Hello LAMMPS community,
I get the error message on missing bonds after deleting atoms (SPCE H2O) and using reset_atom_ids:
ERROR on proc 0: Angle atoms 0 0 0 missing on proc 0 at step 1147 (src/src/ntopo_angle_partial.cpp:64)
I don’t get this error message if I don’t use reset_atom_ids command. If I understand the issue correctly, it results from a loss of ghost atoms. If so, what is the proper way to reset the ghost atoms?
The input script which I used to reproduce the error is below:
data.spce (414.2 KB)
units real
atom_style full
timestep 1.0
pair_style lj/cut/coul/long 9.0 9.0
special_bonds lj/coul 0.0 0.0 0.5
bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style none
read_data data.spce
replicate 1 1 10
pair_coeff 1 1 0.15539421659476232 3.16555789 #O-O
pair_coeff 1 2 0.0000 0.0000 # O-H
pair_coeff 2 2 0.0000 0.0000 #H-H
pair_modify tail yes
kspace_style pppm 1.0e-4
bond_coeff 1 5000.00 1.000
angle_coeff 1 500.0 109.47
minimize 1e-25 1e-19 10000 10000
neighbor 2.0 bin
neigh_modify every 1 delay 10 check yes
region to_del block INF INF INF INF 160.0 170.0
delete_atoms region to_del mol yes
write_data test_4.dat
reset_atom_ids
group water type 1 2
fix 4 water shake 0.0001 20 0 b 1 a 1
dump d_sys all atom 1000 test_4.dump
fix 2 all npt temp 300.0 300.0 100.0 iso 0.0 0.0 $(1000.0*dt)
thermo_style one
thermo 500
run 5000
unfix 2
