I am simulating a “polymer+solvent system interacting with CNT” using hybrid pair styles in LAMMPS.
*CNT interactions: Using airebo/morse, as π-π stacking interactions are important.
*Polymer & Solvent interactions: Using GEAFF, which consists of Lennard-Jones (LJ) + Coulomb interactions.
The issue is that airebo/morse is typically defined in metal units, whereas GEAFF uses real units. Since LAMMPS does not support multiple units within a single simulation, I am wondering:
- Is it possible to use
airebo/morsewithunits real?
- If so, are there any recommended ways to modify the potential file properly?
- Alternatively, can
GEAFFbe used withunits metalinstead ofreal? - If neither is feasible, what would be the best workaround to simulate this hybrid system?
Any suggestions or past experiences on handling mixed-unit hybrid potentials would be greatly appreciated.
Thank you!
