Hi everyone, I wanted to create a polymerized ionic liquids system with the monomer as follows:
CCCC[N+]1=CN(C=C1)*CC *
I am able to run the esh file to create a build.emc file for it; however, when I tried to run the build.emc file using build.emc 2>&1 | tee build.out command, errors occurred like this:
Info: applying ‘~/Desktop/v9.4.4/field/opls/2012/opls-aa.prm’
Warning: missing rules for field ‘~/Desktop/v9.4.4/field/opls/2012/opls-aa.prm’.
Warning: missing rule for {group, site} = {monomer, 16}.
Warning: missing rule for {group, site} = {monomer, 21}.
Error: core/fields.c:432 FieldsApply:
Missing rules.
Program aborted.
I specified opls-aa ff as the force field in the esh file. What should I do to solve these errors? Should I modify the opls-aa prm file or what? Thank you all. Really appreciate it!
note: I followed the previous post and found my site 16 and site 21 are two atoms: N in an imidazole ring and C that is bonded to it.
I checked the opls-aa.define file and found there is some kind of definition of imidazole:
But this piece of information is missing in opls-aa.prm file, so the errors occurred.
I followed the other post, used the emc_opls.pl file to execute the convert.sh file in the same directory, and then ran build.emc again, the errors still occurred. What should be done next? Thank you all.
