Hi all
I am attempting to build furfural and acetonitrile molecules using the OPLS-AA (2024) force field in EMC. However, I got these errors indicating missing rules for both molecules.
For furfural (c1cc(oc1)C=O), the following warnings and error are reported:
Warning: no rule found for {group, site} = {FF, 0}
Warning: no rule found for {group, site} = {FF, 2}
Warning: no rule found for {group, site} = {FF, 4}
Warning: no rule found for {group, site} = {FF, 6}
Warning: no rule found for {group, site} = {FF, 8}
Error: core/fields.c:433 FieldsApply: Missing rules. Program aborted.
For acetonitrile (SMILES: CC#N), I obtain the following error:
Warning: no rule found for {group, site} = {ACN, 4}.
I am a relatively new EMC user and am unsure how to properly define new force-field rules for these two molecules. However, the EMC itself on my PC is functioning correctly, as I can successfully generate DMSO (CS(=O)C), water molecules, and phenylene polymer chains using the same OPLS-AA force field. The issue appears to be specific to furfural and acetonitrile.
For reference, I have attached the relevant OPLS-AA field files and my .esh input file, excerpts of which are shown below.
ITEM OPTIONS
replace true
field opls-aa
number true
field_charge false
density 0.3
focus true
build_dir .
ITEM END
# Shorthands
ITEM SHORTHAND
FF c1cc(oc1)C=O,10
ACN CC#N,20
SPCE:c=o [O-0.8476]([H+0.4238])([H+0.4238]),3
ITEM END
I would appreciate any guidance on how to correctly define or extend the OPLS-AA rules to support furfural and acetonitrile in EMC.
opls-aa.define (101.5 KB)
opls-aa.top (16.7 KB)
opls-aa.prm (64.5 KB)
