I have been playing around with the molecule command. I created a molecule file for SPC/E water but when I try to use it, I get the error.
“Molecule auto special bond generation overflow”
I believe I have accounted for any extra special bonds when creating my simulation box. (I have varied the number for testing.)
“create_box 2 myRegion bond/types 1 angle/types 1 extra/special/per/atom 1”
Am I missing something obvious here?
Tom
"Molecule auto special bond generation overflow"
"create_box 2 myRegion bond/types 1 angle/types 1 extra/special/per/atom 1"
1 special atom is too few. you should need at least 2.
the most obvious omission is to tell us which version of LAMMPS you
are using and/or whether you tested this with the latest patchlevel
release. you may be running into an issue, that has already been
resolved.
Hello Axel and Tom,
resolved.
The problem is still here with the 20Oct version.
1) Looking into the sources, I've discovered that molecule.cpp looks the
number of special neighbors in atom->maxspecial,
and create_box command sets it in force->special_extra, so atom->maxspecial
seems to stay unchanged.
Changing create_box line 161 to
atom->maxspecial = force->inumeric(FLERR,arg[iarg+1]);
as it was in older versions removes the error. Not sure if it's not
breaking something else.
2) Molecule command has to go after create_box in order for auto special
bonds generation to work, as I've figured out from the code.
Vasily
Hello Axel and Tom,
resolved.
as it was in older versions removes the error. Not sure if it's not breaking
something else.
yes, it does break something else. that is why it was changed. please
provide a test input to demonstrates where the current code is
failing.
please explain and - if possible - provide an example demonstrating
that as well.
thanks,
>failing.
Any molecule bigger than a dimer seems to cause a failure. An example is
attached.
Error comes from molecule.cpp:1142 where the number of derived special
bonds is checked against atom->maxspecial.
atom->maxspecial is 1,
>that as well.
The error comes from the same line molecule.cpp:1142
As far as I can see, both atom->maxspecial and force->special_extra are not
set
before create_box command, hence automatic special bonds for more than a
dimer won't work.
Vasily
trimer.txt (175 Bytes)
moltest.in (438 Bytes)
thanks for the input examples.
the following changes should take care of both issues. i.e. disallow
auto-generated exclusions before the box is defined and preserve both,
[[email protected]... src]$ git diff master create_box.cpp molecule.cpp
diff --git a/src/create_box.cpp b/src/create_box.cpp
index c7fd98b..3a13109 100644
--- a/src/create_box.cpp
+++ b/src/create_box.cpp
@@ -159,6 +159,7 @@ void CreateBox::command(int narg, char **arg)
} else if (strcmp(arg[iarg],"extra/special/per/atom") == 0) {
if (iarg+2 > narg) error->all(FLERR,"Illegal create_box command");
force->special_extra = force->inumeric(FLERR,arg[iarg+1]);
+ atom->maxspecial += force->special_extra;
iarg += 2;
} else error->all(FLERR,"Illegal create_box command");
diff --git a/src/molecule.cpp b/src/molecule.cpp
index 5e9aa29..0febb78 100644
--- a/src/molecule.cpp
+++ b/src/molecule.cpp
@@ -595,6 +595,10 @@ void Molecule::read(int flag)
// set maxspecial on first pass, so allocate() has a size
if (bondflag && specialflag == 0) {
+ if (domain->box_exist == 0)
+ error->all(FLERR,"Cannot auto-generate special bonds before "
+ "simulation box is defined");
