I am trying to calculate NEB (Nudged elastic band) activation energy barrier calculation in LAMMPS using following script.
---------- Initialize Simulation ---------------------
clear
atom_style atomic
atom_modify map array sort 0 0.0
variable u uloop 20
---------- Create Atomistic Structure ---------------------
lattice bcc 2.855
region box block 0.0 10.0 0 10.0 0 10.0
#create_box 2 box
Create Fe atoms
#create_atoms 1 box
Insert Carbon interstitial
#create_atoms 2 single 5.0 5.0 4.5
read_data initial.carbon
---------- Define Interatomic Potential ---------------------
pair_style eam/fs
pair_coeff * * Fe-C_Hepburn_Ackland.eam.fs Fe C
group carbon type 2
group iron type 1
#write_data initial.carbon
---------- Define Settings ---------------------
compute csym all centro/atom bcc
compute eng all pe/atom
compute eatoms all reduce sum c_eng
compute int_en carbon group/group iron
region surround block 3.5 6.5 3.5 6.5 3.5 6.5
group nebatoms region surround
group nonneb subtract all nebatoms
---------- Run Minimization before displacement---------------------
minimize 1e-15 1e-15 5000 5000
reset_timestep 0
thermo 100
#thermo_style custom step pe lx ly lz press pxx pyy pzz c_eatoms
timestep 0.001
fix 1 all nve
fix 2 nonneb setforce 0.0 0.0 0.0
fix 3 nebatoms neb 10.0
dump 1 nebatoms atom 10 dump.neb.$u
dump 2 nonneb atom 10 dump.nonneb.$u
min_style quickmin
neb 1e-15 1e-15 1000 1000 100 final final.carbon
I am moving carbon from one octahedral site (5, 5, 4.5) to other octahedral site (5, 5, 5.5) by one lattice unit. Barrier height , which I am getting is around 1.5 eV whereas it’s reported value is around 0.85 eV. Additionally, my activation energy curve is not that smooth. I am also attaching the curve I get.
Please suggest me where I am going wrong.
Regards,
activation_energy_values_1 (219 Bytes)
