I changed the simulation box to a smaller one ( 0 15.0 0 15.0 0 15.0), changed the kspace style to pppm. However, the system is running very slow and gives this error message:
ERROR on proc 0: Out of range atoms - cannot compute PPPM (…/pppm.cpp:1945).
Please what can I do to solve this problem? Below is the log of the output:
LAMMPS (15 Nov 2018)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (…/comm.cpp:87)
input file for silica glass
units real
atom_style charge
#create atoms
lattice custom 15.5000 a1 1.0 0.0 0.0 a2 0.0 1.0 0.0 a3 0.0 0.0 1.0 basis 0.0 0.0 0.0
Lattice spacing in x,y,z = 15.5 15.5 15.5
region my_box block 0 15.0 0 15.0 0 15.0
create_box 2 my_box
Created orthogonal box = (0 0 0) to (232.5 232.5 232.5)
create_atoms 1 random 144 12345 my_box
Created 144 atoms
Time spent = 0.00102997 secs
create_atoms 2 random 288 6789 my_box
Created 288 atoms
Time spent = 0 secs
mass 1 28.8855 #Si
mass 2 15.9994 #O
set type 1 charge 2.4 #Si
144 settings made for charge
set type 2 charge -1.2 #O
288 settings made for charge
velocity all create 100 28459 rot yes dist gaussian mom yes
#potential
include pot.dat
BKS potential
pair_style buck/coul/long 5.5 10.0
pair_coeff 1 1 0.0 1.0 0.0 # Si-Si
pair_coeff 1 2 414512.50 0.20520 2075.270 # Si-O
pair_coeff 2 2 31932.360 0.26231 4030.1136 # o-o
MD parameters
kspace_style pppm 1.0e-4
neighbor 2.0 bin
neigh_modify delay 2 every 1 check yes
timestep 1.0
#delete_atoms overlap 0.1 all all
#outputs
thermo 100
thermo_style custom step temp pe press vol lx density
dump 2 all custom 1000 md.lammpstrj id type x y z
initial minimisation
minimize 1.0e-10 1.0e-10 100000 100000
WARNING: Using ‘neigh_modify every 1 delay 0 check yes’ setting during minimization (…/min.cpp:168)
PPPM initialization …
using 12-bit tables for long-range coulomb (…/kspace.cpp:321)
G vector (1/distance) = 0.217539
grid = 72 72 72
stencil order = 5
estimated absolute RMS force accuracy = 0.0441621
estimated relative force accuracy = 0.000132993
using double precision FFTs
3d grid and FFT values/proc = 456533 373248
Neighbor list info …
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 12
ghost atom cutoff = 12
binsize = 6, bins = 39 39 39
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair buck/coul/long, perpetual
attributes: half, newton on
pair build: half/bin/atomonly/newton
stencil: half/bin/3d/newton
bin: standard
Per MPI rank memory allocation (min/avg/max) = 55.19 | 55.19 | 55.19 Mbytes
Step Temp PotEng Press Volume Lx Density
0 100 -2947.8847 -4.2259964 12568078 232.5 0.0011583719
100 100 -9424.8238 -7.6864537 12568078 232.5 0.0011583719
200 100 -15072.744 -9.3869562 12568078 232.5 0.0011583719
300 100 -21663.574 -9.5092738 12568078 232.5 0.0011583719
400 100 -27441.332 -7.9772078 12568078 232.5 0.0011583719
500 100 -30780.863 -9.7996849 12568078 232.5 0.0011583719
600 100 -35035.801 -9.9700243 12568078 232.5 0.0011583719
700 100 -39165.413 -10.269136 12568078 232.5 0.0011583719
800 100 -43405.625 -10.158131 12568078 232.5 0.0011583719
900 100 -48058.149 -10.925422 12568078 232.5 0.0011583719
1000 100 -52427.961 -9.2218171 12568078 232.5 0.0011583719
1100 100 -55482.942 -8.9668087 12568078 232.5 0.0011583719
1200 100 -58534.132 -8.6989445 12568078 232.5 0.0011583719
1300 100 -62857.09 -7.3863786 12568078 232.5 0.0011583719
1400 100 -65649.199 -6.9545053 12568078 232.5 0.0011583719
1500 100 -67358.709 -7.9208115 12568078 232.5 0.0011583719
1600 100 -68935.352 -8.384078 12568078 232.5 0.0011583719
1700 100 -71855.668 -7.5914616 12568078 232.5 0.0011583719
1800 100 -73966.802 -6.2087742 12568078 232.5 0.0011583719
1900 100 -75759.098 -7.3707116 12568078 232.5 0.0011583719
2000 100 -78428.089 -5.9684084 12568078 232.5 0.0011583719
2100 100 -80146.737 -5.8971696 12568078 232.5 0.0011583719
2200 100 -81286.488 -7.8780854 12568078 232.5 0.0011583719
2300 100 -82961.738 -7.0036067 12568078 232.5 0.0011583719
2400 100 -84446.055 -5.5900274 12568078 232.5 0.0011583719
2500 100 -86407.021 -6.9769645 12568078 232.5 0.0011583719
2600 100 -88013.235 -5.118597 12568078 232.5 0.0011583719
2700 100 -89499.036 -6.8546617 12568078 232.5 0.0011583719
2800 100 -91395.314 -4.8720255 12568078 232.5 0.0011583719
2900 100 -93081.746 -4.4753371 12568078 232.5 0.0011583719
3000 100 -94620.013 -5.0686173 12568078 232.5 0.0011583719
3100 100 -95666.492 -5.7505246 12568078 232.5 0.0011583719
3200 100 -97591.92 -3.9778653 12568078 232.5 0.0011583719
3300 100 -98758.936 -3.9486505 12568078 232.5 0.0011583719
3400 100 -100146.3 -4.3258372 12568078 232.5 0.0011583719
3500 100 -101445.26 -4.7338972 12568078 232.5 0.0011583719
3600 100 -102822.93 -4.3075052 12568078 232.5 0.0011583719
3700 100 -103991.9 -3.0897534 12568078 232.5 0.0011583719
3800 100 -104889.09 -2.8390408 12568078 232.5 0.0011583719
3900 100 -105831.29 -2.5734776 12568078 232.5 0.0011583719
4000 100 -106779.8 -2.9171904 12568078 232.5 0.0011583719
4100 100 -108174.28 -2.3989923 12568078 232.5 0.0011583719
4200 100 -108837.64 -2.7518206 12568078 232.5 0.0011583719
4300 100 -109943.78 -2.6966478 12568078 232.5 0.0011583719
4400 100 -110502.98 -2.5154998 12568078 232.5 0.0011583719
4500 100 -111424.8 -2.452291 12568078 232.5 0.0011583719
4560 100 -6.3742531e+84 -6.0059497e+82 12568078 232.5 0.0011583719
Loop time of 1289.96 on 1 procs for 4560 steps with 432 atoms
99.8% CPU use with 1 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = energy tolerance
Energy initial, next-to-last, final =
-2947.88474049 -6.37425306156e+84 -6.37425306156e+84
Force two-norm initial, final = 179.588 1.84621e+99
Force max component initial, final = 31.9848 1.26649e+99
Final line search alpha, max atom move = 8.97654e-114 1.13687e-14
Iterations, force evaluations = 4560 6561
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 0.29806 | 0.29806 | 0.29806 | 0.0 | 0.02
Kspace | 1288.8 | 1288.8 | 1288.8 | 0.0 | 99.91
Neigh | 0.071902 | 0.071902 | 0.071902 | 0.0 | 0.01
Comm | 0.041991 | 0.041991 | 0.041991 | 0.0 | 0.00
Output | 0.5452 | 0.5452 | 0.5452 | 0.0 | 0.04
Modify | 0 | 0 | 0 | 0.0 | 0.00
Other | | 0.183 | | | 0.01
Nlocal: 432 ave 432 max 432 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 132 ave 132 max 132 min
Neighs: 317 ave 317 max 317 min
Total # of neighbors = 317
Ave neighs/atom = 0.733796
Neighbor list builds = 350
Dangerous builds = 0
Initial mixing
fix 1 all nvt temp 2700 2700 100
run 200000
grid = 72 72 72
stencil order = 5
Per MPI rank memory allocation (min/avg/max) = 54.07 | 54.07 | 54.07 Mbytes
Last command: run 200000
