Hello all,
I need some help with my MD simulation. I am working on MD simulation of nanomachining of silicon, my script is as written bellow:
in.Si_C
#newton on
atom_style atomic
pair_style tersoff
read_data data.finalSi_C2change
pair_coeff * * SiC.tersoff Si Si Si C
#pair_coeff 1 * eam Cu_u3.eam
#pair_coeff 3 * eam Cu_u3.eam
#pair_coeff 4 4 eam Cu_u3.eam
#pair_coeff 1 2 lj/cut 0.4096 2.338
#pair_coeff 2 3 lj/cut 0.4096 2.338
#pair_coeff 2 4 lj/cut 0.4096 2.338
neighbor 2.0 bin
neigh_modify delay 2
neigh_modify exclude type 4 4
group newtonian type 1
group thermostat type 2
group boundary type 3
group tool type 4
group mobile subtract all boundary tool
fix 1 tool rigid single
#fix 1 thermostat rigid single
initial velocities
compute new mobile temp
velocity mobile create 293 564329 temp new
velocity tool set 2.0 0 0 sum yes units box
fix 2 mobile nve
#fix 2 all nve
#unfix 2
fix 3 mobile temp/rescale 10 293 293 0.01 1.0
fix_modify 3 temp new
fix 4 boundary setforce 0.0 0.0 0.0
fix 5 tool setforce 0.0 0.0 0.0
velocity thermostat scale 293.0
thermo 500
thermo_style custom step temp epair pe ke etotal vol press
thermo_modify temp new
thermo_modify lost warn
compute_modify new extra 3
dump 1 all atom 500 dump.Si_C
dump_modify 1 scale no
dump 2 all custom 1000 dump.forceSi_C.* id type x y z vx vy vz fx fy fz
timestep 0.0003
run 100000
If i remove the comment on “unfix 2” my mobile atoms remained in the box but the tool just passed and the atoms joined again FIGURE 1 (as if my tool is embedded in the workpiece) and the workpiece is not machined. But when i put comment on “unfix 2” (i.e. #unfix 2) the atoms expands and bulge even before the approach of the tool (FIGURE 2). I need the tool to displace (machine) the workpiece as shown in FIGURE 3. I am using LAMMPS version 20170127
Can anybody please help?
The figures are attached.
FOR LAMMPS MAILING LIST 2.pdf (322 KB)
