Hello everyone,
I am running LAMMPS using MPI and I am wondering if I installed lammps correctly. I used GNU compilers. MPI breakdown looks like this:
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 1601.8 | 2808.9 | 4369.8 | 993.6 | 42.31
Neigh | 0.00014366 | 0.00018994 | 0.00023398 | 0.0 | 0.00
Comm | 2203.9 | 3698.9 | 4923.3 | 855.3 | 55.71
Output | 0.11648 | 0.15851 | 0.1741 | 3.7 | 0.00
Modify | 58.658 | 124.24 | 252.16 | 478.0 | 1.87
Other | | 7.419 | | | 0.11
It seems to me that Comm part is way too large. The input script looks like this:
units metal # this keyword defines the units used in simulation, you can check the definitions on lammps website
# For GAP always metal
atom_style atomic # This defines how atoms are defined (are they charged or not)
boundary p p p #Periodic conditions
box tilt large # Here you specify that the simulation box is really skewed. You can skip this one if your simulation
# box is cubic.
read_data data.pos #Structure file. I think it would be easy for you to generate one. Just follow the rules for
# triclinic cell explained on LAMMPS website
# Atomic masses
mass 3 207.2
mass 2 132.9
mass 1 79.9
# Definition of potential
pair_style quip
pair_coeff * * /scratch/djordjedangic/CsPbBr3/Fit_potential/v12/GAP.xml "IP GAP" 35 55 82 #Empirical potential
# Setup neighbor style, you do not really need to change this unless you try to melt GeTe
neighbor 1.0 nsq
neigh_modify delay 100
variable t equal 100 #Define the temperature (t)
variable dt equal 0.001
timestep ${dt} #Define time step
# This defines the output in the LOG file. What each keyword means is on LAMMPS website
thermo_style custom step temp pe ke press pxx pyy pzz pxy pxz pyz
thermo 200
# Define starting velocities of atoms
velocity all create $t 153278 dist gaussian mom yes
velocity all scale $t
# Equilibrium run
fix 1 all nvt temp $t $t $(dt*100) # Here you say you are using NVT ensemble with temperature relaxation time of 100 timesteps
run 10000 # Run it for 50k timesteps
unfix 1 # Here you say stop the run 1
fix 11 all npt temp $t $t $(dt*100) x 0 0 $(dt*1000) y 0.0 0.0 $(dt*1000) z 0.0 0.0 $(dt*1000) couple none # Here you say you are using NVT ensemble with temperature relaxation time of 100 timesteps
run 40000 # Run it for 50k timesteps
unfix 11 # Here you say stop the run 1
# the main part of the run
fix 2 all npt temp $t $t $(dt*100) x 0 0 $(dt*1000) y 0.0 0.0 $(dt*1000) z 0.0 0.0 $(dt*1000) couple none # Here you say you are using NVT ensemble with temperature relaxation time of 100 timesteps
# define the output file
# Here 2 means collect every 2 timesteps, name of the file is data.atom and the format is id of the atom,
# followed by atomic positions, velocities and forces in Cartesian coordinates
dump tdep all custom 200 data.atom id element x y z vx vy vz fx fy fz
dump_modify tdep sort id
dump_modify tdep element Br Cs Pb
run 200000 #Number of timesteps for main part
Is this the value of Comm that is expected? If it is not, is there something wrong with my input script?
Kind regards,
Dorde
