Hello all,
In my program, a file called ''flame_log.yaml" is generated
I created validator named FlameFilesValidator to check for this file ''flame_log.yaml"
and associated to custodian
the code is
from custodian.custodian import Validator
import os
class FlameFilesValidator(Validator):
Check for existence of some of the files that flame
normally create/s upon running.
def __init__(self):
pass
def check(self):
for vfile in ["flame_log.yaml"]:
if not os.path.exists(vfile):
return True
return False
The error is
File "/scratch/hpc-prf-cbsc/ram/thesis/atomate_3.6/codes/custodian/custodian/custodian.py", line 372, in run
self._run_job(job_n, job)
File "/scratch/hpc-prf-cbsc/ram/thesis/atomate_3.6/codes/custodian/custodian/custodian.py", line 500, in _run_job
for v in self.validators:
TypeError: 'type' object is not iterable
NOTE:
i was able to run successfully without using validator ,
i am getting this error only when i use validator
and i have posted what is needed to look at …All other parts of the code that i have are running smoothly without any issue…i am having problems only when i use validator
Any help would be highly appreciated, thank you
