Hey,
I have recently started learning to use the Materials Project API and was trying to execute one of the examples. The code below worked fine.
from pymatgen.ext.matproj import MPRester
with MPRester(SUHAS_API_KEY) as mpr:
print('Exact TaC formula matches are:', mpr.get_materials_ids("TaC"))
print('All compounds in the Ta-C system are:', mpr.get_materials_ids('Ta-C'))
But when MPRester () is called from the mp_api.client, I am facing the error mentioned below.
docs = mpr.materials.summary.search(material_ids=["mp-149"], fields=["structure"])
structure = docs[0].structure
# -- Shortcut for a single Materials Project ID:
structure = mpr.get_structure_by_material_id("mp-149")
This is the error I get:
“You are using deprecated API endpoints. Please read our documentation (https://docs.materialsproject.org) and upgrade to the latest version of the mp-api client (mp-api · PyPI).”
Also sometimes, I get that MPRester has no atttribute ‘get_structure_by_material_id’
Please help
