Hello! I’m trying to model the behavior of aqueous ions in an ion trap, and the results that I’m getting seem somewhat erratic. I can’t seem, to arrive at a correct value for for the damp factor in the fix ID group-ID langevin Tstart Tstop damp. In a field of 100 volt / meter, a chloride ion of 5.88e-26 kg, charge of 1.602e-19 C, stokes radius of 1.24e-10 m, in water with a dynamic viscosity of 8.9e-4 kg/(ms), should have a ‘damp’ factor of 2.83e-14 as I understand it. Which I arrive at via [5.88e-26 kg]/(6PI*[8.9e-4 kg/(ms)][1.24e-10 m]). Given the drift velocity of sodium in water of 7.7e-8 (m^2)/(V*S), the velocity of a chloride ion in the above mentioned field would be a paltry 7.7e-6 m/s. However, when subjected to these conditions, the particle rapidly accelerates out of the bounds of the simulation, despite my 1e-6s time step.
Could someone please help me understand the error in my code?
Am I using the ‘damp’ factor properly, and messing up somewhere else?
I admit, I’m not using LAMMPS directly, but a this python wrapper but I am digging into the LAMMPS documentation to try to understand the LAMMPS file that it is outputting:
units si
atom_style charge
# Creating simulation box...
boundary m m m
region simulationDomain block -0.005 0.005 -0.005 0.005 -0.005 0.005 units box
create_box 1 simulationDomain
# Configure neighbour list...
neighbor 1 nsq
neigh_modify once yes
# Configure pairwise interactions for long range Coulombics only...
pair_style coul/cut 10
pair_coeff * *
# Placing individual ions...
create_atoms 1 single 0.0045 0.0045 0 units box
# Species...
mass 1 5.894913449999999e-26
set type 1 charge 1.6021764599999998e-19
group 1 type 1
timestep 1e-06
# Configuring additional output to flush buffer during simulation...
thermo 10000
thermo_style custom step cpu
thermo_modify flush yes
# Time integration...
group nonRigidBody union all
fix timeIntegrator nonRigidBody nve
# Creating a Linear Paul Trap... (fixID=3903137266868)
variable endCapV3903137266868 equal 1.000000e+00
variable radius3903137266868 equal 5.000000e-03
variable zLength3903137266868 equal 5.000000e-03
variable geomC3903137266868 equal 1.000000e+00
# Define frequency components.
variable oscVx39031372668680 equal 1.000000e+00
variable oscVy39031372668680 equal 1.000000e+00
variable phase39031372668680 equal "0.000000e+00 * step*dt"
variable oscConstx39031372668680 equal "v_oscVx39031372668680/(v_radius3903137266868*v_radius3903137266868)"
variable oscConsty39031372668680 equal "v_oscVy39031372668680/(v_radius3903137266868*v_radius3903137266868)"
variable statConst3903137266868 equal "v_geomC3903137266868 * v_endCapV3903137266868 / (v_zLength3903137266868 * v_zLength3903137266868)"
variable oscEX3903137266868 atom "v_oscConstx39031372668680 * cos(v_phase39031372668680) * x + v_statConst3903137266868 * x"
variable oscEY3903137266868 atom "v_oscConsty39031372668680 * cos(v_phase39031372668680) * -y + v_statConst3903137266868 * y"
variable statEZ3903137266868 atom "v_statConst3903137266868 * 2 * -z"
fix 3903137266868 all efield v_oscEX3903137266868 v_oscEY3903137266868 v_statEZ3903137266868
# Adding a langevin bath...
fix 5853822124365 all langevin 0.000000e+00 0.000000e+00 2.830000e-14 1337
dump 3902694972670 all custom 10 positions.txt id x y z
fix 3902689020878 all ave/atom 1 20 20 vx vy vz
dump 5854270558203 all custom 200 secv.txt id f_3902689020878[1] f_3902689020878[2] f_3902689020878[3]
# Run simulation
run 10000
Thank you for any help that you can provide!
