I am new to lammps. I would like to apply the gcmc fix on a molecule. I have input the molecule using the molecule command. The molecule’s structure consists of 2 domains which are linked by a chain. So I would like the two domains to act as rigid bodies. Inorder to do so I have to apply the rigid/small fix. But the rigid/small fix groups the whole molecule and considers the whole molecule as one rigid body since they all have the same molecule template ID. Could you please guide on me how can I make the two domains of the same molecule inputed using molecule command be identified as rigid/small
this is currently not possible, and i don't see an easy way to implement
this. i would also be doubtful, that fix gcmc as implemented in LAMMPS is
meaningful on such a "large" molecule.
I would like to perform Monte Carlo simulation on this molecule using lammps. Could you tell me on how could I perform MC simulation which will facilitate rigid body simulation as well using lammps.
LAMMPS is an MD code and not an MC code. Just look at the documentation and see. If you want to turn it into an MC code, you will have to do a lot of C++ programming.
