Hi Steve,
Trying to work with MPI first time & had specified following settings in the make G++3 file: Please advice.
Makefile settings:
Hi Steve,
Makefile settings:
Hi Steve,
Makefile settings:
# compiler/linker settings
# specify flags and libraries needed for your compilerCC = mpicc
CCFLAGS = -g -O
DEPFLAGS = -M
LINK = mpicc
LINKFLAGS = -g -O
LIB =
ARCHIVE = ar
ARFLAGS = -rc
SIZE = size# ---------------------------------------------------------------------
# LAMMPS-specific settings
# specify settings for LAMMPS features you will use# LAMMPS ifdef options, see doc/Section_start.html
LMP_INC = -DLAMMPS_GZIP
# MPI library, can be src/STUBS dummy lib
# INC = path for mpi.h, MPI compiler settings
# PATH = path for MPI library
# LIB = name of MPI libraryMPI_INC = -I../STUBS/mpich/include
MPI_PATH =
MPI_LIB = ../STUBS/mpich/lib/libmpich.a# FFT library, can be -DFFT_NONE if not using PPPM from kspace package
# INC = -DFFT_FFTW, -DFFT_INTEL, -DFFT_NONE, etc, FFT compiler settings
# PATH = path for FFT library
# LIB = name of FFT libraryFFT_INC = -DFFT_FFTW
FFT_PATH =
FFT_LIB = ../STUBS/lib/libfftw.a-------------------------------------------------------------------------------------------------------------------------------
Errors received:
_intersect.o region_plane.o region_prism.o region_sphere.o region_union.o
remap.o remap_wrap.o replicate.o respa.o run.o set.o special.o thermo.o
timer.o universe.o update.o variable.o velocity.o verlet.o write_restart.o
-lreax -lmeam ../STUBS/mpich/lib/libmpich.a ../STUBS/lib/libfftw.a
-lifcore -lsvml -lompstub -limf -lifcore -lsvml -lompstub -limf -o
../lmp_g++3
/usr/bin/ld: cannot find -lifcore
/usr/bin/ld: cannot find -lsvml
/usr/bin/ld: cannot find -lompstub
/usr/bin/ld: cannot find -limf
these have _nothing_ to do with MPI,
but if you compile in one of the lammps packages
that interface to fortran code (reax or meam).
those will bite you the same way,
if you compile a serial executable.
