Hello everyone
I’m now studying on the simulation of the sinterering process of microparticle silver. Because of the big size of particles, I need to use the ATC package. I want to treat the interconnected part between particles by using MD and the other part by using FE (as shown in the figure below). Do you think that my problem can be solved with this package please ?
Best regareds
Xudong
The gridding that the ATC package uses is regular Cartesian.
So 3 spheres is not compatible. But a MD box embedded in
a FE box is. I suggest you study the examples and doc pages
for the ATC package and fix atc command.
Hello everyone
that is impossible to say at this level of generality. how large are the
particles and what is the time scale of the process you are looking at?
unless i miss my guess, i would expect, that those length and time scales
are too far apart to make the kind of model you propose practical. if you
want to make some experiment, you should look for something much simpler.
you may also want to do some research of the published literature into
available mesoscale models. it looks to me, that what you need could be
something conceptually similar to either lattice-boltzmann or peridynamics,
or perhaps there might be a suitable formulation for either of them, that
you could use.
