I have a slightly different error message, pointing at SSL verification.
I am behind corporate proxy, and using jupyter on a windows machine.
I can ping materialsproject.org with requests (note the InsecureRequestWarning message)
PMG_MAPI_KEY = '******'
import requests
import os
os.environ['http_proxy'] = 'http://uname:pwd@address:port'
os.environ['https_proxy'] = 'http://uname:pwd@address:port'
response = requests.get("https://materialsproject.org/rest/v2/api_check",
{"API_KEY" : PMG_MAPI_KEY },
verify = False
print(response.text)
C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\connectionpool.py:1043: InsecureRequestWarning: Unverified HTTPS request is being made to host '150.45.87.133'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings
warnings.warn(
{"valid_response": true, "response": {"api_key_valid": true, "version": {"db": "2020_09_08", "pymatgen": "2022.0.8", "rest": "2.0"}}}
but I cannot get the MPRester connected:
from pymatgen.ext.matproj import MPRester
with MPRester(api_key=PMG_MAPI_KEY, notify_db_version=False) as mpr:
print( mpr.get_materials_ids("TaC") )
SSLCertVerificationError Traceback (most recent call last)
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\connectionpool.py:700, in HTTPConnectionPool.urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
699 if is_new_proxy_conn and http_tunnel_required:
--> 700 self._prepare_proxy(conn)
702 # Make the request on the httplib connection object.
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\connectionpool.py:994, in HTTPSConnectionPool._prepare_proxy(self, conn)
992 conn.tls_in_tls_required = True
--> 994 conn.connect()
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\connection.py:414, in HTTPSConnection.connect(self)
412 context.load_default_certs()
--> 414 self.sock = ssl_wrap_socket(
415 sock=conn,
416 keyfile=self.key_file,
417 certfile=self.cert_file,
418 key_password=self.key_password,
419 ca_certs=self.ca_certs,
420 ca_cert_dir=self.ca_cert_dir,
421 ca_cert_data=self.ca_cert_data,
422 server_hostname=server_hostname,
423 ssl_context=context,
424 tls_in_tls=tls_in_tls,
425 )
427 # If we're using all defaults and the connection
428 # is TLSv1 or TLSv1.1 we throw a DeprecationWarning
429 # for the host.
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\util\ssl_.py:449, in ssl_wrap_socket(sock, keyfile, certfile, cert_reqs, ca_certs, server_hostname, ssl_version, ciphers, ssl_context, ca_cert_dir, key_password, ca_cert_data, tls_in_tls)
448 if send_sni:
--> 449 ssl_sock = _ssl_wrap_socket_impl(
450 sock, context, tls_in_tls, server_hostname=server_hostname
451 )
452 else:
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\util\ssl_.py:493, in _ssl_wrap_socket_impl(sock, ssl_context, tls_in_tls, server_hostname)
492 if server_hostname:
--> 493 return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
494 else:
File C:\ProgramData\Anaconda3\envs\py38_64\lib\ssl.py:500, in SSLContext.wrap_socket(self, sock, server_side, do_handshake_on_connect, suppress_ragged_eofs, server_hostname, session)
494 def wrap_socket(self, sock, server_side=False,
495 do_handshake_on_connect=True,
496 suppress_ragged_eofs=True,
497 server_hostname=None, session=None):
498 # SSLSocket class handles server_hostname encoding before it calls
499 # ctx._wrap_socket()
--> 500 return self.sslsocket_class._create(
501 sock=sock,
502 server_side=server_side,
503 do_handshake_on_connect=do_handshake_on_connect,
504 suppress_ragged_eofs=suppress_ragged_eofs,
505 server_hostname=server_hostname,
506 context=self,
507 session=session
508 )
File C:\ProgramData\Anaconda3\envs\py38_64\lib\ssl.py:1040, in SSLSocket._create(cls, sock, server_side, do_handshake_on_connect, suppress_ragged_eofs, server_hostname, context, session)
1039 raise ValueError("do_handshake_on_connect should not be specified for non-blocking sockets")
-> 1040 self.do_handshake()
1041 except (OSError, ValueError):
File C:\ProgramData\Anaconda3\envs\py38_64\lib\ssl.py:1309, in SSLSocket.do_handshake(self, block)
1308 self.settimeout(None)
-> 1309 self._sslobj.do_handshake()
1310 finally:
SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)
During handling of the above exception, another exception occurred:
MaxRetryError Traceback (most recent call last)
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\requests\adapters.py:489, in HTTPAdapter.send(self, request, stream, timeout, verify, cert, proxies)
488 if not chunked:
--> 489 resp = conn.urlopen(
490 method=request.method,
491 url=url,
492 body=request.body,
493 headers=request.headers,
494 redirect=False,
495 assert_same_host=False,
496 preload_content=False,
497 decode_content=False,
498 retries=self.max_retries,
499 timeout=timeout,
500 )
502 # Send the request.
503 else:
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\connectionpool.py:785, in HTTPConnectionPool.urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
783 e = ProtocolError("Connection aborted.", e)
--> 785 retries = retries.increment(
786 method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
787 )
788 retries.sleep()
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\urllib3\util\retry.py:592, in Retry.increment(self, method, url, response, error, _pool, _stacktrace)
591 if new_retry.is_exhausted():
--> 592 raise MaxRetryError(_pool, url, error or ResponseError(cause))
594 log.debug("Incremented Retry for (url='%s'): %r", url, new_retry)
MaxRetryError: HTTPSConnectionPool(host='materialsproject.org', port=443): Max retries exceeded with url: /rest/v2/materials/TaC/mids (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)')))
SSLError Traceback (most recent call last)
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\pymatgen\ext\matproj.py:263, in MPRester._make_request(self, sub_url, payload, method, mp_decode)
262 else:
--> 263 response = self.session.get(url, params=payload, verify=True)
264 if response.status_code in [200, 400]:
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\requests\sessions.py:600, in Session.get(self, url, **kwargs)
599 kwargs.setdefault("allow_redirects", True)
--> 600 return self.request("GET", url, **kwargs)
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\requests\sessions.py:587, in Session.request(self, method, url, params, data, headers, cookies, files, auth, timeout, allow_redirects, proxies, hooks, stream, verify, cert, json)
586 send_kwargs.update(settings)
--> 587 resp = self.send(prep, **send_kwargs)
589 return resp
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\requests\sessions.py:701, in Session.send(self, request, **kwargs)
700 # Send the request
--> 701 r = adapter.send(request, **kwargs)
703 # Total elapsed time of the request (approximately)
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\requests\adapters.py:563, in HTTPAdapter.send(self, request, stream, timeout, verify, cert, proxies)
561 if isinstance(e.reason, _SSLError):
562 # This branch is for urllib3 v1.22 and later.
--> 563 raise SSLError(e, request=request)
565 raise ConnectionError(e, request=request)
SSLError: HTTPSConnectionPool(host='materialsproject.org', port=443): Max retries exceeded with url: /rest/v2/materials/TaC/mids (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)')))
MPRestError Traceback (most recent call last)
Input In [6], in <cell line: 2>()
1 from pymatgen.ext.matproj import MPRester
2 with MPRester(api_key=PMG_MAPI_KEY, notify_db_version=False) as mpr:
----> 3 print( mpr.get_materials_ids("TaC") )
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\pymatgen\ext\matproj.py:362, in MPRester.get_materials_ids(self, chemsys_formula)
351 def get_materials_ids(self, chemsys_formula):
352 """
353 Get all materials ids for a formula or chemsys.
354
360 ([str]) List of all materials ids.
361 """
--> 362 return self._make_request(f"/materials/{chemsys_formula}/mids", mp_decode=False)
File C:\ProgramData\Anaconda3\envs\py38_64\lib\site-packages\pymatgen\ext\matproj.py:279, in MPRester._make_request(self, sub_url, payload, method, mp_decode)
277 except Exception as ex:
278 msg = f"{ex}. Content: {response.content}" if hasattr(response, "content") else str(ex)
--> 279 raise MPRestError(msg)
MPRestError: HTTPSConnectionPool(host='materialsproject.org', port=443): Max retries exceeded with url: /rest/v2/materials/TaC/mids (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1131)')))
could anyone advise?
Marco
