I got a reply from Jason Lambert who wrote the oplsaa_moltemplate.py
conversion script ([email protected]).
I suspect that the oplsaa_moltemplate.py script generates bond, angle,
dihedral, and improper interaction types for combinations of atoms for
which are defined somewhere in the "oplsaa.txt" file. It does this
even if some of those interactions are not present in the molecules in
your particular system.
I will forward this to Jason Lambert:Like the gaff.lt file, the oplsaa.lt file generated encompasses all
available combinations of 2,3,and 4 body interactions between the
given atoms so your answer was spot on Andrew.
If that is the case, then the additional bond, angle, dihedral, and
improper types (and coefficients) are harmless. Since they are not
used, they should not effect the physics of your simulation.
(At some point I was thinking of writing a script to strip out
unnecessary information from the data files created by moltemplate,
but I got lazy.)
I hope this allays this one particular concern.
I am still worried about how improper interactions are generated by moltemplate.
Moltemplate currently examines the network of bonds in your files and
generates impropers with the atom order I,J,K,L assuming that the
first atom in the list ("I") is the central atom. (This might change
soon.) For example:
------ nbody_Impropers.py (from moltemplate) -------
# 4-body "improper" interaction subgraph:
# L
# * 1st bond connects atoms I and J
# | => 2nd bond connects atoms I and K
# _.*._ 3rd bond connects atoms I and L
# *' I `*
# J K
Now I THINK THAT oplsaa_moltemplate.py also assumes that the improper
interaction parameters stored in the oplsaa.txt/oplsaa.prm files list
the atom types in the same order:
------ oplsaa.prm --------
imptors 0 0 3 4 21.000 180.0 2
imptors 0 0 3 52 21.000 180.0 2
imptors 0 0 24 0 5.000 180.0 2
imptors 0 0 47 0 30.000 180.0 2
imptors 0 0 48 0 5.000 180.0 2
Since "0" is a wildcard character I'm guessing the central atom is
stored in the 3rd column (what I am calling "K". It's hard to tell,
but some of these numbers "3", "47", "48" appear to be carbons).
I don't expect you to know the answer, but I'm curious: is the central
atom in this file stored in the 3rd column?
(In that case, we might need to patch the code.)
I will forward this question to Jason too.
Cheers
Andrew
