Msd
Dear LAMMPS users,
this is my code for calculating MSD all atoms, but in fact I have doubt that this code is correct! there was no error when code ran but Contrary to expectations, the data showed very little change.
I would be grateful if you could guide me.
atom_style atomic
read_data data.data
MD Simulation Settings
mass 1 26.98
mass 2 63.55
pair_style eam/alloy
pair_coeff * * AlCu.eam.alloy Al Cu
#Setting
compute 1 all ke/atom
compute 2 all pe/atom
compute 3 all centro/atom fcc
compute 4 all cna/atom 2
compute 5 all msd
variable MSDall equal c_5[4]
fix monitor_All all print 1000 “${MSDall}” file MSD_All_monitor.txt
#Equilibration & Output Settings
thermo 1000
thermo_style custom step time temp pe etotal press vol
dump 1 all cfg 10000 alti.*.cfg mass type xs ys zs c_1 c_2 c_3 c_4
timestep 0.001
#relaxing 1
fix 1 all npt temp 300 300 0.01 iso 0 0 1
run 140000
unfix 1
fix 2 all npt temp 300 600 0.01 iso 0 0 1
run 120000
unfix 2
fix 3 all npt temp 600 600 0.01 iso 0 0 1
run 140000
unfix 3
The first advice I have is: don’t post your question in the wrong category! You are asking about LAMMPS, so why do you post in “Materials Project”?
The second advice is: study and follow the forum guidelines, especially those about quoting and formatting test files.
