 274 279
1035 8 278 274 279
1036 8 268 275 277
1037 7 280 275 268
1038 7 7 275 268
1039 7 280 275 277
1040 7 7 275 277
1041 17 280 275 7
1042 11 273 276 274
1043 12 273 276 323
1044 11 323 276 274
1045 11 263 277 275
1046 12 263 277 51
1047 11 51 277 275
1048 14 274 278 601
1049 14 274 279 3
1050 13 254 280 275
1051 15 1 281 282
1052 15 629 281 282
1053 16 1 281 629
1054 3 257 283 271
1055 2 257 283 316
1056 1 286 283 257
1057 3 257 283 311
1058 2 257 283 213
1059 3 316 283 271
1060 4 286 283 271
1061 5 271 283 311
1062 3 213 283 271
1063 1 286 283 316
1064 3 316 283 311
1065 2 316 283 213
1066 4 286 283 311
1067 1 286 283 213
1068 3 213 283 311
1069 6 286 284 288
1070 6 286 284 289
1071 6 286 284 186
1072 6 288 284 289
1073 6 288 284 186
1074 6 289 284 186
1075 8 269 285 287
1076 8 269 285 290
1077 7 594 285 269
1078 8 287 285 290
1079 7 594 285 287
1080 7 594 285 290
1081 9 283 286 284
1082 10 283 286 313
1083 9 313 286 284
1084 11 293 287 285
1085 11 589 287 285
1086 12 293 287 589
1087 13 284 288 255
1088 13 284 289 265
1089 14 285 290 180
1090 16 263 291 303
1091 15 263 291 292
1092 15 303 291 292
1093 2 266 293 287
1094 1 296 293 266
1095 3 266 293 617
1096 2 266 293 663
1097 3 266 293 69
1098 1 296 293 287
1099 3 287 293 617
1100 2 287 293 663
1101 3 287 293 69
1102 4 296 293 617
1103 1 296 293 663
1104 4 296 293 69
1105 3 663 293 617
1106 5 617 293 69
1107 3 663 293 69
1108 6 296 294 298
1109 6 296 294 299
1110 6 296 294 320
1111 6 298 294 299
1112 6 298 294 320
1113 6 299 294 320
1114 7 328 295 297
1115 8 297 295 300
1116 8 297 295 67
1117 7 328 295 300
1118 7 328 295 67
1119 8 300 295 67
1120 10 263 296 293
1121 9 263 296 294
1122 9 293 296 294
1123 11 323 297 295
1124 11 31 297 295
1125 12 323 297 31
1126 13 294 298 661
1127 13 294 299 63
1128 14 295 300 314
1129 15 609 301 302
1130 15 61 301 302
1131 16 609 301 61
1132 4 256 303 291
1133 1 256 303 306
1134 1 256 303 317
1135 4 256 303 331
1136 1 256 303 193
1137 3 306 303 291
1138 3 317 303 291
1139 5 291 303 331
1140 3 193 303 291
1141 2 306 303 317
1142 3 306 303 331
1143 2 306 303 193
1144 3 317 303 331
1145 2 317 303 193
1146 3 193 303 331
1147 8 306 304 308
1148 8 306 304 309
1149 8 306 304 246
1150 8 308 304 309
1151 8 308 304 246
1152 8 309 304 246
1153 7 329 305 307
1154 7 310 305 307
1155 8 307 305 654
1156 17 329 305 310
1157 7 329 305 654
1158 7 310 305 654
1159 12 253 306 303
1160 11 253 306 304
1161 11 303 306 304
1162 11 273 307 305
1163 12 273 307 649
1164 11 649 307 305
1165 14 304 308 315
1166 14 304 309 325
1167 13 240 310 305
1168 16 283 311 323
1169 15 283 311 312
1170 15 323 311 312
1171 1 286 313 267
1172 2 267 313 316
1173 3 267 313 597
1174 3 267 313 217
1175 2 267 313 643
1176 1 286 313 316
1177 4 286 313 597
1178 4 286 313 217
1179 1 286 313 643
1180 3 316 313 597
1181 3 316 313 217
1182 2 316 313 643
1183 5 597 313 217
1184 3 643 313 597
1185 3 643 313 217
1186 8 300 314 316
1187 8 300 314 318
1188 8 300 314 319
1189 8 316 314 318
1190 8 316 314 319
1191 8 318 314 319
1192 8 308 315 317
1193 7 320 315 308
1194 7 215 315 308
1195 7 320 315 317
1196 7 215 315 317
1197 17 320 315 215
1198 12 283 316 313
1199 11 283 316 314
1200 11 313 316 314
1201 11 303 317 315
1202 12 303 317 179
1203 11 179 317 315
1204 14 314 318 641
1205 14 314 319 211
1206 13 294 320 315
1207 15 589 321 322
1208 15 209 321 322
1209 16 589 321 209
1210 3 276 323 271
1211 3 297 323 271
1212 5 271 323 311
1213 4 326 323 271
1214 3 5 323 271
1215 2 276 323 297
1216 3 276 323 311
1217 1 326 323 276
1218 2 276 323 5
1219 3 297 323 311
1220 1 326 323 297
1221 2 297 323 5
1222 4 326 323 311
1223 3 5 323 311
1224 1 326 323 5
1225 6 326 324 328
1226 6 326 324 329
1227 6 326 324 58
1228 6 328 324 329
1229 6 328 324 58
1230 6 329 324 58
1231 8 309 325 327
1232 8 309 325 330
1233 7 634 325 309
1234 8 327 325 330
1235 7 634 325 327
1236 7 634 325 330
1237 10 273 326 323
1238 9 273 326 324
1239 9 323 326 324
1240 11 253 327 325
1241 12 253 327 629
1242 11 629 327 325
1243 13 324 328 295
1244 13 324 329 305
1245 14 325 330 52
1246 16 263 331 303
1247 15 263 331 332
1248 15 303 331 332
1249 1 340 337 390
1250 2 390 337 411
1251 2 390 337 35
1252 3 390 337 617
1253 3 390 337 69
1254 1 340 337 411
1255 1 340 337 35
1256 4 340 337 617
1257 4 340 337 69
1258 2 411 337 35
1259 3 411 337 617
1260 3 411 337 69
1261 3 35 337 617
1262 3 35 337 69
1263 5 617 337 69
1264 6 340 338 342
1265 6 340 338 343
1266 6 340 338 364
1267 6 342 338 343
1268 6 342 338 364
1269 6 343 338 364
1270 7 372 339 341
1271 8 341 339 344
1272 8 341 339 615
1273 7 372 339 344
1274 7 372 339 615
1275 8 344 339 615
1276 9 337 340 338
1277 10 337 340 387
1278 9 387 340 338
1279 11 367 341 339
1280 11 659 341 339
1281 12 367 341 659
1282 13 338 342 33
1283 13 338 343 611
1284 14 339 344 358
1285 15 609 345 346
1286 15 61 345 346
1287 16 609 345 61
1288 1 380 347 350
1289 1 380 347 361
1290 4 380 347 375
1291 4 380 347 415
1292 1 380 347 485
1293 2 350 347 361
1294 3 350 347 375
1295 3 350 347 415
1296 2 350 347 485
1297 3 361 347 375
1298 3 361 347 415
1299 2 361 347 485
1300 5 375 347 415
1301 3 485 347 375
1302 3 485 347 415
1303 8 350 348 352
1304 8 350 348 353
1305 8 350 348 458
1306 8 352 348 353
1307 8 352 348 458
1308 8 353 348 458
1309 7 373 349 351
1310 7 354 349 351
1311 8 351 349 26
1312 17 373 349 354
1313 7 373 349 26
1314 7 354 349 26
1315 11 347 350 348
1316 12 347 350 377
1317 11 377 350 348
1318 11 397 351 349
1319 11 21 351 349
1320 12 397 351 21
1321 14 348 352 359
1322 14 348 353 369
1323 13 452 354 349
1324 16 367 355 407
1325 15 367 355 356
1326 15 407 355 356
1327 1 410 357 360
1328 1 410 357 391
1329 4 410 357 429
1330 1 410 357 15
1331 4 410 357 49
1332 2 360 357 391
1333 3 360 357 429
1334 2 360 357 15
1335 3 360 357 49
1336 3 391 357 429
1337 2 391 357 15
1338 3 391 357 49
1339 3 15 357 429
1340 5 429 357 49
1341 3 15 357 49
1342 8 344 358 360
1343 8 344 358 362
1344 8 344 358 363
1345 8 360 358 362
1346 8 360 358 363
1347 8 362 358 363
1348 8 352 359 361
1349 7 364 359 352
1350 7 427 359 352
1351 7 364 359 361
1352 7 427 359 361
1353 17 364 359 427
1354 11 357 360 358
1355 12 357 360 407
1356 11 407 360 358
1357 11 347 361 359
1358 12 347 361 471
1359 11 471 361 359
1360 14 358 362 13
1361 14 358 363 423
1362 13 338 364 359
1363 15 421 365 366
1364 15 41 365 366
1365 16 421 365 41
1366 3 341 367 355
1367 2 341 367 400
1368 1 370 367 341
1369 3 341 367 395
1370 2 341 367 633
1371 3 400 367 355
1372 4 370 367 355
1373 5 355 367 395
1374 3 633 367 355
1375 1 370 367 400
1376 3 400 367 395
1377 2 400 367 633
1378 4 370 367 395
1379 1 370 367 633
1380 3 633 367 395
1381 6 370 368 372
1382 6 370 368 373
1383 6 370 368 606
1384 6 372 368 373
1385 6 372 368 606
1386 6 373 368 606
1387 8 353 369 371
1388 8 353 369 374
1389 7 6 369 353
1390 8 371 369 374
1391 7 6 369 371
1392 7 6 369 374
1393 9 367 370 368
1394 10 367 370 397
1395 9 397 370 368
1396 11 377 371 369
1397 11 1 371 369
1398 12 377 371 1
1399 13 368 372 339
1400 13 368 373 349
1401 14 369 374 600
1402 16 347 375 387
1403 15 347 375 376
1404 15 387 375 376
1405 2 350 377 371
1406 1 380 377 350
1407 3 350 377 29
1408 2 350 377 75
1409 3 350 377 489
1410 1 380 377 371
1411 3 371 377 29
1412 2 371 377 75
1413 3 371 377 489
1414 4 380 377 29
1415 1 380 377 75
1416 4 380 377 489
1417 3 75 377 29
1418 5 29 377 489
1419 3 75 377 489
1420 6 380 378 382
1421 6 380 378 383
1422 6 380 378 404
1423 6 382 378 383
1424 6 382 378 404
1425 6 383 378 404
1426 7 412 379 381
1427 8 381 379 384
1428 8 381 379 487
1429 7 412 379 384
1430 7 412 379 487
1431 8 384 379 487
1432 10 347 380 377
1433 9 347 380 378
1434 9 377 380 378
1435 11 407 381 379
1436 11 451 381 379
1437 12 407 381 451
1438 13 378 382 73
1439 13 378 383 483
1440 14 379 384 398
1441 15 21 385 386
1442 15 481 385 386
1443 16 21 385 481
1444 4 340 387 375
1445 1 340 387 390
1446 1 340 387 401
1447 4 340 387 415
1448 1 340 387 613
1449 3 390 387 375
1450 3 401 387 375
1451 5 375 387 415
1452 3 613 387 375
1453 2 390 387 401
1454 3 390 387 415
1455 2 390 387 613
1456 3 401 387 415
1457 2 401 387 613
1458 3 613 387 415
1459 8 390 388 392
1460 8 390 388 393
1461 8 390 388 666
1462 8 392 388 393
1463 8 392 388 666
1464 8 393 388 666
1465 7 413 389 391
1466 7 394 389 391
1467 8 391 389 66
1468 17 413 389 394
1469 7 413 389 66
1470 7 394 389 66
1471 12 337 390 387
1472 11 337 390 388
1473 11 387 390 388
1474 11 357 391 389
1475 12 357 391 61
1476 11 61 391 389
1477 14 388 392 399
1478 14 388 393 409
1479 13 660 394 389
1480 16 367 395 407
1481 15 367 395 396
1482 15 407 395 396
1483 1 370 397 351
1484 2 351 397 400
1485 3 351 397 9
1486 3 351 397 637
1487 2 351 397 55
1488 1 370 397 400
1489 4 370 397 9
1490 4 370 397 637
1491 1 370 397 55
1492 3 400 397 9
1493 3 400 397 637
1494 2 400 397 55
1495 5 9 397 637
1496 3 55 397 9
1497 3 55 397 637
1498 8 384 398 400
1499 8 384 398 402
1500 8 384 398 403
1501 8 400 398 402
1502 8 400 398 403
1503 8 402 398 403
1504 8 392 399 401
1505 7 404 399 392
1506 7 635 399 392
1507 7 404 399 401
1508 7 635 399 401
1509 17 404 399 635
1510 12 367 400 397
1511 11 367 400 398
1512 11 397 400 398
1513 11 387 401 399
1514 12 387 401 599
1515 11 599 401 399
1516 14 398 402 53
1517 14 398 403 631
1518 13 378 404 399
1519 15 1 405 406
1520 15 629 405 406
1521 16 1 405 629
1522 3 360 407 355
1523 3 381 407 355
1524 5 355 407 395
1525 4 410 407 355
1526 3 425 407 355
1527 2 360 407 381
1528 3 360 407 395
1529 1 410 407 360
1530 2 360 407 425
1531 3 381 407 395
1532 1 410 407 381
1533 2 381 407 425
1534 4 410 407 395
1535 3 425 407 395
1536 1 410 407 425
1537 6 410 408 412
1538 6 410 408 413
1539 6 410 408 478
1540 6 412 408 413
1541 6 412 408 478
1542 6 413 408 478
1543 8 393 409 411
1544 8 393 409 414
1545 7 46 409 393
1546 8 411 409 414
1547 7 46 409 411
1548 7 46 409 414
1549 10 357 410 407
1550 9 357 410 408
1551 9 407 410 408
1552 11 337 411 409
1553 12 337 411 41
1554 11 41 411 409
1555 13 408 412 379
1556 13 408 413 389
1557 14 409 414 472
1558 16 347 415 387
1559 15 347 415 416
1560 15 387 415 416
1561 1 424 421 474
1562 2 474 421 495
1563 2 474 421 119
1564 3 474 421 365
1565 3 474 421 153
1566 1 424 421 495
1567 1 424 421 119
1568 4 424 421 365
1569 4 424 421 153
1570 2 495 421 119
1571 3 495 421 365
1572 3 495 421 153
1573 3 119 421 365
1574 3 119 421 153
1575 5 365 421 153
1576 6 424 422 426
1577 6 424 422 427
1578 6 424 422 448
1579 6 426 422 427
1580 6 426 422 448
1581 6 427 422 448
1582 7 456 423 425
1583 8 425 423 428
1584 8 425 423 363
1585 7 456 423 428
1586 7 456 423 363
1587 8 428 423 363
1588 9 421 424 422
1589 10 421 424 471
1590 9 471 424 422
1591 11 451 425 423
1592 11 407 425 423
1593 12 451 425 407
1594 13 422 426 117
1595 13 422 427 359
1596 14 423 428 442
1597 15 357 429 430
1598 15 145 429 430
1599 16 357 429 145
1600 1 464 431 434
1601 1 464 431 445
1602 4 464 431 459
1603 4 464 431 499
1604 1 464 431 569
1605 2 434 431 445
1606 3 434 431 459
1607 3 434 431 499
1608 2 434 431 569
1609 3 445 431 459
1610 3 445 431 499
1611 2 445 431 569
1612 5 459 431 499
1613 3 569 431 459
1614 3 569 431 499
1615 8 434 432 436
1616 8 434 432 437
1617 8 434 432 542
1618 8 436 432 437
1619 8 436 432 542
1620 8 437 432 542
1621 7 457 433 435
1622 7 438 433 435
1623 8 435 433 110
1624 17 457 433 438
1625 7 457 433 110
1626 7 438 433 110
1627 11 431 434 432
1628 12 431 434 461
1629 11 461 434 432
1630 11 481 435 433
1631 11 105 435 433
1632 12 481 435 105
1633 14 432 436 443
1634 14 432 437 453
1635 13 536 438 433
1636 16 451 439 491
1637 15 451 439 440
1638 15 491 439 440
1639 1 494 441 444
1640 1 494 441 475
1641 4 494 441 513
1642 1 494 441 99
1643 4 494 441 133
1644 2 444 441 475
1645 3 444 441 513
1646 2 444 441 99
1647 3 444 441 133
1648 3 475 441 513
1649 2 475 441 99
1650 3 475 441 133
1651 3 99 441 513
1652 5 513 441 133
1653 3 99 441 133
1654 8 428 442 444
1655 8 428 442 446
1656 8 428 442 447
1657 8 444 442 446
1658 8 444 442 447
1659 8 446 442 447
1660 8 436 443 445
1661 7 448 443 436
1662 7 511 443 436
1663 7 448 443 445
1664 7 511 443 445
1665 17 448 443 511
1666 11 441 444 442
1667 12 441 444 491
1668 11 491 444 442
1669 11 431 445 443
1670 12 431 445 555
1671 11 555 445 443
1672 14 442 446 97
1673 14 442 447 507
1674 13 422 448 443
1675 15 505 449 450
1676 15 125 449 450
1677 16 505 449 125
1678 3 425 451 439
1679 2 425 451 484
1680 1 454 451 425
1681 3 425 451 479
1682 2 425 451 381
1683 3 484 451 439
1684 4 454 451 439
1685 5 439 451 479
1686 3 381 451 439
1687 1 454 451 484
1688 3 484 451 479
1689 2 484 451 381
1690 4 454 451 479
1691 1 454 451 381
1692 3 381 451 479
1693 6 454 452 456
1694 6 454 452 457
1695 6 454 452 354
1696 6 456 452 457
1697 6 456 452 354
1698 6 457 452 354
1699 8 437 453 455
1700 8 437 453 458
1701 7 90 453 437
1702 8 455 453 458
1703 7 90 453 455
1704 7 90 453 458
1705 9 451 454 452
1706 10 451 454 481
1707 9 481 454 452
1708 11 461 455 453
1709 11 85 455 453
1710 12 461 455 85
1711 13 452 456 423
1712 13 452 457 433
1713 14 453 458 348
1714 16 431 459 471
1715 15 431 459 460
1716 15 471 459 460
1717 2 434 461 455
1718 1 464 461 434
1719 3 434 461 113
1720 2 434 461 159
1721 3 434 461 573
1722 1 464 461 455
1723 3 455 461 113
1724 2 455 461 159
1725 3 455 461 573
1726 4 464 461 113
1727 1 464 461 159
1728 4 464 461 573
1729 3 159 461 113
1730 5 113 461 573
1731 3 159 461 573
1732 6 464 462 466
1733 6 464 462 467
1734 6 464 462 488
1735 6 466 462 467
1736 6 466 462 488
1737 6 467 462 488
1738 7 496 463 465
1739 8 465 463 468
1740 8 465 463 571
1741 7 496 463 468
1742 7 496 463 571
1743 8 468 463 571
1744 10 431 464 461
1745 9 431 464 462
1746 9 461 464 462
1747 11 491 465 463
1748 11 535 465 463
1749 12 491 465 535
1750 13 462 466 157
1751 13 462 467 567
1752 14 463 468 482
1753 15 105 469 470
1754 15 565 469 470
1755 16 105 469 565
1756 4 424 471 459
1757 1 424 471 474
1758 1 424 471 485
1759 4 424 471 499
1760 1 424 471 361
1761 3 474 471 459
1762 3 485 471 459
1763 5 459 471 499
1764 3 361 471 459
1765 2 474 471 485
1766 3 474 471 499
1767 2 474 471 361
1768 3 485 471 499
1769 2 485 471 361
1770 3 361 471 499
1771 8 474 472 476
1772 8 474 472 477
1773 8 474 472 414
1774 8 476 472 477
1775 8 476 472 414
1776 8 477 472 414
1777 7 497 473 475
1778 7 478 473 475
1779 8 475 473 150
1780 17 497 473 478
1781 7 497 473 150
1782 7 478 473 150
1783 12 421 474 471
1784 11 421 474 472
1785 11 471 474 472
1786 11 441 475 473
1787 12 441 475 145
1788 11 145 475 473
1789 14 472 476 483
1790 14 472 477 493
1791 13 408 478 473
1792 16 451 479 491
1793 15 451 479 480
1794 15 491 479 480
1795 1 454 481 435
1796 2 435 481 484
1797 3 435 481 93
1798 3 435 481 385
1799 2 435 481 139
1800 1 454 481 484
1801 4 454 481 93
1802 4 454 481 385
1803 1 454 481 139
1804 3 484 481 93
1805 3 484 481 385
1806 2 484 481 139
1807 5 93 481 385
1808 3 139 481 93
1809 3 139 481 385
1810 8 468 482 484
1811 8 468 482 486
1812 8 468 482 487
1813 8 484 482 486
1814 8 484 482 487
1815 8 486 482 487
1816 8 476 483 485
1817 7 488 483 476
1818 7 383 483 476
1819 7 488 483 485
1820 7 383 483 485
1821 17 488 483 383
1822 12 451 484 481
1823 11 451 484 482
1824 11 481 484 482
1825 11 471 485 483
1826 12 471 485 347
1827 11 347 485 483
1828 14 482 486 137
1829 14 482 487 379
1830 13 462 488 483
1831 15 85 489 490
1832 15 377 489 490
1833 16 85 489 377
1834 3 444 491 439
1835 3 465 491 439
1836 5 439 491 479
1837 4 494 491 439
1838 3 509 491 439
1839 2 444 491 465
1840 3 444 491 479
1841 1 494 491 444
1842 2 444 491 509
1843 3 465 491 479
1844 1 494 491 465
1845 2 465 491 509
1846 4 494 491 479
1847 3 509 491 479
1848 1 494 491 509
1849 6 494 492 496
1850 6 494 492 497
1851 6 494 492 562
1852 6 496 492 497
1853 6 496 492 562
1854 6 497 492 562
1855 8 477 493 495
1856 8 477 493 498
1857 7 130 493 477
1858 8 495 493 498
1859 7 130 493 495
1860 7 130 493 498
1861 10 441 494 491
1862 9 441 494 492
1863 9 491 494 492
1864 11 421 495 493
1865 12 421 495 125
1866 11 125 495 493
1867 13 492 496 463
1868 13 492 497 473
1869 14 493 498 556
1870 16 431 499 471
1871 15 431 499 500
1872 15 471 499 500
1873 1 508 505 558
1874 2 558 505 579
1875 2 558 505 203
1876 3 558 505 449
1877 3 558 505 237
1878 1 508 505 579
1879 1 508 505 203
1880 4 508 505 449
1881 4 508 505 237
1882 2 579 505 203
1883 3 579 505 449
1884 3 579 505 237
1885 3 203 505 449
1886 3 203 505 237
1887 5 449 505 237
1888 6 508 506 510
1889 6 508 506 511
1890 6 508 506 532
1891 6 510 506 511
1892 6 510 506 532
1893 6 511 506 532
1894 7 540 507 509
1895 8 509 507 512
1896 8 509 507 447
1897 7 540 507 512
1898 7 540 507 447
1899 8 512 507 447
1900 9 505 508 506
1901 10 505 508 555
1902 9 555 508 506
1903 11 535 509 507
1904 11 491 509 507
1905 12 535 509 491
1906 13 506 510 201
1907 13 506 511 443
1908 14 507 512 526
1909 15 441 513 514
1910 15 229 513 514
1911 16 441 513 229
1912 1 548 515 518
1913 1 548 515 529
1914 4 548 515 543
1915 4 548 515 583
1916 1 548 515 653
1917 2 518 515 529
1918 3 518 515 543
1919 3 518 515 583
1920 2 518 515 653
1921 3 529 515 543
1922 3 529 515 583
1923 2 529 515 653
1924 5 543 515 583
1925 3 653 515 543
1926 3 653 515 583
1927 8 518 516 520
1928 8 518 516 521
1929 8 518 516 626
1930 8 520 516 521
1931 8 520 516 626
1932 8 521 516 626
1933 7 541 517 519
1934 7 522 517 519
1935 8 519 517 194
1936 17 541 517 522
1937 7 541 517 194
1938 7 522 517 194
1939 11 515 518 516
1940 12 515 518 545
1941 11 545 518 516
1942 11 565 519 517
1943 11 189 519 517
1944 12 565 519 189
1945 14 516 520 527
1946 14 516 521 537
1947 13 620 522 517
1948 16 535 523 575
1949 15 535 523 524
1950 15 575 523 524
1951 1 578 525 528
1952 1 578 525 559
1953 4 578 525 597
1954 1 578 525 183
1955 4 578 525 217
1956 2 528 525 559
1957 3 528 525 597
1958 2 528 525 183
1959 3 528 525 217
1960 3 559 525 597
1961 2 559 525 183
1962 3 559 525 217
1963 3 183 525 597
1964 5 597 525 217
1965 3 183 525 217
1966 8 512 526 528
1967 8 512 526 530
1968 8 512 526 531
1969 8 528 526 530
1970 8 528 526 531
1971 8 530 526 531
1972 8 520 527 529
1973 7 532 527 520
1974 7 595 527 520
1975 7 532 527 529
1976 7 595 527 529
1977 17 532 527 595
1978 11 525 528 526
1979 12 525 528 575
1980 11 575 528 526
1981 11 515 529 527
1982 12 515 529 639
1983 11 639 529 527
1984 14 526 530 181
1985 14 526 531 591
1986 13 506 532 527
1987 15 589 533 534
1988 15 209 533 534
1989 16 589 533 209
1990 3 509 535 523
1991 2 509 535 568
1992 1 538 535 509
1993 3 509 535 563
1994 2 509 535 465
1995 3 568 535 523
1996 4 538 535 523
1997 5 523 535 563
1998 3 465 535 523
1999 1 538 535 568
2000 3 568 535 563
2001 2 568 535 465
2002 4 538 535 563
2003 1 538 535 465
2004 3 465 535 563
2005 6 538 536 540
2006 6 538 536 541
2007 6 538 536 438
2008 6 540 536 541
2009 6 540 536 438
2010 6 541 536 438
2011 8 521 537 539
2012 8 521 537 542
2013 7 174 537 521
2014 8 539 537 542
2015 7 174 537 539
2016 7 174 537 542
2017 9 535 538 536
2018 10 535 538 565
2019 9 565 538 536
2020 11 545 539 537
2021 11 169 539 537
2022 12 545 539 169
2023 13 536 540 507
2024 13 536 541 517
2025 14 537 542 432
2026 16 515 543 555
2027 15 515 543 544
2028 15 555 543 544
2029 2 518 545 539
2030 1 548 545 518
2031 3 518 545 197
2032 2 518 545 243
2033 3 518 545 657
2034 1 548 545 539
2035 3 539 545 197
2036 2 539 545 243
2037 3 539 545 657
2038 4 548 545 197
2039 1 548 545 243
2040 4 548 545 657
2041 3 243 545 197
2042 5 197 545 657
2043 3 243 545 657
2044 6 548 546 550
2045 6 548 546 551
2046 6 548 546 572
2047 6 550 546 551
2048 6 550 546 572
2049 6 551 546 572
2050 7 580 547 549
2051 8 549 547 552
2052 8 549 547 655
2053 7 580 547 552
2054 7 580 547 655
2055 8 552 547 655
2056 10 515 548 545
2057 9 515 548 546
2058 9 545 548 546
2059 11 575 549 547
2060 11 619 549 547
2061 12 575 549 619
2062 13 546 550 241
2063 13 546 551 651
2064 14 547 552 566
2065 15 189 553 554
2066 15 649 553 554
2067 16 189 553 649
2068 4 508 555 543
2069 1 508 555 558
2070 1 508 555 569
2071 4 508 555 583
2072 1 508 555 445
2073 3 558 555 543
2074 3 569 555 543
2075 5 543 555 583
2076 3 445 555 543
2077 2 558 555 569
2078 3 558 555 583
2079 2 558 555 445
2080 3 569 555 583
2081 2 569 555 445
2082 3 445 555 583
2083 8 558 556 560
2084 8 558 556 561
2085 8 558 556 498
2086 8 560 556 561
2087 8 560 556 498
2088 8 561 556 498
2089 7 581 557 559
2090 7 562 557 559
2091 8 559 557 234
2092 17 581 557 562
2093 7 581 557 234
2094 7 562 557 234
2095 12 505 558 555
2096 11 505 558 556
2097 11 555 558 556
2098 11 525 559 557
2099 12 525 559 229
2100 11 229 559 557
2101 14 556 560 567
2102 14 556 561 577
2103 13 492 562 557
2104 16 535 563 575
2105 15 535 563 564
2106 15 575 563 564
2107 1 538 565 519
2108 2 519 565 568
2109 3 519 565 177
2110 3 519 565 469
2111 2 519 565 223
2112 1 538 565 568
2113 4 538 565 177
2114 4 538 565 469
2115 1 538 565 223
2116 3 568 565 177
2117 3 568 565 469
2118 2 568 565 223
2119 5 177 565 469
2120 3 223 565 177
2121 3 223 565 469
2122 8 552 566 568
2123 8 552 566 570
2124 8 552 566 571
2125 8 568 566 570
2126 8 568 566 571
2127 8 570 566 571
2128 8 560 567 569
2129 7 572 567 560
2130 7 467 567 560
2131 7 572 567 569
2132 7 467 567 569
2133 17 572 567 467
2134 12 535 568 565
2135 11 535 568 566
2136 11 565 568 566
2137 11 555 569 567
2138 12 555 569 431
2139 11 431 569 567
2140 14 566 570 221
2141 14 566 571 463
2142 13 546 572 567
2143 15 169 573 574
2144 15 461 573 574
2145 16 169 573 461
2146 3 528 575 523
2147 3 549 575 523
2148 5 523 575 563
2149 4 578 575 523
2150 3 593 575 523
2151 2 528 575 549
2152 3 528 575 563
2153 1 578 575 528
2154 2 528 575 593
2155 3 549 575 563
2156 1 578 575 549
2157 2 549 575 593
2158 4 578 575 563
2159 3 593 575 563
2160 1 578 575 593
2161 6 578 576 580
2162 6 578 576 581
2163 6 578 576 646
2164 6 580 576 581
2165 6 580 576 646
2166 6 581 576 646
2167 8 561 577 579
2168 8 561 577 582
2169 7 214 577 561
2170 8 579 577 582
2171 7 214 577 579
2172 7 214 577 582
2173 10 525 578 575
2174 9 525 578 576
2175 9 575 578 576
2176 11 505 579 577
2177 12 505 579 209
2178 11 209 579 577
2179 13 576 580 547
2180 13 576 581 557
2181 14 577 582 640
2182 16 515 583 555
2183 15 515 583 584
2184 15 555 583 584
2185 1 592 589 642
2186 2 642 589 663
2187 2 642 589 287
2188 3 642 589 533
2189 3 642 589 321
2190 1 592 589 663
2191 1 592 589 287
2192 4 592 589 533
2193 4 592 589 321
2194 2 663 589 287
2195 3 663 589 533
2196 3 663 589 321
2197 3 287 589 533
2198 3 287 589 321
2199 5 533 589 321
2200 6 592 590 594
2201 6 592 590 595
2202 6 592 590 616
2203 6 594 590 595
2204 6 594 590 616
2205 6 595 590 616
2206 7 624 591 593
2207 8 593 591 596
2208 8 593 591 531
2209 7 624 591 596
2210 7 624 591 531
2211 8 596 591 531
2212 9 589 592 590
2213 10 589 592 639
2214 9 639 592 590
2215 11 619 593 591
2216 11 575 593 591
2217 12 619 593 575
2218 13 590 594 285
2219 13 590 595 527
2220 14 591 596 610
2221 15 525 597 598
2222 15 313 597 598
2223 16 525 597 313
2224 1 632 599 602
2225 1 632 599 613
2226 4 632 599 627
2227 4 632 599 667
2228 1 632 599 401
2229 2 602 599 613
2230 3 602 599 627
2231 3 602 599 667
2232 2 602 599 401
2233 3 613 599 627
2234 3 613 599 667
2235 2 613 599 401
2236 5 627 599 667
2237 3 401 599 627
2238 3 401 599 667
2239 8 602 600 604
2240 8 602 600 605
2241 8 602 600 374
2242 8 604 600 605
2243 8 604 600 374
2244 8 605 600 374
2245 7 625 601 603
2246 7 606 601 603
2247 8 603 601 278
2248 17 625 601 606
2249 7 625 601 278
2250 7 606 601 278
2251 11 599 602 600
2252 12 599 602 629
2253 11 629 602 600
2254 11 649 603 601
2255 11 273 603 601
2256 12 649 603 273
2257 14 600 604 611
2258 14 600 605 621
2259 13 368 606 601
2260 16 619 607 659
2261 15 619 607 608
2262 15 659 607 608
2263 1 662 609 612
2264 1 662 609 643
2265 4 662 609 345
2266 1 662 609 267
2267 4 662 609 301
2268 2 612 609 643
2269 3 612 609 345
2270 2 612 609 267
2271 3 612 609 301
2272 3 643 609 345
2273 2 643 609 267
2274 3 643 609 301
2275 3 267 609 345
2276 5 345 609 301
2277 3 267 609 301
2278 8 596 610 612
2279 8 596 610 614
2280 8 596 610 615
2281 8 612 610 614
2282 8 612 610 615
2283 8 614 610 615
2284 8 604 611 613
2285 7 616 611 604
2286 7 343 611 604
2287 7 616 611 613
2288 7 343 611 613
2289 17 616 611 343
2290 11 609 612 610
2291 12 609 612 659
2292 11 659 612 610
2293 11 599 613 611
2294 12 599 613 387
2295 11 387 613 611
2296 14 610 614 265
2297 14 610 615 339
2298 13 590 616 611
2299 15 337 617 618
2300 15 293 617 618
2301 16 337 617 293
2302 3 593 619 607
2303 2 593 619 652
2304 1 622 619 593
2305 3 593 619 647
2306 2 593 619 549
2307 3 652 619 607
2308 4 622 619 607
2309 5 607 619 647
2310 3 549 619 607
2311 1 622 619 652
2312 3 652 619 647
2313 2 652 619 549
2314 4 622 619 647
2315 1 622 619 549
2316 3 549 619 647
2317 6 622 620 624
2318 6 622 620 625
2319 6 622 620 522
2320 6 624 620 625
2321 6 624 620 522
2322 6 625 620 522
2323 8 605 621 623
2324 8 605 621 626
2325 7 258 621 605
2326 8 623 621 626
2327 7 258 621 623
2328 7 258 621 626
2329 9 619 622 620
2330 10 619 622 649
2331 9 649 622 620
2332 11 629 623 621
2333 11 253 623 621
2334 12 629 623 253
2335 13 620 624 591
2336 13 620 625 601
2337 14 621 626 516
2338 16 599 627 639
2339 15 599 627 628
2340 15 639 627 628
2341 2 602 629 623
2342 1 632 629 602
2343 3 602 629 281
2344 2 602 629 327
2345 3 602 629 405
2346 1 632 629 623
2347 3 623 629 281
2348 2 623 629 327
2349 3 623 629 405
2350 4 632 629 281
2351 1 632 629 327
2352 4 632 629 405
2353 3 327 629 281
2354 5 281 629 405
2355 3 327 629 405
2356 6 632 630 634
2357 6 632 630 635
2358 6 632 630 656
2359 6 634 630 635
2360 6 634 630 656
2361 6 635 630 656
2362 7 664 631 633
2363 8 633 631 636
2364 8 633 631 403
2365 7 664 631 636
2366 7 664 631 403
2367 8 636 631 403
2368 10 599 632 629
2369 9 599 632 630
2370 9 629 632 630
2371 11 659 633 631
2372 11 367 633 631
2373 12 659 633 367
2374 13 630 634 325
2375 13 630 635 399
2376 14 631 636 650
2377 15 273 637 638
2378 15 397 637 638
2379 16 273 637 397
2380 4 592 639 627
2381 1 592 639 642
2382 1 592 639 653
2383 4 592 639 667
2384 1 592 639 529
2385 3 642 639 627
2386 3 653 639 627
2387 5 627 639 667
2388 3 529 639 627
2389 2 642 639 653
2390 3 642 639 667
2391 2 642 639 529
2392 3 653 639 667
2393 2 653 639 529
2394 3 529 639 667
2395 8 642 640 644
2396 8 642 640 645
2397 8 642 640 582
2398 8 644 640 645
2399 8 644 640 582
2400 8 645 640 582
2401 7 665 641 643
2402 7 646 641 643
2403 8 643 641 318
2404 17 665 641 646
2405 7 665 641 318
2406 7 646 641 318
2407 12 589 642 639
2408 11 589 642 640
2409 11 639 642 640
2410 11 609 643 641
2411 12 609 643 313
2412 11 313 643 641
2413 14 640 644 651
2414 14 640 645 661
2415 13 576 646 641
2416 16 619 647 659
2417 15 619 647 648
2418 15 659 647 648
2419 1 622 649 603
2420 2 603 649 652
2421 3 603 649 261
2422 3 603 649 553
2423 2 603 649 307
2424 1 622 649 652
2425 4 622 649 261
2426 4 622 649 553
2427 1 622 649 307
2428 3 652 649 261
2429 3 652 649 553
2430 2 652 649 307
2431 5 261 649 553
2432 3 307 649 261
2433 3 307 649 553
2434 8 636 650 652
2435 8 636 650 654
2436 8 636 650 655
2437 8 652 650 654
2438 8 652 650 655
2439 8 654 650 655
2440 8 644 651 653
2441 7 656 651 644
2442 7 551 651 644
2443 7 656 651 653
2444 7 551 651 653
2445 17 656 651 551
2446 12 619 652 649
2447 11 619 652 650
2448 11 649 652 650
2449 11 639 653 651
2450 12 639 653 515
2451 11 515 653 651
2452 14 650 654 305
2453 14 650 655 547
2454 13 630 656 651
2455 15 253 657 658
2456 15 545 657 658
2457 16 253 657 545
2458 3 612 659 607
2459 3 633 659 607
2460 5 607 659 647
2461 4 662 659 607
2462 3 341 659 607
2463 2 612 659 633
2464 3 612 659 647
2465 1 662 659 612
2466 2 612 659 341
2467 3 633 659 647
2468 1 662 659 633
2469 2 633 659 341
2470 4 662 659 647
2471 3 341 659 647
2472 1 662 659 341
2473 6 662 660 664
2474 6 662 660 665
2475 6 662 660 394
2476 6 664 660 665
2477 6 664 660 394
2478 6 665 660 394
2479 8 645 661 663
2480 8 645 661 666
2481 7 298 661 645
2482 8 663 661 666
2483 7 298 661 663
2484 7 298 661 666
2485 10 609 662 659
2486 9 609 662 660
2487 9 659 662 660
2488 11 589 663 661
2489 12 589 663 293
2490 11 293 663 661
2491 13 660 664 631
2492 13 660 665 641
2493 14 661 666 388
2494 16 599 667 639
2495 15 599 667 668
2496 15 639 667 668
Dihedrals
1 1 4 1 54 51
2 2 4 1 54 52
3 3 75 1 54 51
4 4 75 1 54 52
5 3 371 1 54 51
6 4 371 1 54 52
7 5 281 1 54 51
8 6 281 1 54 52
9 5 405 1 54 51
10 6 405 1 54 52
11 7 54 1 4 2
12 8 54 1 4 51
13 7 75 1 4 2
14 8 75 1 4 51
15 7 371 1 4 2
16 8 371 1 4 51
17 9 281 1 4 2
18 10 281 1 4 51
19 9 405 1 4 2
20 10 405 1 4 51
21 4 54 1 75 73
22 3 54 1 75 377
23 2 4 1 75 73
24 1 4 1 75 377
25 4 371 1 75 73
26 3 371 1 75 377
27 6 281 1 75 73
28 5 281 1 75 377
29 6 405 1 75 73
30 5 405 1 75 377
31 4 54 1 371 369
32 3 54 1 371 377
33 2 4 1 371 369
34 1 4 1 371 377
35 4 75 1 371 369
36 3 75 1 371 377
37 6 281 1 371 369
38 5 281 1 371 377
39 6 405 1 371 369
40 5 405 1 371 377
41 11 54 1 281 282
42 12 54 1 281 629
43 13 4 1 281 282
44 14 4 1 281 629
45 11 75 1 281 282
46 12 75 1 281 629
47 11 371 1 281 282
48 12 371 1 281 629
49 15 405 1 281 282
50 16 405 1 281 629
51 11 54 1 405 406
52 12 54 1 405 629
53 13 4 1 405 406
54 14 4 1 405 629
55 11 75 1 405 406
56 12 75 1 405 629
57 11 371 1 405 406
58 12 371 1 405 629
59 15 281 1 405 406
60 16 281 1 405 629
61 17 6 2 4 1
62 17 6 2 4 51
63 17 7 2 4 1
64 17 7 2 4 51
65 17 28 2 4 1
66 17 28 2 4 51
67 18 4 2 6 369
68 18 7 2 6 369
69 18 28 2 6 369
70 18 4 2 7 275
71 18 6 2 7 275
72 18 28 2 7 275
73 18 4 2 28 23
74 18 6 2 28 23
75 18 7 2 28 23
76 19 36 3 5 31
77 19 36 3 5 323
78 20 8 3 5 31
79 20 8 3 5 323
80 20 279 3 5 31
81 20 279 3 5 323
82 21 5 3 36 32
83 21 8 3 36 32
84 21 279 3 36 32
85 22 5 3 8 22
86 23 36 3 8 22
87 22 279 3 8 22
88 22 5 3 279 274
89 23 36 3 279 274
90 22 8 3 279 274
91 10 39 51 4 1
92 8 54 51 4 1
93 8 65 51 4 1
94 10 79 51 4 1
95 8 277 51 4 1
96 9 39 51 4 2
97 7 54 51 4 2
98 7 65 51 4 2
99 9 79 51 4 2
100 7 277 51 4 2
101 6 19 31 5 3
102 4 64 31 5 3
103 2 34 31 5 3
104 6 59 31 5 3
105 4 297 31 5 3
106 5 19 31 5 323
107 3 64 31 5 323
108 1 34 31 5 323
109 5 59 31 5 323
110 3 297 31 5 323
111 6 271 323 5 3
112 4 276 323 5 3
113 4 297 323 5 3
114 6 311 323 5 3
115 2 326 323 5 3
116 5 271 323 5 31
117 3 276 323 5 31
118 3 297 323 5 31
119 5 311 323 5 31
120 1 326 323 5 31
121 21 353 369 6 2
122 21 371 369 6 2
123 21 374 369 6 2
124 21 268 275 7 2
125 21 277 275 7 2
126 24 280 275 7 2
127 22 24 22 8 3
128 22 26 22 8 3
129 22 27 22 8 3
130 13 326 273 9 10
131 11 276 273 9 10
132 11 307 273 9 10
133 11 603 273 9 10
134 15 637 273 9 10
135 14 326 273 9 397
136 12 276 273 9 397
137 12 307 273 9 397
138 12 603 273 9 397
139 16 637 273 9 397
140 11 351 397 9 10
141 13 370 397 9 10
142 11 400 397 9 10
143 15 637 397 9 10
144 11 55 397 9 10
145 12 351 397 9 273
146 14 370 397 9 273
147 12 400 397 9 273
148 16 637 397 9 273
149 12 55 397 9 273
150 8 14 11 44 41
151 7 14 11 44 42
152 8 25 11 44 41
153 7 25 11 44 42
154 10 39 11 44 41
155 9 39 11 44 42
156 10 79 11 44 41
157 9 79 11 44 42
158 8 149 11 44 41
159 7 149 11 44 42
160 2 44 11 14 12
161 1 44 11 14 41
162 4 25 11 14 12
163 3 25 11 14 41
164 6 39 11 14 12
165 5 39 11 14 41
166 6 79 11 14 12
167 5 79 11 14 41
168 4 149 11 14 12
169 3 149 11 14 41
170 2 44 11 25 23
171 1 44 11 25 135
172 4 14 11 25 23
173 3 14 11 25 135
174 6 39 11 25 23
175 5 39 11 25 135
176 6 79 11 25 23
177 5 79 11 25 135
178 4 149 11 25 23
179 3 149 11 25 135
180 14 44 11 39 51
181 13 44 11 39 40
182 12 14 11 39 51
183 11 14 11 39 40
184 12 25 11 39 51
185 11 25 11 39 40
186 16 79 11 39 51
187 15 79 11 39 40
188 12 149 11 39 51
189 11 149 11 39 40
190 14 44 11 79 51
191 13 44 11 79 80
192 12 14 11 79 51
193 11 14 11 79 80
194 12 25 11 79 51
195 11 25 11 79 80
196 16 39 11 79 51
197 15 39 11 79 80
198 12 149 11 79 51
199 11 149 11 79 80
200 1 44 11 149 135
201 2 44 11 149 147
202 3 14 11 149 135
203 4 14 11 149 147
204 3 25 11 149 135
205 4 25 11 149 147
206 5 39 11 149 135
207 6 39 11 149 147
208 5 79 11 149 135
209 6 79 11 149 147
210 20 16 12 14 11
211 20 16 12 14 41
212 20 17 12 14 11
213 20 17 12 14 41
214 20 122 12 14 11
215 20 122 12 14 41
216 22 14 12 16 23
217 22 17 12 16 23
218 22 122 12 16 23
219 22 14 12 17 33
220 22 16 12 17 33
221 22 122 12 17 33
222 22 14 12 122 117
223 22 16 12 122 117
224 22 17 12 122 117
225 19 37 13 15 61
226 19 37 13 15 357
227 19 18 13 15 61
228 19 18 13 15 357
229 20 362 13 15 61
230 20 362 13 15 357
231 21 15 13 37 32
232 24 18 13 37 32
233 21 362 13 37 32
234 21 15 13 18 116
235 24 37 13 18 116
236 21 362 13 18 116
237 22 15 13 362 358
238 23 37 13 362 358
239 23 18 13 362 358
240 3 35 41 14 11
241 1 44 41 14 11
242 5 365 41 14 11
243 3 411 41 14 11
244 5 153 41 14 11
245 4 35 41 14 12
246 2 44 41 14 12
247 6 365 41 14 12
248 4 411 41 14 12
249 6 153 41 14 12
250 2 34 61 15 13
251 4 64 61 15 13
252 6 345 61 15 13
253 6 301 61 15 13
254 4 391 61 15 13
255 1 34 61 15 357
256 3 64 61 15 357
257 5 345 61 15 357
258 5 301 61 15 357
259 3 391 61 15 357
260 2 410 357 15 13
261 4 360 357 15 13
262 4 391 357 15 13
263 6 429 357 15 13
264 6 49 357 15 13
265 1 410 357 15 61
266 3 360 357 15 61
267 3 391 357 15 61
268 5 429 357 15 61
269 5 49 357 15 61
270 22 25 23 16 12
271 23 28 23 16 12
272 23 91 23 16 12
273 22 35 33 17 12
274 22 38 33 17 12
275 23 342 33 17 12
276 18 118 116 18 13
277 18 120 116 18 13
278 18 121 116 18 13
279 12 5 31 19 71
280 12 64 31 19 71
281 14 34 31 19 71
282 16 59 31 19 71
283 12 297 31 19 71
284 11 5 31 19 20
285 11 64 31 19 20
286 13 34 31 19 20
287 15 59 31 19 20
288 11 297 31 19 20
289 12 24 71 19 31
290 12 45 71 19 31
291 16 59 71 19 31
292 14 74 71 19 31
293 12 89 71 19 31
294 11 24 71 19 20
295 11 45 71 19 20
296 15 59 71 19 20
297 13 74 71 19 20
298 11 89 71 19 20
299 8 24 21 74 71
300 7 24 21 74 72
301 8 55 21 74 71
302 7 55 21 74 72
303 10 93 21 74 71
304 9 93 21 74 72
305 8 351 21 74 71
306 7 351 21 74 72
307 10 385 21 74 71
308 9 385 21 74 72
309 2 74 21 24 22
310 1 74 21 24 71
311 4 55 21 24 22
312 3 55 21 24 71
313 6 93 21 24 22
314 5 93 21 24 71
315 4 351 21 24 22
316 3 351 21 24 71
317 6 385 21 24 22
318 5 385 21 24 71
319 2 74 21 55 53
320 1 74 21 55 397
321 4 24 21 55 53
322 3 24 21 55 397
323 6 93 21 55 53
324 5 93 21 55 397
325 4 351 21 55 53
326 3 351 21 55 397
327 6 385 21 55 53
328 5 385 21 55 397
329 13 74 21 93 94
330 14 74 21 93 481
331 11 24 21 93 94
332 12 24 21 93 481
333 11 55 21 93 94
334 12 55 21 93 481
335 11 351 21 93 94
336 12 351 21 93 481
337 15 385 21 93 94
338 16 385 21 93 481
339 2 74 21 351 349
340 1 74 21 351 397
341 4 24 21 351 349
342 3 24 21 351 397
343 4 55 21 351 349
344 3 55 21 351 397
345 6 93 21 351 349
346 5 93 21 351 397
347 6 385 21 351 349
348 5 385 21 351 397
349 13 74 21 385 386
350 14 74 21 385 481
351 11 24 21 385 386
352 12 24 21 385 481
353 11 55 21 385 386
354 12 55 21 385 481
355 15 93 21 385 386
356 16 93 21 385 481
357 11 351 21 385 386
358 12 351 21 385 481
359 20 8 22 24 21
360 20 8 22 24 71
361 20 26 22 24 21
362 20 26 22 24 71
363 20 27 22 24 21
364 20 27 22 24 71
365 22 8 22 26 349
366 22 24 22 26 349
367 22 27 22 26 349
368 22 8 22 27 87
369 22 24 22 27 87
370 22 26 22 27 87
371 20 16 23 25 11
372 20 16 23 25 135
373 19 28 23 25 11
374 19 28 23 25 135
375 19 91 23 25 11
376 19 91 23 25 135
377 21 16 23 28 2
378 21 25 23 28 2
379 24 91 23 28 2
380 21 16 23 91 86
381 21 25 23 91 86
382 24 28 23 91 86
383 5 19 71 24 21
384 3 45 71 24 21
385 5 59 71 24 21
386 1 74 71 24 21
387 3 89 71 24 21
388 6 19 71 24 22
389 4 45 71 24 22
390 6 59 71 24 22
391 2 74 71 24 22
392 4 89 71 24 22
393 1 88 135 25 11
394 5 123 135 25 11
395 3 138 135 25 11
396 3 149 135 25 11
397 5 163 135 25 11
398 2 88 135 25 23
399 6 123 135 25 23
400 4 138 135 25 23
401 4 149 135 25 23
402 6 163 135 25 23
403 22 351 349 26 22
404 23 373 349 26 22
405 23 354 349 26 22
406 22 89 87 27 22
407 23 120 87 27 22
408 22 92 87 27 22
409 11 138 85 29 30
410 13 88 85 29 30
411 11 159 85 29 30
412 11 455 85 29 30
413 15 489 85 29 30
414 12 138 85 29 377
415 14 88 85 29 377
416 12 159 85 29 377
417 12 455 85 29 377
418 16 489 85 29 377
419 11 350 377 29 30
420 11 371 377 29 30
421 13 380 377 29 30
422 11 75 377 29 30
423 15 489 377 29 30
424 12 350 377 29 85
425 12 371 377 29 85
426 14 380 377 29 85
427 12 75 377 29 85
428 16 489 377 29 85
429 3 5 31 64 61
430 4 5 31 64 62
431 5 19 31 64 61
432 6 19 31 64 62
433 1 34 31 64 61
434 2 34 31 64 62
435 5 59 31 64 61
436 6 59 31 64 62
437 3 297 31 64 61
438 4 297 31 64 62
439 7 5 31 34 32
440 8 5 31 34 61
441 9 19 31 34 32
442 10 19 31 34 61
443 7 64 31 34 32
444 8 64 31 34 61
445 9 59 31 34 32
446 10 59 31 34 61
447 7 297 31 34 32
448 8 297 31 34 61
449 12 5 31 59 71
450 11 5 31 59 60
451 16 19 31 59 71
452 15 19 31 59 60
453 12 64 31 59 71
454 11 64 31 59 60
455 14 34 31 59 71
456 13 34 31 59 60
457 12 297 31 59 71
458 11 297 31 59 60
459 4 5 31 297 295
460 3 5 31 297 323
461 6 19 31 297 295
462 5 19 31 297 323
463 4 64 31 297 295
464 3 64 31 297 323
465 2 34 31 297 295
466 1 34 31 297 323
467 6 59 31 297 295
468 5 59 31 297 323
469 17 36 32 34 31
470 17 36 32 34 61
471 17 37 32 34 31
472 17 37 32 34 61
473 17 270 32 34 31
474 17 270 32 34 61
475 18 34 32 36 3
476 18 37 32 36 3
477 18 270 32 36 3
478 18 34 32 37 13
479 18 36 32 37 13
480 18 270 32 37 13
481 18 34 32 270 265
482 18 36 32 270 265
483 18 37 32 270 265
484 20 17 33 35 41
485 20 17 33 35 337
486 20 38 33 35 41
487 20 38 33 35 337
488 19 342 33 35 41
489 19 342 33 35 337
490 22 17 33 38 264
491 22 35 33 38 264
492 23 342 33 38 264
493 21 17 33 342 338
494 21 35 33 342 338
495 21 38 33 342 338
496 8 15 61 34 31
497 8 64 61 34 31
498 10 345 61 34 31
499 10 301 61 34 31
500 8 391 61 34 31
501 7 15 61 34 32
502 7 64 61 34 32
503 9 345 61 34 32
504 9 301 61 34 32
505 7 391 61 34 32
506 4 14 41 35 33
507 2 44 41 35 33
508 6 365 41 35 33
509 4 411 41 35 33
510 6 153 41 35 33
511 3 14 41 35 337
512 1 44 41 35 337
513 5 365 41 35 337
514 3 411 41 35 337
515 5 153 41 35 337
516 4 390 337 35 33
517 2 340 337 35 33
518 4 411 337 35 33
519 6 617 337 35 33
520 6 69 337 35 33
521 3 390 337 35 41
522 1 340 337 35 41
523 3 411 337 35 41
524 5 617 337 35 41
525 5 69 337 35 41
526 22 266 264 38 33
527 22 268 264 38 33
528 22 269 264 38 33
529 14 4 51 39 11
530 12 54 51 39 11
531 12 65 51 39 11
532 16 79 51 39 11
533 12 277 51 39 11
534 13 4 51 39 40
535 11 54 51 39 40
536 11 65 51 39 40
537 15 79 51 39 40
538 11 277 51 39 40
539 8 14 41 44 11
540 7 14 41 44 42
541 8 35 41 44 11
542 7 35 41 44 42
543 10 365 41 44 11
544 9 365 41 44 42
545 8 411 41 44 11
546 7 411 41 44 42
547 10 153 41 44 11
548 9 153 41 44 42
549 11 14 41 365 366
550 12 14 41 365 421
551 11 35 41 365 366
552 12 35 41 365 421
553 13 44 41 365 366
554 14 44 41 365 421
555 11 411 41 365 366
556 12 411 41 365 421
557 15 153 41 365 366
558 16 153 41 365 421
559 3 14 41 411 337
560 4 14 41 411 409
561 3 35 41 411 337
562 4 35 41 411 409
563 1 44 41 411 337
564 2 44 41 411 409
565 5 365 41 411 337
566 6 365 41 411 409
567 5 153 41 411 337
568 6 153 41 411 409
569 11 14 41 153 154
570 12 14 41 153 421
571 11 35 41 153 154
572 12 35 41 153 421
573 13 44 41 153 154
574 14 44 41 153 421
575 15 365 41 153 154
576 16 365 41 153 421
577 11 411 41 153 154
578 12 411 41 153 421
579 17 46 42 44 11
580 17 46 42 44 41
581 17 47 42 44 11
582 17 47 42 44 41
583 17 68 42 44 11
584 17 68 42 44 41
585 18 44 42 46 409
586 18 47 42 46 409
587 18 68 42 46 409
588 18 44 42 47 147
589 18 46 42 47 147
590 18 68 42 47 147
591 18 44 42 68 63
592 18 46 42 68 63
593 18 47 42 68 63
594 19 76 43 45 71
595 19 76 43 45 115
596 20 48 43 45 71
597 20 48 43 45 115
598 20 151 43 45 71
599 20 151 43 45 115
600 21 45 43 76 72
601 21 48 43 76 72
602 21 151 43 76 72
603 22 45 43 48 62
604 23 76 43 48 62
605 22 151 43 48 62
606 22 45 43 151 146
607 23 76 43 151 146
608 22 48 43 151 146
609 6 19 71 45 43
610 4 24 71 45 43
611 6 59 71 45 43
612 2 74 71 45 43
613 4 89 71 45 43
614 5 19 71 45 115
615 3 24 71 45 115
616 5 59 71 45 115
617 1 74 71 45 115
618 3 89 71 45 115
619 4 89 115 45 43
620 6 103 115 45 43
621 4 148 115 45 43
622 2 118 115 45 43
623 6 143 115 45 43
624 3 89 115 45 71
625 5 103 115 45 71
626 3 148 115 45 71
627 1 118 115 45 71
628 5 143 115 45 71
629 21 393 409 46 42
630 21 411 409 46 42
631 21 414 409 46 42
632 21 140 147 47 42
633 21 149 147 47 42
634 24 152 147 47 42
635 22 64 62 48 43
636 22 66 62 48 43
637 22 67 62 48 43
638 13 410 357 49 50
639 11 360 357 49 50
640 11 391 357 49 50
641 15 429 357 49 50
642 11 15 357 49 50
643 14 410 357 49 145
644 12 360 357 49 145
645 12 391 357 49 145
646 16 429 357 49 145
647 12 15 357 49 145
648 11 99 145 49 50
649 13 118 145 49 50
650 11 148 145 49 50
651 15 429 145 49 50
652 11 475 145 49 50
653 12 99 145 49 357
654 14 118 145 49 357
655 12 148 145 49 357
656 16 429 145 49 357
657 12 475 145 49 357
658 1 4 51 54 1
659 2 4 51 54 52
660 5 39 51 54 1
661 6 39 51 54 52
662 3 65 51 54 1
663 4 65 51 54 52
664 5 79 51 54 1
665 6 79 51 54 52
666 3 277 51 54 1
667 4 277 51 54 52
668 2 4 51 65 63
669 1 4 51 65 263
670 6 39 51 65 63
671 5 39 51 65 263
672 4 54 51 65 63
673 3 54 51 65 263
674 6 79 51 65 63
675 5 79 51 65 263
676 4 277 51 65 63
677 3 277 51 65 263
678 14 4 51 79 11
679 13 4 51 79 80
680 16 39 51 79 11
681 15 39 51 79 80
682 12 54 51 79 11
683 11 54 51 79 80
684 12 65 51 79 11
685 11 65 51 79 80
686 12 277 51 79 11
687 11 277 51 79 80
688 1 4 51 277 263
689 2 4 51 277 275
690 5 39 51 277 263
691 6 39 51 277 275
692 3 54 51 277 263
693 4 54 51 277 275
694 3 65 51 277 263
695 4 65 51 277 275
696 5 79 51 277 263
697 6 79 51 277 275
698 20 56 52 54 1
699 20 56 52 54 51
700 20 57 52 54 1
701 20 57 52 54 51
702 20 330 52 54 1
703 20 330 52 54 51
704 22 54 52 56 63
705 22 57 52 56 63
706 22 330 52 56 63
707 22 54 52 57 73
708 22 56 52 57 73
709 22 330 52 57 73
710 22 54 52 330 325
711 22 56 52 330 325
712 22 57 52 330 325
713 19 77 53 55 21
714 19 77 53 55 397
715 19 58 53 55 21
716 19 58 53 55 397
717 20 402 53 55 21
718 20 402 53 55 397
719 21 55 53 77 72
720 24 58 53 77 72
721 21 402 53 77 72
722 21 55 53 58 324
723 24 77 53 58 324
724 21 402 53 58 324
725 22 55 53 402 398
726 23 77 53 402 398
727 23 58 53 402 398
728 3 351 397 55 21
729 1 370 397 55 21
730 3 400 397 55 21
731 5 9 397 55 21
732 5 637 397 55 21
733 4 351 397 55 53
734 2 370 397 55 53
735 4 400 397 55 53
736 6 9 397 55 53
737 6 637 397 55 53
738 22 65 63 56 52
739 23 68 63 56 52
740 23 299 63 56 52
741 22 75 73 57 52
742 22 78 73 57 52
743 23 382 73 57 52
744 18 326 324 58 53
745 18 328 324 58 53
746 18 329 324 58 53
747 16 19 71 59 31
748 12 24 71 59 31
749 12 45 71 59 31
750 14 74 71 59 31
751 12 89 71 59 31
752 15 19 71 59 60
753 11 24 71 59 60
754 11 45 71 59 60
755 13 74 71 59 60
756 11 89 71 59 60
757 3 15 61 64 31
758 4 15 61 64 62
759 1 34 61 64 31
760 2 34 61 64 62
761 5 345 61 64 31
762 6 345 61 64 62
763 5 301 61 64 31
764 6 301 61 64 62
765 3 391 61 64 31
766 4 391 61 64 62
767 11 15 61 345 346
768 12 15 61 345 609
769 13 34 61 345 346
770 14 34 61 345 609
771 11 64 61 345 346
772 12 64 61 345 609
773 15 301 61 345 346
774 16 301 61 345 609
775 11 391 61 345 346
776 12 391 61 345 609
777 11 15 61 301 302
778 12 15 61 301 609
779 13 34 61 301 302
780 14 34 61 301 609
781 11 64 61 301 302
782 12 64 61 301 609
783 15 345 61 301 302
784 16 345 61 301 609
785 11 391 61 301 302
786 12 391 61 301 609
787 3 15 61 391 357
788 4 15 61 391 389
789 1 34 61 391 357
790 2 34 61 391 389
791 3 64 61 391 357
792 4 64 61 391 389
793 5 345 61 391 357
794 6 345 61 391 389
795 5 301 61 391 357
796 6 301 61 391 389
797 20 48 62 64 31
798 20 48 62 64 61
799 20 66 62 64 31
800 20 66 62 64 61
801 20 67 62 64 31
802 20 67 62 64 61
803 22 48 62 66 389
804 22 64 62 66 389
805 22 67 62 66 389
806 22 48 62 67 295
807 22 64 62 67 295
808 22 66 62 67 295
809 20 56 63 65 51
810 20 56 63 65 263
811 19 68 63 65 51
812 19 68 63 65 263
813 19 299 63 65 51
814 19 299 63 65 263
815 21 56 63 68 42
816 21 65 63 68 42
817 24 299 63 68 42
818 21 56 63 299 294
819 21 65 63 299 294
820 24 68 63 299 294
821 1 296 263 65 51
822 3 266 263 65 51
823 3 277 263 65 51
824 5 291 263 65 51
825 5 331 263 65 51
826 2 296 263 65 63
827 4 266 263 65 63
828 4 277 263 65 63
829 6 291 263 65 63
830 6 331 263 65 63
831 22 391 389 66 62
832 23 413 389 66 62
833 23 394 389 66 62
834 22 297 295 67 62
835 23 328 295 67 62
836 22 300 295 67 62
837 11 390 337 69 70
838 13 340 337 69 70
839 11 411 337 69 70
840 11 35 337 69 70
841 15 617 337 69 70
842 12 390 337 69 293
843 14 340 337 69 293
844 12 411 337 69 293
845 12 35 337 69 293
846 16 617 337 69 293
847 11 266 293 69 70
848 11 287 293 69 70
849 13 296 293 69 70
850 15 617 293 69 70
851 11 663 293 69 70
852 12 266 293 69 337
853 12 287 293 69 337
854 14 296 293 69 337
855 16 617 293 69 337
856 12 663 293 69 337
857 10 19 71 74 21
858 9 19 71 74 72
859 8 24 71 74 21
860 7 24 71 74 72
861 8 45 71 74 21
862 7 45 71 74 72
863 10 59 71 74 21
864 9 59 71 74 72
865 8 89 71 74 21
866 7 89 71 74 72
867 6 19 71 89 87
868 5 19 71 89 115
869 4 24 71 89 87
870 3 24 71 89 115
871 4 45 71 89 87
872 3 45 71 89 115
873 6 59 71 89 87
874 5 59 71 89 115
875 2 74 71 89 87
876 1 74 71 89 115
877 17 76 72 74 21
878 17 76 72 74 71
879 17 77 72 74 21
880 17 77 72 74 71
881 17 142 72 74 21
882 17 142 72 74 71
883 18 74 72 76 43
884 18 77 72 76 43
885 18 142 72 76 43
886 18 74 72 77 53
887 18 76 72 77 53
888 18 142 72 77 53
889 18 74 72 142 137
890 18 76 72 142 137
891 18 77 72 142 137
892 20 57 73 75 1
893 20 57 73 75 377
894 20 78 73 75 1
895 20 78 73 75 377
896 19 382 73 75 1
897 19 382 73 75 377
898 22 57 73 78 136
899 22 75 73 78 136
900 23 382 73 78 136
901 21 57 73 382 378
902 21 75 73 382 378
903 21 78 73 382 378
904 3 350 377 75 1
905 3 371 377 75 1
906 1 380 377 75 1
907 5 29 377 75 1
908 5 489 377 75 1
909 4 350 377 75 73
910 4 371 377 75 73
911 2 380 377 75 73
912 6 29 377 75 73
913 6 489 377 75 73
914 22 138 136 78 73
915 22 140 136 78 73
916 22 141 136 78 73
917 1 88 85 138 135
918 2 88 85 138 136
919 3 159 85 138 135
920 4 159 85 138 136
921 3 455 85 138 135
922 4 455 85 138 136
923 5 29 85 138 135
924 6 29 85 138 136
925 5 489 85 138 135
926 6 489 85 138 136
927 7 138 85 88 86
928 8 138 85 88 135
929 7 159 85 88 86
930 8 159 85 88 135
931 7 455 85 88 86
932 8 455 85 88 135
933 9 29 85 88 86
934 10 29 85 88 135
935 9 489 85 88 86
936 10 489 85 88 135
937 4 138 85 159 157
938 3 138 85 159 461
939 2 88 85 159 157
940 1 88 85 159 461
941 4 455 85 159 157
942 3 455 85 159 461
943 6 29 85 159 157
944 5 29 85 159 461
945 6 489 85 159 157
946 5 489 85 159 461
947 4 138 85 455 453
948 3 138 85 455 461
949 2 88 85 455 453
950 1 88 85 455 461
951 4 159 85 455 453
952 3 159 85 455 461
953 6 29 85 455 453
954 5 29 85 455 461
955 6 489 85 455 453
956 5 489 85 455 461
957 11 138 85 489 490
958 12 138 85 489 377
959 13 88 85 489 490
960 14 88 85 489 377
961 11 159 85 489 490
962 12 159 85 489 377
963 11 455 85 489 490
964 12 455 85 489 377
965 15 29 85 489 490
966 16 29 85 489 377
967 17 90 86 88 85
968 17 90 86 88 135
969 17 91 86 88 85
970 17 91 86 88 135
971 17 112 86 88 85
972 17 112 86 88 135
973 18 88 86 90 453
974 18 91 86 90 453
975 18 112 86 90 453
976 18 88 86 91 23
977 18 90 86 91 23
978 18 112 86 91 23
979 18 88 86 112 107
980 18 90 86 112 107
981 18 91 86 112 107
982 19 120 87 89 115
983 19 120 87 89 71
984 20 92 87 89 115
985 20 92 87 89 71
986 20 27 87 89 115
987 20 27 87 89 71
988 21 89 87 120 116
989 21 92 87 120 116
990 21 27 87 120 116
991 22 89 87 92 106
992 23 120 87 92 106
993 22 27 87 92 106
994 10 123 135 88 85
995 8 138 135 88 85
996 8 149 135 88 85
997 10 163 135 88 85
998 8 25 135 88 85
999 9 123 135 88 86
1000 7 138 135 88 86
1001 7 149 135 88 86
1002 9 163 135 88 86
1003 7 25 135 88 86
1004 6 103 115 89 87
1005 4 148 115 89 87
1006 2 118 115 89 87
1007 6 143 115 89 87
1008 4 45 115 89 87
1009 5 103 115 89 71
1010 3 148 115 89 71
1011 1 118 115 89 71
1012 5 143 115 89 71
1013 3 45 115 89 71
1014 21 437 453 90 86
1015 21 455 453 90 86
1016 21 458 453 90 86
1017 22 108 106 92 87
1018 22 110 106 92 87
1019 22 111 106 92 87
1020 11 435 481 93 94
1021 13 454 481 93 94
1022 11 484 481 93 94
1023 15 385 481 93 94
1024 11 139 481 93 94
1025 12 435 481 93 21
1026 14 454 481 93 21
1027 12 484 481 93 21
1028 16 385 481 93 21
1029 12 139 481 93 21
1030 8 98 95 128 125
1031 7 98 95 128 126
1032 8 109 95 128 125
1033 7 109 95 128 126
1034 10 123 95 128 125
1035 9 123 95 128 126
1036 10 163 95 128 125
1037 9 163 95 128 126
1038 8 233 95 128 125
1039 7 233 95 128 126
1040 2 128 95 98 96
1041 1 128 95 98 125
1042 4 109 95 98 96
1043 3 109 95 98 125
1044 6 123 95 98 96
1045 5 123 95 98 125
1046 6 163 95 98 96
1047 5 163 95 98 125
1048 4 233 95 98 96
1049 3 233 95 98 125
1050 2 128 95 109 107
1051 1 128 95 109 219
1052 4 98 95 109 107
1053 3 98 95 109 219
1054 6 123 95 109 107
1055 5 123 95 109 219
1056 6 163 95 109 107
1057 5 163 95 109 219
1058 4 233 95 109 107
1059 3 233 95 109 219
1060 14 128 95 123 135
1061 13 128 95 123 124
1062 12 98 95 123 135
1063 11 98 95 123 124
1064 12 109 95 123 135
1065 11 109 95 123 124
1066 16 163 95 123 135
1067 15 163 95 123 124
1068 12 233 95 123 135
1069 11 233 95 123 124
1070 14 128 95 163 135
1071 13 128 95 163 164
1072 12 98 95 163 135
1073 11 98 95 163 164
1074 12 109 95 163 135
1075 11 109 95 163 164
1076 16 123 95 163 135
1077 15 123 95 163 164
1078 12 233 95 163 135
1079 11 233 95 163 164
1080 1 128 95 233 219
1081 2 128 95 233 231
1082 3 98 95 233 219
1083 4 98 95 233 231
1084 3 109 95 233 219
1085 4 109 95 233 231
1086 5 123 95 233 219
1087 6 123 95 233 231
1088 5 163 95 233 219
1089 6 163 95 233 231
1090 20 100 96 98 95
1091 20 100 96 98 125
1092 20 101 96 98 95
1093 20 101 96 98 125
1094 20 206 96 98 95
1095 20 206 96 98 125
1096 22 98 96 100 107
1097 22 101 96 100 107
1098 22 206 96 100 107
1099 22 98 96 101 117
1100 22 100 96 101 117
1101 22 206 96 101 117
1102 22 98 96 206 201
1103 22 100 96 206 201
1104 22 101 96 206 201
1105 19 121 97 99 145
1106 19 121 97 99 441
1107 19 102 97 99 145
1108 19 102 97 99 441
1109 20 446 97 99 145
1110 20 446 97 99 441
1111 21 99 97 121 116
1112 24 102 97 121 116
1113 21 446 97 121 116
1114 21 99 97 102 200
1115 24 121 97 102 200
1116 21 446 97 102 200
1117 22 99 97 446 442
1118 23 121 97 446 442
1119 23 102 97 446 442
1120 3 119 125 98 95
1121 1 128 125 98 95
1122 5 449 125 98 95
1123 3 495 125 98 95
1124 5 237 125 98 95
1125 4 119 125 98 96
1126 2 128 125 98 96
1127 6 449 125 98 96
1128 4 495 125 98 96
1129 6 237 125 98 96
1130 2 118 145 99 97
1131 4 148 145 99 97
1132 6 429 145 99 97
1133 6 49 145 99 97
1134 4 475 145 99 97
1135 1 118 145 99 441
1136 3 148 145 99 441
1137 5 429 145 99 441
1138 5 49 145 99 441
1139 3 475 145 99 441
1140 2 494 441 99 97
1141 4 444 441 99 97
1142 4 475 441 99 97
1143 6 513 441 99 97
1144 6 133 441 99 97
1145 1 494 441 99 145
1146 3 444 441 99 145
1147 3 475 441 99 145
1148 5 513 441 99 145
1149 5 133 441 99 145
1150 22 109 107 100 96
1151 23 112 107 100 96
1152 23 175 107 100 96
1153 22 119 117 101 96
1154 22 122 117 101 96
1155 23 426 117 101 96
1156 18 202 200 102 97
1157 18 204 200 102 97
1158 18 205 200 102 97
1159 12 89 115 103 155
1160 12 148 115 103 155
1161 14 118 115 103 155
1162 16 143 115 103 155
1163 12 45 115 103 155
1164 11 89 115 103 104
1165 11 148 115 103 104
1166 13 118 115 103 104
1167 15 143 115 103 104
1168 11 45 115 103 104
1169 12 108 155 103 115
1170 12 129 155 103 115
1171 16 143 155 103 115
1172 14 158 155 103 115
1173 12 173 155 103 115
1174 11 108 155 103 104
1175 11 129 155 103 104
1176 15 143 155 103 104
1177 13 158 155 103 104
1178 11 173 155 103 104
1179 8 108 105 158 155
1180 7 108 105 158 156
1181 8 139 105 158 155
1182 7 139 105 158 156
1183 10 177 105 158 155
1184 9 177 105 158 156
1185 8 435 105 158 155
1186 7 435 105 158 156
1187 10 469 105 158 155
1188 9 469 105 158 156
1189 2 158 105 108 106
1190 1 158 105 108 155
1191 4 139 105 108 106
1192 3 139 105 108 155
1193 6 177 105 108 106
1194 5 177 105 108 155
1195 4 435 105 108 106
1196 3 435 105 108 155
1197 6 469 105 108 106
1198 5 469 105 108 155
1199 2 158 105 139 137
1200 1 158 105 139 481
1201 4 108 105 139 137
1202 3 108 105 139 481
1203 6 177 105 139 137
1204 5 177 105 139 481
1205 4 435 105 139 137
1206 3 435 105 139 481
1207 6 469 105 139 137
1208 5 469 105 139 481
1209 13 158 105 177 178
1210 14 158 105 177 565
1211 11 108 105 177 178
1212 12 108 105 177 565
1213 11 139 105 177 178
1214 12 139 105 177 565
1215 11 435 105 177 178
1216 12 435 105 177 565
1217 15 469 105 177 178
1218 16 469 105 177 565
1219 2 158 105 435 433
1220 1 158 105 435 481
1221 4 108 105 435 433
1222 3 108 105 435 481
1223 4 139 105 435 433
1224 3 139 105 435 481
1225 6 177 105 435 433
1226 5 177 105 435 481
1227 6 469 105 435 433
1228 5 469 105 435 481
1229 13 158 105 469 470
1230 14 158 105 469 565
1231 11 108 105 469 470
1232 12 108 105 469 565
1233 11 139 105 469 470
1234 12 139 105 469 565
1235 15 177 105 469 470
1236 16 177 105 469 565
1237 11 435 105 469 470
1238 12 435 105 469 565
1239 20 92 106 108 105
1240 20 92 106 108 155
1241 20 110 106 108 105
1242 20 110 106 108 155
1243 20 111 106 108 105
1244 20 111 106 108 155
1245 22 92 106 110 433
1246 22 108 106 110 433
1247 22 111 106 110 433
1248 22 92 106 111 171
1249 22 108 106 111 171
1250 22 110 106 111 171
1251 20 100 107 109 95
1252 20 100 107 109 219
1253 19 112 107 109 95
1254 19 112 107 109 219
1255 19 175 107 109 95
1256 19 175 107 109 219
1257 21 100 107 112 86
1258 21 109 107 112 86
1259 24 175 107 112 86
1260 21 100 107 175 170
1261 21 109 107 175 170
1262 24 112 107 175 170
1263 5 103 155 108 105
1264 3 129 155 108 105
1265 5 143 155 108 105
1266 1 158 155 108 105
1267 3 173 155 108 105
1268 6 103 155 108 106
1269 4 129 155 108 106
1270 6 143 155 108 106
1271 2 158 155 108 106
1272 4 173 155 108 106
1273 1 172 219 109 95
1274 5 207 219 109 95
1275 3 222 219 109 95
1276 3 233 219 109 95
1277 5 247 219 109 95
1278 2 172 219 109 107
1279 6 207 219 109 107
1280 4 222 219 109 107
1281 4 233 219 109 107
1282 6 247 219 109 107
1283 22 435 433 110 106
1284 23 457 433 110 106
1285 23 438 433 110 106
1286 22 173 171 111 106
1287 23 204 171 111 106
1288 22 176 171 111 106
1289 11 222 169 113 114
1290 13 172 169 113 114
1291 11 243 169 113 114
1292 11 539 169 113 114
1293 15 573 169 113 114
1294 12 222 169 113 461
1295 14 172 169 113 461
1296 12 243 169 113 461
1297 12 539 169 113 461
1298 16 573 169 113 461
1299 11 434 461 113 114
1300 11 455 461 113 114
1301 13 464 461 113 114
1302 11 159 461 113 114
1303 15 573 461 113 114
1304 12 434 461 113 169
1305 12 455 461 113 169
1306 14 464 461 113 169
1307 12 159 461 113 169
1308 16 573 461 113 169
1309 3 89 115 148 145
1310 4 89 115 148 146
1311 5 103 115 148 145
1312 6 103 115 148 146
1313 1 118 115 148 145
1314 2 118 115 148 146
1315 5 143 115 148 145
1316 6 143 115 148 146
1317 3 45 115 148 145
1318 4 45 115 148 146
1319 7 89 115 118 116
1320 8 89 115 118 145
1321 9 103 115 118 116
1322 10 103 115 118 145
1323 7 148 115 118 116
1324 8 148 115 118 145
1325 9 143 115 118 116
1326 10 143 115 118 145
1327 7 45 115 118 116
1328 8 45 115 118 145
1329 12 89 115 143 155
1330 11 89 115 143 144
1331 16 103 115 143 155
1332 15 103 115 143 144
1333 12 148 115 143 155
1334 11 148 115 143 144
1335 14 118 115 143 155
1336 13 118 115 143 144
1337 12 45 115 143 155
1338 11 45 115 143 144
1339 17 120 116 118 115
1340 17 120 116 118 145
1341 17 121 116 118 115
1342 17 121 116 118 145
1343 17 18 116 118 115
1344 17 18 116 118 145
1345 18 118 116 120 87
1346 18 121 116 120 87
1347 18 18 116 120 87
1348 18 118 116 121 97
1349 18 120 116 121 97
1350 18 18 116 121 97
1351 20 101 117 119 125
1352 20 101 117 119 421
1353 20 122 117 119 125
1354 20 122 117 119 421
1355 19 426 117 119 125
1356 19 426 117 119 421
1357 22 101 117 122 12
1358 22 119 117 122 12
1359 23 426 117 122 12
1360 21 101 117 426 422
1361 21 119 117 426 422
1362 21 122 117 426 422
1363 8 99 145 118 115
1364 8 148 145 118 115
1365 10 429 145 118 115
1366 10 49 145 118 115
1367 8 475 145 118 115
1368 7 99 145 118 116
1369 7 148 145 118 116
1370 9 429 145 118 116
1371 9 49 145 118 116
1372 7 475 145 118 116
1373 4 98 125 119 117
1374 2 128 125 119 117
1375 6 449 125 119 117
1376 4 495 125 119 117
1377 6 237 125 119 117
1378 3 98 125 119 421
1379 1 128 125 119 421
1380 5 449 125 119 421
1381 3 495 125 119 421
1382 5 237 125 119 421
1383 4 474 421 119 117
1384 2 424 421 119 117
1385 4 495 421 119 117
1386 6 365 421 119 117
1387 6 153 421 119 117
1388 3 474 421 119 125
1389 1 424 421 119 125
1390 3 495 421 119 125
1391 5 365 421 119 125
1392 5 153 421 119 125
1393 14 88 135 123 95
1394 12 138 135 123 95
1395 12 149 135 123 95
1396 16 163 135 123 95
1397 12 25 135 123 95
1398 13 88 135 123 124
1399 11 138 135 123 124
1400 11 149 135 123 124
1401 15 163 135 123 124
1402 11 25 135 123 124
1403 8 98 125 128 95
1404 7 98 125 128 126
1405 8 119 125 128 95
1406 7 119 125 128 126
1407 10 449 125 128 95
1408 9 449 125 128 126
1409 8 495 125 128 95
1410 7 495 125 128 126
1411 10 237 125 128 95
1412 9 237 125 128 126
1413 11 98 125 449 450
1414 12 98 125 449 505
1415 11 119 125 449 450
1416 12 119 125 449 505
1417 13 128 125 449 450
1418 14 128 125 449 505
1419 11 495 125 449 450
1420 12 495 125 449 505
1421 15 237 125 449 450
1422 16 237 125 449 505
1423 3 98 125 495 421
1424 4 98 125 495 493
1425 3 119 125 495 421
1426 4 119 125 495 493
1427 1 128 125 495 421
1428 2 128 125 495 493
1429 5 449 125 495 421
1430 6 449 125 495 493
1431 5 237 125 495 421
1432 6 237 125 495 493
1433 11 98 125 237 238
1434 12 98 125 237 505
1435 11 119 125 237 238
1436 12 119 125 237 505
1437 13 128 125 237 238
1438 14 128 125 237 505
1439 15 449 125 237 238
1440 16 449 125 237 505
1441 11 495 125 237 238
1442 12 495 125 237 505
1443 17 130 126 128 95
1444 17 130 126 128 125
1445 17 131 126 128 95
1446 17 131 126 128 125
1447 17 152 126 128 95
1448 17 152 126 128 125
1449 18 128 126 130 493
1450 18 131 126 130 493
1451 18 152 126 130 493
1452 18 128 126 131 231
1453 18 130 126 131 231
1454 18 152 126 131 231
1455 18 128 126 152 147
1456 18 130 126 152 147
1457 18 131 126 152 147
1458 19 160 127 129 155
1459 19 160 127 129 199
1460 20 132 127 129 155
1461 20 132 127 129 199
1462 20 235 127 129 155
1463 20 235 127 129 199
1464 21 129 127 160 156
1465 21 132 127 160 156
1466 21 235 127 160 156
1467 22 129 127 132 146
1468 23 160 127 132 146
1469 22 235 127 132 146
1470 22 129 127 235 230
1471 23 160 127 235 230
1472 22 132 127 235 230
1473 6 103 155 129 127
1474 4 108 155 129 127
1475 6 143 155 129 127
1476 2 158 155 129 127
1477 4 173 155 129 127
1478 5 103 155 129 199
1479 3 108 155 129 199
1480 5 143 155 129 199
1481 1 158 155 129 199
1482 3 173 155 129 199
1483 4 173 199 129 127
1484 6 187 199 129 127
1485 4 232 199 129 127
1486 2 202 199 129 127
1487 6 227 199 129 127
1488 3 173 199 129 155
1489 5 187 199 129 155
1490 3 232 199 129 155
1491 1 202 199 129 155
1492 5 227 199 129 155
1493 21 477 493 130 126
1494 21 495 493 130 126
1495 21 498 493 130 126
1496 21 224 231 131 126
1497 21 233 231 131 126
1498 24 236 231 131 126
1499 22 148 146 132 127
1500 22 150 146 132 127
1501 22 151 146 132 127
1502 13 494 441 133 134
1503 11 444 441 133 134
1504 11 475 441 133 134
1505 15 513 441 133 134
1506 11 99 441 133 134
1507 14 494 441 133 229
1508 12 444 441 133 229
1509 12 475 441 133 229
1510 16 513 441 133 229
1511 12 99 441 133 229
1512 11 183 229 133 134
1513 13 202 229 133 134
1514 11 232 229 133 134
1515 15 513 229 133 134
1516 11 559 229 133 134
1517 12 183 229 133 441
1518 14 202 229 133 441
1519 12 232 229 133 441
1520 16 513 229 133 441
1521 12 559 229 133 441
1522 1 88 135 138 85
1523 2 88 135 138 136
1524 5 123 135 138 85
1525 6 123 135 138 136
1526 3 149 135 138 85
1527 4 149 135 138 136
1528 5 163 135 138 85
1529 6 163 135 138 136
1530 3 25 135 138 85
1531 4 25 135 138 136
1532 2 88 135 149 147
1533 1 88 135 149 11
1534 6 123 135 149 147
1535 5 123 135 149 11
1536 4 138 135 149 147
1537 3 138 135 149 11
1538 6 163 135 149 147
1539 5 163 135 149 11
1540 4 25 135 149 147
1541 3 25 135 149 11
1542 14 88 135 163 95
1543 13 88 135 163 164
1544 16 123 135 163 95
1545 15 123 135 163 164
1546 12 138 135 163 95
1547 11 138 135 163 164
1548 12 149 135 163 95
1549 11 149 135 163 164
1550 12 25 135 163 95
1551 11 25 135 163 164
1552 20 140 136 138 85
1553 20 140 136 138 135
1554 20 141 136 138 85
1555 20 141 136 138 135
1556 20 78 136 138 85
1557 20 78 136 138 135
1558 22 138 136 140 147
1559 22 141 136 140 147
1560 22 78 136 140 147
1561 22 138 136 141 157
1562 22 140 136 141 157
1563 22 78 136 141 157
1564 19 161 137 139 105
1565 19 161 137 139 481
1566 19 142 137 139 105
1567 19 142 137 139 481
1568 20 486 137 139 105
1569 20 486 137 139 481
1570 21 139 137 161 156
1571 24 142 137 161 156
1572 21 486 137 161 156
1573 21 139 137 142 72
1574 24 161 137 142 72
1575 21 486 137 142 72
1576 22 139 137 486 482
1577 23 161 137 486 482
1578 23 142 137 486 482
1579 3 435 481 139 105
1580 1 454 481 139 105
1581 3 484 481 139 105
1582 5 93 481 139 105
1583 5 385 481 139 105
1584 4 435 481 139 137
1585 2 454 481 139 137
1586 4 484 481 139 137
1587 6 93 481 139 137
1588 6 385 481 139 137
1589 22 149 147 140 136
1590 23 152 147 140 136
1591 23 47 147 140 136
1592 22 159 157 141 136
1593 22 162 157 141 136
1594 23 466 157 141 136
1595 16 103 155 143 115
1596 12 108 155 143 115
1597 12 129 155 143 115
1598 14 158 155 143 115
1599 12 173 155 143 115
1600 15 103 155 143 144
1601 11 108 155 143 144
1602 11 129 155 143 144
1603 13 158 155 143 144
1604 11 173 155 143 144
1605 3 99 145 148 115
1606 4 99 145 148 146
1607 1 118 145 148 115
1608 2 118 145 148 146
1609 5 429 145 148 115
1610 6 429 145 148 146
1611 5 49 145 148 115
1612 6 49 145 148 146
1613 3 475 145 148 115
1614 4 475 145 148 146
1615 11 99 145 429 430
1616 12 99 145 429 357
1617 13 118 145 429 430
1618 14 118 145 429 357
1619 11 148 145 429 430
1620 12 148 145 429 357
1621 15 49 145 429 430
1622 16 49 145 429 357
1623 11 475 145 429 430
1624 12 475 145 429 357
1625 3 99 145 475 441
1626 4 99 145 475 473
1627 1 118 145 475 441
1628 2 118 145 475 473
1629 3 148 145 475 441
1630 4 148 145 475 473
1631 5 429 145 475 441
1632 6 429 145 475 473
1633 5 49 145 475 441
1634 6 49 145 475 473
1635 20 132 146 148 115
1636 20 132 146 148 145
1637 20 150 146 148 115
1638 20 150 146 148 145
1639 20 151 146 148 115
1640 20 151 146 148 145
1641 22 132 146 150 473
1642 22 148 146 150 473
1643 22 151 146 150 473
1644 22 132 146 151 43
1645 22 148 146 151 43
1646 22 150 146 151 43
1647 20 140 147 149 135
1648 20 140 147 149 11
1649 19 152 147 149 135
1650 19 152 147 149 11
1651 19 47 147 149 135
1652 19 47 147 149 11
1653 21 140 147 152 126
1654 21 149 147 152 126
1655 24 47 147 152 126
1656 22 475 473 150 146
1657 23 497 473 150 146
1658 23 478 473 150 146
1659 11 474 421 153 154
1660 13 424 421 153 154
1661 11 495 421 153 154
1662 11 119 421 153 154
1663 15 365 421 153 154
1664 12 474 421 153 41
1665 14 424 421 153 41
1666 12 495 421 153 41
1667 12 119 421 153 41
1668 16 365 421 153 41
1669 10 103 155 158 105
1670 9 103 155 158 156
1671 8 108 155 158 105
1672 7 108 155 158 156
1673 8 129 155 158 105
1674 7 129 155 158 156
1675 10 143 155 158 105
1676 9 143 155 158 156
1677 8 173 155 158 105
1678 7 173 155 158 156
1679 6 103 155 173 171
1680 5 103 155 173 199
1681 4 108 155 173 171
1682 3 108 155 173 199
1683 4 129 155 173 171
1684 3 129 155 173 199
1685 6 143 155 173 171
1686 5 143 155 173 199
1687 2 158 155 173 171
1688 1 158 155 173 199
1689 17 160 156 158 105
1690 17 160 156 158 155
1691 17 161 156 158 105
1692 17 161 156 158 155
1693 17 226 156 158 105
1694 17 226 156 158 155
1695 18 158 156 160 127
1696 18 161 156 160 127
1697 18 226 156 160 127
1698 18 158 156 161 137
1699 18 160 156 161 137
1700 18 226 156 161 137
1701 18 158 156 226 221
1702 18 160 156 226 221
1703 18 161 156 226 221
1704 20 141 157 159 85
1705 20 141 157 159 461
1706 20 162 157 159 85
1707 20 162 157 159 461
1708 19 466 157 159 85
1709 19 466 157 159 461
1710 22 141 157 162 220
1711 22 159 157 162 220
1712 23 466 157 162 220
1713 21 141 157 466 462
1714 21 159 157 466 462
1715 21 162 157 466 462
1716 3 434 461 159 85
1717 3 455 461 159 85
1718 1 464 461 159 85
1719 5 113 461 159 85
1720 5 573 461 159 85
1721 4 434 461 159 157
1722 4 455 461 159 157
1723 2 464 461 159 157
1724 6 113 461 159 157
1725 6 573 461 159 157
1726 22 222 220 162 157
1727 22 224 220 162 157
1728 22 225 220 162 157
1729 1 172 169 222 219
1730 2 172 169 222 220
1731 3 243 169 222 219
1732 4 243 169 222 220
1733 3 539 169 222 219
1734 4 539 169 222 220
1735 5 113 169 222 219
1736 6 113 169 222 220
1737 5 573 169 222 219
1738 6 573 169 222 220
1739 7 222 169 172 170
1740 8 222 169 172 219
1741 7 243 169 172 170
1742 8 243 169 172 219
1743 7 539 169 172 170
1744 8 539 169 172 219
1745 9 113 169 172 170
1746 10 113 169 172 219
1747 9 573 169 172 170
1748 10 573 169 172 219
1749 4 222 169 243 241
1750 3 222 169 243 545
1751 2 172 169 243 241
1752 1 172 169 243 545
1753 4 539 169 243 241
1754 3 539 169 243 545
1755 6 113 169 243 241
1756 5 113 169 243 545
1757 6 573 169 243 241
1758 5 573 169 243 545
1759 4 222 169 539 537
1760 3 222 169 539 545
1761 2 172 169 539 537
1762 1 172 169 539 545
1763 4 243 169 539 537
1764 3 243 169 539 545
1765 6 113 169 539 537
1766 5 113 169 539 545
1767 6 573 169 539 537
1768 5 573 169 539 545
1769 11 222 169 573 574
1770 12 222 169 573 461
1771 13 172 169 573 574
1772 14 172 169 573 461
1773 11 243 169 573 574
1774 12 243 169 573 461
1775 11 539 169 573 574
1776 12 539 169 573 461
1777 15 113 169 573 574
1778 16 113 169 573 461
1779 17 174 170 172 169
1780 17 174 170 172 219
1781 17 175 170 172 169
1782 17 175 170 172 219
1783 17 196 170 172 169
1784 17 196 170 172 219
1785 18 172 170 174 537
1786 18 175 170 174 537
1787 18 196 170 174 537
1788 18 172 170 175 107
1789 18 174 170 175 107
1790 18 196 170 175 107
1791 18 172 170 196 191
1792 18 174 170 196 191
1793 18 175 170 196 191
1794 19 204 171 173 199
1795 19 204 171 173 155
1796 20 176 171 173 199
1797 20 176 171 173 155
1798 20 111 171 173 199
1799 20 111 171 173 155
1800 21 173 171 204 200
1801 21 176 171 204 200
1802 21 111 171 204 200
1803 22 173 171 176 190
1804 23 204 171 176 190
1805 22 111 171 176 190
1806 10 207 219 172 169
1807 8 222 219 172 169
1808 8 233 219 172 169
1809 10 247 219 172 169
1810 8 109 219 172 169
1811 9 207 219 172 170
1812 7 222 219 172 170
1813 7 233 219 172 170
1814 9 247 219 172 170
1815 7 109 219 172 170
1816 6 187 199 173 171
1817 4 232 199 173 171
1818 2 202 199 173 171
1819 6 227 199 173 171
1820 4 129 199 173 171
1821 5 187 199 173 155
1822 3 232 199 173 155
1823 1 202 199 173 155
1824 5 227 199 173 155
1825 3 129 199 173 155
1826 21 521 537 174 170
1827 21 539 537 174 170
1828 21 542 537 174 170
1829 22 192 190 176 171
1830 22 194 190 176 171
1831 22 195 190 176 171
1832 11 519 565 177 178
1833 13 538 565 177 178
1834 11 568 565 177 178
1835 15 469 565 177 178
1836 11 223 565 177 178
1837 12 519 565 177 105
1838 14 538 565 177 105
1839 12 568 565 177 105
1840 16 469 565 177 105
1841 12 223 565 177 105
1842 8 182 179 212 209
1843 7 182 179 212 210
1844 8 193 179 212 209
1845 7 193 179 212 210
1846 10 207 179 212 209
1847 9 207 179 212 210
1848 10 247 179 212 209
1849 9 247 179 212 210
1850 8 317 179 212 209
1851 7 317 179 212 210
1852 2 212 179 182 180
1853 1 212 179 182 209
1854 4 193 179 182 180
1855 3 193 179 182 209
1856 6 207 179 182 180
1857 5 207 179 182 209
1858 6 247 179 182 180
1859 5 247 179 182 209
1860 4 317 179 182 180
1861 3 317 179 182 209
1862 2 212 179 193 191
1863 1 212 179 193 303
1864 4 182 179 193 191
1865 3 182 179 193 303
1866 6 207 179 193 191
1867 5 207 179 193 303
1868 6 247 179 193 191
1869 5 247 179 193 303
1870 4 317 179 193 191
1871 3 317 179 193 303
1872 14 212 179 207 219
1873 13 212 179 207 208
1874 12 182 179 207 219
1875 11 182 179 207 208
1876 12 193 179 207 219
1877 11 193 179 207 208
1878 16 247 179 207 219
1879 15 247 179 207 208
1880 12 317 179 207 219
1881 11 317 179 207 208
1882 14 212 179 247 219
1883 13 212 179 247 248
1884 12 182 179 247 219
1885 11 182 179 247 248
1886 12 193 179 247 219
1887 11 193 179 247 248
1888 16 207 179 247 219
1889 15 207 179 247 248
1890 12 317 179 247 219
1891 11 317 179 247 248
1892 1 212 179 317 303
1893 2 212 179 317 315
1894 3 182 179 317 303
1895 4 182 179 317 315
1896 3 193 179 317 303
1897 4 193 179 317 315
1898 5 207 179 317 303
1899 6 207 179 317 315
1900 5 247 179 317 303
1901 6 247 179 317 315
1902 20 184 180 182 179
1903 20 184 180 182 209
1904 20 185 180 182 179
1905 20 185 180 182 209
1906 20 290 180 182 179
1907 20 290 180 182 209
1908 22 182 180 184 191
1909 22 185 180 184 191
1910 22 290 180 184 191
1911 22 182 180 185 201
1912 22 184 180 185 201
1913 22 290 180 185 201
1914 22 182 180 290 285
1915 22 184 180 290 285
1916 22 185 180 290 285
1917 19 205 181 183 229
1918 19 205 181 183 525
1919 19 186 181 183 229
1920 19 186 181 183 525
1921 20 530 181 183 229
1922 20 530 181 183 525
1923 21 183 181 205 200
1924 24 186 181 205 200
1925 21 530 181 205 200
1926 21 183 181 186 284
1927 24 205 181 186 284
1928 21 530 181 186 284
1929 22 183 181 530 526
1930 23 205 181 530 526
1931 23 186 181 530 526
1932 3 203 209 182 179
1933 1 212 209 182 179
1934 5 533 209 182 179
1935 3 579 209 182 179
1936 5 321 209 182 179
1937 4 203 209 182 180
1938 2 212 209 182 180
1939 6 533 209 182 180
1940 4 579 209 182 180
1941 6 321 209 182 180
1942 2 202 229 183 181
1943 4 232 229 183 181
1944 6 513 229 183 181
1945 6 133 229 183 181
1946 4 559 229 183 181
1947 1 202 229 183 525
1948 3 232 229 183 525
1949 5 513 229 183 525
1950 5 133 229 183 525
1951 3 559 229 183 525
1952 2 578 525 183 181
1953 4 528 525 183 181
1954 4 559 525 183 181
1955 6 597 525 183 181
1956 6 217 525 183 181
1957 1 578 525 183 229
1958 3 528 525 183 229
1959 3 559 525 183 229
1960 5 597 525 183 229
1961 5 217 525 183 229
1962 22 193 191 184 180
1963 23 196 191 184 180
1964 23 259 191 184 180
1965 22 203 201 185 180
1966 22 206 201 185 180
1967 23 510 201 185 180
1968 18 286 284 186 181
1969 18 288 284 186 181
1970 18 289 284 186 181
1971 12 173 199 187 239
1972 12 232 199 187 239
1973 14 202 199 187 239
1974 16 227 199 187 239
1975 12 129 199 187 239
1976 11 173 199 187 188
1977 11 232 199 187 188
1978 13 202 199 187 188
1979 15 227 199 187 188
1980 11 129 199 187 188
1981 12 192 239 187 199
1982 12 213 239 187 199
1983 16 227 239 187 199
1984 14 242 239 187 199
1985 12 257 239 187 199
1986 11 192 239 187 188
1987 11 213 239 187 188
1988 15 227 239 187 188
1989 13 242 239 187 188
1990 11 257 239 187 188
1991 8 192 189 242 239
1992 7 192 189 242 240
1993 8 223 189 242 239
1994 7 223 189 242 240
1995 10 261 189 242 239
1996 9 261 189 242 240
1997 8 519 189 242 239
1998 7 519 189 242 240
1999 10 553 189 242 239
2000 9 553 189 242 240
2001 2 242 189 192 190
2002 1 242 189 192 239
2003 4 223 189 192 190
2004 3 223 189 192 239
2005 6 261 189 192 190
2006 5 261 189 192 239
2007 4 519 189 192 190
2008 3 519 189 192 239
2009 6 553 189 192 190
2010 5 553 189 192 239
2011 2 242 189 223 221
2012 1 242 189 223 565
2013 4 192 189 223 221
2014 3 192 189 223 565
2015 6 261 189 223 221
2016 5 261 189 223 565
2017 4 519 189 223 221
2018 3 519 189 223 565
2019 6 553 189 223 221
2020 5 553 189 223 565
2021 13 242 189 261 262
2022 14 242 189 261 649
2023 11 192 189 261 262
2024 12 192 189 261 649
2025 11 223 189 261 262
2026 12 223 189 261 649
2027 11 519 189 261 262
2028 12 519 189 261 649
2029 15 553 189 261 262
2030 16 553 189 261 649
2031 2 242 189 519 517
2032 1 242 189 519 565
2033 4 192 189 519 517
2034 3 192 189 519 565
2035 4 223 189 519 517
2036 3 223 189 519 565
2037 6 261 189 519 517
2038 5 261 189 519 565
2039 6 553 189 519 517
2040 5 553 189 519 565
2041 13 242 189 553 554
2042 14 242 189 553 649
2043 11 192 189 553 554
2044 12 192 189 553 649
2045 11 223 189 553 554
2046 12 223 189 553 649
2047 15 261 189 553 554
2048 16 261 189 553 649
2049 11 519 189 553 554
2050 12 519 189 553 649
2051 20 176 190 192 189
2052 20 176 190 192 239
2053 20 194 190 192 189
2054 20 194 190 192 239
2055 20 195 190 192 189
2056 20 195 190 192 239
2057 22 176 190 194 517
2058 22 192 190 194 517
2059 22 195 190 194 517
2060 22 176 190 195 255
2061 22 192 190 195 255
2062 22 194 190 195 255
2063 20 184 191 193 179
2064 20 184 191 193 303
2065 19 196 191 193 179
2066 19 196 191 193 303
2067 19 259 191 193 179
2068 19 259 191 193 303
2069 21 184 191 196 170
2070 21 193 191 196 170
2071 24 259 191 196 170
2072 21 184 191 259 254
2073 21 193 191 259 254
2074 24 196 191 259 254
2075 5 187 239 192 189
2076 3 213 239 192 189
2077 5 227 239 192 189
2078 1 242 239 192 189
2079 3 257 239 192 189
2080 6 187 239 192 190
2081 4 213 239 192 190
2082 6 227 239 192 190
2083 2 242 239 192 190
2084 4 257 239 192 190
2085 1 256 303 193 179
2086 5 291 303 193 179
2087 3 306 303 193 179
2088 3 317 303 193 179
2089 5 331 303 193 179
2090 2 256 303 193 191
2091 6 291 303 193 191
2092 4 306 303 193 191
2093 4 317 303 193 191
2094 6 331 303 193 191
2095 22 519 517 194 190
2096 23 541 517 194 190
2097 23 522 517 194 190
2098 22 257 255 195 190
2099 23 288 255 195 190
2100 22 260 255 195 190
2101 11 306 253 197 198
2102 13 256 253 197 198
2103 11 327 253 197 198
2104 11 623 253 197 198
2105 15 657 253 197 198
2106 12 306 253 197 545
2107 14 256 253 197 545
2108 12 327 253 197 545
2109 12 623 253 197 545
2110 16 657 253 197 545
2111 11 518 545 197 198
2112 11 539 545 197 198
2113 13 548 545 197 198
2114 11 243 545 197 198
2115 15 657 545 197 198
2116 12 518 545 197 253
2117 12 539 545 197 253
2118 14 548 545 197 253
2119 12 243 545 197 253
2120 16 657 545 197 253
2121 3 173 199 232 229
2122 4 173 199 232 230
2123 5 187 199 232 229
2124 6 187 199 232 230
2125 1 202 199 232 229
2126 2 202 199 232 230
2127 5 227 199 232 229
2128 6 227 199 232 230
2129 3 129 199 232 229
2130 4 129 199 232 230
2131 7 173 199 202 200
2132 8 173 199 202 229
2133 9 187 199 202 200
2134 10 187 199 202 229
2135 7 232 199 202 200
2136 8 232 199 202 229
2137 9 227 199 202 200
2138 10 227 199 202 229
2139 7 129 199 202 200
2140 8 129 199 202 229
2141 12 173 199 227 239
2142 11 173 199 227 228
2143 16 187 199 227 239
2144 15 187 199 227 228
2145 12 232 199 227 239
2146 11 232 199 227 228
2147 14 202 199 227 239
2148 13 202 199 227 228
2149 12 129 199 227 239
2150 11 129 199 227 228
2151 17 204 200 202 199
2152 17 204 200 202 229
2153 17 205 200 202 199
2154 17 205 200 202 229
2155 17 102 200 202 199
2156 17 102 200 202 229
2157 18 202 200 204 171
2158 18 205 200 204 171
2159 18 102 200 204 171
2160 18 202 200 205 181
2161 18 204 200 205 181
2162 18 102 200 205 181
2163 20 185 201 203 209
2164 20 185 201 203 505
2165 20 206 201 203 209
2166 20 206 201 203 505
2167 19 510 201 203 209
2168 19 510 201 203 505
2169 22 185 201 206 96
2170 22 203 201 206 96
2171 23 510 201 206 96
2172 21 185 201 510 506
2173 21 203 201 510 506
2174 21 206 201 510 506
2175 8 183 229 202 199
2176 8 232 229 202 199
2177 10 513 229 202 199
2178 10 133 229 202 199
2179 8 559 229 202 199
2180 7 183 229 202 200
2181 7 232 229 202 200
2182 9 513 229 202 200
2183 9 133 229 202 200
2184 7 559 229 202 200
2185 4 182 209 203 201
2186 2 212 209 203 201
2187 6 533 209 203 201
2188 4 579 209 203 201
2189 6 321 209 203 201
2190 3 182 209 203 505
2191 1 212 209 203 505
2192 5 533 209 203 505
2193 3 579 209 203 505
2194 5 321 209 203 505
2195 4 558 505 203 201
2196 2 508 505 203 201
2197 4 579 505 203 201
2198 6 449 505 203 201
2199 6 237 505 203 201
2200 3 558 505 203 209
2201 1 508 505 203 209
2202 3 579 505 203 209
2203 5 449 505 203 209
2204 5 237 505 203 209
2205 14 172 219 207 179
2206 12 222 219 207 179
2207 12 233 219 207 179
2208 16 247 219 207 179
2209 12 109 219 207 179
2210 13 172 219 207 208
2211 11 222 219 207 208
2212 11 233 219 207 208
2213 15 247 219 207 208
2214 11 109 219 207 208
2215 8 182 209 212 179
2216 7 182 209 212 210
2217 8 203 209 212 179
2218 7 203 209 212 210
2219 10 533 209 212 179
2220 9 533 209 212 210
2221 8 579 209 212 179
2222 7 579 209 212 210
2223 10 321 209 212 179
2224 9 321 209 212 210
2225 11 182 209 533 534
2226 12 182 209 533 589
2227 11 203 209 533 534
2228 12 203 209 533 589
2229 13 212 209 533 534
2230 14 212 209 533 589
2231 11 579 209 533 534
2232 12 579 209 533 589
2233 15 321 209 533 534
2234 16 321 209 533 589
2235 3 182 209 579 505
2236 4 182 209 579 577
2237 3 203 209 579 505
2238 4 203 209 579 577
2239 1 212 209 579 505
2240 2 212 209 579 577
2241 5 533 209 579 505
2242 6 533 209 579 577
2243 5 321 209 579 505
2244 6 321 209 579 577
2245 11 182 209 321 322
2246 12 182 209 321 589
2247 11 203 209 321 322
2248 12 203 209 321 589
2249 13 212 209 321 322
2250 14 212 209 321 589
2251 15 533 209 321 322
2252 16 533 209 321 589
2253 11 579 209 321 322
2254 12 579 209 321 589
2255 17 214 210 212 179
2256 17 214 210 212 209
2257 17 215 210 212 179
2258 17 215 210 212 209
2259 17 236 210 212 179
2260 17 236 210 212 209
2261 18 212 210 214 577
2262 18 215 210 214 577
2263 18 236 210 214 577
2264 18 212 210 215 315
2265 18 214 210 215 315
2266 18 236 210 215 315
2267 18 212 210 236 231
2268 18 214 210 236 231
2269 18 215 210 236 231
2270 19 244 211 213 239
2271 19 244 211 213 283
2272 20 216 211 213 239
2273 20 216 211 213 283
2274 20 319 211 213 239
2275 20 319 211 213 283
2276 21 213 211 244 240
2277 21 216 211 244 240
2278 21 319 211 244 240
2279 22 213 211 216 230
2280 23 244 211 216 230
2281 22 319 211 216 230
2282 22 213 211 319 314
2283 23 244 211 319 314
2284 22 216 211 319 314
2285 6 187 239 213 211
2286 4 192 239 213 211
2287 6 227 239 213 211
2288 2 242 239 213 211
2289 4 257 239 213 211
2290 5 187 239 213 283
2291 3 192 239 213 283
2292 5 227 239 213 283
2293 1 242 239 213 283
2294 3 257 239 213 283
2295 4 257 283 213 211
2296 6 271 283 213 211
2297 4 316 283 213 211
2298 2 286 283 213 211
2299 6 311 283 213 211
2300 3 257 283 213 239
2301 5 271 283 213 239
2302 3 316 283 213 239
2303 1 286 283 213 239
2304 5 311 283 213 239
2305 21 561 577 214 210
2306 21 579 577 214 210
2307 21 582 577 214 210
2308 21 308 315 215 210
2309 21 317 315 215 210
2310 24 320 315 215 210
2311 22 232 230 216 211
2312 22 234 230 216 211
2313 22 235 230 216 211
2314 13 578 525 217 218
2315 11 528 525 217 218
2316 11 559 525 217 218
2317 15 597 525 217 218
2318 11 183 525 217 218
2319 14 578 525 217 313
2320 12 528 525 217 313
2321 12 559 525 217 313
2322 16 597 525 217 313
2323 12 183 525 217 313
2324 11 267 313 217 218
2325 13 286 313 217 218
2326 11 316 313 217 218
2327 15 597 313 217 218
2328 11 643 313 217 218
2329 12 267 313 217 525
2330 14 286 313 217 525
2331 12 316 313 217 525
2332 16 597 313 217 525
2333 12 643 313 217 525
2334 1 172 219 222 169
2335 2 172 219 222 220
2336 5 207 219 222 169
2337 6 207 219 222 220
2338 3 233 219 222 169
2339 4 233 219 222 220
2340 5 247 219 222 169
2341 6 247 219 222 220
2342 3 109 219 222 169
2343 4 109 219 222 220
2344 2 172 219 233 231
2345 1 172 219 233 95
2346 6 207 219 233 231
2347 5 207 219 233 95
2348 4 222 219 233 231
2349 3 222 219 233 95
2350 6 247 219 233 231
2351 5 247 219 233 95
2352 4 109 219 233 231
2353 3 109 219 233 95
2354 14 172 219 247 179
2355 13 172 219 247 248
2356 16 207 219 247 179
2357 15 207 219 247 248
2358 12 222 219 247 179
2359 11 222 219 247 248
2360 12 233 219 247 179
2361 11 233 219 247 248
2362 12 109 219 247 179
2363 11 109 219 247 248
2364 20 224 220 222 169
2365 20 224 220 222 219
2366 20 225 220 222 169
2367 20 225 220 222 219
2368 20 162 220 222 169
2369 20 162 220 222 219
2370 22 222 220 224 231
2371 22 225 220 224 231
2372 22 162 220 224 231
2373 22 222 220 225 241
2374 22 224 220 225 241
2375 22 162 220 225 241
2376 19 245 221 223 189
2377 19 245 221 223 565
2378 19 226 221 223 189
2379 19 226 221 223 565
2380 20 570 221 223 189
2381 20 570 221 223 565
2382 21 223 221 245 240
2383 24 226 221 245 240
2384 21 570 221 245 240
2385 21 223 221 226 156
2386 24 245 221 226 156
2387 21 570 221 226 156
2388 22 223 221 570 566
2389 23 245 221 570 566
2390 23 226 221 570 566
2391 3 519 565 223 189
2392 1 538 565 223 189
2393 3 568 565 223 189
2394 5 177 565 223 189
2395 5 469 565 223 189
2396 4 519 565 223 221
2397 2 538 565 223 221
2398 4 568 565 223 221
2399 6 177 565 223 221
2400 6 469 565 223 221
2401 22 233 231 224 220
2402 23 236 231 224 220
2403 23 131 231 224 220
2404 22 243 241 225 220
2405 22 246 241 225 220
2406 23 550 241 225 220
2407 16 187 239 227 199
2408 12 192 239 227 199
2409 12 213 239 227 199
2410 14 242 239 227 199
2411 12 257 239 227 199
2412 15 187 239 227 228
2413 11 192 239 227 228
2414 11 213 239 227 228
2415 13 242 239 227 228
2416 11 257 239 227 228
2417 3 183 229 232 199
2418 4 183 229 232 230
2419 1 202 229 232 199
2420 2 202 229 232 230
2421 5 513 229 232 199
2422 6 513 229 232 230
2423 5 133 229 232 199
2424 6 133 229 232 230
2425 3 559 229 232 199
2426 4 559 229 232 230
2427 11 183 229 513 514
2428 12 183 229 513 441
2429 13 202 229 513 514
2430 14 202 229 513 441
2431 11 232 229 513 514
2432 12 232 229 513 441
2433 15 133 229 513 514
2434 16 133 229 513 441
2435 11 559 229 513 514
2436 12 559 229 513 441
2437 3 183 229 559 525
2438 4 183 229 559 557
2439 1 202 229 559 525
2440 2 202 229 559 557
2441 3 232 229 559 525
2442 4 232 229 559 557
2443 5 513 229 559 525
2444 6 513 229 559 557
2445 5 133 229 559 525
2446 6 133 229 559 557
2447 20 216 230 232 199
2448 20 216 230 232 229
2449 20 234 230 232 199
2450 20 234 230 232 229
2451 20 235 230 232 199
2452 20 235 230 232 229
2453 22 216 230 234 557
2454 22 232 230 234 557
2455 22 235 230 234 557
2456 22 216 230 235 127
2457 22 232 230 235 127
2458 22 234 230 235 127
2459 20 224 231 233 219
2460 20 224 231 233 95
2461 19 236 231 233 219
2462 19 236 231 233 95
2463 19 131 231 233 219
2464 19 131 231 233 95
2465 21 224 231 236 210
2466 21 233 231 236 210
2467 24 131 231 236 210
2468 22 559 557 234 230
2469 23 581 557 234 230
2470 23 562 557 234 230
2471 11 558 505 237 238
2472 13 508 505 237 238
2473 11 579 505 237 238
2474 11 203 505 237 238
2475 15 449 505 237 238
2476 12 558 505 237 125
2477 14 508 505 237 125
2478 12 579 505 237 125
2479 12 203 505 237 125
2480 16 449 505 237 125
2481 10 187 239 242 189
2482 9 187 239 242 240
2483 8 192 239 242 189
2484 7 192 239 242 240
2485 8 213 239 242 189
2486 7 213 239 242 240
2487 10 227 239 242 189
2488 9 227 239 242 240
2489 8 257 239 242 189
2490 7 257 239 242 240
2491 6 187 239 257 255
2492 5 187 239 257 283
2493 4 192 239 257 255
2494 3 192 239 257 283
2495 4 213 239 257 255
2496 3 213 239 257 283
2497 6 227 239 257 255
2498 5 227 239 257 283
2499 2 242 239 257 255
2500 1 242 239 257 283
2501 17 244 240 242 189
2502 17 244 240 242 239
2503 17 245 240 242 189
2504 17 245 240 242 239
2505 17 310 240 242 189
2506 17 310 240 242 239
2507 18 242 240 244 211
2508 18 245 240 244 211
2509 18 310 240 244 211
2510 18 242 240 245 221
2511 18 244 240 245 221
2512 18 310 240 245 221
2513 18 242 240 310 305
2514 18 244 240 310 305
2515 18 245 240 310 305
2516 20 225 241 243 169
2517 20 225 241 243 545
2518 20 246 241 243 169
2519 20 246 241 243 545
2520 19 550 241 243 169
2521 19 550 241 243 545
2522 22 225 241 246 304
2523 22 243 241 246 304
2524 23 550 241 246 304
2525 21 225 241 550 546
2526 21 243 241 550 546
2527 21 246 241 550 546
2528 3 518 545 243 169
2529 3 539 545 243 169
2530 1 548 545 243 169
2531 5 197 545 243 169
2532 5 657 545 243 169
2533 4 518 545 243 241
2534 4 539 545 243 241
2535 2 548 545 243 241
2536 6 197 545 243 241
2537 6 657 545 243 241
2538 22 306 304 246 241
2539 22 308 304 246 241
2540 22 309 304 246 241
2541 1 256 253 306 303
2542 2 256 253 306 304
2543 3 327 253 306 303
2544 4 327 253 306 304
2545 3 623 253 306 303
2546 4 623 253 306 304
2547 5 197 253 306 303
2548 6 197 253 306 304
2549 5 657 253 306 303
2550 6 657 253 306 304
2551 7 306 253 256 254
2552 8 306 253 256 303
2553 7 327 253 256 254
2554 8 327 253 256 303
2555 7 623 253 256 254
2556 8 623 253 256 303
2557 9 197 253 256 254
2558 10 197 253 256 303
2559 9 657 253 256 254
2560 10 657 253 256 303
2561 4 306 253 327 325
2562 3 306 253 327 629
2563 2 256 253 327 325
2564 1 256 253 327 629
2565 4 623 253 327 325
2566 3 623 253 327 629
2567 6 197 253 327 325
2568 5 197 253 327 629
2569 6 657 253 327 325
2570 5 657 253 327 629
2571 4 306 253 623 621
2572 3 306 253 623 629
2573 2 256 253 623 621
2574 1 256 253 623 629
2575 4 327 253 623 621
2576 3 327 253 623 629
2577 6 197 253 623 621
2578 5 197 253 623 629
2579 6 657 253 623 621
2580 5 657 253 623 629
2581 11 306 253 657 658
2582 12 306 253 657 545
2583 13 256 253 657 658
2584 14 256 253 657 545
2585 11 327 253 657 658
2586 12 327 253 657 545
2587 11 623 253 657 658
2588 12 623 253 657 545
2589 15 197 253 657 658
2590 16 197 253 657 545
2591 17 258 254 256 253
2592 17 258 254 256 303
2593 17 259 254 256 253
2594 17 259 254 256 303
2595 17 280 254 256 253
2596 17 280 254 256 303
2597 18 256 254 258 621
2598 18 259 254 258 621
2599 18 280 254 258 621
2600 18 256 254 259 191
2601 18 258 254 259 191
2602 18 280 254 259 191
2603 18 256 254 280 275
2604 18 258 254 280 275
2605 18 259 254 280 275
2606 19 288 255 257 283
2607 19 288 255 257 239
2608 20 260 255 257 283
2609 20 260 255 257 239
2610 20 195 255 257 283
2611 20 195 255 257 239
2612 21 257 255 288 284
2613 21 260 255 288 284
2614 21 195 255 288 284
2615 22 257 255 260 274
2616 23 288 255 260 274
2617 22 195 255 260 274
2618 10 291 303 256 253
2619 8 306 303 256 253
2620 8 317 303 256 253
2621 10 331 303 256 253
2622 8 193 303 256 253
2623 9 291 303 256 254
2624 7 306 303 256 254
2625 7 317 303 256 254
2626 9 331 303 256 254
2627 7 193 303 256 254
2628 6 271 283 257 255
2629 4 316 283 257 255
2630 2 286 283 257 255
2631 6 311 283 257 255
2632 4 213 283 257 255
2633 5 271 283 257 239
2634 3 316 283 257 239
2635 1 286 283 257 239
2636 5 311 283 257 239
2637 3 213 283 257 239
2638 21 605 621 258 254
2639 21 623 621 258 254
2640 21 626 621 258 254
2641 22 276 274 260 255
2642 22 278 274 260 255
2643 22 279 274 260 255
2644 11 603 649 261 262
2645 13 622 649 261 262
2646 11 652 649 261 262
2647 15 553 649 261 262
2648 11 307 649 261 262
2649 12 603 649 261 189
2650 14 622 649 261 189
2651 12 652 649 261 189
2652 16 553 649 261 189
2653 12 307 649 261 189
2654 8 266 263 296 293
2655 7 266 263 296 294
2656 8 277 263 296 293
2657 7 277 263 296 294
2658 10 291 263 296 293
2659 9 291 263 296 294
2660 10 331 263 296 293
2661 9 331 263 296 294
2662 8 65 263 296 293
2663 7 65 263 296 294
2664 2 296 263 266 264
2665 1 296 263 266 293
2666 4 277 263 266 264
2667 3 277 263 266 293
2668 6 291 263 266 264
2669 5 291 263 266 293
2670 6 331 263 266 264
2671 5 331 263 266 293
2672 4 65 263 266 264
2673 3 65 263 266 293
2674 2 296 263 277 275
2675 1 296 263 277 51
2676 4 266 263 277 275
2677 3 266 263 277 51
2678 6 291 263 277 275
2679 5 291 263 277 51
2680 6 331 263 277 275
2681 5 331 263 277 51
2682 4 65 263 277 275
2683 3 65 263 277 51
2684 14 296 263 291 303
2685 13 296 263 291 292
2686 12 266 263 291 303
2687 11 266 263 291 292
2688 12 277 263 291 303
2689 11 277 263 291 292
2690 16 331 263 291 303
2691 15 331 263 291 292
2692 12 65 263 291 303
2693 11 65 263 291 292
2694 14 296 263 331 303
2695 13 296 263 331 332
2696 12 266 263 331 303
2697 11 266 263 331 332
2698 12 277 263 331 303
2699 11 277 263 331 332
2700 16 291 263 331 303
2701 15 291 263 331 332
2702 12 65 263 331 303
2703 11 65 263 331 332
2704 20 268 264 266 263
2705 20 268 264 266 293
2706 20 269 264 266 263
2707 20 269 264 266 293
2708 20 38 264 266 263
2709 20 38 264 266 293
2710 22 266 264 268 275
2711 22 269 264 268 275
2712 22 38 264 268 275
2713 22 266 264 269 285
2714 22 268 264 269 285
2715 22 38 264 269 285
2716 19 289 265 267 313
2717 19 289 265 267 609
2718 19 270 265 267 313
2719 19 270 265 267 609
2720 20 614 265 267 313
2721 20 614 265 267 609
2722 21 267 265 289 284
2723 24 270 265 289 284
2724 21 614 265 289 284
2725 21 267 265 270 32
2726 24 289 265 270 32
2727 21 614 265 270 32
2728 22 267 265 614 610
2729 23 289 265 614 610
2730 23 270 265 614 610
2731 3 287 293 266 263
2732 1 296 293 266 263
2733 5 617 293 266 263
2734 3 663 293 266 263
2735 5 69 293 266 263
2736 4 287 293 266 264
2737 2 296 293 266 264
2738 6 617 293 266 264
2739 4 663 293 266 264
2740 6 69 293 266 264
2741 2 286 313 267 265
2742 4 316 313 267 265
2743 6 597 313 267 265
2744 6 217 313 267 265
2745 4 643 313 267 265
2746 1 286 313 267 609
2747 3 316 313 267 609
2748 5 597 313 267 609
2749 5 217 313 267 609
2750 3 643 313 267 609
2751 2 662 609 267 265
2752 4 612 609 267 265
2753 4 643 609 267 265
2754 6 345 609 267 265
2755 6 301 609 267 265
2756 1 662 609 267 313
2757 3 612 609 267 313
2758 3 643 609 267 313
2759 5 345 609 267 313
2760 5 301 609 267 313
2761 22 277 275 268 264
2762 23 280 275 268 264
2763 23 7 275 268 264
2764 22 287 285 269 264
2765 22 290 285 269 264
2766 23 594 285 269 264
2767 12 257 283 271 323
2768 12 316 283 271 323
2769 14 286 283 271 323
2770 16 311 283 271 323
2771 12 213 283 271 323
2772 11 257 283 271 272
2773 11 316 283 271 272
2774 13 286 283 271 272
2775 15 311 283 271 272
2776 11 213 283 271 272
2777 12 276 323 271 283
2778 12 297 323 271 283
2779 16 311 323 271 283
2780 14 326 323 271 283
2781 12 5 323 271 283
2782 11 276 323 271 272
2783 11 297 323 271 272
2784 15 311 323 271 272
2785 13 326 323 271 272
2786 11 5 323 271 272
2787 8 276 273 326 323
2788 7 276 273 326 324
2789 8 307 273 326 323
2790 7 307 273 326 324
2791 10 9 273 326 323
2792 9 9 273 326 324
2793 8 603 273 326 323
2794 7 603 273 326 324
2795 10 637 273 326 323
2796 9 637 273 326 324
2797 2 326 273 276 274
2798 1 326 273 276 323
2799 4 307 273 276 274
2800 3 307 273 276 323
2801 6 9 273 276 274
2802 5 9 273 276 323
2803 4 603 273 276 274
2804 3 603 273 276 323
2805 6 637 273 276 274
2806 5 637 273 276 323
2807 2 326 273 307 305
2808 1 326 273 307 649
2809 4 276 273 307 305
2810 3 276 273 307 649
2811 6 9 273 307 305
2812 5 9 273 307 649
2813 4 603 273 307 305
2814 3 603 273 307 649
2815 6 637 273 307 305
2816 5 637 273 307 649
2817 2 326 273 603 601
2818 1 326 273 603 649
2819 4 276 273 603 601
2820 3 276 273 603 649
2821 4 307 273 603 601
2822 3 307 273 603 649
2823 6 9 273 603 601
2824 5 9 273 603 649
2825 6 637 273 603 601
2826 5 637 273 603 649
2827 13 326 273 637 638
2828 14 326 273 637 397
2829 11 276 273 637 638
2830 12 276 273 637 397
2831 11 307 273 637 638
2832 12 307 273 637 397
2833 15 9 273 637 638
2834 16 9 273 637 397
2835 11 603 273 637 638
2836 12 603 273 637 397
2837 20 260 274 276 273
2838 20 260 274 276 323
2839 20 278 274 276 273
2840 20 278 274 276 323
2841 20 279 274 276 273
2842 20 279 274 276 323
2843 22 260 274 278 601
2844 22 276 274 278 601
2845 22 279 274 278 601
2846 22 260 274 279 3
2847 22 276 274 279 3
2848 22 278 274 279 3
2849 20 268 275 277 263
2850 20 268 275 277 51
2851 19 280 275 277 263
2852 19 280 275 277 51
2853 19 7 275 277 263
2854 19 7 275 277 51
2855 21 268 275 280 254
2856 21 277 275 280 254
2857 24 7 275 280 254
2858 5 271 323 276 273
2859 3 297 323 276 273
2860 5 311 323 276 273
2861 1 326 323 276 273
2862 3 5 323 276 273
2863 6 271 323 276 274
2864 4 297 323 276 274
2865 6 311 323 276 274
2866 2 326 323 276 274
2867 4 5 323 276 274
2868 22 603 601 278 274
2869 23 625 601 278 274
2870 23 606 601 278 274
2871 11 602 629 281 282
2872 11 623 629 281 282
2873 13 632 629 281 282
2874 11 327 629 281 282
2875 15 405 629 281 282
2876 12 602 629 281 1
2877 12 623 629 281 1
2878 14 632 629 281 1
2879 12 327 629 281 1
2880 16 405 629 281 1
2881 3 257 283 316 313
2882 4 257 283 316 314
2883 5 271 283 316 313
2884 6 271 283 316 314
2885 1 286 283 316 313
2886 2 286 283 316 314
2887 5 311 283 316 313
2888 6 311 283 316 314
2889 3 213 283 316 313
2890 4 213 283 316 314
2891 7 257 283 286 284
2892 8 257 283 286 313
2893 9 271 283 286 284
2894 10 271 283 286 313
2895 7 316 283 286 284
2896 8 316 283 286 313
2897 9 311 283 286 284
2898 10 311 283 286 313
2899 7 213 283 286 284
2900 8 213 283 286 313
2901 12 257 283 311 323
2902 11 257 283 311 312
2903 16 271 283 311 323
2904 15 271 283 311 312
2905 12 316 283 311 323
2906 11 316 283 311 312
2907 14 286 283 311 323
2908 13 286 283 311 312
2909 12 213 283 311 323
2910 11 213 283 311 312
2911 17 288 284 286 283
2912 17 288 284 286 313
2913 17 289 284 286 283
2914 17 289 284 286 313
2915 17 186 284 286 283
2916 17 186 284 286 313
2917 18 286 284 288 255
2918 18 289 284 288 255
2919 18 186 284 288 255
2920 18 286 284 289 265
2921 18 288 284 289 265
2922 18 186 284 289 265
2923 20 269 285 287 293
2924 20 269 285 287 589
2925 20 290 285 287 293
2926 20 290 285 287 589
2927 19 594 285 287 293
2928 19 594 285 287 589
2929 22 269 285 290 180
2930 22 287 285 290 180
2931 23 594 285 290 180
2932 21 269 285 594 590
2933 21 287 285 594 590
2934 21 290 285 594 590
2935 8 267 313 286 283
2936 8 316 313 286 283
2937 10 597 313 286 283
2938 10 217 313 286 283
2939 8 643 313 286 283
2940 7 267 313 286 284
2941 7 316 313 286 284
2942 9 597 313 286 284
2943 9 217 313 286 284
2944 7 643 313 286 284
2945 4 266 293 287 285
2946 2 296 293 287 285
2947 6 617 293 287 285
2948 4 663 293 287 285
2949 6 69 293 287 285
2950 3 266 293 287 589
2951 1 296 293 287 589
2952 5 617 293 287 589
2953 3 663 293 287 589
2954 5 69 293 287 589
2955 4 642 589 287 285
2956 2 592 589 287 285
2957 4 663 589 287 285
2958 6 533 589 287 285
2959 6 321 589 287 285
2960 3 642 589 287 293
2961 1 592 589 287 293
2962 3 663 589 287 293
2963 5 533 589 287 293
2964 5 321 589 287 293
2965 14 256 303 291 263
2966 12 306 303 291 263
2967 12 317 303 291 263
2968 16 331 303 291 263
2969 12 193 303 291 263
2970 13 256 303 291 292
2971 11 306 303 291 292
2972 11 317 303 291 292
2973 15 331 303 291 292
2974 11 193 303 291 292
2975 8 266 293 296 263
2976 7 266 293 296 294
2977 8 287 293 296 263
2978 7 287 293 296 294
2979 10 617 293 296 263
2980 9 617 293 296 294
2981 8 663 293 296 263
2982 7 663 293 296 294
2983 10 69 293 296 263
2984 9 69 293 296 294
2985 11 266 293 617 618
2986 12 266 293 617 337
2987 11 287 293 617 618
2988 12 287 293 617 337
2989 13 296 293 617 618
2990 14 296 293 617 337
2991 11 663 293 617 618
2992 12 663 293 617 337
2993 15 69 293 617 618
2994 16 69 293 617 337
2995 3 266 293 663 589
2996 4 266 293 663 661
2997 3 287 293 663 589
2998 4 287 293 663 661
2999 1 296 293 663 589
3000 2 296 293 663 661
3001 5 617 293 663 589
3002 6 617 293 663 661
3003 5 69 293 663 589
3004 6 69 293 663 661
3005 17 298 294 296 263
3006 17 298 294 296 293
3007 17 299 294 296 263
3008 17 299 294 296 293
3009 17 320 294 296 263
3010 17 320 294 296 293
3011 18 296 294 298 661
3012 18 299 294 298 661
3013 18 320 294 298 661
3014 18 296 294 299 63
3015 18 298 294 299 63
3016 18 320 294 299 63
3017 18 296 294 320 315
3018 18 298 294 320 315
3019 18 299 294 320 315
3020 19 328 295 297 323
3021 19 328 295 297 31
3022 20 300 295 297 323
3023 20 300 295 297 31
3024 20 67 295 297 323
3025 20 67 295 297 31
3026 21 297 295 328 324
3027 21 300 295 328 324
3028 21 67 295 328 324
3029 22 297 295 300 314
3030 23 328 295 300 314
3031 22 67 295 300 314
3032 6 271 323 297 295
3033 4 276 323 297 295
3034 6 311 323 297 295
3035 2 326 323 297 295
3036 4 5 323 297 295
3037 5 271 323 297 31
3038 3 276 323 297 31
3039 5 311 323 297 31
3040 1 326 323 297 31
3041 3 5 323 297 31
3042 21 645 661 298 294
3043 21 663 661 298 294
3044 21 666 661 298 294
3045 22 316 314 300 295
3046 22 318 314 300 295
3047 22 319 314 300 295
3048 13 662 609 301 302
3049 11 612 609 301 302
3050 11 643 609 301 302
3051 15 345 609 301 302
3052 11 267 609 301 302
3053 14 662 609 301 61
3054 12 612 609 301 61
3055 12 643 609 301 61
3056 16 345 609 301 61
3057 12 267 609 301 61
3058 1 256 303 306 253
3059 2 256 303 306 304
3060 5 291 303 306 253
3061 6 291 303 306 304
3062 3 317 303 306 253
3063 4 317 303 306 304
3064 5 331 303 306 253
3065 6 331 303 306 304
3066 3 193 303 306 253
3067 4 193 303 306 304
3068 2 256 303 317 315
3069 1 256 303 317 179
3070 6 291 303 317 315
3071 5 291 303 317 179
3072 4 306 303 317 315
3073 3 306 303 317 179
3074 6 331 303 317 315
3075 5 331 303 317 179
3076 4 193 303 317 315
3077 3 193 303 317 179
3078 14 256 303 331 263
3079 13 256 303 331 332
3080 16 291 303 331 263
3081 15 291 303 331 332
3082 12 306 303 331 263
3083 11 306 303 331 332
3084 12 317 303 331 263
3085 11 317 303 331 332
3086 12 193 303 331 263
3087 11 193 303 331 332
3088 20 308 304 306 253
3089 20 308 304 306 303
3090 20 309 304 306 253
3091 20 309 304 306 303
3092 20 246 304 306 253
3093 20 246 304 306 303
3094 22 306 304 308 315
3095 22 309 304 308 315
3096 22 246 304 308 315
3097 22 306 304 309 325
3098 22 308 304 309 325
3099 22 246 304 309 325
3100 19 329 305 307 273
3101 19 329 305 307 649
3102 19 310 305 307 273
3103 19 310 305 307 649
3104 20 654 305 307 273
3105 20 654 305 307 649
3106 21 307 305 329 324
3107 24 310 305 329 324
3108 21 654 305 329 324
3109 21 307 305 310 240
3110 24 329 305 310 240
3111 21 654 305 310 240
3112 22 307 305 654 650
3113 23 329 305 654 650
3114 23 310 305 654 650
3115 3 603 649 307 273
3116 1 622 649 307 273
3117 3 652 649 307 273
3118 5 261 649 307 273
3119 5 553 649 307 273
3120 4 603 649 307 305
3121 2 622 649 307 305
3122 4 652 649 307 305
3123 6 261 649 307 305
3124 6 553 649 307 305
3125 22 317 315 308 304
3126 23 320 315 308 304
3127 23 215 315 308 304
3128 22 327 325 309 304
3129 22 330 325 309 304
3130 23 634 325 309 304
3131 16 271 323 311 283
3132 12 276 323 311 283
3133 12 297 323 311 283
3134 14 326 323 311 283
3135 12 5 323 311 283
3136 15 271 323 311 312
3137 11 276 323 311 312
3138 11 297 323 311 312
3139 13 326 323 311 312
3140 11 5 323 311 312
3141 3 267 313 316 283
3142 4 267 313 316 314
3143 1 286 313 316 283
3144 2 286 313 316 314
3145 5 597 313 316 283
3146 6 597 313 316 314
3147 5 217 313 316 283
3148 6 217 313 316 314
3149 3 643 313 316 283
3150 4 643 313 316 314
3151 11 267 313 597 598
3152 12 267 313 597 525
3153 13 286 313 597 598
3154 14 286 313 597 525
3155 11 316 313 597 598
3156 12 316 313 597 525
3157 15 217 313 597 598
3158 16 217 313 597 525
3159 11 643 313 597 598
3160 12 643 313 597 525
3161 3 267 313 643 609
3162 4 267 313 643 641
3163 1 286 313 643 609
3164 2 286 313 643 641
3165 3 316 313 643 609
3166 4 316 313 643 641
3167 5 597 313 643 609
3168 6 597 313 643 641
3169 5 217 313 643 609
3170 6 217 313 643 641
3171 20 300 314 316 283
3172 20 300 314 316 313
3173 20 318 314 316 283
3174 20 318 314 316 313
3175 20 319 314 316 283
3176 20 319 314 316 313
3177 22 300 314 318 641
3178 22 316 314 318 641
3179 22 319 314 318 641
3180 22 300 314 319 211
3181 22 316 314 319 211
3182 22 318 314 319 211
3183 20 308 315 317 303
3184 20 308 315 317 179
3185 19 320 315 317 303
3186 19 320 315 317 179
3187 19 215 315 317 303
3188 19 215 315 317 179
3189 21 308 315 320 294
3190 21 317 315 320 294
3191 24 215 315 320 294
3192 22 643 641 318 314
3193 23 665 641 318 314
3194 23 646 641 318 314
3195 11 642 589 321 322
3196 13 592 589 321 322
3197 11 663 589 321 322
3198 11 287 589 321 322
3199 15 533 589 321 322
3200 12 642 589 321 209
3201 14 592 589 321 209
3202 12 663 589 321 209
3203 12 287 589 321 209
3204 16 533 589 321 209
3205 10 271 323 326 273
3206 9 271 323 326 324
3207 8 276 323 326 273
3208 7 276 323 326 324
3209 8 297 323 326 273
3210 7 297 323 326 324
3211 10 311 323 326 273
3212 9 311 323 326 324
3213 8 5 323 326 273
3214 7 5 323 326 324
3215 17 328 324 326 273
3216 17 328 324 326 323
3217 17 329 324 326 273
3218 17 329 324 326 323
3219 17 58 324 326 273
3220 17 58 324 326 323
3221 18 326 324 328 295
3222 18 329 324 328 295
3223 18 58 324 328 295
3224 18 326 324 329 305
3225 18 328 324 329 305
3226 18 58 324 329 305
3227 20 309 325 327 253
3228 20 309 325 327 629
3229 20 330 325 327 253
3230 20 330 325 327 629
3231 19 634 325 327 253
3232 19 634 325 327 629
3233 22 309 325 330 52
3234 22 327 325 330 52
3235 23 634 325 330 52
3236 21 309 325 634 630
3237 21 327 325 634 630
3238 21 330 325 634 630
3239 3 602 629 327 253
3240 3 623 629 327 253
3241 1 632 629 327 253
3242 5 281 629 327 253
3243 5 405 629 327 253
3244 4 602 629 327 325
3245 4 623 629 327 325
3246 2 632 629 327 325
3247 6 281 629 327 325
3248 6 405 629 327 325
3249 1 340 337 390 387
3250 2 340 337 390 388
3251 3 411 337 390 387
3252 4 411 337 390 388
3253 3 35 337 390 387
3254 4 35 337 390 388
3255 5 617 337 390 387
3256 6 617 337 390 388
3257 5 69 337 390 387
3258 6 69 337 390 388
3259 7 390 337 340 338
3260 8 390 337 340 387
3261 7 411 337 340 338
3262 8 411 337 340 387
3263 7 35 337 340 338
3264 8 35 337 340 387
3265 9 617 337 340 338
3266 10 617 337 340 387
3267 9 69 337 340 338
3268 10 69 337 340 387
3269 4 390 337 411 409
3270 3 390 337 411 41
3271 2 340 337 411 409
3272 1 340 337 411 41
3273 4 35 337 411 409
3274 3 35 337 411 41
3275 6 617 337 411 409
3276 5 617 337 411 41
3277 6 69 337 411 409
3278 5 69 337 411 41
3279 11 390 337 617 618
3280 12 390 337 617 293
3281 13 340 337 617 618
3282 14 340 337 617 293
3283 11 411 337 617 618
3284 12 411 337 617 293
3285 11 35 337 617 618
3286 12 35 337 617 293
3287 15 69 337 617 618
3288 16 69 337 617 293
3289 17 342 338 340 337
3290 17 342 338 340 387
3291 17 343 338 340 337
3292 17 343 338 340 387
3293 17 364 338 340 337
3294 17 364 338 340 387
3295 18 340 338 342 33
3296 18 343 338 342 33
3297 18 364 338 342 33
3298 18 340 338 343 611
3299 18 342 338 343 611
3300 18 364 338 343 611
3301 18 340 338 364 359
3302 18 342 338 364 359
3303 18 343 338 364 359
3304 19 372 339 341 367
3305 19 372 339 341 659
3306 20 344 339 341 367
3307 20 344 339 341 659
3308 20 615 339 341 367
3309 20 615 339 341 659
3310 21 341 339 372 368
3311 21 344 339 372 368
3312 21 615 339 372 368
3313 22 341 339 344 358
3314 23 372 339 344 358
3315 22 615 339 344 358
3316 22 341 339 615 610
3317 23 372 339 615 610
3318 22 344 339 615 610
3319 10 375 387 340 337
3320 8 390 387 340 337
3321 8 401 387 340 337
3322 10 415 387 340 337
3323 8 613 387 340 337
3324 9 375 387 340 338
3325 7 390 387 340 338
3326 7 401 387 340 338
3327 9 415 387 340 338
3328 7 613 387 340 338
3329 6 355 367 341 339
3330 4 400 367 341 339
3331 2 370 367 341 339
3332 6 395 367 341 339
3333 4 633 367 341 339
3334 5 355 367 341 659
3335 3 400 367 341 659
3336 1 370 367 341 659
3337 5 395 367 341 659
3338 3 633 367 341 659
3339 6 607 659 341 339
3340 4 612 659 341 339
3341 4 633 659 341 339
3342 6 647 659 341 339
3343 2 662 659 341 339
3344 5 607 659 341 367
3345 3 612 659 341 367
3346 3 633 659 341 367
3347 5 647 659 341 367
3348 1 662 659 341 367
3349 21 604 611 343 338
3350 21 613 611 343 338
3351 24 616 611 343 338
3352 22 360 358 344 339
3353 22 362 358 344 339
3354 22 363 358 344 339
3355 13 662 609 345 346
3356 11 612 609 345 346
3357 11 643 609 345 346
3358 11 267 609 345 346
3359 15 301 609 345 346
3360 14 662 609 345 61
3361 12 612 609 345 61
3362 12 643 609 345 61
3363 12 267 609 345 61
3364 16 301 609 345 61
3365 8 350 347 380 377
3366 7 350 347 380 378
3367 8 361 347 380 377
3368 7 361 347 380 378
3369 10 375 347 380 377
3370 9 375 347 380 378
3371 10 415 347 380 377
3372 9 415 347 380 378
3373 8 485 347 380 377
3374 7 485 347 380 378
3375 2 380 347 350 348
3376 1 380 347 350 377
3377 4 361 347 350 348
3378 3 361 347 350 377
3379 6 375 347 350 348
3380 5 375 347 350 377
3381 6 415 347 350 348
3382 5 415 347 350 377
3383 4 485 347 350 348
3384 3 485 347 350 377
3385 2 380 347 361 359
3386 1 380 347 361 471
3387 4 350 347 361 359
3388 3 350 347 361 471
3389 6 375 347 361 359
3390 5 375 347 361 471
3391 6 415 347 361 359
3392 5 415 347 361 471
3393 4 485 347 361 359
3394 3 485 347 361 471
3395 14 380 347 375 387
3396 13 380 347 375 376
3397 12 350 347 375 387
3398 11 350 347 375 376
3399 12 361 347 375 387
3400 11 361 347 375 376
3401 16 415 347 375 387
3402 15 415 347 375 376
3403 12 485 347 375 387
3404 11 485 347 375 376
3405 14 380 347 415 387
3406 13 380 347 415 416
3407 12 350 347 415 387
3408 11 350 347 415 416
3409 12 361 347 415 387
3410 11 361 347 415 416
3411 16 375 347 415 387
3412 15 375 347 415 416
3413 12 485 347 415 387
3414 11 485 347 415 416
3415 1 380 347 485 471
3416 2 380 347 485 483
3417 3 350 347 485 471
3418 4 350 347 485 483
3419 3 361 347 485 471
3420 4 361 347 485 483
3421 5 375 347 485 471
3422 6 375 347 485 483
3423 5 415 347 485 471
3424 6 415 347 485 483
3425 20 352 348 350 347
3426 20 352 348 350 377
3427 20 353 348 350 347
3428 20 353 348 350 377
3429 20 458 348 350 347
3430 20 458 348 350 377
3431 22 350 348 352 359
3432 22 353 348 352 359
3433 22 458 348 352 359
3434 22 350 348 353 369
3435 22 352 348 353 369
3436 22 458 348 353 369
3437 22 350 348 458 453
3438 22 352 348 458 453
3439 22 353 348 458 453
3440 19 373 349 351 397
3441 19 373 349 351 21
3442 19 354 349 351 397
3443 19 354 349 351 21
3444 20 26 349 351 397
3445 20 26 349 351 21
3446 21 351 349 373 368
3447 24 354 349 373 368
3448 21 26 349 373 368
3449 21 351 349 354 452
3450 24 373 349 354 452
3451 21 26 349 354 452
3452 3 371 377 350 347
3453 1 380 377 350 347
3454 5 29 377 350 347
3455 3 75 377 350 347
3456 5 489 377 350 347
3457 4 371 377 350 348
3458 2 380 377 350 348
3459 6 29 377 350 348
3460 4 75 377 350 348
3461 6 489 377 350 348
3462 2 370 397 351 349
3463 4 400 397 351 349
3464 6 9 397 351 349
3465 6 637 397 351 349
3466 4 55 397 351 349
3467 1 370 397 351 21
3468 3 400 397 351 21
3469 5 9 397 351 21
3470 5 637 397 351 21
3471 3 55 397 351 21
3472 22 361 359 352 348
3473 23 364 359 352 348
3474 23 427 359 352 348
3475 22 371 369 353 348
3476 22 374 369 353 348
3477 23 6 369 353 348
3478 18 454 452 354 349
3479 18 456 452 354 349
3480 18 457 452 354 349
3481 12 341 367 355 407
3482 12 400 367 355 407
3483 14 370 367 355 407
3484 16 395 367 355 407
3485 12 633 367 355 407
3486 11 341 367 355 356
3487 11 400 367 355 356
3488 13 370 367 355 356
3489 15 395 367 355 356
3490 11 633 367 355 356
3491 12 360 407 355 367
3492 12 381 407 355 367
3493 16 395 407 355 367
3494 14 410 407 355 367
3495 12 425 407 355 367
3496 11 360 407 355 356
3497 11 381 407 355 356
3498 15 395 407 355 356
3499 13 410 407 355 356
3500 11 425 407 355 356
3501 8 360 357 410 407
3502 7 360 357 410 408
3503 8 391 357 410 407
3504 7 391 357 410 408
3505 10 429 357 410 407
3506 9 429 357 410 408
3507 8 15 357 410 407
3508 7 15 357 410 408
3509 10 49 357 410 407
3510 9 49 357 410 408
3511 2 410 357 360 358
3512 1 410 357 360 407
3513 4 391 357 360 358
3514 3 391 357 360 407
3515 6 429 357 360 358
3516 5 429 357 360 407
3517 4 15 357 360 358
3518 3 15 357 360 407
3519 6 49 357 360 358
3520 5 49 357 360 407
3521 2 410 357 391 389
3522 1 410 357 391 61
3523 4 360 357 391 389
3524 3 360 357 391 61
3525 6 429 357 391 389
3526 5 429 357 391 61
3527 4 15 357 391 389
3528 3 15 357 391 61
3529 6 49 357 391 389
3530 5 49 357 391 61
3531 13 410 357 429 430
3532 14 410 357 429 145
3533 11 360 357 429 430
3534 12 360 357 429 145
3535 11 391 357 429 430
3536 12 391 357 429 145
3537 11 15 357 429 430
3538 12 15 357 429 145
3539 15 49 357 429 430
3540 16 49 357 429 145
3541 20 344 358 360 357
3542 20 344 358 360 407
3543 20 362 358 360 357
3544 20 362 358 360 407
3545 20 363 358 360 357
3546 20 363 358 360 407
3547 22 344 358 362 13
3548 22 360 358 362 13
3549 22 363 358 362 13
3550 22 344 358 363 423
3551 22 360 358 363 423
3552 22 362 358 363 423
3553 20 352 359 361 347
3554 20 352 359 361 471
3555 19 364 359 361 347
3556 19 364 359 361 471
3557 19 427 359 361 347
3558 19 427 359 361 471
3559 21 352 359 364 338
3560 21 361 359 364 338
3561 24 427 359 364 338
3562 21 352 359 427 422
3563 21 361 359 427 422
3564 24 364 359 427 422
3565 5 355 407 360 357
3566 3 381 407 360 357
3567 5 395 407 360 357
3568 1 410 407 360 357
3569 3 425 407 360 357
3570 6 355 407 360 358
3571 4 381 407 360 358
3572 6 395 407 360 358
3573 2 410 407 360 358
3574 4 425 407 360 358
3575 1 424 471 361 347
3576 5 459 471 361 347
3577 3 474 471 361 347
3578 3 485 471 361 347
3579 5 499 471 361 347
3580 2 424 471 361 359
3581 6 459 471 361 359
3582 4 474 471 361 359
3583 4 485 471 361 359
3584 6 499 471 361 359
3585 22 425 423 363 358
3586 23 456 423 363 358
3587 22 428 423 363 358
3588 11 474 421 365 366
3589 13 424 421 365 366
3590 11 495 421 365 366
3591 11 119 421 365 366
3592 15 153 421 365 366
3593 12 474 421 365 41
3594 14 424 421 365 41
3595 12 495 421 365 41
3596 12 119 421 365 41
3597 16 153 421 365 41
3598 3 341 367 400 397
3599 4 341 367 400 398
3600 5 355 367 400 397
3601 6 355 367 400 398
3602 1 370 367 400 397
3603 2 370 367 400 398
3604 5 395 367 400 397
3605 6 395 367 400 398
3606 3 633 367 400 397
3607 4 633 367 400 398
3608 7 341 367 370 368
3609 8 341 367 370 397
3610 9 355 367 370 368
3611 10 355 367 370 397
3612 7 400 367 370 368
3613 8 400 367 370 397
3614 9 395 367 370 368
3615 10 395 367 370 397
3616 7 633 367 370 368
3617 8 633 367 370 397
3618 12 341 367 395 407
3619 11 341 367 395 396
3620 16 355 367 395 407
3621 15 355 367 395 396
3622 12 400 367 395 407
3623 11 400 367 395 396
3624 14 370 367 395 407
3625 13 370 367 395 396
3626 12 633 367 395 407
3627 11 633 367 395 396
3628 4 341 367 633 631
3629 3 341 367 633 659
3630 6 355 367 633 631
3631 5 355 367 633 659
3632 4 400 367 633 631
3633 3 400 367 633 659
3634 2 370 367 633 631
3635 1 370 367 633 659
3636 6 395 367 633 631
3637 5 395 367 633 659
3638 17 372 368 370 367
3639 17 372 368 370 397
3640 17 373 368 370 367
3641 17 373 368 370 397
3642 17 606 368 370 367
3643 17 606 368 370 397
3644 18 370 368 372 339
3645 18 373 368 372 339
3646 18 606 368 372 339
3647 18 370 368 373 349
3648 18 372 368 373 349
3649 18 606 368 373 349
3650 18 370 368 606 601
3651 18 372 368 606 601
3652 18 373 368 606 601
3653 20 353 369 371 377
3654 20 353 369 371 1
3655 20 374 369 371 377
3656 20 374 369 371 1
3657 19 6 369 371 377
3658 19 6 369 371 1
3659 22 353 369 374 600
3660 22 371 369 374 600
3661 23 6 369 374 600
3662 8 351 397 370 367
3663 8 400 397 370 367
3664 10 9 397 370 367
3665 10 637 397 370 367
3666 8 55 397 370 367
3667 7 351 397 370 368
3668 7 400 397 370 368
3669 9 9 397 370 368
3670 9 637 397 370 368
3671 7 55 397 370 368
3672 4 350 377 371 369
3673 2 380 377 371 369
3674 6 29 377 371 369
3675 4 75 377 371 369
3676 6 489 377 371 369
3677 3 350 377 371 1
3678 1 380 377 371 1
3679 5 29 377 371 1
3680 3 75 377 371 1
3681 5 489 377 371 1
3682 22 602 600 374 369
3683 22 604 600 374 369
3684 22 605 600 374 369
3685 14 340 387 375 347
3686 12 390 387 375 347
3687 12 401 387 375 347
3688 16 415 387 375 347
3689 12 613 387 375 347
3690 13 340 387 375 376
3691 11 390 387 375 376
3692 11 401 387 375 376
3693 15 415 387 375 376
3694 11 613 387 375 376
3695 8 350 377 380 347
3696 7 350 377 380 378
3697 8 371 377 380 347
3698 7 371 377 380 378
3699 10 29 377 380 347
3700 9 29 377 380 378
3701 8 75 377 380 347
3702 7 75 377 380 378
3703 10 489 377 380 347
3704 9 489 377 380 378
3705 11 350 377 489 490
3706 12 350 377 489 85
3707 11 371 377 489 490
3708 12 371 377 489 85
3709 13 380 377 489 490
3710 14 380 377 489 85
3711 15 29 377 489 490
3712 16 29 377 489 85
3713 11 75 377 489 490
3714 12 75 377 489 85
3715 17 382 378 380 347
3716 17 382 378 380 377
3717 17 383 378 380 347
3718 17 383 378 380 377
3719 17 404 378 380 347
3720 17 404 378 380 377
3721 18 380 378 382 73
3722 18 383 378 382 73
3723 18 404 378 382 73
3724 18 380 378 383 483
3725 18 382 378 383 483
3726 18 404 378 383 483
3727 18 380 378 404 399
3728 18 382 378 404 399
3729 18 383 378 404 399
3730 19 412 379 381 407
3731 19 412 379 381 451
3732 20 384 379 381 407
3733 20 384 379 381 451
3734 20 487 379 381 407
3735 20 487 379 381 451
3736 21 381 379 412 408
3737 21 384 379 412 408
3738 21 487 379 412 408
3739 22 381 379 384 398
3740 23 412 379 384 398
3741 22 487 379 384 398
3742 22 381 379 487 482
3743 23 412 379 487 482
3744 22 384 379 487 482
3745 6 355 407 381 379
3746 4 360 407 381 379
3747 6 395 407 381 379
3748 2 410 407 381 379
3749 4 425 407 381 379
3750 5 355 407 381 451
3751 3 360 407 381 451
3752 5 395 407 381 451
3753 1 410 407 381 451
3754 3 425 407 381 451
3755 4 425 451 381 379
3756 6 439 451 381 379
3757 4 484 451 381 379
3758 2 454 451 381 379
3759 6 479 451 381 379
3760 3 425 451 381 407
3761 5 439 451 381 407
3762 3 484 451 381 407
3763 1 454 451 381 407
3764 5 479 451 381 407
3765 21 476 483 383 378
3766 21 485 483 383 378
3767 24 488 483 383 378
3768 22 400 398 384 379
3769 22 402 398 384 379
3770 22 403 398 384 379
3771 11 435 481 385 386
3772 13 454 481 385 386
3773 11 484 481 385 386
3774 15 93 481 385 386
3775 11 139 481 385 386
3776 12 435 481 385 21
3777 14 454 481 385 21
3778 12 484 481 385 21
3779 16 93 481 385 21
3780 12 139 481 385 21
3781 1 340 387 390 337
3782 2 340 387 390 388
3783 5 375 387 390 337
3784 6 375 387 390 388
3785 3 401 387 390 337
3786 4 401 387 390 388
3787 5 415 387 390 337
3788 6 415 387 390 388
3789 3 613 387 390 337
3790 4 613 387 390 388
3791 2 340 387 401 399
3792 1 340 387 401 599
3793 6 375 387 401 399
3794 5 375 387 401 599
3795 4 390 387 401 399
3796 3 390 387 401 599
3797 6 415 387 401 399
3798 5 415 387 401 599
3799 4 613 387 401 399
3800 3 613 387 401 599
3801 14 340 387 415 347
3802 13 340 387 415 416
3803 16 375 387 415 347
3804 15 375 387 415 416
3805 12 390 387 415 347
3806 11 390 387 415 416
3807 12 401 387 415 347
3808 11 401 387 415 416
3809 12 613 387 415 347
3810 11 613 387 415 416
3811 1 340 387 613 599
3812 2 340 387 613 611
3813 5 375 387 613 599
3814 6 375 387 613 611
3815 3 390 387 613 599
3816 4 390 387 613 611
3817 3 401 387 613 599
3818 4 401 387 613 611
3819 5 415 387 613 599
3820 6 415 387 613 611
3821 20 392 388 390 337
3822 20 392 388 390 387
3823 20 393 388 390 337
3824 20 393 388 390 387
3825 20 666 388 390 337
3826 20 666 388 390 387
3827 22 390 388 392 399
3828 22 393 388 392 399
3829 22 666 388 392 399
3830 22 390 388 393 409
3831 22 392 388 393 409
3832 22 666 388 393 409
3833 22 390 388 666 661
3834 22 392 388 666 661
3835 22 393 388 666 661
3836 19 413 389 391 357
3837 19 413 389 391 61
3838 19 394 389 391 357
3839 19 394 389 391 61
3840 20 66 389 391 357
3841 20 66 389 391 61
3842 21 391 389 413 408
3843 24 394 389 413 408
3844 21 66 389 413 408
3845 21 391 389 394 660
3846 24 413 389 394 660
3847 21 66 389 394 660
3848 22 401 399 392 388
3849 23 404 399 392 388
3850 23 635 399 392 388
3851 22 411 409 393 388
3852 22 414 409 393 388
3853 23 46 409 393 388
3854 18 662 660 394 389
3855 18 664 660 394 389
3856 18 665 660 394 389
3857 16 355 407 395 367
3858 12 360 407 395 367
3859 12 381 407 395 367
3860 14 410 407 395 367
3861 12 425 407 395 367
3862 15 355 407 395 396
3863 11 360 407 395 396
3864 11 381 407 395 396
3865 13 410 407 395 396
3866 11 425 407 395 396
3867 3 351 397 400 367
3868 4 351 397 400 398
3869 1 370 397 400 367
3870 2 370 397 400 398
3871 5 9 397 400 367
3872 6 9 397 400 398
3873 5 637 397 400 367
3874 6 637 397 400 398
3875 3 55 397 400 367
3876 4 55 397 400 398
3877 11 351 397 637 638
3878 12 351 397 637 273
3879 13 370 397 637 638
3880 14 370 397 637 273
3881 11 400 397 637 638
3882 12 400 397 637 273
3883 15 9 397 637 638
3884 16 9 397 637 273
3885 11 55 397 637 638
3886 12 55 397 637 273
3887 20 384 398 400 367
3888 20 384 398 400 397
3889 20 402 398 400 367
3890 20 402 398 400 397
3891 20 403 398 400 367
3892 20 403 398 400 397
3893 22 384 398 402 53
3894 22 400 398 402 53
3895 22 403 398 402 53
3896 22 384 398 403 631
3897 22 400 398 403 631
3898 22 402 398 403 631
3899 20 392 399 401 387
3900 20 392 399 401 599
3901 19 404 399 401 387
3902 19 404 399 401 599
3903 19 635 399 401 387
3904 19 635 399 401 599
3905 21 392 399 404 378
3906 21 401 399 404 378
3907 24 635 399 404 378
3908 21 392 399 635 630
3909 21 401 399 635 630
3910 24 404 399 635 630
3911 1 632 599 401 387
3912 3 602 599 401 387
3913 3 613 599 401 387
3914 5 627 599 401 387
3915 5 667 599 401 387
3916 2 632 599 401 399
3917 4 602 599 401 399
3918 4 613 599 401 399
3919 6 627 599 401 399
3920 6 667 599 401 399
3921 22 633 631 403 398
3922 23 664 631 403 398
3923 22 636 631 403 398
3924 11 602 629 405 406
3925 11 623 629 405 406
3926 13 632 629 405 406
3927 15 281 629 405 406
3928 11 327 629 405 406
3929 12 602 629 405 1
3930 12 623 629 405 1
3931 14 632 629 405 1
3932 16 281 629 405 1
3933 12 327 629 405 1
3934 10 355 407 410 357
3935 9 355 407 410 408
3936 8 360 407 410 357
3937 7 360 407 410 408
3938 8 381 407 410 357
3939 7 381 407 410 408
3940 10 395 407 410 357
3941 9 395 407 410 408
3942 8 425 407 410 357
3943 7 425 407 410 408
3944 6 355 407 425 423
3945 5 355 407 425 451
3946 4 360 407 425 423
3947 3 360 407 425 451
3948 4 381 407 425 423
3949 3 381 407 425 451
3950 6 395 407 425 423
3951 5 395 407 425 451
3952 2 410 407 425 423
3953 1 410 407 425 451
3954 17 412 408 410 357
3955 17 412 408 410 407
3956 17 413 408 410 357
3957 17 413 408 410 407
3958 17 478 408 410 357
3959 17 478 408 410 407
3960 18 410 408 412 379
3961 18 413 408 412 379
3962 18 478 408 412 379
3963 18 410 408 413 389
3964 18 412 408 413 389
3965 18 478 408 413 389
3966 18 410 408 478 473
3967 18 412 408 478 473
3968 18 413 408 478 473
3969 20 393 409 411 337
3970 20 393 409 411 41
3971 20 414 409 411 337
3972 20 414 409 411 41
3973 19 46 409 411 337
3974 19 46 409 411 41
3975 22 393 409 414 472
3976 22 411 409 414 472
3977 23 46 409 414 472
3978 22 474 472 414 409
3979 22 476 472 414 409
3980 22 477 472 414 409
3981 1 424 421 474 471
3982 2 424 421 474 472
3983 3 495 421 474 471
3984 4 495 421 474 472
3985 3 119 421 474 471
3986 4 119 421 474 472
3987 5 365 421 474 471
3988 6 365 421 474 472
3989 5 153 421 474 471
3990 6 153 421 474 472
3991 7 474 421 424 422
3992 8 474 421 424 471
3993 7 495 421 424 422
3994 8 495 421 424 471
3995 7 119 421 424 422
3996 8 119 421 424 471
3997 9 365 421 424 422
3998 10 365 421 424 471
3999 9 153 421 424 422
4000 10 153 421 424 471
4001 4 474 421 495 493
4002 3 474 421 495 125
4003 2 424 421 495 493
4004 1 424 421 495 125
4005 4 119 421 495 493
4006 3 119 421 495 125
4007 6 365 421 495 493
4008 5 365 421 495 125
4009 6 153 421 495 493
4010 5 153 421 495 125
4011 17 426 422 424 421
4012 17 426 422 424 471
4013 17 427 422 424 421
4014 17 427 422 424 471
4015 17 448 422 424 421
4016 17 448 422 424 471
4017 18 424 422 426 117
4018 18 427 422 426 117
4019 18 448 422 426 117
4020 18 424 422 427 359
4021 18 426 422 427 359
4022 18 448 422 427 359
4023 18 424 422 448 443
4024 18 426 422 448 443
4025 18 427 422 448 443
4026 19 456 423 425 451
4027 19 456 423 425 407
4028 20 428 423 425 451
4029 20 428 423 425 407
4030 20 363 423 425 451
4031 20 363 423 425 407
4032 21 425 423 456 452
4033 21 428 423 456 452
4034 21 363 423 456 452
4035 22 425 423 428 442
4036 23 456 423 428 442
4037 22 363 423 428 442
4038 10 459 471 424 421
4039 8 474 471 424 421
4040 8 485 471 424 421
4041 10 499 471 424 421
4042 8 361 471 424 421
4043 9 459 471 424 422
4044 7 474 471 424 422
4045 7 485 471 424 422
4046 9 499 471 424 422
4047 7 361 471 424 422
4048 6 439 451 425 423
4049 4 484 451 425 423
4050 2 454 451 425 423
4051 6 479 451 425 423
4052 4 381 451 425 423
4053 5 439 451 425 407
4054 3 484 451 425 407
4055 1 454 451 425 407
4056 5 479 451 425 407
4057 3 381 451 425 407
4058 22 444 442 428 423
4059 22 446 442 428 423
4060 22 447 442 428 423
4061 8 434 431 464 461
4062 7 434 431 464 462
4063 8 445 431 464 461
4064 7 445 431 464 462
4065 10 459 431 464 461
4066 9 459 431 464 462
4067 10 499 431 464 461
4068 9 499 431 464 462
4069 8 569 431 464 461
4070 7 569 431 464 462
4071 2 464 431 434 432
4072 1 464 431 434 461
4073 4 445 431 434 432
4074 3 445 431 434 461
4075 6 459 431 434 432
4076 5 459 431 434 461
4077 6 499 431 434 432
4078 5 499 431 434 461
4079 4 569 431 434 432
4080 3 569 431 434 461
4081 2 464 431 445 443
4082 1 464 431 445 555
4083 4 434 431 445 443
4084 3 434 431 445 555
4085 6 459 431 445 443
4086 5 459 431 445 555
4087 6 499 431 445 443
4088 5 499 431 445 555
4089 4 569 431 445 443
4090 3 569 431 445 555
4091 14 464 431 459 471
4092 13 464 431 459 460
4093 12 434 431 459 471
4094 11 434 431 459 460
4095 12 445 431 459 471
4096 11 445 431 459 460
4097 16 499 431 459 471
4098 15 499 431 459 460
4099 12 569 431 459 471
4100 11 569 431 459 460
4101 14 464 431 499 471
4102 13 464 431 499 500
4103 12 434 431 499 471
4104 11 434 431 499 500
4105 12 445 431 499 471
4106 11 445 431 499 500
4107 16 459 431 499 471
4108 15 459 431 499 500
4109 12 569 431 499 471
4110 11 569 431 499 500
4111 1 464 431 569 555
4112 2 464 431 569 567
4113 3 434 431 569 555
4114 4 434 431 569 567
4115 3 445 431 569 555
4116 4 445 431 569 567
4117 5 459 431 569 555
4118 6 459 431 569 567
4119 5 499 431 569 555
4120 6 499 431 569 567
4121 20 436 432 434 431
4122 20 436 432 434 461
4123 20 437 432 434 431
4124 20 437 432 434 461
4125 20 542 432 434 431
4126 20 542 432 434 461
4127 22 434 432 436 443
4128 22 437 432 436 443
4129 22 542 432 436 443
4130 22 434 432 437 453
4131 22 436 432 437 453
4132 22 542 432 437 453
4133 22 434 432 542 537
4134 22 436 432 542 537
4135 22 437 432 542 537
4136 19 457 433 435 481
4137 19 457 433 435 105
4138 19 438 433 435 481
4139 19 438 433 435 105
4140 20 110 433 435 481
4141 20 110 433 435 105
4142 21 435 433 457 452
4143 24 438 433 457 452
4144 21 110 433 457 452
4145 21 435 433 438 536
4146 24 457 433 438 536
4147 21 110 433 438 536
4148 3 455 461 434 431
4149 1 464 461 434 431
4150 5 113 461 434 431
4151 3 159 461 434 431
4152 5 573 461 434 431
4153 4 455 461 434 432
4154 2 464 461 434 432
4155 6 113 461 434 432
4156 4 159 461 434 432
4157 6 573 461 434 432
4158 2 454 481 435 433
4159 4 484 481 435 433
4160 6 93 481 435 433
4161 6 385 481 435 433
4162 4 139 481 435 433
4163 1 454 481 435 105
4164 3 484 481 435 105
4165 5 93 481 435 105
4166 5 385 481 435 105
4167 3 139 481 435 105
4168 22 445 443 436 432
4169 23 448 443 436 432
4170 23 511 443 436 432
4171 22 455 453 437 432
4172 22 458 453 437 432
4173 23 90 453 437 432
4174 18 538 536 438 433
4175 18 540 536 438 433
4176 18 541 536 438 433
4177 12 425 451 439 491
4178 12 484 451 439 491
4179 14 454 451 439 491
4180 16 479 451 439 491
4181 12 381 451 439 491
4182 11 425 451 439 440
4183 11 484 451 439 440
4184 13 454 451 439 440
4185 15 479 451 439 440
4186 11 381 451 439 440
4187 12 444 491 439 451
4188 12 465 491 439 451
4189 16 479 491 439 451
4190 14 494 491 439 451
4191 12 509 491 439 451
4192 11 444 491 439 440
4193 11 465 491 439 440
4194 15 479 491 439 440
4195 13 494 491 439 440
4196 11 509 491 439 440
4197 8 444 441 494 491
4198 7 444 441 494 492
4199 8 475 441 494 491
4200 7 475 441 494 492
4201 10 513 441 494 491
4202 9 513 441 494 492
4203 8 99 441 494 491
4204 7 99 441 494 492
4205 10 133 441 494 491
4206 9 133 441 494 492
4207 2 494 441 444 442
4208 1 494 441 444 491
4209 4 475 441 444 442
4210 3 475 441 444 491
4211 6 513 441 444 442
4212 5 513 441 444 491
4213 4 99 441 444 442
4214 3 99 441 444 491
4215 6 133 441 444 442
4216 5 133 441 444 491
4217 2 494 441 475 473
4218 1 494 441 475 145
4219 4 444 441 475 473
4220 3 444 441 475 145
4221 6 513 441 475 473
4222 5 513 441 475 145
4223 4 99 441 475 473
4224 3 99 441 475 145
4225 6 133 441 475 473
4226 5 133 441 475 145
4227 13 494 441 513 514
4228 14 494 441 513 229
4229 11 444 441 513 514
4230 12 444 441 513 229
4231 11 475 441 513 514
4232 12 475 441 513 229
4233 11 99 441 513 514
4234 12 99 441 513 229
4235 15 133 441 513 514
4236 16 133 441 513 229
4237 20 428 442 444 441
4238 20 428 442 444 491
4239 20 446 442 444 441
4240 20 446 442 444 491
4241 20 447 442 444 441
4242 20 447 442 444 491
4243 22 428 442 446 97
4244 22 444 442 446 97
4245 22 447 442 446 97
4246 22 428 442 447 507
4247 22 444 442 447 507
4248 22 446 442 447 507
4249 20 436 443 445 431
4250 20 436 443 445 555
4251 19 448 443 445 431
4252 19 448 443 445 555
4253 19 511 443 445 431
4254 19 511 443 445 555
4255 21 436 443 448 422
4256 21 445 443 448 422
4257 24 511 443 448 422
4258 21 436 443 511 506
4259 21 445 443 511 506
4260 24 448 443 511 506
4261 5 439 491 444 441
4262 3 465 491 444 441
4263 5 479 491 444 441
4264 1 494 491 444 441
4265 3 509 491 444 441
4266 6 439 491 444 442
4267 4 465 491 444 442
4268 6 479 491 444 442
4269 2 494 491 444 442
4270 4 509 491 444 442
4271 1 508 555 445 431
4272 5 543 555 445 431
4273 3 558 555 445 431
4274 3 569 555 445 431
4275 5 583 555 445 431
4276 2 508 555 445 443
4277 6 543 555 445 443
4278 4 558 555 445 443
4279 4 569 555 445 443
4280 6 583 555 445 443
4281 22 509 507 447 442
4282 23 540 507 447 442
4283 22 512 507 447 442
4284 11 558 505 449 450
4285 13 508 505 449 450
4286 11 579 505 449 450
4287 11 203 505 449 450
4288 15 237 505 449 450
4289 12 558 505 449 125
4290 14 508 505 449 125
4291 12 579 505 449 125
4292 12 203 505 449 125
4293 16 237 505 449 125
4294 3 425 451 484 481
4295 4 425 451 484 482
4296 5 439 451 484 481
4297 6 439 451 484 482
4298 1 454 451 484 481
4299 2 454 451 484 482
4300 5 479 451 484 481
4301 6 479 451 484 482
4302 3 381 451 484 481
4303 4 381 451 484 482
4304 7 425 451 454 452
4305 8 425 451 454 481
4306 9 439 451 454 452
4307 10 439 451 454 481
4308 7 484 451 454 452
4309 8 484 451 454 481
4310 9 479 451 454 452
4311 10 479 451 454 481
4312 7 381 451 454 452
4313 8 381 451 454 481
4314 12 425 451 479 491
4315 11 425 451 479 480
4316 16 439 451 479 491
4317 15 439 451 479 480
4318 12 484 451 479 491
4319 11 484 451 479 480
4320 14 454 451 479 491
4321 13 454 451 479 480
4322 12 381 451 479 491
4323 11 381 451 479 480
4324 17 456 452 454 451
4325 17 456 452 454 481
4326 17 457 452 454 451
4327 17 457 452 454 481
4328 17 354 452 454 451
4329 17 354 452 454 481
4330 18 454 452 456 423
4331 18 457 452 456 423
4332 18 354 452 456 423
4333 18 454 452 457 433
4334 18 456 452 457 433
4335 18 354 452 457 433
4336 20 437 453 455 461
4337 20 437 453 455 85
4338 20 458 453 455 461
4339 20 458 453 455 85
4340 19 90 453 455 461
4341 19 90 453 455 85
4342 22 437 453 458 348
4343 22 455 453 458 348
4344 23 90 453 458 348
4345 8 435 481 454 451
4346 8 484 481 454 451
4347 10 93 481 454 451
4348 10 385 481 454 451
4349 8 139 481 454 451
4350 7 435 481 454 452
4351 7 484 481 454 452
4352 9 93 481 454 452
4353 9 385 481 454 452
4354 7 139 481 454 452
4355 4 434 461 455 453
4356 2 464 461 455 453
4357 6 113 461 455 453
4358 4 159 461 455 453
4359 6 573 461 455 453
4360 3 434 461 455 85
4361 1 464 461 455 85
4362 5 113 461 455 85
4363 3 159 461 455 85
4364 5 573 461 455 85
4365 14 424 471 459 431
4366 12 474 471 459 431
4367 12 485 471 459 431
4368 16 499 471 459 431
4369 12 361 471 459 431
4370 13 424 471 459 460
4371 11 474 471 459 460
4372 11 485 471 459 460
4373 15 499 471 459 460
4374 11 361 471 459 460
4375 8 434 461 464 431
4376 7 434 461 464 462
4377 8 455 461 464 431
4378 7 455 461 464 462
4379 10 113 461 464 431
4380 9 113 461 464 462
4381 8 159 461 464 431
4382 7 159 461 464 462
4383 10 573 461 464 431
4384 9 573 461 464 462
4385 11 434 461 573 574
4386 12 434 461 573 169
4387 11 455 461 573 574
4388 12 455 461 573 169
4389 13 464 461 573 574
4390 14 464 461 573 169
4391 15 113 461 573 574
4392 16 113 461 573 169
4393 11 159 461 573 574
4394 12 159 461 573 169
4395 17 466 462 464 431
4396 17 466 462 464 461
4397 17 467 462 464 431
4398 17 467 462 464 461
4399 17 488 462 464 431
4400 17 488 462 464 461
4401 18 464 462 466 157
4402 18 467 462 466 157
4403 18 488 462 466 157
4404 18 464 462 467 567
4405 18 466 462 467 567
4406 18 488 462 467 567
4407 18 464 462 488 483
4408 18 466 462 488 483
4409 18 467 462 488 483
4410 19 496 463 465 491
4411 19 496 463 465 535
4412 20 468 463 465 491
4413 20 468 463 465 535
4414 20 571 463 465 491
4415 20 571 463 465 535
4416 21 465 463 496 492
4417 21 468 463 496 492
4418 21 571 463 496 492
4419 22 465 463 468 482
4420 23 496 463 468 482
4421 22 571 463 468 482
4422 22 465 463 571 566
4423 23 496 463 571 566
4424 22 468 463 571 566
4425 6 439 491 465 463
4426 4 444 491 465 463
4427 6 479 491 465 463
4428 2 494 491 465 463
4429 4 509 491 465 463
4430 5 439 491 465 535
4431 3 444 491 465 535
4432 5 479 491 465 535
4433 1 494 491 465 535
4434 3 509 491 465 535
4435 4 509 535 465 463
4436 6 523 535 465 463
4437 4 568 535 465 463
4438 2 538 535 465 463
4439 6 563 535 465 463
4440 3 509 535 465 491
4441 5 523 535 465 491
4442 3 568 535 465 491
4443 1 538 535 465 491
4444 5 563 535 465 491
4445 21 560 567 467 462
4446 21 569 567 467 462
4447 24 572 567 467 462
4448 22 484 482 468 463
4449 22 486 482 468 463
4450 22 487 482 468 463
4451 11 519 565 469 470
4452 13 538 565 469 470
4453 11 568 565 469 470
4454 15 177 565 469 470
4455 11 223 565 469 470
4456 12 519 565 469 105
4457 14 538 565 469 105
4458 12 568 565 469 105
4459 16 177 565 469 105
4460 12 223 565 469 105
4461 1 424 471 474 421
4462 2 424 471 474 472
4463 5 459 471 474 421
4464 6 459 471 474 472
4465 3 485 471 474 421
4466 4 485 471 474 472
4467 5 499 471 474 421
4468 6 499 471 474 472
4469 3 361 471 474 421
4470 4 361 471 474 472
4471 2 424 471 485 483
4472 1 424 471 485 347
4473 6 459 471 485 483
4474 5 459 471 485 347
4475 4 474 471 485 483
4476 3 474 471 485 347
4477 6 499 471 485 483
4478 5 499 471 485 347
4479 4 361 471 485 483
4480 3 361 471 485 347
4481 14 424 471 499 431
4482 13 424 471 499 500
4483 16 459 471 499 431
4484 15 459 471 499 500
4485 12 474 471 499 431
4486 11 474 471 499 500
4487 12 485 471 499 431
4488 11 485 471 499 500
4489 12 361 471 499 431
4490 11 361 471 499 500
4491 20 476 472 474 421
4492 20 476 472 474 471
4493 20 477 472 474 421
4494 20 477 472 474 471
4495 20 414 472 474 421
4496 20 414 472 474 471
4497 22 474 472 476 483
4498 22 477 472 476 483
4499 22 414 472 476 483
4500 22 474 472 477 493
4501 22 476 472 477 493
4502 22 414 472 477 493
4503 19 497 473 475 441
4504 19 497 473 475 145
4505 19 478 473 475 441
4506 19 478 473 475 145
4507 20 150 473 475 441
4508 20 150 473 475 145
4509 21 475 473 497 492
4510 24 478 473 497 492
4511 21 150 473 497 492
4512 21 475 473 478 408
4513 24 497 473 478 408
4514 21 150 473 478 408
4515 22 485 483 476 472
4516 23 488 483 476 472
4517 23 383 483 476 472
4518 22 495 493 477 472
4519 22 498 493 477 472
4520 23 130 493 477 472
4521 16 439 491 479 451
4522 12 444 491 479 451
4523 12 465 491 479 451
4524 14 494 491 479 451
4525 12 509 491 479 451
4526 15 439 491 479 480
4527 11 444 491 479 480
4528 11 465 491 479 480
4529 13 494 491 479 480
4530 11 509 491 479 480
4531 3 435 481 484 451
4532 4 435 481 484 482
4533 1 454 481 484 451
4534 2 454 481 484 482
4535 5 93 481 484 451
4536 6 93 481 484 482
4537 5 385 481 484 451
4538 6 385 481 484 482
4539 3 139 481 484 451
4540 4 139 481 484 482
4541 20 468 482 484 451
4542 20 468 482 484 481
4543 20 486 482 484 451
4544 20 486 482 484 481
4545 20 487 482 484 451
4546 20 487 482 484 481
4547 22 468 482 486 137
4548 22 484 482 486 137
4549 22 487 482 486 137
4550 22 468 482 487 379
4551 22 484 482 487 379
4552 22 486 482 487 379
4553 20 476 483 485 471
4554 20 476 483 485 347
4555 19 488 483 485 471
4556 19 488 483 485 347
4557 19 383 483 485 471
4558 19 383 483 485 347
4559 21 476 483 488 462
4560 21 485 483 488 462
4561 24 383 483 488 462
4562 10 439 491 494 441
4563 9 439 491 494 492
4564 8 444 491 494 441
4565 7 444 491 494 492
4566 8 465 491 494 441
4567 7 465 491 494 492
4568 10 479 491 494 441
4569 9 479 491 494 492
4570 8 509 491 494 441
4571 7 509 491 494 492
4572 6 439 491 509 507
4573 5 439 491 509 535
4574 4 444 491 509 507
4575 3 444 491 509 535
4576 4 465 491 509 507
4577 3 465 491 509 535
4578 6 479 491 509 507
4579 5 479 491 509 535
4580 2 494 491 509 507
4581 1 494 491 509 535
4582 17 496 492 494 441
4583 17 496 492 494 491
4584 17 497 492 494 441
4585 17 497 492 494 491
4586 17 562 492 494 441
4587 17 562 492 494 491
4588 18 494 492 496 463
4589 18 497 492 496 463
4590 18 562 492 496 463
4591 18 494 492 497 473
4592 18 496 492 497 473
4593 18 562 492 497 473
4594 18 494 492 562 557
4595 18 496 492 562 557
4596 18 497 492 562 557
4597 20 477 493 495 421
4598 20 477 493 495 125
4599 20 498 493 495 421
4600 20 498 493 495 125
4601 19 130 493 495 421
4602 19 130 493 495 125
4603 22 477 493 498 556
4604 22 495 493 498 556
4605 23 130 493 498 556
4606 22 558 556 498 493
4607 22 560 556 498 493
4608 22 561 556 498 493
4609 1 508 505 558 555
4610 2 508 505 558 556
4611 3 579 505 558 555
4612 4 579 505 558 556
4613 3 203 505 558 555
4614 4 203 505 558 556
4615 5 449 505 558 555
4616 6 449 505 558 556
4617 5 237 505 558 555
4618 6 237 505 558 556
4619 7 558 505 508 506
4620 8 558 505 508 555
4621 7 579 505 508 506
4622 8 579 505 508 555
4623 7 203 505 508 506
4624 8 203 505 508 555
4625 9 449 505 508 506
4626 10 449 505 508 555
4627 9 237 505 508 506
4628 10 237 505 508 555
4629 4 558 505 579 577
4630 3 558 505 579 209
4631 2 508 505 579 577
4632 1 508 505 579 209
4633 4 203 505 579 577
4634 3 203 505 579 209
4635 6 449 505 579 577
4636 5 449 505 579 209
4637 6 237 505 579 577
4638 5 237 505 579 209
4639 17 510 506 508 505
4640 17 510 506 508 555
4641 17 511 506 508 505
4642 17 511 506 508 555
4643 17 532 506 508 505
4644 17 532 506 508 555
4645 18 508 506 510 201
4646 18 511 506 510 201
4647 18 532 506 510 201
4648 18 508 506 511 443
4649 18 510 506 511 443
4650 18 532 506 511 443
4651 18 508 506 532 527
4652 18 510 506 532 527
4653 18 511 506 532 527
4654 19 540 507 509 535
4655 19 540 507 509 491
4656 20 512 507 509 535
4657 20 512 507 509 491
4658 20 447 507 509 535
4659 20 447 507 509 491
4660 21 509 507 540 536
4661 21 512 507 540 536
4662 21 447 507 540 536
4663 22 509 507 512 526
4664 23 540 507 512 526
4665 22 447 507 512 526
4666 10 543 555 508 505
4667 8 558 555 508 505
4668 8 569 555 508 505
4669 10 583 555 508 505
4670 8 445 555 508 505
4671 9 543 555 508 506
4672 7 558 555 508 506
4673 7 569 555 508 506
4674 9 583 555 508 506
4675 7 445 555 508 506
4676 6 523 535 509 507
4677 4 568 535 509 507
4678 2 538 535 509 507
4679 6 563 535 509 507
4680 4 465 535 509 507
4681 5 523 535 509 491
4682 3 568 535 509 491
4683 1 538 535 509 491
4684 5 563 535 509 491
4685 3 465 535 509 491
4686 22 528 526 512 507
4687 22 530 526 512 507
4688 22 531 526 512 507
4689 8 518 515 548 545
4690 7 518 515 548 546
4691 8 529 515 548 545
4692 7 529 515 548 546
4693 10 543 515 548 545
4694 9 543 515 548 546
4695 10 583 515 548 545
4696 9 583 515 548 546
4697 8 653 515 548 545
4698 7 653 515 548 546
4699 2 548 515 518 516
4700 1 548 515 518 545
4701 4 529 515 518 516
4702 3 529 515 518 545
4703 6 543 515 518 516
4704 5 543 515 518 545
4705 6 583 515 518 516
4706 5 583 515 518 545
4707 4 653 515 518 516
4708 3 653 515 518 545
4709 2 548 515 529 527
4710 1 548 515 529 639
4711 4 518 515 529 527
4712 3 518 515 529 639
4713 6 543 515 529 527
4714 5 543 515 529 639
4715 6 583 515 529 527
4716 5 583 515 529 639
4717 4 653 515 529 527
4718 3 653 515 529 639
4719 14 548 515 543 555
4720 13 548 515 543 544
4721 12 518 515 543 555
4722 11 518 515 543 544
4723 12 529 515 543 555
4724 11 529 515 543 544
4725 16 583 515 543 555
4726 15 583 515 543 544
4727 12 653 515 543 555
4728 11 653 515 543 544
4729 14 548 515 583 555
4730 13 548 515 583 584
4731 12 518 515 583 555
4732 11 518 515 583 584
4733 12 529 515 583 555
4734 11 529 515 583 584
4735 16 543 515 583 555
4736 15 543 515 583 584
4737 12 653 515 583 555
4738 11 653 515 583 584
4739 1 548 515 653 639
4740 2 548 515 653 651
4741 3 518 515 653 639
4742 4 518 515 653 651
4743 3 529 515 653 639
4744 4 529 515 653 651
4745 5 543 515 653 639
4746 6 543 515 653 651
4747 5 583 515 653 639
4748 6 583 515 653 651
4749 20 520 516 518 515
4750 20 520 516 518 545
4751 20 521 516 518 515
4752 20 521 516 518 545
4753 20 626 516 518 515
4754 20 626 516 518 545
4755 22 518 516 520 527
4756 22 521 516 520 527
4757 22 626 516 520 527
4758 22 518 516 521 537
4759 22 520 516 521 537
4760 22 626 516 521 537
4761 22 518 516 626 621
4762 22 520 516 626 621
4763 22 521 516 626 621
4764 19 541 517 519 565
4765 19 541 517 519 189
4766 19 522 517 519 565
4767 19 522 517 519 189
4768 20 194 517 519 565
4769 20 194 517 519 189
4770 21 519 517 541 536
4771 24 522 517 541 536
4772 21 194 517 541 536
4773 21 519 517 522 620
4774 24 541 517 522 620
4775 21 194 517 522 620
4776 3 539 545 518 515
4777 1 548 545 518 515
4778 5 197 545 518 515
4779 3 243 545 518 515
4780 5 657 545 518 515
4781 4 539 545 518 516
4782 2 548 545 518 516
4783 6 197 545 518 516
4784 4 243 545 518 516
4785 6 657 545 518 516
4786 2 538 565 519 517
4787 4 568 565 519 517
4788 6 177 565 519 517
4789 6 469 565 519 517
4790 4 223 565 519 517
4791 1 538 565 519 189
4792 3 568 565 519 189
4793 5 177 565 519 189
4794 5 469 565 519 189
4795 3 223 565 519 189
4796 22 529 527 520 516
4797 23 532 527 520 516
4798 23 595 527 520 516
4799 22 539 537 521 516
4800 22 542 537 521 516
4801 23 174 537 521 516
4802 18 622 620 522 517
4803 18 624 620 522 517
4804 18 625 620 522 517
4805 12 509 535 523 575
4806 12 568 535 523 575
4807 14 538 535 523 575
4808 16 563 535 523 575
4809 12 465 535 523 575
4810 11 509 535 523 524
4811 11 568 535 523 524
4812 13 538 535 523 524
4813 15 563 535 523 524
4814 11 465 535 523 524
4815 12 528 575 523 535
4816 12 549 575 523 535
4817 16 563 575 523 535
4818 14 578 575 523 535
4819 12 593 575 523 535
4820 11 528 575 523 524
4821 11 549 575 523 524
4822 15 563 575 523 524
4823 13 578 575 523 524
4824 11 593 575 523 524
4825 8 528 525 578 575
4826 7 528 525 578 576
4827 8 559 525 578 575
4828 7 559 525 578 576
4829 10 597 525 578 575
4830 9 597 525 578 576
4831 8 183 525 578 575
4832 7 183 525 578 576
4833 10 217 525 578 575
4834 9 217 525 578 576
4835 2 578 525 528 526
4836 1 578 525 528 575
4837 4 559 525 528 526
4838 3 559 525 528 575
4839 6 597 525 528 526
4840 5 597 525 528 575
4841 4 183 525 528 526
4842 3 183 525 528 575
4843 6 217 525 528 526
4844 5 217 525 528 575
4845 2 578 525 559 557
4846 1 578 525 559 229
4847 4 528 525 559 557
4848 3 528 525 559 229
4849 6 597 525 559 557
4850 5 597 525 559 229
4851 4 183 525 559 557
4852 3 183 525 559 229
4853 6 217 525 559 557
4854 5 217 525 559 229
4855 13 578 525 597 598
4856 14 578 525 597 313
4857 11 528 525 597 598
4858 12 528 525 597 313
4859 11 559 525 597 598
4860 12 559 525 597 313
4861 11 183 525 597 598
4862 12 183 525 597 313
4863 15 217 525 597 598
4864 16 217 525 597 313
4865 20 512 526 528 525
4866 20 512 526 528 575
4867 20 530 526 528 525
4868 20 530 526 528 575
4869 20 531 526 528 525
4870 20 531 526 528 575
4871 22 512 526 530 181
4872 22 528 526 530 181
4873 22 531 526 530 181
4874 22 512 526 531 591
4875 22 528 526 531 591
4876 22 530 526 531 591
4877 20 520 527 529 515
4878 20 520 527 529 639
4879 19 532 527 529 515
4880 19 532 527 529 639
4881 19 595 527 529 515
4882 19 595 527 529 639
4883 21 520 527 532 506
4884 21 529 527 532 506
4885 24 595 527 532 506
4886 21 520 527 595 590
4887 21 529 527 595 590
4888 24 532 527 595 590
4889 5 523 575 528 525
4890 3 549 575 528 525
4891 5 563 575 528 525
4892 1 578 575 528 525
4893 3 593 575 528 525
4894 6 523 575 528 526
4895 4 549 575 528 526
4896 6 563 575 528 526
4897 2 578 575 528 526
4898 4 593 575 528 526
4899 1 592 639 529 515
4900 5 627 639 529 515
4901 3 642 639 529 515
4902 3 653 639 529 515
4903 5 667 639 529 515
4904 2 592 639 529 527
4905 6 627 639 529 527
4906 4 642 639 529 527
4907 4 653 639 529 527
4908 6 667 639 529 527
4909 22 593 591 531 526
4910 23 624 591 531 526
4911 22 596 591 531 526
4912 11 642 589 533 534
4913 13 592 589 533 534
4914 11 663 589 533 534
4915 11 287 589 533 534
4916 15 321 589 533 534
4917 12 642 589 533 209
4918 14 592 589 533 209
4919 12 663 589 533 209
4920 12 287 589 533 209
4921 16 321 589 533 209
4922 3 509 535 568 565
4923 4 509 535 568 566
4924 5 523 535 568 565
4925 6 523 535 568 566
4926 1 538 535 568 565
4927 2 538 535 568 566
4928 5 563 535 568 565
4929 6 563 535 568 566
4930 3 465 535 568 565
4931 4 465 535 568 566
4932 7 509 535 538 536
4933 8 509 535 538 565
4934 9 523 535 538 536
4935 10 523 535 538 565
4936 7 568 535 538 536
4937 8 568 535 538 565
4938 9 563 535 538 536
4939 10 563 535 538 565
4940 7 465 535 538 536
4941 8 465 535 538 565
4942 12 509 535 563 575
4943 11 509 535 563 564
4944 16 523 535 563 575
4945 15 523 535 563 564
4946 12 568 535 563 575
4947 11 568 535 563 564
4948 14 538 535 563 575
4949 13 538 535 563 564
4950 12 465 535 563 575
4951 11 465 535 563 564
4952 17 540 536 538 535
4953 17 540 536 538 565
4954 17 541 536 538 535
4955 17 541 536 538 565
4956 17 438 536 538 535
4957 17 438 536 538 565
4958 18 538 536 540 507
4959 18 541 536 540 507
4960 18 438 536 540 507
4961 18 538 536 541 517
4962 18 540 536 541 517
4963 18 438 536 541 517
4964 20 521 537 539 545
4965 20 521 537 539 169
4966 20 542 537 539 545
4967 20 542 537 539 169
4968 19 174 537 539 545
4969 19 174 537 539 169
4970 22 521 537 542 432
4971 22 539 537 542 432
4972 23 174 537 542 432
4973 8 519 565 538 535
4974 8 568 565 538 535
4975 10 177 565 538 535
4976 10 469 565 538 535
4977 8 223 565 538 535
4978 7 519 565 538 536
4979 7 568 565 538 536
4980 9 177 565 538 536
4981 9 469 565 538 536
4982 7 223 565 538 536
4983 4 518 545 539 537
4984 2 548 545 539 537
4985 6 197 545 539 537
4986 4 243 545 539 537
4987 6 657 545 539 537
4988 3 518 545 539 169
4989 1 548 545 539 169
4990 5 197 545 539 169
4991 3 243 545 539 169
4992 5 657 545 539 169
4993 14 508 555 543 515
4994 12 558 555 543 515
4995 12 569 555 543 515
4996 16 583 555 543 515
4997 12 445 555 543 515
4998 13 508 555 543 544
4999 11 558 555 543 544
5000 11 569 555 543 544
5001 15 583 555 543 544
5002 11 445 555 543 544
5003 8 518 545 548 515
5004 7 518 545 548 546
5005 8 539 545 548 515
5006 7 539 545 548 546
5007 10 197 545 548 515
5008 9 197 545 548 546
5009 8 243 545 548 515
5010 7 243 545 548 546
5011 10 657 545 548 515
5012 9 657 545 548 546
5013 11 518 545 657 658
5014 12 518 545 657 253
5015 11 539 545 657 658
5016 12 539 545 657 253
5017 13 548 545 657 658
5018 14 548 545 657 253
5019 15 197 545 657 658
5020 16 197 545 657 253
5021 11 243 545 657 658
5022 12 243 545 657 253
5023 17 550 546 548 515
5024 17 550 546 548 545
5025 17 551 546 548 515
5026 17 551 546 548 545
5027 17 572 546 548 515
5028 17 572 546 548 545
5029 18 548 546 550 241
5030 18 551 546 550 241
5031 18 572 546 550 241
5032 18 548 546 551 651
5033 18 550 546 551 651
5034 18 572 546 551 651
5035 18 548 546 572 567
5036 18 550 546 572 567
5037 18 551 546 572 567
5038 19 580 547 549 575
5039 19 580 547 549 619
5040 20 552 547 549 575
5041 20 552 547 549 619
5042 20 655 547 549 575
5043 20 655 547 549 619
5044 21 549 547 580 576
5045 21 552 547 580 576
5046 21 655 547 580 576
5047 22 549 547 552 566
5048 23 580 547 552 566
5049 22 655 547 552 566
5050 22 549 547 655 650
5051 23 580 547 655 650
5052 22 552 547 655 650
5053 6 523 575 549 547
5054 4 528 575 549 547
5055 6 563 575 549 547
5056 2 578 575 549 547
5057 4 593 575 549 547
5058 5 523 575 549 619
5059 3 528 575 549 619
5060 5 563 575 549 619
5061 1 578 575 549 619
5062 3 593 575 549 619
5063 4 593 619 549 547
5064 6 607 619 549 547
5065 4 652 619 549 547
5066 2 622 619 549 547
5067 6 647 619 549 547
5068 3 593 619 549 575
5069 5 607 619 549 575
5070 3 652 619 549 575
5071 1 622 619 549 575
5072 5 647 619 549 575
5073 21 644 651 551 546
5074 21 653 651 551 546
5075 24 656 651 551 546
5076 22 568 566 552 547
5077 22 570 566 552 547
5078 22 571 566 552 547
5079 11 603 649 553 554
5080 13 622 649 553 554
5081 11 652 649 553 554
5082 15 261 649 553 554
5083 11 307 649 553 554
5084 12 603 649 553 189
5085 14 622 649 553 189
5086 12 652 649 553 189
5087 16 261 649 553 189
5088 12 307 649 553 189
5089 1 508 555 558 505
5090 2 508 555 558 556
5091 5 543 555 558 505
5092 6 543 555 558 556
5093 3 569 555 558 505
5094 4 569 555 558 556
5095 5 583 555 558 505
5096 6 583 555 558 556
5097 3 445 555 558 505
5098 4 445 555 558 556
5099 2 508 555 569 567
5100 1 508 555 569 431
5101 6 543 555 569 567
5102 5 543 555 569 431
5103 4 558 555 569 567
5104 3 558 555 569 431
5105 6 583 555 569 567
5106 5 583 555 569 431
5107 4 445 555 569 567
5108 3 445 555 569 431
5109 14 508 555 583 515
5110 13 508 555 583 584
5111 16 543 555 583 515
5112 15 543 555 583 584
5113 12 558 555 583 515
5114 11 558 555 583 584
5115 12 569 555 583 515
5116 11 569 555 583 584
5117 12 445 555 583 515
5118 11 445 555 583 584
5119 20 560 556 558 505
5120 20 560 556 558 555
5121 20 561 556 558 505
5122 20 561 556 558 555
5123 20 498 556 558 505
5124 20 498 556 558 555
5125 22 558 556 560 567
5126 22 561 556 560 567
5127 22 498 556 560 567
5128 22 558 556 561 577
5129 22 560 556 561 577
5130 22 498 556 561 577
5131 19 581 557 559 525
5132 19 581 557 559 229
5133 19 562 557 559 525
5134 19 562 557 559 229
5135 20 234 557 559 525
5136 20 234 557 559 229
5137 21 559 557 581 576
5138 24 562 557 581 576
5139 21 234 557 581 576
5140 21 559 557 562 492
5141 24 581 557 562 492
5142 21 234 557 562 492
5143 22 569 567 560 556
5144 23 572 567 560 556
5145 23 467 567 560 556
5146 22 579 577 561 556
5147 22 582 577 561 556
5148 23 214 577 561 556
5149 16 523 575 563 535
5150 12 528 575 563 535
5151 12 549 575 563 535
5152 14 578 575 563 535
5153 12 593 575 563 535
5154 15 523 575 563 564
5155 11 528 575 563 564
5156 11 549 575 563 564
5157 13 578 575 563 564
5158 11 593 575 563 564
5159 3 519 565 568 535
5160 4 519 565 568 566
5161 1 538 565 568 535
5162 2 538 565 568 566
5163 5 177 565 568 535
5164 6 177 565 568 566
5165 5 469 565 568 535
5166 6 469 565 568 566
5167 3 223 565 568 535
5168 4 223 565 568 566
5169 20 552 566 568 535
5170 20 552 566 568 565
5171 20 570 566 568 535
5172 20 570 566 568 565
5173 20 571 566 568 535
5174 20 571 566 568 565
5175 22 552 566 570 221
5176 22 568 566 570 221
5177 22 571 566 570 221
5178 22 552 566 571 463
5179 22 568 566 571 463
5180 22 570 566 571 463
5181 20 560 567 569 555
5182 20 560 567 569 431
5183 19 572 567 569 555
5184 19 572 567 569 431
5185 19 467 567 569 555
5186 19 467 567 569 431
5187 21 560 567 572 546
5188 21 569 567 572 546
5189 24 467 567 572 546
5190 10 523 575 578 525
5191 9 523 575 578 576
5192 8 528 575 578 525
5193 7 528 575 578 576
5194 8 549 575 578 525
5195 7 549 575 578 576
5196 10 563 575 578 525
5197 9 563 575 578 576
5198 8 593 575 578 525
5199 7 593 575 578 576
5200 6 523 575 593 591
5201 5 523 575 593 619
5202 4 528 575 593 591
5203 3 528 575 593 619
5204 4 549 575 593 591
5205 3 549 575 593 619
5206 6 563 575 593 591
5207 5 563 575 593 619
5208 2 578 575 593 591
5209 1 578 575 593 619
5210 17 580 576 578 525
5211 17 580 576 578 575
5212 17 581 576 578 525
5213 17 581 576 578 575
5214 17 646 576 578 525
5215 17 646 576 578 575
5216 18 578 576 580 547
5217 18 581 576 580 547
5218 18 646 576 580 547
5219 18 578 576 581 557
5220 18 580 576 581 557
5221 18 646 576 581 557
5222 18 578 576 646 641
5223 18 580 576 646 641
5224 18 581 576 646 641
5225 20 561 577 579 505
5226 20 561 577 579 209
5227 20 582 577 579 505
5228 20 582 577 579 209
5229 19 214 577 579 505
5230 19 214 577 579 209
5231 22 561 577 582 640
5232 22 579 577 582 640
5233 23 214 577 582 640
5234 22 642 640 582 577
5235 22 644 640 582 577
5236 22 645 640 582 577
5237 1 592 589 642 639
5238 2 592 589 642 640
5239 3 663 589 642 639
5240 4 663 589 642 640
5241 3 287 589 642 639
5242 4 287 589 642 640
5243 5 533 589 642 639
5244 6 533 589 642 640
5245 5 321 589 642 639
5246 6 321 589 642 640
5247 7 642 589 592 590
5248 8 642 589 592 639
5249 7 663 589 592 590
5250 8 663 589 592 639
5251 7 287 589 592 590
5252 8 287 589 592 639
5253 9 533 589 592 590
5254 10 533 589 592 639
5255 9 321 589 592 590
5256 10 321 589 592 639
5257 4 642 589 663 661
5258 3 642 589 663 293
5259 2 592 589 663 661
5260 1 592 589 663 293
5261 4 287 589 663 661
5262 3 287 589 663 293
5263 6 533 589 663 661
5264 5 533 589 663 293
5265 6 321 589 663 661
5266 5 321 589 663 293
5267 17 594 590 592 589
5268 17 594 590 592 639
5269 17 595 590 592 589
5270 17 595 590 592 639
5271 17 616 590 592 589
5272 17 616 590 592 639
5273 18 592 590 594 285
5274 18 595 590 594 285
5275 18 616 590 594 285
5276 18 592 590 595 527
5277 18 594 590 595 527
5278 18 616 590 595 527
5279 18 592 590 616 611
5280 18 594 590 616 611
5281 18 595 590 616 611
5282 19 624 591 593 619
5283 19 624 591 593 575
5284 20 596 591 593 619
5285 20 596 591 593 575
5286 20 531 591 593 619
5287 20 531 591 593 575
5288 21 593 591 624 620
5289 21 596 591 624 620
5290 21 531 591 624 620
5291 22 593 591 596 610
5292 23 624 591 596 610
5293 22 531 591 596 610
5294 10 627 639 592 589
5295 8 642 639 592 589
5296 8 653 639 592 589
5297 10 667 639 592 589
5298 8 529 639 592 589
5299 9 627 639 592 590
5300 7 642 639 592 590
5301 7 653 639 592 590
5302 9 667 639 592 590
5303 7 529 639 592 590
5304 6 607 619 593 591
5305 4 652 619 593 591
5306 2 622 619 593 591
5307 6 647 619 593 591
5308 4 549 619 593 591
5309 5 607 619 593 575
5310 3 652 619 593 575
5311 1 622 619 593 575
5312 5 647 619 593 575
5313 3 549 619 593 575
5314 22 612 610 596 591
5315 22 614 610 596 591
5316 22 615 610 596 591
5317 8 602 599 632 629
5318 7 602 599 632 630
5319 8 613 599 632 629
5320 7 613 599 632 630
5321 10 627 599 632 629
5322 9 627 599 632 630
5323 10 667 599 632 629
5324 9 667 599 632 630
5325 8 401 599 632 629
5326 7 401 599 632 630
5327 2 632 599 602 600
5328 1 632 599 602 629
5329 4 613 599 602 600
5330 3 613 599 602 629
5331 6 627 599 602 600
5332 5 627 599 602 629
5333 6 667 599 602 600
5334 5 667 599 602 629
5335 4 401 599 602 600
5336 3 401 599 602 629
5337 2 632 599 613 611
5338 1 632 599 613 387
5339 4 602 599 613 611
5340 3 602 599 613 387
5341 6 627 599 613 611
5342 5 627 599 613 387
5343 6 667 599 613 611
5344 5 667 599 613 387
5345 4 401 599 613 611
5346 3 401 599 613 387
5347 14 632 599 627 639
5348 13 632 599 627 628
5349 12 602 599 627 639
5350 11 602 599 627 628
5351 12 613 599 627 639
5352 11 613 599 627 628
5353 16 667 599 627 639
5354 15 667 599 627 628
5355 12 401 599 627 639
5356 11 401 599 627 628
5357 14 632 599 667 639
5358 13 632 599 667 668
5359 12 602 599 667 639
5360 11 602 599 667 668
5361 12 613 599 667 639
5362 11 613 599 667 668
5363 16 627 599 667 639
5364 15 627 599 667 668
5365 12 401 599 667 639
5366 11 401 599 667 668
5367 20 604 600 602 599
5368 20 604 600 602 629
5369 20 605 600 602 599
5370 20 605 600 602 629
5371 20 374 600 602 599
5372 20 374 600 602 629
5373 22 602 600 604 611
5374 22 605 600 604 611
5375 22 374 600 604 611
5376 22 602 600 605 621
5377 22 604 600 605 621
5378 22 374 600 605 621
5379 19 625 601 603 649
5380 19 625 601 603 273
5381 19 606 601 603 649
5382 19 606 601 603 273
5383 20 278 601 603 649
5384 20 278 601 603 273
5385 21 603 601 625 620
5386 24 606 601 625 620
5387 21 278 601 625 620
5388 21 603 601 606 368
5389 24 625 601 606 368
5390 21 278 601 606 368
5391 3 623 629 602 599
5392 1 632 629 602 599
5393 5 281 629 602 599
5394 3 327 629 602 599
5395 5 405 629 602 599
5396 4 623 629 602 600
5397 2 632 629 602 600
5398 6 281 629 602 600
5399 4 327 629 602 600
5400 6 405 629 602 600
5401 2 622 649 603 601
5402 4 652 649 603 601
5403 6 261 649 603 601
5404 6 553 649 603 601
5405 4 307 649 603 601
5406 1 622 649 603 273
5407 3 652 649 603 273
5408 5 261 649 603 273
5409 5 553 649 603 273
5410 3 307 649 603 273
5411 22 613 611 604 600
5412 23 616 611 604 600
5413 23 343 611 604 600
5414 22 623 621 605 600
5415 22 626 621 605 600
5416 23 258 621 605 600
5417 12 593 619 607 659
5418 12 652 619 607 659
5419 14 622 619 607 659
5420 16 647 619 607 659
5421 12 549 619 607 659
5422 11 593 619 607 608
5423 11 652 619 607 608
5424 13 622 619 607 608
5425 15 647 619 607 608
5426 11 549 619 607 608
5427 12 612 659 607 619
5428 12 633 659 607 619
5429 16 647 659 607 619
5430 14 662 659 607 619
5431 12 341 659 607 619
5432 11 612 659 607 608
5433 11 633 659 607 608
5434 15 647 659 607 608
5435 13 662 659 607 608
5436 11 341 659 607 608
5437 8 612 609 662 659
5438 7 612 609 662 660
5439 8 643 609 662 659
5440 7 643 609 662 660
5441 10 345 609 662 659
5442 9 345 609 662 660
5443 8 267 609 662 659
5444 7 267 609 662 660
5445 10 301 609 662 659
5446 9 301 609 662 660
5447 2 662 609 612 610
5448 1 662 609 612 659
5449 4 643 609 612 610
5450 3 643 609 612 659
5451 6 345 609 612 610
5452 5 345 609 612 659
5453 4 267 609 612 610
5454 3 267 609 612 659
5455 6 301 609 612 610
5456 5 301 609 612 659
5457 2 662 609 643 641
5458 1 662 609 643 313
5459 4 612 609 643 641
5460 3 612 609 643 313
5461 6 345 609 643 641
5462 5 345 609 643 313
5463 4 267 609 643 641
5464 3 267 609 643 313
5465 6 301 609 643 641
5466 5 301 609 643 313
5467 20 596 610 612 609
5468 20 596 610 612 659
5469 20 614 610 612 609
5470 20 614 610 612 659
5471 20 615 610 612 609
5472 20 615 610 612 659
5473 22 596 610 614 265
5474 22 612 610 614 265
5475 22 615 610 614 265
5476 22 596 610 615 339
5477 22 612 610 615 339
5478 22 614 610 615 339
5479 20 604 611 613 599
5480 20 604 611 613 387
5481 19 616 611 613 599
5482 19 616 611 613 387
5483 19 343 611 613 599
5484 19 343 611 613 387
5485 21 604 611 616 590
5486 21 613 611 616 590
5487 24 343 611 616 590
5488 5 607 659 612 609
5489 3 633 659 612 609
5490 5 647 659 612 609
5491 1 662 659 612 609
5492 3 341 659 612 609
5493 6 607 659 612 610
5494 4 633 659 612 610
5495 6 647 659 612 610
5496 2 662 659 612 610
5497 4 341 659 612 610
5498 3 593 619 652 649
5499 4 593 619 652 650
5500 5 607 619 652 649
5501 6 607 619 652 650
5502 1 622 619 652 649
5503 2 622 619 652 650
5504 5 647 619 652 649
5505 6 647 619 652 650
5506 3 549 619 652 649
5507 4 549 619 652 650
5508 7 593 619 622 620
5509 8 593 619 622 649
5510 9 607 619 622 620
5511 10 607 619 622 649
5512 7 652 619 622 620
5513 8 652 619 622 649
5514 9 647 619 622 620
5515 10 647 619 622 649
5516 7 549 619 622 620
5517 8 549 619 622 649
5518 12 593 619 647 659
5519 11 593 619 647 648
5520 16 607 619 647 659
5521 15 607 619 647 648
5522 12 652 619 647 659
5523 11 652 619 647 648
5524 14 622 619 647 659
5525 13 622 619 647 648
5526 12 549 619 647 659
5527 11 549 619 647 648
5528 17 624 620 622 619
5529 17 624 620 622 649
5530 17 625 620 622 619
5531 17 625 620 622 649
5532 17 522 620 622 619
5533 17 522 620 622 649
5534 18 622 620 624 591
5535 18 625 620 624 591
5536 18 522 620 624 591
5537 18 622 620 625 601
5538 18 624 620 625 601
5539 18 522 620 625 601
5540 20 605 621 623 629
5541 20 605 621 623 253
5542 20 626 621 623 629
5543 20 626 621 623 253
5544 19 258 621 623 629
5545 19 258 621 623 253
5546 22 605 621 626 516
5547 22 623 621 626 516
5548 23 258 621 626 516
5549 8 603 649 622 619
5550 8 652 649 622 619
5551 10 261 649 622 619
5552 10 553 649 622 619
5553 8 307 649 622 619
5554 7 603 649 622 620
5555 7 652 649 622 620
5556 9 261 649 622 620
5557 9 553 649 622 620
5558 7 307 649 622 620
5559 4 602 629 623 621
5560 2 632 629 623 621
5561 6 281 629 623 621
5562 4 327 629 623 621
5563 6 405 629 623 621
5564 3 602 629 623 253
5565 1 632 629 623 253
5566 5 281 629 623 253
5567 3 327 629 623 253
5568 5 405 629 623 253
5569 14 592 639 627 599
5570 12 642 639 627 599
5571 12 653 639 627 599
5572 16 667 639 627 599
5573 12 529 639 627 599
5574 13 592 639 627 628
5575 11 642 639 627 628
5576 11 653 639 627 628
5577 15 667 639 627 628
5578 11 529 639 627 628
5579 8 602 629 632 599
5580 7 602 629 632 630
5581 8 623 629 632 599
5582 7 623 629 632 630
5583 10 281 629 632 599
5584 9 281 629 632 630
5585 8 327 629 632 599
5586 7 327 629 632 630
5587 10 405 629 632 599
5588 9 405 629 632 630
5589 17 634 630 632 599
5590 17 634 630 632 629
5591 17 635 630 632 599
5592 17 635 630 632 629
5593 17 656 630 632 599
5594 17 656 630 632 629
5595 18 632 630 634 325
5596 18 635 630 634 325
5597 18 656 630 634 325
5598 18 632 630 635 399
5599 18 634 630 635 399
5600 18 656 630 635 399
5601 18 632 630 656 651
5602 18 634 630 656 651
5603 18 635 630 656 651
5604 19 664 631 633 659
5605 19 664 631 633 367
5606 20 636 631 633 659
5607 20 636 631 633 367
5608 20 403 631 633 659
5609 20 403 631 633 367
5610 21 633 631 664 660
5611 21 636 631 664 660
5612 21 403 631 664 660
5613 22 633 631 636 650
5614 23 664 631 636 650
5615 22 403 631 636 650
5616 6 607 659 633 631
5617 4 612 659 633 631
5618 6 647 659 633 631
5619 2 662 659 633 631
5620 4 341 659 633 631
5621 5 607 659 633 367
5622 3 612 659 633 367
5623 5 647 659 633 367
5624 1 662 659 633 367
5625 3 341 659 633 367
5626 22 652 650 636 631
5627 22 654 650 636 631
5628 22 655 650 636 631
5629 1 592 639 642 589
5630 2 592 639 642 640
5631 5 627 639 642 589
5632 6 627 639 642 640
5633 3 653 639 642 589
5634 4 653 639 642 640
5635 5 667 639 642 589
5636 6 667 639 642 640
5637 3 529 639 642 589
5638 4 529 639 642 640
5639 2 592 639 653 651
5640 1 592 639 653 515
5641 6 627 639 653 651
5642 5 627 639 653 515
5643 4 642 639 653 651
5644 3 642 639 653 515
5645 6 667 639 653 651
5646 5 667 639 653 515
5647 4 529 639 653 651
5648 3 529 639 653 515
5649 14 592 639 667 599
5650 13 592 639 667 668
5651 16 627 639 667 599
5652 15 627 639 667 668
5653 12 642 639 667 599
5654 11 642 639 667 668
5655 12 653 639 667 599
5656 11 653 639 667 668
5657 12 529 639 667 599
5658 11 529 639 667 668
5659 20 644 640 642 589
5660 20 644 640 642 639
5661 20 645 640 642 589
5662 20 645 640 642 639
5663 20 582 640 642 589
5664 20 582 640 642 639
5665 22 642 640 644 651
5666 22 645 640 644 651
5667 22 582 640 644 651
5668 22 642 640 645 661
5669 22 644 640 645 661
5670 22 582 640 645 661
5671 19 665 641 643 609
5672 19 665 641 643 313
5673 19 646 641 643 609
5674 19 646 641 643 313
5675 20 318 641 643 609
5676 20 318 641 643 313
5677 21 643 641 665 660
5678 24 646 641 665 660
5679 21 318 641 665 660
5680 21 643 641 646 576
5681 24 665 641 646 576
5682 21 318 641 646 576
5683 22 653 651 644 640
5684 23 656 651 644 640
5685 23 551 651 644 640
5686 22 663 661 645 640
5687 22 666 661 645 640
5688 23 298 661 645 640
5689 16 607 659 647 619
5690 12 612 659 647 619
5691 12 633 659 647 619
5692 14 662 659 647 619
5693 12 341 659 647 619
5694 15 607 659 647 648
5695 11 612 659 647 648
5696 11 633 659 647 648
5697 13 662 659 647 648
5698 11 341 659 647 648
5699 3 603 649 652 619
5700 4 603 649 652 650
5701 1 622 649 652 619
5702 2 622 649 652 650
5703 5 261 649 652 619
5704 6 261 649 652 650
5705 5 553 649 652 619
5706 6 553 649 652 650
5707 3 307 649 652 619
5708 4 307 649 652 650
5709 20 636 650 652 619
5710 20 636 650 652 649
5711 20 654 650 652 619
5712 20 654 650 652 649
5713 20 655 650 652 619
5714 20 655 650 652 649
5715 22 636 650 654 305
5716 22 652 650 654 305
5717 22 655 650 654 305
5718 22 636 650 655 547
5719 22 652 650 655 547
5720 22 654 650 655 547
5721 20 644 651 653 639
5722 20 644 651 653 515
5723 19 656 651 653 639
5724 19 656 651 653 515
5725 19 551 651 653 639
5726 19 551 651 653 515
5727 21 644 651 656 630
5728 21 653 651 656 630
5729 24 551 651 656 630
5730 10 607 659 662 609
5731 9 607 659 662 660
5732 8 612 659 662 609
5733 7 612 659 662 660
5734 8 633 659 662 609
5735 7 633 659 662 660
5736 10 647 659 662 609
5737 9 647 659 662 660
5738 8 341 659 662 609
5739 7 341 659 662 660
5740 17 664 660 662 609
5741 17 664 660 662 659
5742 17 665 660 662 609
5743 17 665 660 662 659
5744 17 394 660 662 609
5745 17 394 660 662 659
5746 18 662 660 664 631
5747 18 665 660 664 631
5748 18 394 660 664 631
5749 18 662 660 665 641
5750 18 664 660 665 641
5751 18 394 660 665 641
5752 20 645 661 663 589
5753 20 645 661 663 293
5754 20 666 661 663 589
5755 20 666 661 663 293
5756 19 298 661 663 589
5757 19 298 661 663 293
5758 22 645 661 666 388
5759 22 663 661 666 388
5760 23 298 661 666 388
Impropers
1 1 1 4 51 2
2 2 31 5 323 3
3 3 273 9 397 10
4 2 11 14 41 12
5 2 61 15 357 13
6 3 31 19 71 20
7 2 21 24 71 22
8 2 11 25 135 23
9 3 85 29 377 30
10 1 31 34 61 32
11 2 41 35 337 33
12 3 11 39 51 40
13 1 11 44 41 42
14 2 71 45 115 43
15 3 357 49 145 50
16 2 1 54 51 52
17 2 21 55 397 53
18 3 31 59 71 60
19 2 31 64 61 62
20 2 51 65 263 63
21 3 337 69 293 70
22 1 21 74 71 72
23 2 1 75 377 73
24 3 11 79 51 80
25 1 85 88 135 86
26 2 115 89 71 87
27 3 21 93 481 94
28 2 95 98 125 96
29 2 145 99 441 97
30 3 115 103 155 104
31 2 105 108 155 106
32 2 95 109 219 107
33 3 169 113 461 114
34 1 115 118 145 116
35 2 125 119 421 117
36 3 95 123 135 124
37 1 95 128 125 126
38 2 155 129 199 127
39 3 441 133 229 134
40 2 85 138 135 136
41 2 105 139 481 137
42 3 115 143 155 144
43 2 115 148 145 146
44 2 135 149 11 147
45 3 421 153 41 154
46 1 105 158 155 156
47 2 85 159 461 157
48 3 95 163 135 164
49 1 169 172 219 170
50 2 199 173 155 171
51 3 105 177 565 178
52 2 179 182 209 180
53 2 229 183 525 181
54 3 199 187 239 188
55 2 189 192 239 190
56 2 179 193 303 191
57 3 253 197 545 198
58 1 199 202 229 200
59 2 209 203 505 201
60 3 179 207 219 208
61 1 179 212 209 210
62 2 239 213 283 211
63 3 525 217 313 218
64 2 169 222 219 220
65 2 189 223 565 221
66 3 199 227 239 228
67 2 199 232 229 230
68 2 219 233 95 231
69 3 505 237 125 238
70 1 189 242 239 240
71 2 169 243 545 241
72 3 179 247 219 248
73 1 253 256 303 254
74 2 283 257 239 255
75 3 189 261 649 262
76 2 263 266 293 264
77 2 313 267 609 265
78 3 283 271 323 272
79 2 273 276 323 274
80 2 263 277 51 275
81 3 1 281 629 282
82 1 283 286 313 284
83 2 293 287 589 285
84 3 263 291 303 292
85 1 263 296 293 294
86 2 323 297 31 295
87 3 609 301 61 302
88 2 253 306 303 304
89 2 273 307 649 305
90 3 283 311 323 312
91 2 283 316 313 314
92 2 303 317 179 315
93 3 589 321 209 322
94 1 273 326 323 324
95 2 253 327 629 325
96 3 263 331 303 332
97 1 337 340 387 338
98 2 367 341 659 339
99 3 609 345 61 346
100 2 347 350 377 348
101 2 397 351 21 349
102 3 367 355 407 356
103 2 357 360 407 358
104 2 347 361 471 359
105 3 421 365 41 366
106 1 367 370 397 368
107 2 377 371 1 369
108 3 347 375 387 376
109 1 347 380 377 378
110 2 407 381 451 379
111 3 21 385 481 386
112 2 337 390 387 388
113 2 357 391 61 389
114 3 367 395 407 396
115 2 367 400 397 398
116 2 387 401 599 399
117 3 1 405 629 406
118 1 357 410 407 408
119 2 337 411 41 409
120 3 347 415 387 416
121 1 421 424 471 422
122 2 451 425 407 423
123 3 357 429 145 430
124 2 431 434 461 432
125 2 481 435 105 433
126 3 451 439 491 440
127 2 441 444 491 442
128 2 431 445 555 443
129 3 505 449 125 450
130 1 451 454 481 452
131 2 461 455 85 453
132 3 431 459 471 460
133 1 431 464 461 462
134 2 491 465 535 463
135 3 105 469 565 470
136 2 421 474 471 472
137 2 441 475 145 473
138 3 451 479 491 480
139 2 451 484 481 482
140 2 471 485 347 483
141 3 85 489 377 490
142 1 441 494 491 492
143 2 421 495 125 493
144 3 431 499 471 500
145 1 505 508 555 506
146 2 535 509 491 507
147 3 441 513 229 514
148 2 515 518 545 516
149 2 565 519 189 517
150 3 535 523 575 524
151 2 525 528 575 526
152 2 515 529 639 527
153 3 589 533 209 534
154 1 535 538 565 536
155 2 545 539 169 537
156 3 515 543 555 544
157 1 515 548 545 546
158 2 575 549 619 547
159 3 189 553 649 554
160 2 505 558 555 556
161 2 525 559 229 557
162 3 535 563 575 564
163 2 535 568 565 566
164 2 555 569 431 567
165 3 169 573 461 574
166 1 525 578 575 576
167 2 505 579 209 577
168 3 515 583 555 584
169 1 589 592 639 590
170 2 619 593 575 591
171 3 525 597 313 598
172 2 599 602 629 600
173 2 649 603 273 601
174 3 619 607 659 608
175 2 609 612 659 610
176 2 599 613 387 611
177 3 337 617 293 618
178 1 619 622 649 620
179 2 629 623 253 621
180 3 599 627 639 628
181 1 599 632 629 630
182 2 659 633 367 631
183 3 273 637 397 638
184 2 589 642 639 640
185 2 609 643 313 641
186 3 619 647 659 648
187 2 619 652 649 650
188 2 639 653 515 651
189 3 253 657 545 658
190 1 609 662 659 660
191 2 589 663 293 661
192 3 599 667 639 668
Thanks in advance
Sincerely
Naresh
