My MacBook Air struggles with some of my simulation work
I’m using a MacBook Air to inspect molecular dynamics trajectories for a uni project. I’ve noticed that visualizing larger files can be quite demanding, especially when I have other lab work open at the same time.
Does OVITO’s memory usage tend to increase as you move through a trajectory, or does it depend more on the visualization settings? I’m trying to work out what makes the biggest difference.
Visualizing a large dataset will always require memory for each object in the scene, so in general, memory usage scales with system size.
OVITO’s pipeline system caches the intermediate results of each modifier. This allows the pipeline to be re-evaluated quickly without recomputing every modifier. If you’re tight on memory, you can disable the caching of intermediate results.
If you’re severely constrained on memory and willing to compromise on the precision of the output, you can reduce OVITO’s internal data representation from double precision (float64) to single precision (float32). This cuts the memory required for each value in half.
Both options are explained in detail in our manual: General settings — OVITO User Manual 3.17.2 documentation. Please note that some of these memory-saving features are only available in recent versions of OVITO.
Trajectory length does not significantly affect the memory footprint, because OVITO evicts the data of old frames from the cache when a new frame is loaded.
Out of curiosity, how large is the dataset you’re processing? Are you using surface meshes or voxel grids? Those can add large geometries to the scene.
